  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 329.8k Views 52 Watching
    Are you setting all pins to low during setup?
    • dbemowskD
      dbemowskD
      So I had started this build going on a year ago but never finished it. That was before I found the easy newbie boards which is what I plan on using to resurrect this build. My question is, can this be built using a 3.3V pro mini, or should I be using a 5V one. I am just wondering if I need to set up my newbie board with a 3.3V regulator or not. My other question is on the resistors. I have a bunch of 1/8 watt resistors and was wondering if they would work or if I should go to 1/4 watt. I have all of the parts in my parts bin and with the newbie board it shouldn't take long to put it together, just need direction on those couple things.
        It's hard to answer since you aren't providing many details like is it battery powered? What kind of valves are you using? What are you using those resistors for?
        dbemowskD 1 Reply Last reply
          dbemowskD
          dbemowskD
          @gohan Sorry, I am talking about the schematic for the irrigation controller in the build section of the site. That is why I posted the question here.
          One other thing that I just noticed, and I will post this in the easy newbie board thread also for @sundberg84, I noticed that there is a change in the pins that are broken out on the header on the left side of the board. This is the board that I am using for the build, and I was going to point out here that the schematic below shows to connect D7 and D8 to the shift register, but the REV 8 board that I am using does not break out D8. After looking at the site on the new REV 9 boards, which I have a batch of, he doesn't break out D7 or D8.. The wiring of the pins is completely different between the REV 8 and REV 9 boards. The reason I mention this is that I was going to write something up here explaining the build with a newbie board, but I think I will hold off as it might be confusing to many depending what REV of the board people have.
          Another thing that I just notices is on the schematic. I have a copy of the schematic that I printed last year when I started this build. There has since been a change. In the old schematic that I have it shows the output enable (OE) pin of the shift register grounded, where in the one below, it showsit connected to D6 through a 1K resistor. I can understand that the change is to give arduino control to the output enable line, but because in the other schematic it didn't show D6 connected, and I didn't have D8 broken out, I used D6 in it's place. I may need to rethink some of this. In any case, I will need to make some changes to the sketch prior to uploading it.
          0_1496074195604_upload-c4616651-6dc5-47bb-a4c6-ff77a1936257
          • dbemowskD dbemowsk
            dbemowskD
            dbemowskD
            OK, so I have this built this and have it mostly working with my Vera Plus. Below is a link to a video of a problem I am having.
            http://www.dan.bemowski.info/videos/20170601_004213.mp4
            So my sprinkler system has a pump start relay which gets turned on any time a valve is turned on. Because of this I made a slight hardware modification which thus required a software modification. For the hardware, I ended up using relay number 1 of my 8 channel relay board as my pump start relay control. This I have wired to pin A1. Relays 2 through 8 are connected to the shift register on Qb through Qh (outputs 2-8) skipping output 1. Because of this I had to change how the code defined which valve to start on. To do this, I changed the commented lines removing the (-1) on the bit shift. I made the assumption that in code, the relay numbers start with 0.
            #ifdef ACTIVE_LOW
            //#define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber-1))
            #define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber))
            #define ALL_VALVES_OFF 0xFFFF
            //#define BITSHIFT_VALVE_NUMBER (1U << (valveNumber-1))
            #define BITSHIFT_VALVE_NUMBER (1U << (valveNumber))
            #define ALL_VALVES_OFF 0U
            Then I needed to define the pump start relay.
            const int pumpStart = A1;
            and then in setup I have this:
              pinMode(pumpStart, OUTPUT);
              digitalWrite (pumpStart, HIGH);
            Lastly, to operate the pump start relay whenever a zone is triggered, this is the updateRelays() function:
            void updateRelays(int value)
              if (value == ALL_VALVES_OFF)
                digitalWrite(pumpStart, HIGH);
                digitalWrite(pumpStart, LOW);
              digitalWrite(latchPin, LOW);
              digitalWrite(latchPin, HIGH);
            All of this seems to work. When I trigger a zone, I see the pump start relay kick on as well as the triggered zone relay. The only problem I have is that the screen keeps cycling valve data: (1-4) on the screen, as can be seen in the video clip.
