  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • mar.conteM
    mar.conteM
    mar.conte
    Hi, i wanted to know in which section of the sketch I turn on and turn off a led when the node controls the battery because at night the led me starts the pir; Now I've put the digitalwrite after nodemanger.loop
    M.C.
    U gohanG 2 Replies Last reply
    • mar.conteM mar.conte
      U
      U
      user2684
      @mar.conte NodeManager does not control any led so I think you are free to place your code where you think is most appropriate for your needs. Thanks
        @mar.conte put a capacitor on the PIR vcc/gnd and increase the size until it is stable.
        mar.conteM 1 Reply Last reply
          mar.conteM
          mar.conteM
          mar.conte
          @gohan
          Good idea Tanks
          M.C.
          • U
            U
            user2684
            Hi, I've added a "How to contribute" section in the documentation of the dev release in case anybody is interested to contribute to this project: https://github.com/mysensors/NodeManager/tree/development#contributing.
            I'm not a git expert so I hope those instructions to have some sense :)
            • U
              U
              user2684
              Pretty big enhancement in the development branch of NodeManager if anybody is interested. I spent quite a good amount of time working on the core code to introduce mainly two features opening up the door to a good list of enhancements.
              The first one is a sort of countdown utility. Can be based on the number of sleeping cycles or minutes. It detects automatically a sleeping node and instead of using millis sum up the sleep interval and reports when the time is over. This approach has been used to:
              • Allow different sensors reporting at different timeframes (e.g. by configuring a specific sensor to report every e.g. 5 minutes or 10 sleeping cycles instead of at the end of each cycle)
              • For output sensors optionally use the input value as an elapsed time (e.g. the output will be turned on and the input value will be used as a timer to turn it off automatically). For example by sending 3 to a relay, it will be turned on and after 3 minutes turned off automatically. Useful if you already know for how long the output should stay on.
              • For output sensors optionally set a safeguard (e.g. after a relay is set to on, turn it off automatically after 1 hour). Useful if e.g. you are controlling a boiler and you are afraid something could prevent the command to turn it off to reach the board.
              • Add timeframe option for reporting battery level (e.g. instead of reporting every 10 sleeping cycles, report every 1 hour regardless of how long is the sleeping cycles).
              The other big change is a an complete remote API. With the current version you could send to NodeManager's service child id a limited list of commands to change the behavior of the board remotely, mainly to alter the duration of the sleep cycle. In the development release instead, almost every function of both NodeManager AND of every sensor can be invoked remotely. This is done by sending a V_CUSTOM message with a function_id and optional value to pass along to the service child id or each sensor's child id. More details here: https://github.com/mysensors/NodeManager/tree/development#communicate-with-nodemanager-and-its-sensors
              This development branch is available here: https://github.com/mysensors/NodeManager/tree/development
                Do you think it may be possible to add the function to use a digital pin to power a PIR sensor to turn it on only when setting it armed? (to save a little power)
                U 1 Reply Last reply
                • rakeshpaiR
                  rakeshpaiR
                  rakeshpai
                  Why does the power manager use two pins to power the sensor? Could we just use one pin for Vcc, and assume that the GND is permanently connected?
                  • mar.conteM
                    mar.conteM
                    mar.conte
                    wrote on last edited by mar.conte
                    #176
                    But i'm trying to test a Pir of panasonic EKMB1201113 papirs series cost a bit but they have low power consumption
                    1 to 100 microampers in sleep mode, just connect a 100 kohm resistance in pulldown and it is very precise up to 12 meters
                    link text
                    M.C.
                      U
                      U
                      user2684
                      @gohan interesting use case. I personally prefer to have the arm/disarm logic on the controller but I can understand there are also different situations. I've opened https://github.com/mysensors/NodeManager/issues/138 for this. Thanks for the suggestion!
                      • rakeshpaiR rakeshpai
                        U
                        U
                        user2684
                        @rakeshpai said in NodeManager: plugin for a rapid development of battery-powered sensors:
                        I usually use the power pins when either I need to save power or I do not have vcc/gnd pins available on the arduino board. But yes, you're right, there are other scenarios to consider. I've opened https://github.com/mysensors/NodeManager/issues/139 for this. Thanks
                          saving pins is always good :D
                          • mar.conteM
                            mar.conteM
                            mar.conte
                            #180
                            Hello how can i enter the commands type 254; 200; 2; 0; 48; BATTERY in a lua script of domoticz?
                            M.C.
                              U
                              U
                              user2684
                              @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
                              Sorry, I don't use domoticz so I cannot help with that. I hope somebody else here will have an answer for you :-)
                              • U
                                U
                                user2684
                                Guys, @hek has been so kind to offer a dedicated section within the forum for NodeManager so feel free to open new topics directly under https://forum.mysensors.org/category/43/nodemanager. I hope this can facilitate new users to better find the answers they are looking for and you guys to follow the discussions in a smoother way without the need to jump here and there along the same long thread.
                                • U
                                  U
                                  user2684
                                  Hello All,
                                  I've just released on GitHub (https://github.com/mysensors/NodeManager) a hotfix (v1.5.1) for NodeManager in order to include the memory optimization improvements already part of the development version.
                                  This is to allow saving up to 20% of memory on a pro mini and prevent the board to crash or become unpredictable when approaching the memory limit. No new features or enhancements have been added to this hotfix.
                                  If instead interested in testing out the development version or contribute please refer to https://github.com/mysensors/NodeManager/tree/development and https://github.com/mysensors/NodeManager/milestone/7.
                                  • U
                                    U
                                    user2684
                                    wrote on last edited by user2684
                                    #184
                                    Hello, NodeManager's version 1.6 is almost ready. Plenty of new things and fixes are about to be available but I'd need some diverse testing before officially releasing it.
                                    The first step would be to ensure that what was working with the current version is still working with this new release :)
                                    All the new things are instead detailed here https://github.com/mysensors/NodeManager/issues?utf8=✓&q=milestone%3Av1.6 is%3Aclosed label%3Afixed and in the associated PRs.
                                    The code is available at https://github.com/mysensors/NodeManager/tree/development.
                                    Whoever is willing to give it a try, please report any issue directly on github whenever there is already an issue open or on https://forum.mysensors.org/topic/7266/nodemanager-v1-6-dev-comments-and-issues otherwise.
                                    Ideally I'm targeting mid August for releasing a stable v1.6.
                                    Many thanks!
                                    • G
                                      G
                                      Getz99
                                      @user2684
                                      I'm using NM for all my projects and I really like it!
                                      Will NodeManager support APDS-9960 RGB and Gesture Sensor in the future?
                                      • G Getz99
                                        @user2684
                                        U
                                        U
                                        user2684
                                        @Getz99 thanks for your feedback! I've created https://github.com/mysensors/NodeManager/issues/201 to track this request. Keep in mind no new features will be part of v1.6 which should be released soon so I've added this to the v1.7 backlog. Thanks
                                        G 1 Reply Last reply
                                        • U user2684
                                          G
                                          G
                                          Getz99
                                          @user2684 Thanks! I understand it will not be in v1.6, I'm waiting for that release!
