  3. UPS
UPS
30 Posts 8 Posters 9.0k Views 8 Watching
  • tbowmoT tbowmo
    @ben999
    Something like this: https://hackaday.io/project/9461-lifepo4weredpi ??
    ben999B
    ben999B
    ben999
    @tbowmo
    Thanks a lot ! Very neat !
    But it seems that this unit can only power the Pi itself...
    I am more looking at keeping the box AND the Pi alive for a few minutes (or more) :
    • at least enough time to let me know that there's a power cut
    • and (even better) plenty enough time to keep the alarm system going in case the power-cut is due to burglars...
    Thanks a lot anyway... that device could be useful for some other projects :) Ta
    • ben999B ben999
      @tbowmo
      @ben999 what type of box are you looking to power?
      ben999B 1 Reply Last reply
        ben999B
        ben999B
        ben999
        @mfalkvidd
        Hi
        Thank you for your message
        The box I am talking about is the internet/phone ISDN box (sorry I didn't make that clear)
        Power supply is rated 12v 2A
        The box powers the Pi via USB
        • ben999B ben999
          @mfalkvidd
          Hi
          @ben999 thanks for clarifying.
          Are you able to get details for the isdn box? If it can handle something like 11-13.8V in, you could probably use something as simple as a (small) car battery and a car battery charger.
          Examples:
          http://www.conrad.com/ce/en/product/200081/H-Tronic-AL800-2-12V-Lead-Acid-Battery-Charger-08A-12-40Ah?ref=searchDetail
          http://www.conrad.com/ce/en/product/250165/VRLA-12-V-12-Ah-Conrad-energy-CE12V12Ah-250165-AGM-W-x-H-x-D-97-x-52-x-48-mm-48-mm-blade-terminal-Maintenance-free?ref=searchDetail
            You can always make a small mod to ups and bring out the 12V from the internal battery and leave ups off, the internal circuit will keep the battery charged while not consuming power for dc-ac converter (if of course you can use the voltage a little higher than 12v).
            I have a spare ups ready to be modified for this purpose
            • Nca78N
              For those looking at a backup for pi only, I found this on AliExpress with (claimed) 2500mAh battery so it should get 4-5 hours on a pi 3. I buy one and will give a feedback, I have regular and long power cuts here and this should ensure continuity for at least logging all MySensors events.
              https://www.aliexpress.com/item/Geekworm-RPi-UPS-HAT-Board-for-Raspberry-Pi-3-Model-B-Pi-2B-B/32766227090.html
              If someone knows about a safe DIY circuit for li-ion or even better li-FePO4 (much safer) that I could use for smaller things like a GSM node or wifi gateway, please share !
                There is also this cheap solution https://www.aliexpress.com/item/6W-5V-UPS-mobile-power-Diy-Board-Charger-Step-up-DC-DC-Converter-Module-for-3/32790658678.html
                Nca78N 1 Reply Last reply
                  @gohan said in UPS:
                  Thank you that can be useful for small nodes, I will buy one to test.
                  Not for Pi unfortunately as it's not powerful enough.
                    my rpi3 usually uses 0.3A @5v with peaks of 0.6, I think it will be within 6W without problems
                      @gohan said in UPS:
                      Wow that's surprisingly low, I guess it's not loaded too much, not using peripherals and video/hdmi output ?
                        actually it is just sitting there headless with a NRF24 connected to it. I checked consumption with relays and with 5 relays on the consumption goes from 0.3 to 0.6A. I have 8 relays but I guess there will not be many of them on at the same time for a prolonged time.
                        • ben999B ben999
                          Hi guys
                          I am using MySensors together with OpenHAB to protect my home and also for access control
                          To make more sense I decided that all security related sensors shall be powered via battery
                          To make even more sense I run my gateway and the box from an UPS. But...
                          That UPS uses 220V AC to keep its 12V DC battery in shape. That's fine.
                          But when it goes off the grid it converts 12V DC to 220V AC back to 12V DC for box (which powers Raspberry via USB)
                          Would it make sense to have a pack of LiIon batteries that supply directly the box via some DC-DC regulator? And have the LiIon cells charged/balanced via these boards found on eBay?
                          I imagine there would be a cut-off voltage unit that would protect the cells.
                          Your comments on this matter would be welcome.
                          As i am not able to design any electronics, best would be to use board found on eBay or similar...
                          Thanks a lot for reading and even more thanks for your input
                          See ya
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @ben999
                          I'm using on of these
                          http://www.pimodulescart.com/shop/
                          I have LiFePO4 4000mAh battery pack - this is enough to weather the longest power outage
                          • alexsh1A alexsh1
                            @ben999
                            @alexsh1 thank you for the link.
                            I'll give a try to the AliExpress version first for financial reasons, but I'll check yours if the cheap one fails.
                            gohanG alexsh1A 2 Replies Last reply
                            • Nca78N Nca78
                              @Nca78 keep in mind that the one I posted is missing battery protection, so you need to have put one (unless your batteries have internal protection)
                              • Nca78N Nca78
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @Nca78 you are not too rich to spend you money on cheap stuff, are you? :-)
                                If you want a real UPS with many feathers programmable buttons and LEDs, it cannot be super cheap. Anyway, it's your call
                                  @gohan said in UPS:
                                  Yes on the circuit you linked I'll put a 18650 with protection, I will test it on a wifi gateway.
                                  For RPI I'll use the "hat" with battery that I linked in message above, only 17€ with battery.
                                  • ben999B
                                    ben999B
                                    ben999
                                    wrote on last edited by ben999
                                    Guys
                                    I am planning to use a 4S li-ion 18650 battery.
                                    Please have a look at my Fritzing sketch :)
                                    Battery pack will be monitored by this item :
                                    http://www.ebay.com/itm/4S-6A-Li-ion-Lithium-Batterie-3-7v-18650-Charger-Battery-Protection-Board/382109076738?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
                                    When off-grid ISDN box and RPi will be powered with that battery via this board :
                                    http://www.ebay.com/itm/Automatic-Buck-Boost-Step-Up-Down-DC-DC-Power-Supply-Converter-Replace-XL6009/142371180585?ssPageName=STRK%3AMEBIDX%3AIT&var=441392018812&_trksid=p2057872.m2749.l2649
                                    When on-grid, this charger will charge the battery pack and power ISDN box/Rpi :
                                    http://www.ebay.com/itm/EU-Plug-4S-16-8V-2A-AC-DC-Charger-Adapter-for-18650-Lithium-Li-ion-Battery-Cell-/262728544983?epid=507598255&hash=item3d2bd772d7:g:m6oAAOSwcLxYJaSF
                                    Is this the correct way of building my UPS ?
                                    Can i draw current from the charger to power box and RPi while it is charging ?
                                    Thanks again for your input/advice.
                                    • rozpruwaczR
                                      rozpruwaczR
                                      rozpruwacz
                                      isn't it better to buy ready made solution ? e.g. http://www.powerwalker.com/index.php?page=select&lang=en&cat=dc
                                      • rozpruwaczR rozpruwacz
                                        ben999B
                                        ben999B
                                        ben999
                                        @rozpruwacz
                                        No DIY, no fun ! :wink:
                                        gohanG 1 Reply Last reply
                                        • rozpruwaczR
                                          rozpruwaczR
                                          rozpruwacz
                                          haha :) yeah, totally agree :P
                                          12.5k