            Here is my entire modified sketch that I have uploaded:
            MySprinkler for MySensors
            Arduino Multi-Zone Sprinkler Control
            May 31, 2015
            *** Version 2.0
            * LED status indicator
            PARTS LIST:
            * Relays (8 channel)
            * NRF24L01 Radio
            * Arduino (I used a Pro Mini)
            * Capacitors (10uf and .1uf)
            * 3.3v voltage regulator
            * Resistors (270, 1K & 10K)
            * Female Dupont Cables
            * LED
            * Push button
            * Shift Register (SN74HC595)
            * 18 gauge wire (for relay)
            INSTRUCTIONS:
              on the serial monitor.
            // Enable debug prints
            //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
            #include <TimeLib.h>
            #include <LiquidCrystal.h>
            #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
            #define VALVE_TIMES_RELOAD 300000UL  // Change this (in milliseconds) for how often to update all valves data from the controller (Loops at value/number valves)
                                                 // ie: 300000 for 8 valves produces requests 37.5seconds with all valves updated every 5mins
            #define SKETCH_VERSION "2.2"
            #define CHILD_ID_SPRINKLER 0
            #define ACTIVE_LOW // comment out this line if your relays are active high
            #ifdef ACTIVE_LOW
            #ifdef DEBUG_ON
            #define SERIAL_START(x)
            typedef enum {
            SprinklerStates;
            SprinklerStates lastState;
            byte menuState = 0;
            unsigned long menuTimer;
            byte countDownTime = 10;
            int allZoneTime [NUMBER_OF_VALVES + 1];
            int valveSoloTime [NUMBER_OF_VALVES + 1];
            int valveNumber;
            int lastValve;
            unsigned long startMillis;
            const int ledPin = 5;
            const int waterButtonPin = 3;
            bool buttonPushed = false;
            bool showTime = true;
            bool clockUpdating = false;
            bool recentUpdate = true;
            int allVars[] = {V_VAR1, V_VAR2, V_VAR3};
            const char *dayOfWeek[] = {
            String valveNickName[17] = {
            time_t lastTimeRun = 0;
            //Setup Shift Register...
            const int latchPin = 6;
            const int clockPin = 4;
            const int dataPin  = 7;
            const int outputEnablePin = A0;
            LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27. Mine was actually 0x3F
            bool receivedInitialValue = false;
            bool inSetup = true;
              pinMode(latchPin, OUTPUT);
              pinMode(clockPin, OUTPUT);
              pinMode(dataPin, OUTPUT);
              pinMode(ledPin, OUTPUT);
              pinMode(outputEnablePin, OUTPUT);
              digitalWrite (outputEnablePin, LOW);
              attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
              digitalWrite (ledPin, HIGH);
              updateRelays(ALL_VALVES_OFF);
              //delay(5000);
              lcd.clear();
              lcd.backlight();
              lcd.createChar(0, clock);
              lcd.createChar(1, raindrop);
              delay(500);
              if (loadState(0) == 0xFF) // EEPROM flag
                for (int i = 0; i < 4 ; i++)
                  lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
              digitalWrite (ledPin, LOW);
              DEBUG_PRINTLN(F("Ready..."));
              lcd.setCursor(0, 0);
              lcd.setCursor(15, 0);
              lcd.write(byte(0));
              lcd.setCursor(0, 1);
              int clockCounter = 0;
                requestTime();
                wait(1000);
                lcd.print(".");
                clockCounter++;
                if (clockCounter > 16)
                  lcd.clear();
                  wait(2000);
              for (byte i = 1; i <= NUMBER_OF_VALVES; i++)
                lcd.clear();
                goGetValveTimes();
              lcd.clear();
                present(i, S_LIGHT);
              updateClock();
              updateDisplay();
              goGetValveTimes();
              if (buttonPushed)
                menuTimer = millis();
                  state = ZONE_SELECT_MENU;
                  menuState = 0;
                  menuState++;
                    menuState = 0;
                slowToggleLED ();
                if (state != lastState)
                    wait(50);
                    send(msg1valve.setSensor(i).set(false), false);
                  lcd.clear();
