  3. Vera
  4. VERA 2 Device Install
64 Posts 11 Posters 43.4k Views 1 Watching
  • stofakillerS
    stofakillerS
    stofakiller
    Hi, i got mine to work, when i change the port from 5003 to 80...
    DeltaNu1142D 1 Reply Last reply
    • stofakillerS stofakiller
      DeltaNu1142D
      DeltaNu1142D
      DeltaNu1142
      @stofakiller
      Do you mean, the device was blank until you changed the port? Or are you using an Ethernet gateway?
      • stofakillerS
        stofakillerS
        stofakiller
        Yes, it was blank until i choose port 80...
        I choose 192.168.1.166 as ip for my ethernet gateway, but it didn't work for me with the standard port 5003 (192.168.1.166:5003), but when i changed it in the sketch to port 80 and also in the MySensors Plugin, then it worked.
        • DeltaNu1142D
          DeltaNu1142D
          DeltaNu1142
          I've been attempting to use a USB gateway. I'm unmotivated at this time to try an Ethernet gateway as I don't have any reason to think it would work.
            No, it is really strange and unfortunate that your Vera2 seems to handle the MySensors plugin differently than on the 3/Lite model. I tried finding some information on the differences but haven't found any on the micasa-forum.
            Using the ethernet gateway wouldn't make a difference at this point.
            • N
              N
              Nicola Reina
              Hello
              I was going to buy a few arduinos supposing that the project works with a Vera 2 (not vera light).
              Can you please confirm that someone has it installed successfully on a Vera 2?
                @Nicola-Reina
                Perhaps you could try to install the vera-plugin and see what happens. @DeltaNu1142 had problem just getting plugin to startup correctly.
                Would be interesting to see if you are experiencing the same thing.
                • DeltaNu1142D
                  DeltaNu1142D
                  DeltaNu1142
                  I'd like to see what luck you have with it. I'd be willing to "float" you an Arduino Nano and radio if you wanted to try it out.
                  • DvbitD
                    DvbitD
                    Dvbit
                    I am Planning to buy some sensor. Is vera 2 supported? Or is it just vera lite ?
                      sailhome
                      I have been using a VERA 2 with the Arduino usb gateway for two weeks now. I have two nodes, one with a motion sensor and the second node with a humidity/temp sensor. They are working well. I had to reload the VERA UI several times after I uploaded the files to VERA. After the reboots the gateway worked properly. I have more Arduinos and sensors on order, these things are great. Other than affirming that a VERA 2 will work I can't be of much more help.
                      hekH DeltaNu1142D 2 Replies Last reply
                      • S sailhome
                        @sailhome
                        Good to hear. But this makes the problems @DeltaNu1142 experience a mystery.
                        • DvbitD
                          DvbitD
                          Dvbit
                          Thanks. So i go a ahead and hold thumbs
                          • DvbitD
                            DvbitD
                            Dvbit
                            Vera is temperamental at least ...
                            I have some plugins that once worked now not. Apparently nothing changed
                              Yeah, Vera is moody sometimes.
                              • S sailhome
                                DeltaNu1142D
                                DeltaNu1142D
                                DeltaNu1142
                                wrote on last edited by DeltaNu1142
                                #41
                                I wish I could attribute my troubles between this plugin & my Vera 2 to something. I hung it up a while ago. I've since installed ping sensors & then uninstalled them, but they worked as expected while I had them.
                                Let me ask this... should you be able to install the Arduino plugin without the hardware, and get... anything? All I ever saw in the plugin was a blue circle. It's as if the plugin never configured.
                                • J
                                  J
                                  jmmorgan
                                  I am just starting to install my plug in for VERA 2. It created the plug in without a problems. When Vera starts the plug in it states that the serial port has to be selected. How do I do that? Under the serial port tab there is only my serial port for my alarm system. If I ssh into vera I can see both USB ports. My alarm port (usbserial.c: PL-2303 converter now attached to ttyUSB1 (or usb/tts/1 for devfs)0 and the gateway USB (usbserial.c: CP210X converter now attached to ttyUSB0 (or usb/tts/0 for devfs)). So I know it connects, but I do not know how to tell the plug in to use that port. Any help would be appreciated.
                                  John
                                    It usually pops up on the serial configuration page. You're using a Arduino Nano right?
                                    J 1 Reply Last reply
                                      J
                                      J
                                      jmmorgan
                                      @hek I am using Arduino Nano, but it does not pop up in the serial configuration page. I have read a lot of the post on USB to serial connection on the Vera forum, but no luck.
                                      JOhn
                                      • J
                                        J
                                        jmmorgan
                                        After much effort, I got it to recognize the serial gateway: Here what I did
                                        Log into WinSCP
                                        Run lsusb
                                        You should see a line similar to this. Bus 001 Device 006: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x Composite Device. The 10c4 is the vendor and the ea60 is the product.
                                        Find
                                        /etc/cmh/serproxy.port
                                        Open it up and make sure it has the line
                                        vendor:10c4 product:ea60
                                        If serproxy.port does not exist, manual create it.
                                        Reboot, Reboot and hope.
                                        Now on to the next step. I hope it is easier.
                                        • J
                                          J
                                          jmmorgan
                                          Well, I knew it was to good to be true. The plug-in loads properly without error and I have set the serial port. However, when I hit the start button (is it suppose to change color and stay that color until is stop) and reset the sensor, nothing happens. What is my next step. The sensor is sending a request for node id, which the gateway acknowledges, but it never send the node ID back. I tried looking at the Vera log, but there are just too many entries.
                                          hekH 1 Reply Last reply
