  3. 💬 Sensebender Micro mk2
temperaturesensebendersamdhumidity
37 Posts 11 Posters 16.4k Views 12 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Is there any site where you can upload the pcb+bom and have all the components (maybe not radio and pinheaders) soldered before they send the pcb?
    tbowmoT 1 Reply Last reply
    • scalzS scalz
      @Ptibu
      I'm also using some custom atsamd boards on my side. I looked a while ago at SAML. They have some some common points, but if i remember SAML datasheet, it's not completely the same, especially for low power modes, additional features etc.. Is SAML Arduino compatible now? i'm just curious, i don't really need it as there are already so much other great mcu or complete module :)
      P
      P
      Ptibu
      wrote on last edited by Ptibu
      Not yet. but it is WIP
      https://github.com/arduino/arduino-builder/issues/176#issuecomment-269110984
      It is called PCBA service. dirtypcbs and itead have such services.
      Got price estimation from itead few weeks ago for this board: about 550$ / 10 boards, including PCD ~100$, stencil ~60$, components ~219$ and assembly ~150$)
        tbowmoT
        tbowmoT
        tbowmo
        @Cliff-Karlsson @Ptibu
        You can order the board from our partner itead studio here, with all SMD components mounted. You need to add radio / ethernet module yourself.
        • tbowmoT
          tbowmoT
          tbowmo
          @Ptibu
          Just checked mouser prices, for 100 units:
          ATSAML21E18B-AUT : 519,0$
          ATSAMD20E18A-AUT : 298,0$
          ATSHA204A-STUCZ-T : 83,7$
          total : 381,7$
          price difference: 137,3$ for 100 boards, or 1.37$ per board. So we can still save a couple of bucks by using atsamd + atsha204
          P 1 Reply Last reply
          • tbowmoT tbowmo
            @Ptibu
            total : 381,7$
            P
            P
            Ptibu
            @tbowmo OK, for 100 pieces, it makes a huge difference, sorry.
            And glad to see the gateway available, good work !
            • tbowmoT
              tbowmoT
              tbowmo
              @Ptibu
              I'm always looking at larger quantities when designing boards :).. Specially when designing the sensebender boards, if we can lower the price just a little it means cheaper boards for the community, or a bit more contribution to the site maintenance etc.
              • bjornhallbergB
                bjornhallbergB
                bjornhallberg
                Any progress on the mk2?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @bjornhallberg
                  I've got the first prototype pcbs for it.. So just need to get components and assemble the first sample. However, the wife thinks that a new chicken coop (which will be filled with sensors :D) , and various other projects, have higher priority :).
                  • L
                    L
                    lafleur
                    wrote on last edited by lafleur
                    Is this board using the RFM69HCW footprint so that one could also use an RFM95??
                    If not, please consider this change and you might want to consider as an option for DIO-1 connected to an I/O pin on the CPU.. (this would also make it compatible with LoRaWan network)
                    • L lafleur
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @lafleur
                      I used the standard RFM69W footprint at the moment. This is because I do not need the high power variant, that the RFM69HCW is (it is more power hungry as well)
                      Things can still change...
                      • L
                        L
                        lafleur
                        Both the RFM69HC and RFM69HCW are available in the smaller package.... again, this would allow RFM95 to be used.
                        Thanks...
                        [0_1496601875842_RFM69HC_DataSheet_v1.1.pdf](/assets/uploads/files/1496601877634-rfm69hc_datasheet_v1.1.pdf)
                        • L lafleur
                          Thanks...
                          tbowmoT
                          tbowmoT
                          tbowmo
                          @lafleur but doesn't the H denote a high power output device? Which means higher power consumption.
                          • L
                            L
                            lafleur
                            Yes, The H = High Power version, C = Compact version 16x16mm pkg, vis 16x19mm pkg
                            My error, RFM69CW and RFM69HCW are available, also note that if you do not use the power over +13dbm, power consumption is about the same between the radios.
                            https://lowpowerlab.com/forum/rf-range-antennas-rfm69-library/rfm69w-and-rfm69hw-current-consumption/
                            [0_1496604219131_RFM69CW-V1.1.pdf](/assets/uploads/files/1496604221362-rfm69cw-v1.1.pdf)
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @lafleur
                              RFM69CW and RFM69HCW are not pin compatible.. One downside with hoperf, that they can't stick with a standard footprint layout..
                              • L
                                L
                                lafleur
                                Well, that news to me. I've always use the HCW variant and did NOT noticed the pin change. My error for not looking at the detail... (This was not the case with the RFM69W and HW radios, both shared the same pin-out)
                                but again, using the HCW allow one to also use the RFM95 radios, and if you keep power below +13, power consumption is about the same... also the new RFM69 radio driver in 2.2b use adaptive power control as an option, this keep power use to a minimum saving power.
                                I just re-checked the data sheets, RFM95 and RFM69HCW do share the same pin-out.
                                • tbowmoT tbowmo
                                  @lafleur
                                  #22
                                  @tbowmo from what I understand, they are pin compatible.
                                  C and "non-C" are not pin compatible, but H and "non-H" are.
                                  Older discussion on a similar topic: https://forum.mysensors.org/post/60304
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @mfalkvidd
                                    Check the datasheets, RFM69HCW has 16 pins, while RFM69CW only has 14 pins.
                                    At least when I looked at the datasheets a couple of hours ago
                                    • L lafleur
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @lafleur
                                      Seems that you are right about the power consumption.. According to the datasheets, they use the same in receive mode, and when transmitting 13dBm.. So in theory it shouldn't do any harm on battery life..
                                      Well I'll see if I can incorporate it in the second prototype..
                                      • tbowmoT tbowmo
                                        @mfalkvidd
                                        @tbowmo said in 💬 Sensebender Micro mk2:
                                        @mfalkvidd
                                        Yes you are right. Sorry for the confusion.
                                        • bjornhallbergB
                                          bjornhallbergB
                                          bjornhallberg
                                          Could we do what Moteino has done and drop support for HW/W radios and opt for HCW/CW/RFM95/96/RFM12 using double sets of pads?
                                          https://lowpowerlab.com/shop/product/99
                                          Would be great if the community could settle on just one radio or a common way of doing things.