                  lcd.setCursor(0,0);
                  lcd.setCursor(0,1);
                  wait(2000);
                  lastValve = -1;
                if (lastValve != valveNumber)
                      send(msg1valve.setSensor(i).set(true), false);
                    wait(50);
                lastValve = valveNumber;
                fastToggleLed();
                  valveNumber = 1;
                  startMillis = millis();
                  valveNumber++;
                    state = CYCLE_COMPLETE;
                    lastValve = -1;
                    lastTimeRun = now();
                      wait(50);
                    DEBUG_PRINT(F("State = "));
                    DEBUG_PRINTLN(state);
                fastToggleLed();
                    wait(50);
                  DEBUG_PRINT(F("Zone: "));
                  DEBUG_PRINTLN(valveNumber);
                  fastToggleLed();
                displayMenu();
                lastState = state;
            void displayMenu(void)
              static int lastSecond;
                lcd.clear();
                lcd.print(F("Starting"));
                lcd.print(F("."));
                Serial.print(".");
              lastSecond = thisSecond;
                if (menuState == 0)
                  valveNumber = 1;
                  state = RUN_ALL_ZONES;
                  valveNumber = menuState;
                  state = RUN_SINGLE_ZONE;
              lastMenuState = menuState;
                buttonPushed = true;
            void fastToggleLed()
                fastLedTimer = millis ();
            void slowToggleLED ()
                slowLedTimer = millis ();
              bool zoneTimeUpdate = false;
              if (message.isAck())
                if (message.sensor == i)
                  if (message.type == V_LIGHT)
                    if (switchState == 0)
                      if (i == 0)
                        valveNumber = 1;
                        valveNumber = i;
                        DEBUG_PRINTLN(i);
                    DEBUG_PRINT(i);
                    DEBUG_PRINT(F(" = "));
                    DEBUG_PRINTLN(variable1);
                      allZoneTime[i] = variable1;
                      zoneTimeUpdate = true;
                    receivedInitialValue = true;
                    DEBUG_PRINT(i);
                    DEBUG_PRINTLN(variable2);
                      valveSoloTime[i] = variable2;
                    if (newMessage.length() == 0)
                      DEBUG_PRINTLN(i);
                    if (newMessage.length() > 16)
                      newMessage.substring(0, 16);
                    valveNickName[i] = "";
                    DEBUG_PRINT(F("Recieved variable3 valve: "));
                    DEBUG_PRINT(i);
              if (zoneTimeUpdate)
                  if (i != 0)
                    DEBUG_PRINT(F("Zone "));
                    DEBUG_PRINT(i);
                    DEBUG_PRINT(allZoneTime[i]);
                    DEBUG_PRINT(F(" name: "));
                recentUpdate = false;
            void updateDisplay()
              static bool displayToggle = false;
                switch (state) {
                  case STAND_BY_ALL_OFF:
                    fastClear();
                    if (displayToggle)
                      if (clockUpdating)
                        lcd.write(byte(0));
                      lcd.print(hourFormat12());
                      lcd.print(minute());
                      lcd.print(month());
                      lcd.print(day());
                      lcd.print(F("/"));
                      lcd.print(year() % 100);
                      if (clockUpdating)
                        lcd.write(byte(0));
                      lcd.setCursor(11, 1);
                      lcd.print(day(lastTimeRun));
                  case RUN_SINGLE_ZONE:
                    fastClear();
                    if (displayToggle)
                      lcd.print(F(" Zone:"));
                      lcd.print(valveNumber);
                      lcd.print(F(" Active"));
                        lcd.print("min");
                        lcd.print("sec  ");
                  case RUN_ALL_ZONES:
                    fastClear();
                    if (displayToggle)
                      lcd.print(F(" Active "));
                      lcd.print("min");
                      lcd.print("sec  ");
                  case CYCLE_COMPLETE:
                    if (displayToggle)
                      int totalTimeRan = 0;
                      lcd.print(totalTimeRan);
                      lcd.print(" Minutes   ");
                  default:
                    // what of ZONE_SELECT_MENU?
