  3. UPS
UPS
30 Posts 8 Posters 9.0k Views 8 Watching
    You can always make a small mod to ups and bring out the 12V from the internal battery and leave ups off, the internal circuit will keep the battery charged while not consuming power for dc-ac converter (if of course you can use the voltage a little higher than 12v).
    I have a spare ups ready to be modified for this purpose
    • Nca78N
      For those looking at a backup for pi only, I found this on AliExpress with (claimed) 2500mAh battery so it should get 4-5 hours on a pi 3. I buy one and will give a feedback, I have regular and long power cuts here and this should ensure continuity for at least logging all MySensors events.
      https://www.aliexpress.com/item/Geekworm-RPi-UPS-HAT-Board-for-Raspberry-Pi-3-Model-B-Pi-2B-B/32766227090.html
      If someone knows about a safe DIY circuit for li-ion or even better li-FePO4 (much safer) that I could use for smaller things like a GSM node or wifi gateway, please share !
        There is also this cheap solution https://www.aliexpress.com/item/6W-5V-UPS-mobile-power-Diy-Board-Charger-Step-up-DC-DC-Converter-Module-for-3/32790658678.html
        Nca78N 1 Reply Last reply
          @gohan said in UPS:
          Thank you that can be useful for small nodes, I will buy one to test.
          Not for Pi unfortunately as it's not powerful enough.
            my rpi3 usually uses 0.3A @5v with peaks of 0.6, I think it will be within 6W without problems
              @gohan said in UPS:
              Wow that's surprisingly low, I guess it's not loaded too much, not using peripherals and video/hdmi output ?
                actually it is just sitting there headless with a NRF24 connected to it. I checked consumption with relays and with 5 relays on the consumption goes from 0.3 to 0.6A. I have 8 relays but I guess there will not be many of them on at the same time for a prolonged time.
                • ben999B ben999
                  Hi guys
                  I am using MySensors together with OpenHAB to protect my home and also for access control
                  To make more sense I decided that all security related sensors shall be powered via battery
                  To make even more sense I run my gateway and the box from an UPS. But...
                  That UPS uses 220V AC to keep its 12V DC battery in shape. That's fine.
                  But when it goes off the grid it converts 12V DC to 220V AC back to 12V DC for box (which powers Raspberry via USB)
                  Would it make sense to have a pack of LiIon batteries that supply directly the box via some DC-DC regulator? And have the LiIon cells charged/balanced via these boards found on eBay?
                  I imagine there would be a cut-off voltage unit that would protect the cells.
                  Your comments on this matter would be welcome.
                  As i am not able to design any electronics, best would be to use board found on eBay or similar...
                  Thanks a lot for reading and even more thanks for your input
                  See ya
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @ben999
                  I'm using on of these
                  http://www.pimodulescart.com/shop/
                  I have LiFePO4 4000mAh battery pack - this is enough to weather the longest power outage
                  • alexsh1A alexsh1
                    @ben999
                    @alexsh1 thank you for the link.
                    I'll give a try to the AliExpress version first for financial reasons, but I'll check yours if the cheap one fails.
                    gohanG alexsh1A 2 Replies Last reply
                    • Nca78N Nca78
                      @Nca78 keep in mind that the one I posted is missing battery protection, so you need to have put one (unless your batteries have internal protection)
                      • Nca78N Nca78
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @Nca78 you are not too rich to spend you money on cheap stuff, are you? :-)
                        If you want a real UPS with many feathers programmable buttons and LEDs, it cannot be super cheap. Anyway, it's your call
                          @gohan said in UPS:
                          Yes on the circuit you linked I'll put a 18650 with protection, I will test it on a wifi gateway.
                          For RPI I'll use the "hat" with battery that I linked in message above, only 17€ with battery.
                          • ben999B
                            ben999B
                            ben999
                            wrote on last edited by ben999
                            Guys
                            I am planning to use a 4S li-ion 18650 battery.
                            Please have a look at my Fritzing sketch :)
                            Battery pack will be monitored by this item :
                            http://www.ebay.com/itm/4S-6A-Li-ion-Lithium-Batterie-3-7v-18650-Charger-Battery-Protection-Board/382109076738?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
                            When off-grid ISDN box and RPi will be powered with that battery via this board :
                            http://www.ebay.com/itm/Automatic-Buck-Boost-Step-Up-Down-DC-DC-Power-Supply-Converter-Replace-XL6009/142371180585?ssPageName=STRK%3AMEBIDX%3AIT&var=441392018812&_trksid=p2057872.m2749.l2649
                            When on-grid, this charger will charge the battery pack and power ISDN box/Rpi :
                            http://www.ebay.com/itm/EU-Plug-4S-16-8V-2A-AC-DC-Charger-Adapter-for-18650-Lithium-Li-ion-Battery-Cell-/262728544983?epid=507598255&hash=item3d2bd772d7:g:m6oAAOSwcLxYJaSF
                            Is this the correct way of building my UPS ?
                            Can i draw current from the charger to power box and RPi while it is charging ?
                            Thanks again for your input/advice.
                            • rozpruwaczR
                              rozpruwaczR
                              rozpruwacz
                              isn't it better to buy ready made solution ? e.g. http://www.powerwalker.com/index.php?page=select&lang=en&cat=dc
                              ben999B 1 Reply Last reply
                              • rozpruwaczR rozpruwacz
                                ben999B
                                ben999B
                                ben999
                                @rozpruwacz
                                No DIY, no fun ! :wink:
                                gohanG 1 Reply Last reply
                                • rozpruwaczR
                                  rozpruwaczR
                                  rozpruwacz
                                  haha :) yeah, totally agree :P
                                  • ben999B ben999
                                    @rozpruwacz
                                    @ben999 said in UPS:
                                    @rozpruwacz
                                    No DIY, no problems, no fun :smile:
                                    • dbemowskD
                                      dbemowskD
                                      I didn't read all the comments, so forgive me if this was mentioned. What if you just used an SLA or AGM battery and connected a battery tender to it. The battery tender should keep the battery topped off without over charging it, and I would think have enough power to power the PI also. Then you are converting 220 down to 12, and if the power goes down, the battery tender will just shut off and the battery would take over. No extra loss in converting 12 to 220 and back to12 again.
                                        I think nobody wants to convert 12 to 220v
                                          ben999B
                                          ben999B
                                          ben999
                                          @dbemowsk
                                          Thank you for your message
                                          @gohan said in UPS:
                                          I think @gohan got me right here. I have a spare "standard" ups at home... but i dont find that tech very sexy (on top of it it's huge)
                                          It's fun to scratch head !!!
                                          12.5k
