  3. 💬 MDMSGate
💬 MDMSGate
atsha204amysensors gatewayesp8266ethernetmysensorsgatewaynrf24l01usbatmega328rfm69
82 Posts 22 Posters 41.7k Views 25 Watching
  • kalinaK
    kalinaK
    kalina
    Hi @fisher, yes it is possible.
    • fisherF
      fisherF
      fisher
      Hi, Finally the parcel from Kalina has arrived. It took two weeks to deliver from Ukraine to Poland (it stuck for 9 days in post office somewhere in Poland)
      The gateway works ok, the box enclosure is tiny and looks really good.
      I highly reccomend Kalina's goods!
      Kalina, thx for your support and for the bonus :)
      1_1496086270578_IMG_20170529_205502.jpg 0_1496086270578_IMG_20170529_205441.jpg
      kalinaK 1 Reply Last reply
      • fisherF fisher
        kalinaK
        kalinaK
        kalina
        @fisher, Thanks for feedback! :simple_smile:
        AnticimexA 1 Reply Last reply
        • kalinaK kalina
          AnticimexA
          AnticimexA
          Anticimex
          @kalina please provide the required documentation for the CERN license. See here if anything is unclear.
          • AnticimexA Anticimex
            kalinaK
            kalinaK
            kalina
            @Anticimex , I have already uploaded the necessary license files.
            • kalinaK
              kalinaK
              kalina
              Unfortunately, for a while the MDMSGate will not be available for the sale (all 15 gateways have been sold). Now I am going to start the next 30 pcs into production. If someone wants to pre-order, please, send a PM to me.
              • kalinaK kalina
                AnticimexA
                AnticimexA
                Anticimex
                @kalina now I see them. Good :+1:
                • kalinaK
                  kalinaK
                  kalina
                  #63
                  New batch of devices is in stock and available now ...
                  • kalinaK kalina
                    MagnusF
                    @kalina I'm new to "MySensors" and I think this device will suits me very well. My plan is to use MQTT and Wi-Fi mode.
                    Is this possible? To use Wi-Fi / Ethernet, as I understand, IP addresses for Gateway, router and controller must be defined but I have read that you in all modes is using the serial gateway sketch which not have IP adresses defined.
                    I wonder if there is any other gateway sketch that shall be used or how to solve this?
                    • M MagnusF
                      kalinaK
                      kalinaK
                      kalina
                      #65
                      @MagnusF said in 💬 MDMSGate:
                      My plan is to use MQTT and Wi-Fi mode. Is this possible?
                      Unfortunately, no. This gateway uses a microcontroller PIC18F67J60. Firmware of this uC doesnt support MQTT protocol (in future I probably add this feature). You can only use it as a ethernet gateway. In Wi-Fi mode, the ESP-12 module acts as well as the PIC18F67J60 microcontroller - converts the packets of TCP/IP to UART and vice versa.
                      Connection to controller through Ethernet :
                      1. Connect MDMSGate to the router (network). After this router will define IP address for gateway through DHCP (for example 192.168.1.6). You also can see this adress in router web interface.
                      2. Open web interface of the controller and fill "IP address" and "Port" for the Ethernet gateway.
                      3. Click "Connect" button and work!
                      Connecting through Wi-Fi a bit more complicated. If you want I can explain.
                      • kalinaK
                        kalinaK
                        kalina
                        #66
                        I have uploaded a small instruction "MDMSGate. Connection to Domoticz". This instruction explains how connect MDMSGate to Domoticz via LAN.
                        • kalinaK
                          kalinaK
                          kalina
                          #67
                          Now available in pcb (lot with 10 pcs) ...
                            marvin78
                            Could you please describe the "WLAN way"? Tank you.