                lastUpdateTime = millis();
              lastDisplayState = state;
              int lastSecond = second();
              int lastMinute = minute();
              int lastHour = hour();
              setTime(newTime);
                DEBUG_PRINT(hourFormat12());
                DEBUG_PRINT(minute());
                DEBUG_PRINT(month());
                DEBUG_PRINT(F("/"));
                DEBUG_PRINT(day());
                DEBUG_PRINTLN(year());
                showTime = false;
            void fastClear()
            void updateClock()
                lcd.write(byte(0));
                clockUpdating = true;
                requestTime();
                lastVeraGetTime = millis();
              if (loadState(0) != 0xFF)
                saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
              for (int i = 1; i < 5; i++)
                saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
            void goGetValveTimes()
              static byte valveIndex = 1;
              if (inSetup || millis() - valveUpdateTime >= VALVE_TIMES_RELOAD / NUMBER_OF_VALVES) // update each valve once every 5 mins (distributes the traffic)
                if (inSetup) {
                  lcd.print(F(" Updating  "));
                  lcd.print(valveIndex);
                bool flashIcon = false;
                DEBUG_PRINT(valveIndex);
                DEBUG_PRINTLN(F(" Data..."));
                for (int a = 0; a < (sizeof(allVars)/sizeof(int)); a++) {
                  byte timeout = 10;
                  while (!receivedInitialValue && timeout > 0)
                    flashIcon = !flashIcon;
                    request(valveIndex, allVars[a]);
                    wait(50);
                    timeout--;
                valveUpdateTime = millis();
                valveIndex++;
                if (valveIndex > NUMBER_OF_VALVES)
                  valveIndex = 1;
            As always, any help is appreciated.
            BulldogLowellB T 2 Replies Last reply
              #ifdef ACTIVE_LOW
              May 31, 2015
              *** Version 2.0
              PARTS LIST:
              * NRF24L01 Radio
              * LED
              * Push button
              INSTRUCTIONS:
              #ifdef ACTIVE_LOW
              #ifdef DEBUG_ON
              typedef enum {
              SprinklerStates;
              byte menuState = 0;
              int valveNumber;
              int lastValve;
                //delay(5000);
                lcd.clear();
                lcd.backlight();
                delay(500);
                lcd.write(byte(0));
                  requestTime();
                  wait(1000);
                  lcd.print(".");
                  clockCounter++;
                    lcd.clear();
                    wait(2000);
                  lcd.clear();
                  goGetValveTimes();
                lcd.clear();
                updateClock();
                updateDisplay();
                goGetValveTimes();
                if (buttonPushed)
                    menuState = 0;
                    menuState++;
                      menuState = 0;
                  slowToggleLED ();
                      wait(50);
                    lcd.clear();
                    lcd.setCursor(0,0);
                    lcd.setCursor(0,1);
                    wait(2000);
                    lastValve = -1;
                      wait(50);
                  fastToggleLed();
                    valveNumber = 1;
                    valveNumber++;
                      lastValve = -1;
                        wait(50);
                  fastToggleLed();
                      wait(50);
                    fastToggleLed();
                  displayMenu();
                  lastState = state;
                  lcd.clear();
                  lcd.print(F("."));
                  Serial.print(".");
                  if (menuState == 0)
                    valveNumber = 1;
                        if (i == 0)
                          valveNumber = 1;
                          valveNumber = i;
                          DEBUG_PRINTLN(i);
                      DEBUG_PRINT(i);
                      DEBUG_PRINT(i);
                        DEBUG_PRINTLN(i);
                      DEBUG_PRINT(i);
                if (zoneTimeUpdate)
                    if (i != 0)
                      DEBUG_PRINT(i);
                  switch (state) {
                      fastClear();
                      if (displayToggle)
                        if (clockUpdating)
                          lcd.write(byte(0));
                        lcd.print(month());
                        lcd.print(day());
                        lcd.print(F("/"));
                        if (clockUpdating)
                          lcd.write(byte(0));
                      fastClear();
                      if (displayToggle)
                          lcd.print("min");
                          lcd.print("sec  ");
                    case RUN_ALL_ZONES:
                      fastClear();
                      if (displayToggle)
                        lcd.print("min");
                        lcd.print("sec  ");
                      if (displayToggle)
                    default:
                setTime(newTime);
                  DEBUG_PRINT(day());
                  showTime = false;
              void fastClear()
              void updateClock()
                  lcd.write(byte(0));
                  requestTime();
                  if (inSetup) {
                    byte timeout = 10;
                      wait(50);
                      timeout--;
                  valveIndex++;
                    valveIndex = 1;
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @dbemowsk
              what's happening in the Serial debug?
