  3. Vera
  4. VERA 2 Device Install
64 Posts 11 Posters 43.4k Views 1 Watching
    No, it is really strange and unfortunate that your Vera2 seems to handle the MySensors plugin differently than on the 3/Lite model. I tried finding some information on the differences but haven't found any on the micasa-forum.
    Using the ethernet gateway wouldn't make a difference at this point.
    • N
      N
      Nicola Reina
      Hello
      I was going to buy a few arduinos supposing that the project works with a Vera 2 (not vera light).
      Can you please confirm that someone has it installed successfully on a Vera 2?
        @Nicola-Reina
        Perhaps you could try to install the vera-plugin and see what happens. @DeltaNu1142 had problem just getting plugin to startup correctly.
        Would be interesting to see if you are experiencing the same thing.
        • DeltaNu1142D
          DeltaNu1142D
          DeltaNu1142
          I'd like to see what luck you have with it. I'd be willing to "float" you an Arduino Nano and radio if you wanted to try it out.
          • DvbitD
            DvbitD
            Dvbit
            I am Planning to buy some sensor. Is vera 2 supported? Or is it just vera lite ?
              sailhome
              I have been using a VERA 2 with the Arduino usb gateway for two weeks now. I have two nodes, one with a motion sensor and the second node with a humidity/temp sensor. They are working well. I had to reload the VERA UI several times after I uploaded the files to VERA. After the reboots the gateway worked properly. I have more Arduinos and sensors on order, these things are great. Other than affirming that a VERA 2 will work I can't be of much more help.
              hekH DeltaNu1142D 2 Replies Last reply
              • S sailhome
                @sailhome
                Good to hear. But this makes the problems @DeltaNu1142 experience a mystery.
                • DvbitD
                  DvbitD
                  Dvbit
                  Thanks. So i go a ahead and hold thumbs
                  • DvbitD
                    DvbitD
                    Dvbit
                    Vera is temperamental at least ...
                    I have some plugins that once worked now not. Apparently nothing changed
                      Yeah, Vera is moody sometimes.
                      • S sailhome
                        DeltaNu1142D
                        DeltaNu1142D
                        DeltaNu1142
                        wrote on last edited by DeltaNu1142
                        #41
                        I wish I could attribute my troubles between this plugin & my Vera 2 to something. I hung it up a while ago. I've since installed ping sensors & then uninstalled them, but they worked as expected while I had them.
                        Let me ask this... should you be able to install the Arduino plugin without the hardware, and get... anything? All I ever saw in the plugin was a blue circle. It's as if the plugin never configured.
                        • J
                          J
                          jmmorgan
                          I am just starting to install my plug in for VERA 2. It created the plug in without a problems. When Vera starts the plug in it states that the serial port has to be selected. How do I do that? Under the serial port tab there is only my serial port for my alarm system. If I ssh into vera I can see both USB ports. My alarm port (usbserial.c: PL-2303 converter now attached to ttyUSB1 (or usb/tts/1 for devfs)0 and the gateway USB (usbserial.c: CP210X converter now attached to ttyUSB0 (or usb/tts/0 for devfs)). So I know it connects, but I do not know how to tell the plug in to use that port. Any help would be appreciated.
                          John
                            It usually pops up on the serial configuration page. You're using a Arduino Nano right?
                            J 1 Reply Last reply
                              J
                              J
                              jmmorgan
                              @hek I am using Arduino Nano, but it does not pop up in the serial configuration page. I have read a lot of the post on USB to serial connection on the Vera forum, but no luck.
                              JOhn
                              • J
                                J
                                jmmorgan
                                After much effort, I got it to recognize the serial gateway: Here what I did
                                Log into WinSCP
                                Run lsusb
                                You should see a line similar to this. Bus 001 Device 006: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x Composite Device. The 10c4 is the vendor and the ea60 is the product.
                                Find
                                /etc/cmh/serproxy.port
                                Open it up and make sure it has the line
                                vendor:10c4 product:ea60
                                If serproxy.port does not exist, manual create it.
                                Reboot, Reboot and hope.
                                Now on to the next step. I hope it is easier.
                                • J
                                  J
                                  jmmorgan
                                  Well, I knew it was to good to be true. The plug-in loads properly without error and I have set the serial port. However, when I hit the start button (is it suppose to change color and stay that color until is stop) and reset the sensor, nothing happens. What is my next step. The sensor is sending a request for node id, which the gateway acknowledges, but it never send the node ID back. I tried looking at the Vera log, but there are just too many entries.
                                  hekH 1 Reply Last reply
                                  • J jmmorgan
                                    @jmmorgan
                                    > grep Arduino /var/log/cmh/LuaUPnP.log
                                    Only shows Arduino related stuff from the log.
                                    • blaceyB
                                      blaceyB
                                      blacey
                                      When my Vera3 fails to show the USB port for the Gateway (typically after a power cycle), I do the following to get it to recognize it.
                                      1. Unplug the gateway USB cable from the Vera3's USB port
                                      2. Click Reload on the upper right of the Vera dashboard and wait for reload to finish
                                      3. Plug the gateway USB cable into the Vera3's USB port
                                      4. Click Reload on the upper right of the Vera dashboard and wait for the reload to finish
                                      5. Navigate to Develop Apps->Serial Port to configure the port.
                                      I don't know why the Vera removes the USB port if the device is power cycled while the gateway is connected but the steps above seem to reliably resolve it for me.
                                      • J
                                        J
                                        jmmorgan
                                        Here is my log. It seems the gateway startup ok and send the inclusion command. The node requests the ID, which the gateway acknowledge, but nothing happens after that.
                                        jmmlog1.pdf
                                          I can't see that the inclusion mode was started in the log.
                                          And what does the log say on the sensor when it requests an id? Does it receive anything?
