  2. Announcements
  3. πŸ’¬ Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 71.9k Views 51 Watching
  • ramoncarranzaR
    ramoncarranzaR
    ramoncarranza
    Thanks so much!!
    This thing's Amazing!!!!!!
    • sghazaghS
      sghazaghS
      sghazagh
      Hi all,
      I try to connect the Radio to Wemos D1 mini Pro and it's not working? I used both ESP8266Gateway and RelayActuator sketches and both Radio Fails...
      Are the pins here work fine with Wemos D1Mini?here is the pinout: http://escapequotes.net/wp-content/uploads/2016/02/d1-mini-esp8266-board-sh_fixled.jpg
      And here is the error I get:
      TSM:INIT
      !TSM:RADIO:FAIL
      !TSM:FAILURE
      TSM:PDT
      thanks,
      • korttomaK
        korttomaK
        korttoma
        If you are using the NRF24L01+ you should wire it according to the instructions here
        And use the sketch from the same page.
        So check your wiring of the radio module.
        • Tomas
        • sghazaghS
          sghazaghS
          sghazagh
          I used the same link (pins and sketches!). Checked it 10 times!
          I think my Radios are not functional....
          korttomaK 1 Reply Last reply
          • sghazaghS sghazagh
            korttomaK
            korttomaK
            korttoma
            @sghazagh maybe you can take a picture of the setup. Maybe someone else can see something that you don't.
            • Tomas
            • sghazaghS
              sghazaghS
              sghazagh
              wrote on last edited by sghazagh
              #31
              Good idea,
              Here is the side by side image from front and back of the PCB.
              The 'j1' marked on wrong pin ,that's why I think my radio is not working at all as it seems it's very bad replicate.
              However, I have rotated it by 180 degree and tried that as well. same result!
              • sghazaghS
                sghazaghS
                sghazagh
                Guys, just an update for my issue regarding Radio and my circuit.
                The Radio was faulty, I received the new one, swapped it and all worked fine.
                I just posted that here if someone want to use my last post image as a reference for connecting the Radio.
                The wiring all are correct.
                • jakesJ
                  jakesJ
                  jakes
                  Hi Hek,
                  Thanks for this guide... I have added an additional 433 RF receiver to my ESP8266 gateway. How can I send the data received from 433 RF to the my Home Assistant controller?
                  • denisvdbD
                    denisvdbD
                    denisvdb
                    Hello, i have build a wifi gateway and use it in jeedom.
                    My gateway wifi as connection problem.
                    In jeedom, in the log of my sensors node I have almost every 2 days the message: diconnected from network gateway.
                    If I restart the node the communication is re-established.
                    Is this a problem with nrf24l01?
                    • D
                      derrij
                      why esp8266 gateway shows only debug info?
                      when i comment //#define MY_DEBUG
                      where is no any serial output.
                      • D derrij
                        @derrij because it is a wifi gateway?
                        • A
                          AndreD
                          If put in client mode
                          #define MY_CONTROLLER_IP_ADDRESS 192, 168, 2, 9
                          I get an error. How to win.
                          Arduino: 1.8.2 (Windows 7), ΠŸΠ»Π°Ρ‚Π°:"Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
                          "C:\Users\DedHP\AppData\Local\Temp\arduino_build_364162\sketch\GatewayESP8266.ino.cpp.o"
                          In file included from C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                                       from C:\Users\DedHP\AppData\Local\Temp\arduino_modified_sketch_313960\GatewayESP8266.ino:132:
                          C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
                          C:\Documents\Arduino\ams\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:207:58: required from here
                          C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
                           size_t left = source.available();
                          C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
                           source.read(buffer.get(), will_send);
                          Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ ESP8266WiFi вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
                          Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ MySensors вСрсии 2.1.1 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Documents\Arduino\ams\Arduino\libraries\MySensors
                          Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ EEPROM вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM
                          Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ SPI вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
                          exit status 1
                          Ошибка компиляции для ΠΏΠ»Π°Ρ‚Ρ‹ Generic ESP8266 Module.*
                          • Jonathan CaesJ
                            Jonathan CaesJ
                            Jonathan Caes
                            Is it possible to use this setup without the nrf24l01 atached, so that i can use the esp8266 just as a sensor (not as a gateway)?
                            • Jonathan CaesJ Jonathan Caes
                              #39
                              @Jonathan-Caes yes. Don't define MY_RADIO_NRF24 and you're good to go. It will still be a gateway, but a gateway with local sensors and no radio.
                              • J
                                J
                                joseyapor
                                Hi how many Gateways Can i have on a network?
                                • J joseyapor
                                  #41
                                  @joseyapor On one MySensors network there can only be one MySensors gateway. But on one IP network, there can be many MySensors gateways. Exactly how many depends on geography and chosen transports but at the very least a few hundred. Thousands if you really need and plan accordingly.
                                  I 1 Reply Last reply
                                  • A
                                    alexalex
                                    Help! After connecting to the WIFI, I'm getting disconnected. Here's a log : https://goo.gl/fyr7ku
                                    Any help in figuring this out would be appreaciated!
                                    • A alexalex
                                      #43
                                      Welcome to the MySensors community @alexalex
                                      The log is missing the first lines, but it looks like the microcontroller is unable to communicate with the radio. Which radio are you using?
                                      See https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#details for more details about the log messages and https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to fix them.
                                      • Bogus ExceptionB
                                        Bogus ExceptionB
                                        Bogus Exception
                                        Is there a complete wiring table, diagram, or schematic? I have a working MyController/MySensors network on nRF24s, but I am adding WiFi with a ESP-201 module (white one with pins broken out for 2.54 pitch; see: http://smarpl.com/sites/default/files/images/ESP8266-ESP-201-pin-reference-v01.png)... TIA!
                                        "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
                                        -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
                                        -ATTiny, ATMega, STM32
                                        -Geek Channel: https://www.youtube.com/TheSalesEngineer
                                        • Bogus ExceptionB Bogus Exception
                                          #45
                                          @Bogus-Exception did you see the instructions linked in the first post in this thread? You probably want the part that says "connect the radio".
                                          With your input, this post could be even better πŸ’—
