  3. 💬 Sensebender Micro mk2
temperaturesensebendersamdhumidity
37 Posts 11 Posters 16.4k Views 12 Watching
  • L
    L
    lafleur
    wrote on last edited by lafleur
    Is this board using the RFM69HCW footprint so that one could also use an RFM95??
    If not, please consider this change and you might want to consider as an option for DIO-1 connected to an I/O pin on the CPU.. (this would also make it compatible with LoRaWan network)
    tbowmoT 1 Reply Last reply
    • L lafleur
      tbowmoT
      tbowmoT
      tbowmo
      @lafleur
      I used the standard RFM69W footprint at the moment. This is because I do not need the high power variant, that the RFM69HCW is (it is more power hungry as well)
      Things can still change...
      • L
        L
        lafleur
        Both the RFM69HC and RFM69HCW are available in the smaller package.... again, this would allow RFM95 to be used.
        Thanks...
        [0_1496601875842_RFM69HC_DataSheet_v1.1.pdf](/assets/uploads/files/1496601877634-rfm69hc_datasheet_v1.1.pdf)
        • L lafleur
          Thanks...
          tbowmoT
          tbowmoT
          tbowmo
          @lafleur but doesn't the H denote a high power output device? Which means higher power consumption.
          • L
            L
            lafleur
            Yes, The H = High Power version, C = Compact version 16x16mm pkg, vis 16x19mm pkg
            My error, RFM69CW and RFM69HCW are available, also note that if you do not use the power over +13dbm, power consumption is about the same between the radios.
            https://lowpowerlab.com/forum/rf-range-antennas-rfm69-library/rfm69w-and-rfm69hw-current-consumption/
            [0_1496604219131_RFM69CW-V1.1.pdf](/assets/uploads/files/1496604221362-rfm69cw-v1.1.pdf)
            • tbowmoT
              tbowmoT
              tbowmo
              @lafleur
              RFM69CW and RFM69HCW are not pin compatible.. One downside with hoperf, that they can't stick with a standard footprint layout..
              • L
                L
                lafleur
                Well, that news to me. I've always use the HCW variant and did NOT noticed the pin change. My error for not looking at the detail... (This was not the case with the RFM69W and HW radios, both shared the same pin-out)
                but again, using the HCW allow one to also use the RFM95 radios, and if you keep power below +13, power consumption is about the same... also the new RFM69 radio driver in 2.2b use adaptive power control as an option, this keep power use to a minimum saving power.
                I just re-checked the data sheets, RFM95 and RFM69HCW do share the same pin-out.
                • tbowmoT tbowmo
                  @lafleur
                  #22
                  @tbowmo from what I understand, they are pin compatible.
                  C and "non-C" are not pin compatible, but H and "non-H" are.
                  Older discussion on a similar topic: https://forum.mysensors.org/post/60304
                    tbowmoT
                    tbowmoT
                    tbowmo
                    @mfalkvidd
                    Check the datasheets, RFM69HCW has 16 pins, while RFM69CW only has 14 pins.
                    At least when I looked at the datasheets a couple of hours ago
                    • L lafleur
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @lafleur
                      Seems that you are right about the power consumption.. According to the datasheets, they use the same in receive mode, and when transmitting 13dBm.. So in theory it shouldn't do any harm on battery life..
                      Well I'll see if I can incorporate it in the second prototype..
                      • tbowmoT tbowmo
                        @mfalkvidd
                        @tbowmo said in 💬 Sensebender Micro mk2:
                        @mfalkvidd
                        Yes you are right. Sorry for the confusion.
                        • bjornhallbergB
                          bjornhallbergB
                          bjornhallberg
                          Could we do what Moteino has done and drop support for HW/W radios and opt for HCW/CW/RFM95/96/RFM12 using double sets of pads?
                          https://lowpowerlab.com/shop/product/99
                          Would be great if the community could settle on just one radio or a common way of doing things.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @bjornhallberg it is on the todo list.. First pcb are using the RFM69(H)W footprint.. As I already have samples of that pcb.. (still need to assemble though)
                            • E
                              E
                              evs
                              Hi Thomas,
                              I like this design! Can you please tell the status and your future plans for this design?
                              EVS
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @evs
                                Currently I have the first prototype pcbs without components, so need to make an order at mouser/digikey. This has been on my task list for the last couple of months though, as wife / kids have a lot of other projects for me during the summer time :)
                                E 1 Reply Last reply
                                • tbowmoT tbowmo
                                  @evs
                                  E
                                  E
                                  evs
                                  @tbowmo
                                  Thanks for the update. But without the time frame. what needs to be done to finish. Is there software for the SAMD processor?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    MySensors is already ported to samd21 so I expect things to be minor in order to get it up and running on samd20.
                                    I will probably change footprint for the rfm69 module to use one that is compatible with rfm95 as well. And some other minor changes as well
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      A small update on this project, which I admit is taking longer than it should be (A lot of other projects has higher priority according to the wife)
                                      I finally got the first prototype assembled saturday evening, I can upload firmware (via jtag/swd), and I have a semi hacked arduino core, that can build. But when programming the samd20e with this core, and a simple sketch toggling an output pin, nothing happens.
                                      It seems that arduino halts in its initialization routine, waiting for some hardware to become ready after a reset, however I have not identified which part of the hardware yet.
                                      alexsh1A 1 Reply Last reply
                                      • tbowmoT tbowmo
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @tbowmo
                                        Hi, any update on this please?
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          Sorry, I got caught up in a couple of other projects, so still haven't got the first prototype up and run nok :(