              • dbemowskD
                dbemowskD
                I'll look later and report. Got company at the moment. The odd thing is that I can turn my zones on and they seem to run for the specified time just fine. It's only what I see on the display that is messed up.
                • Black CatB
                  Black CatB
                  Black Cat
                  I've just started playing with a Z-Uno and was looking at ways to use for a project like this.
                  I'm a believer in not re-inventing the wheel and it seem that all I would need to do is to delete the radio and re-code the sketch for the extra relays ( I have already built a 4 channel relay, it's just getting over the hurdle of learning about Shift Registers).
                  Do you think this is possible or would I be better just starting from scratch?
                  • Black CatB Black Cat
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @Black-Cat said in Irrigation Controller (up to 16 valves with Shift Registers):
                    Z-Uno
                    wicked cool...
                    I'm in North America, so I have to stand by!
                    You you should be able to easily port this for use with Z-Uno...
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @dbemowsk
                      yes, weird...
                        #ifdef ACTIVE_LOW
                        May 31, 2015
                        *** Version 2.0
                        PARTS LIST:
                        * NRF24L01 Radio
                        * LED
                        * Push button
                        INSTRUCTIONS:
                        #ifdef ACTIVE_LOW
                        #ifdef DEBUG_ON
                        typedef enum {
                        SprinklerStates;
                        byte menuState = 0;
                        int valveNumber;
                        int lastValve;
                          //delay(5000);
                          lcd.clear();
                          lcd.backlight();
                          delay(500);
                          lcd.write(byte(0));
                            requestTime();
                            wait(1000);
                            lcd.print(".");
                            clockCounter++;
                              lcd.clear();
                              wait(2000);
                            lcd.clear();
                            goGetValveTimes();
                          lcd.clear();
                          updateClock();
                          updateDisplay();
                          goGetValveTimes();
                          if (buttonPushed)
                              menuState = 0;
                              menuState++;
                                menuState = 0;
                            slowToggleLED ();
                                wait(50);
                              lcd.clear();
                              lcd.setCursor(0,0);
                              lcd.setCursor(0,1);
                              wait(2000);
                              lastValve = -1;
                                wait(50);
                            fastToggleLed();
                              valveNumber = 1;
                              valveNumber++;
                                lastValve = -1;
                                  wait(50);
                            fastToggleLed();
                                wait(50);
                              fastToggleLed();
                            displayMenu();
                            lastState = state;
                            lcd.clear();
                            lcd.print(F("."));
                            Serial.print(".");
                            if (menuState == 0)
                              valveNumber = 1;
                                  if (i == 0)
                                    valveNumber = 1;
                                    valveNumber = i;
                                    DEBUG_PRINTLN(i);
                                DEBUG_PRINT(i);
                                DEBUG_PRINT(i);
                                  DEBUG_PRINTLN(i);
                                DEBUG_PRINT(i);
                          if (zoneTimeUpdate)
                              if (i != 0)
                                DEBUG_PRINT(i);
                            switch (state) {
                                fastClear();
                                if (displayToggle)
                                  if (clockUpdating)
                                    lcd.write(byte(0));
                                  lcd.print(month());
                                  lcd.print(day());
                                  lcd.print(F("/"));
                                  if (clockUpdating)
                                    lcd.write(byte(0));
                                fastClear();
                                if (displayToggle)
                                    lcd.print("min");
                                    lcd.print("sec  ");
                              case RUN_ALL_ZONES:
                                fastClear();
                                if (displayToggle)
                                  lcd.print("min");
                                  lcd.print("sec  ");
                                if (displayToggle)
                              default:
                          setTime(newTime);
                            DEBUG_PRINT(day());
                            showTime = false;
                        void fastClear()
                        void updateClock()
                            lcd.write(byte(0));
