  3. 💬 MDMSGate
💬 MDMSGate
atsha204amysensors gatewayesp8266ethernetmysensorsgatewaynrf24l01usbatmega328rfm69
82 Posts 22 Posters 42.5k Views 25 Watching
  • R
    R
    RonnieMace
    Thanks for the drawing. I understand that the gateway uses or wifi or 868MHz. If I want both I need 2 gateways and connect them to the raspberry controller. Is my assumption correct?
    kalinaK 1 Reply Last reply
    • R RonnieMace
      kalinaK
      kalinaK
      kalina
      @RonnieMace said in 💬 MDMSGate:
      You can use Wi-Fi and 868MHz at the same time, but Wi-Fi is intended for connection to controller only!!! 868MHz is intended for connection to different types of sensors or actuators. You can't establish a connection to any types of sensors via Wi-Fi.
      No.
      • P
        P
        pointbre
        HI Kalina, Would you please let me know how I could pay the extra $2.5 for RFM69 module? I'd like to make a purchase today.
        • P pointbre
          kalinaK
          kalinaK
          kalina
          @pointbre Hi, i am sending to you a PM. Check it pls in a few minutes...
          • fisherF
            fisherF
            fisher
            Hi @kalina:
            Is it possible to buy board only without plastic enclosure?
            • kalinaK
              kalinaK
              kalina
              Hi @fisher, yes it is possible.
              • fisherF
                fisherF
                fisher
                Hi, Finally the parcel from Kalina has arrived. It took two weeks to deliver from Ukraine to Poland (it stuck for 9 days in post office somewhere in Poland)
                The gateway works ok, the box enclosure is tiny and looks really good.
                I highly reccomend Kalina's goods!
                Kalina, thx for your support and for the bonus :)
                1_1496086270578_IMG_20170529_205502.jpg 0_1496086270578_IMG_20170529_205441.jpg
                • fisherF fisher
                  kalinaK
                  kalinaK
                  kalina
                  @fisher, Thanks for feedback! :simple_smile:
                  AnticimexA 1 Reply Last reply
                  • kalinaK kalina
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @kalina please provide the required documentation for the CERN license. See here if anything is unclear.
                    • AnticimexA Anticimex
                      kalinaK
                      kalinaK
                      kalina
                      @Anticimex , I have already uploaded the necessary license files.
                      • kalinaK
                        kalinaK
                        kalina
                        Unfortunately, for a while the MDMSGate will not be available for the sale (all 15 gateways have been sold). Now I am going to start the next 30 pcs into production. If someone wants to pre-order, please, send a PM to me.
                        • kalinaK kalina
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @kalina now I see them. Good :+1:
                          • kalinaK
                            kalinaK
                            kalina
                            #63
                            New batch of devices is in stock and available now ...
                            • kalinaK kalina
                              MagnusF
                              @kalina I'm new to "MySensors" and I think this device will suits me very well. My plan is to use MQTT and Wi-Fi mode.
                              Is this possible? To use Wi-Fi / Ethernet, as I understand, IP addresses for Gateway, router and controller must be defined but I have read that you in all modes is using the serial gateway sketch which not have IP adresses defined.
                              I wonder if there is any other gateway sketch that shall be used or how to solve this?
                              • M MagnusF
                                kalinaK
                                kalinaK
                                kalina
                                #65
                                @MagnusF said in 💬 MDMSGate:
                                My plan is to use MQTT and Wi-Fi mode. Is this possible?
                                Unfortunately, no. This gateway uses a microcontroller PIC18F67J60. Firmware of this uC doesnt support MQTT protocol (in future I probably add this feature). You can only use it as a ethernet gateway. In Wi-Fi mode, the ESP-12 module acts as well as the PIC18F67J60 microcontroller - converts the packets of TCP/IP to UART and vice versa.
                                Connection to controller through Ethernet :
                                1. Connect MDMSGate to the router (network). After this router will define IP address for gateway through DHCP (for example 192.168.1.6). You also can see this adress in router web interface.
                                2. Open web interface of the controller and fill "IP address" and "Port" for the Ethernet gateway.
                                3. Click "Connect" button and work!
                                Connecting through Wi-Fi a bit more complicated. If you want I can explain.
                                • kalinaK
                                  kalinaK
                                  kalina
                                  #66
                                  I have uploaded a small instruction "MDMSGate. Connection to Domoticz". This instruction explains how connect MDMSGate to Domoticz via LAN.
                                  • kalinaK
                                    kalinaK
                                    kalina
                                    #67
                                    Now available in pcb (lot with 10 pcs) ...
                                      marvin78
                                      Could you please describe the "WLAN way"? Tank you.
                                      • M marvin78
                                        kalinaK
                                        kalinaK
                                        kalina
                                        #69
                                        @marvin78 Hi, as i understand you got MDMSGate without Wi-Fi (ESP-12), because you didn't specify it in the order. I have written a small manual that describes how to start work in Wi-Fi mode in this case. Please, go to "Design files" menu and download "MDMSGate. Manual for installing Wi-Fi.pdf" file.
                                        • kalinaK kalina
                                          marvin78
                                          wrote on last edited by marvin78
                                          #70
                                          @kalina You're right. But it is no problem for me to solder in the ESP-12. So thank you.
                                          One question: will I be able to use Wifi, Serial OR (not and) LAN if I follow the steps from your instruction? As in just change jumper positions and use the other one? Does the sketch support that?