                            • M marvin78
                              kalinaK
                              kalinaK
                              kalina
                              #69
                              @marvin78 Hi, as i understand you got MDMSGate without Wi-Fi (ESP-12), because you didn't specify it in the order. I have written a small manual that describes how to start work in Wi-Fi mode in this case. Please, go to "Design files" menu and download "MDMSGate. Manual for installing Wi-Fi.pdf" file.
                              • kalinaK kalina
                                marvin78
                                wrote on last edited by marvin78
                                #70
                                @kalina You're right. But it is no problem for me to solder in the ESP-12. So thank you.
                                One question: will I be able to use Wifi, Serial OR (not and) LAN if I follow the steps from your instruction? As in just change jumper positions and use the other one? Does the sketch support that?
                                • M marvin78
                                  kalinaK
                                  kalinaK
                                  kalina
                                  #71
                                  @marvin78 said in 💬 MDMSGate:
                                  Yes, you're absolutely right. It was the main goal. The mode changing just with change jumpers position. And as for sketch - in all 3 modes it is standard serial gateway sketch. I have written about it befor ....
                                  • G
                                    G
                                    giltesa
                                    Hello Kalina,
                                    On April 7, I presented my domotics nodes at the Arduino Day in Zaragoza, Spain. Your gateway worked all day like a champion!
                                    https://giltesa.com/wp-content/uploads/2018/04/ArduinoDayZgz2018_stand.jpg
                                    I have a question, would it be possible to get the Arduino sketch that has recorded the Atmega328P?
                                    Is this code? Do you only need that to work for NRF24L01+Ethernet?
                                    https://github.com/DmytroKalinkin/MDMS/blob/master/Gateway_2.4GHz/Gateway_2.4GHz.ino
                                    Kind regards.
                                    • G giltesa
                                      Hello Kalina,
                                      Kind regards.
                                      kalinaK
                                      kalinaK
                                      kalina
                                      #73
                                      @giltesa said in 💬 MDMSGate:
                                      Nice to hear! MDMSGate is my first and the best device))
                                      Is this code? https://github.com/DmytroKalinkin/MDMS/blob/master/Gateway_2.4GHz/Gateway_2.4GHz.ino
                                      Yes, MDMSGate is programmed by standard serial gateway sketch.
                                      No, I also use (in some case) serial and Wi-Fi connection. For the serial connection just change jumpers position. As for Wi-Fi connection you can read this
                                      https://www.openhardware.io/dl/5782866b09fcb093053825e4/design/MDMSGate. Manual for installing Wi-Fi.pdf
                                      The sketch the same in all modes.
                                      G 1 Reply Last reply
                                      • kalinaK kalina
                                        G
                                        G
                                        giltesa
                                        wrote on last edited by giltesa
                                        #74
                                        @kalina
                                        I find it surprising that without writing any line of programming code, apart from the constants, the MySensors library takes care of everything, it's great!
                                        My intention was to change the channel of the NRF24L01, the transfer speed, and configure the ATSHA204A.
                                        I think I read that the MDMSGate does not support MQTT because of hardware stuff, do you plan to release a second version?
                                        The truth is that I am not sure that it is essential either, but I ask you out of curiosity.
                                        Edit:
                                        More questions...
                                        Why is the sketch configured with MY_RF24_PA_LEVEL = RF24_PA_LOW? Would not it be better to use the value RF24_PA_HIGH or RF24_PA_MAX?
                                        kalinaK AnticimexA 2 Replies Last reply
                                        • G giltesa
                                          @kalina
                                          Edit:
                                          More questions...
                                          kalinaK
                                          kalinaK
                                          kalina
                                          #75
                                          You can make any changes that the MySensors library allows.
                                          I am completely satisfied with this version. But despite this,
                                          i think about a new version all the time: RS485, Bluetooth, MQTT ... what else???, So, i still don't see "the main feature" of the second version. As soon as i will find it, second version will be released immediately.
                                          Because RF24_PA_LOW configuration completely covers an area on which all my nodes are located. And I see no reason to increase the power.