                            requestTime();
                            if (inSetup) {
                              byte timeout = 10;
                                wait(50);
                                timeout--;
                            valveIndex++;
                              valveIndex = 1;
                        Topdawg2881
                        @dbemowsk
                        I had this same issue. What I did to fix the issue was I commented out in the void loop the line to goGetValveTimes. I then added the timeAlarms library and set a timer to get valve times once every five minutes. The section of code looks like this. Alarm.timerRepeat (300,goGetValveTimes);
                        I inserted that line as the last line of cade in the void setup
                        • dbemowskD
                          dbemowskD
                          Okay, so I was just looking over the code. I first did a search for "Valve Data:" as that was what was showing on the screen. I found that in the goGetValveTimes() method. According to the code, that is only supposed to show if the inSetup variable evaluates to true. I then searched on that variable, and in the code just before the setup() method, I see this:
                          But I don't see anywhere in the code where it sets that value to false. So every time the main loop() calls goGetValveTimes();, it is going to display that since inSetup never gets changed to false. At the very end of the setup routine I see this bit of code:
                              lcd.clear();
                              goGetValveTimes();
                            lcd.clear();
                          I think that it is just after that for loop, or after the lcd.clear(); that it is supposed to set inSetup to false. I have not tested this theory yet as I need to unmount my controller and open it up to push the new code to it, but I am pretty sure that this is the issue. That would explain why everything else with it appears to work normally.
                          I double checked with the example code on the build page to see if possibly I may have deleted something when doing my edits. Looking it over, I found the same thing. If you ask me, this looks to be a bug in the code and it should be fixed and updated.
                                lcd.clear();
                                goGetValveTimes();
                              lcd.clear();
                            Topdawg2881
                            @dbemowsk
                            I am in front of my computer and I have my controller in front of me and hooked up. Give me a couple minutes and I will run it. See what happens.
                            • dbemowskD
                              dbemowskD
                              #295
                              I just made the change and tested it. That was definitely the problem. Works perfect now.
                              Not sure who can change the example code, but all that needs to be added is this:
                                  lcd.clear();
                                  goGetValveTimes();
                                lcd.clear();
                                //Add this line
                                inSetup = false;
                                    lcd.clear();
                                    goGetValveTimes();
                                  lcd.clear();
                                  //Add this line
                                  inSetup = false;
                                Topdawg2881
                                @dbemowsk
                                You beat me too it. I added the same line in same location and it works perfect. Every so often I see the raindrop icon to show that it is pulling data to update the valve times.
                                • dbemowskD
                                  dbemowskD
                                  So it is definitely a confirmed bug. I ended up finding some old sample code from when I started this last year and this bit of code was actually in the setup method and not in goGetValveTimes:
                                  So some time in the past year the sample code had been changed.
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @dbemowsk
                                    good to see you found it. I haven't looked at the code for two years, and mine is still working. (@petewill 's demo worked well too). there must have been some change that managed its way into the source
                                    maybe look on GitHub and do a pull request if you the problem is there...
                                    • tombstoneT
                                      tombstoneT
                                      tombstone
                                      Hi I just order all the parts that was listed. Do I need to read the 230 post or it's ok just watched the video.
                                      • tombstoneT tombstone
                                        dbemowskD
                                        dbemowskD
                                        @tombstone You shouldn't need to read all the posts. Maybe just search the thread if you run into any snags. What kind of setup are you dropping this into? Do you currently have valves installed? Does your setup have a master valve or pump relay? Is it a standard 24V AC system?
                                        • tombstoneT
                                          tombstoneT
                                          tombstone
                                          Ok I read it all. Just want to start with the basic then change to pH reader soil reader water reader rain detector.
