  3. How to connect QUIP300 to Domoticz
31 Posts 3 Posters 8.1k Views 3 Watching
  • M Offline
    M Offline
    mckenzi
    wrote on last edited by mckenzi
    Dear all,
    I would like to ask for your kind support with this PIR. Currently i'm using Arduino UNO (few relays ) as a gateway to Domoticz system installed on my QNAP ( connected via USB cable) . Everything works perfect.
    Now i found that i have old security system which is unused. And there are 4 PIR as on the attached photo.
    Is the any chance to conect to my controler(DOMOTICZ) ?
    (ESP8266 Arduino Uno, Raspberry PiOW) ?
    Thanks in advance for any suggestion!
    Best regards.
      if you find the digital output pin you can use a nano or a mini pro with the motion sensor sketch
      • N Offline
        N Offline
        Hello, be careful as it's powered with 12V and if I believe the doc in Google results min voltage is 8V do it will fry your Arduino.
        There's a relay output on the top right that you could use but it's probably 12V. What's more interesting is the LED connector below the relay output, you should check what voltage you have there when the PIR is triggered.
        • M Offline
          M Offline
          mckenzi
          Thank you Nca78 & gohan.
          Sensor is working very well conected to Wemos D1 mini under Domoticz control. Not i'm testing with 9V battery .
          I faced some problems with conection to Arduino . Basic sketch for motion sensor not working for my setup.
          Any clues how to modify my current sketch ? (for relays)
          0_1497042712762_GatewaySerialWired.ino
          Thank you.
            I can't see your sketch. What problem are you having exactly?
            • M Offline
              M Offline
              mckenzi
              Hello Gohan ,
              Here is my sketch. Arduino is conected via uSB cable to my QNAP.
              And there is few relays conected to Arduino. I would like to avoid wireless conection.
              Now i would like to add PIRs to this sketch.
              //#define MY_RADIO_NRF24
              // Enable serial gateway
              #define MY_GATEWAY_SERIAL
              #if F_CPU == 8000000L
              #define MY_BAUD_RATE 38400
              // Flash leds on rx/tx/err
              // #define MY_LEDS_BLINKING_FEATURE
              // Set blinking period
              // #define MY_DEFAULT_LED_BLINK_PERIOD 300
              // #define MY_WITH_LEDS_BLINKING_INVERSE
              // Enable inclusion mode
              #define MY_REPEATER_FEATURE
              #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
              #define BUTTON_PIN A1
              void before() {
                  pinMode(pin, OUTPUT);
              Bounce debouncer = Bounce();
                delay(10000);
                 // Setup the button.
                pinMode(BUTTON_PIN, INPUT_PULLUP);
                // After setting up the button, setup debouncer.
                debouncer.attach(BUTTON_PIN);
                debouncer.interval(5);
                //presentation();
                sendSketchInfo("Relay", "1.0");
                  present(sensor, S_LIGHT);
              MyMessage msg(1, V_LIGHT);
                if (debouncer.update()) {
                  // Get the update value.
                  int value = debouncer.read();
                  // Send in the new value.
                  if(value == LOW){
                       saveState(1, !loadState(1));
                       digitalWrite(RELAY_1, loadState(1)?RELAY_ON:RELAY_OFF);
                       send(msg.set(loadState(1)));
                if (message.type==V_LIGHT) {
                   // Change relay state
                   // Store state in eeprom
              How to make it ? I'm newbie - sorry.
              Regards.
                Just copy the code from motion sensor sketch, assign a child ID to the pir sensor, present it and in code just check pin status with digitalread() and send value changed from last send
                • M Offline
                  M Offline
                  mckenzi
                  Hey gohan, thanks - basic sketch will do the job.
                  I faced another problem. Now i've conected one of the PIR via WemosD1 mini with ESP Easy.0_1497208049084_DSC_0864.JPG
                  And works very well.
                  But i would like to connect 3 more sensors.
                  Power supply for PIR and Wemos is different and there is only one GND pin .
                  Any idea how to make it?
                    3 more sensor to the same wemos?
                    • M Offline
                      M Offline
                      mckenzi
                      Yes. Possible?
                        With mysensors it is possible, with esp easy I don't know.
                        • M Offline
                          M Offline
                          mckenzi
                          I can swich to MySensors- no problem.
                          • M Offline
                            M Offline
                            mckenzi
                            Hi Gohan, please see my set up i more details.
                            Each of PIR is conected to old/not used alarm control panel.
                            Now it is used as power supply. I've just ordered Arduino Nano + nRF24L01 to conect all motion sensors. I would like to use one of free port to power my node (thru voltage step down : 12V->5V)
                            How should i conect sensors to node?
                              wrote on last edited by gohan
                              Do you want to put the nano in that panel?
                              • M Offline
                                M Offline
                                mckenzi
                                Hi, panel will be use as a power supply only.
                                  Ok, but if you put the nano in that location you will have the yellow cables coming back from the PIR sensors and you would have to use those to connect to digital pins of the arduino, the problem is that you need to check what is the voltage that most likely will be over 5V and you would need to find a way to lower it.
                                  • M Offline
                                    M Offline
                                    mckenzi
                                    Yellow cable is connected to PIR's relay. And this cable i'm going to conect to digital input of arduino.
                                    Second cable from PIR's relay will be connnected to arduino's GND pin. ( not shown on this photo).
                                    There is no voltage on PIR's relay ( works as simple switch).
                                    Is my understanding correct ?
                                      If it is just a relay ok, I thought you were using the output of the pir sensor, but always check before connecting to the Arduino
                                      • M Offline
                                        M Offline
                                        mckenzi
                                        So how to connect 4 PIRs to one node to be able to see in Domoticz which was acivated ?
                                          Connect each one on a different digital pin and create a different child id for each pir sensor and present all of them, it is just replicating 4 times the code of the motion sensor sketch.
                                          12.1k
