  3. 💬 Sensebender Micro mk2
temperaturesensebendersamdhumidity
37 Posts 11 Posters 16.4k Views 12 Watching
  • beaugundersonB beaugunderson
    "Temperature / Humidity sensor Si7021" is listed as an enhancement but the mk1 had the same sensor correct?
    tbowmoT
    tbowmoT
    tbowmo
    @beaugunderson
    Right, my mistake.. :) both flash and si7021 is borrowed from mk1..
    @Ptibu
    I haven't ordered any prototype pcb yet. I'm trying to keep prices down, and SAML is still pretty expensive, compared to SAMD.
    P 1 Reply Last reply
    • tbowmoT tbowmo
      @beaugunderson
      @Ptibu
      P
      P
      Ptibu
      @tbowmo
      Another big advantage of the SAML over the SAMD is the embedded AES core. It would allow strong crypto for both comm & data encryption (at MCU level, not radio) and authentication (ex: AES based CMAC). In this case, the ATSHA is not needed anymore for auth but it will break compatibility with existing ATSHA based boards (unless implementing SHA256 in SW).
      For what I can see, cost for SAML is about the same than SAMD + ATSHA (+/- 0.5€).
      For new (secured) mysensors networks, SAML would have nice advantages with comparable price (+dev efforts of course).
        @Ptibu
        I'm also using some custom atsamd boards on my side. I looked a while ago at SAML. They have some some common points, but if i remember SAML datasheet, it's not completely the same, especially for low power modes, additional features etc.. Is SAML Arduino compatible now? i'm just curious, i don't really need it as there are already so much other great mcu or complete module :)
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          Is there any site where you can upload the pcb+bom and have all the components (maybe not radio and pinheaders) soldered before they send the pcb?
          tbowmoT 1 Reply Last reply
          • scalzS scalz
            @Ptibu
            P
            P
            Ptibu
            wrote on last edited by Ptibu
            Not yet. but it is WIP
            https://github.com/arduino/arduino-builder/issues/176#issuecomment-269110984
            It is called PCBA service. dirtypcbs and itead have such services.
            Got price estimation from itead few weeks ago for this board: about 550$ / 10 boards, including PCD ~100$, stencil ~60$, components ~219$ and assembly ~150$)
              tbowmoT
              tbowmoT
              tbowmo
              @Cliff-Karlsson @Ptibu
              You can order the board from our partner itead studio here, with all SMD components mounted. You need to add radio / ethernet module yourself.
              • tbowmoT
                tbowmoT
                tbowmo
                @Ptibu
                Just checked mouser prices, for 100 units:
                ATSAML21E18B-AUT : 519,0$
                ATSAMD20E18A-AUT : 298,0$
                ATSHA204A-STUCZ-T : 83,7$
                total : 381,7$
                price difference: 137,3$ for 100 boards, or 1.37$ per board. So we can still save a couple of bucks by using atsamd + atsha204
                • tbowmoT tbowmo
                  @Ptibu
                  total : 381,7$
                  P
                  P
                  Ptibu
                  @tbowmo OK, for 100 pieces, it makes a huge difference, sorry.
                  And glad to see the gateway available, good work !
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Ptibu
                    I'm always looking at larger quantities when designing boards :).. Specially when designing the sensebender boards, if we can lower the price just a little it means cheaper boards for the community, or a bit more contribution to the site maintenance etc.
                    • bjornhallbergB
                      bjornhallbergB
                      bjornhallberg
                      Any progress on the mk2?
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @bjornhallberg
                        I've got the first prototype pcbs for it.. So just need to get components and assemble the first sample. However, the wife thinks that a new chicken coop (which will be filled with sensors :D) , and various other projects, have higher priority :).
                        • L
                          L
                          lafleur
                          wrote on last edited by lafleur
                          Is this board using the RFM69HCW footprint so that one could also use an RFM95??
                          If not, please consider this change and you might want to consider as an option for DIO-1 connected to an I/O pin on the CPU.. (this would also make it compatible with LoRaWan network)
                          • L lafleur
                            tbowmoT
                            tbowmoT
                            tbowmo
                            @lafleur
                            I used the standard RFM69W footprint at the moment. This is because I do not need the high power variant, that the RFM69HCW is (it is more power hungry as well)
                            Things can still change...
                            • L
                              L
                              lafleur
                              Both the RFM69HC and RFM69HCW are available in the smaller package.... again, this would allow RFM95 to be used.
                              Thanks...
                              [0_1496601875842_RFM69HC_DataSheet_v1.1.pdf](/assets/uploads/files/1496601877634-rfm69hc_datasheet_v1.1.pdf)
                              • L lafleur
                                Thanks...
                                tbowmoT
                                tbowmoT
                                tbowmo
                                @lafleur but doesn't the H denote a high power output device? Which means higher power consumption.
                                • L
                                  L
                                  lafleur
                                  Yes, The H = High Power version, C = Compact version 16x16mm pkg, vis 16x19mm pkg
                                  My error, RFM69CW and RFM69HCW are available, also note that if you do not use the power over +13dbm, power consumption is about the same between the radios.
                                  https://lowpowerlab.com/forum/rf-range-antennas-rfm69-library/rfm69w-and-rfm69hw-current-consumption/
                                  [0_1496604219131_RFM69CW-V1.1.pdf](/assets/uploads/files/1496604221362-rfm69cw-v1.1.pdf)
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @lafleur
                                    RFM69CW and RFM69HCW are not pin compatible.. One downside with hoperf, that they can't stick with a standard footprint layout..
                                    • L
                                      L
                                      lafleur
                                      Well, that news to me. I've always use the HCW variant and did NOT noticed the pin change. My error for not looking at the detail... (This was not the case with the RFM69W and HW radios, both shared the same pin-out)
                                      but again, using the HCW allow one to also use the RFM95 radios, and if you keep power below +13, power consumption is about the same... also the new RFM69 radio driver in 2.2b use adaptive power control as an option, this keep power use to a minimum saving power.
                                      I just re-checked the data sheets, RFM95 and RFM69HCW do share the same pin-out.
                                      • tbowmoT tbowmo
                                        @lafleur
                                        #22
                                        @tbowmo from what I understand, they are pin compatible.
                                        C and "non-C" are not pin compatible, but H and "non-H" are.
                                        Older discussion on a similar topic: https://forum.mysensors.org/post/60304
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @mfalkvidd
                                          Check the datasheets, RFM69HCW has 16 pins, while RFM69CW only has 14 pins.
                                          At least when I looked at the datasheets a couple of hours ago
