  2. Announcements
  3. 💬 Door, Window and Push-button Sensor
110 Posts 36 Posters 57.7k Views 32 Watching
  • N nickgosling
    Hi, New here but stumbled across this.
    I am planning on re-using an old wired alarm system that has door and window sensors all over my house terminating under my stairs. Can I combine one sketch into multiple door reed switches on one arduino. That seems to have been asked before but there doesn't seem to be an answer. It would be quite annoying to have 8 arduinos next to each other in order to do so.
    Nick
    sundberg84S
    sundberg84S
    @nickgosling - no problem if you have 1 wire for each reedswitch you could just add it to different input/pins and have 1 arduno check which pins is high or low.
    • N
      N
      nickgosling
      Thanks for the response. OK I'm fine with assigning a pin as an input but how would I change the code to reflect this .thanks.
      • N nickgosling
        sundberg84S
        sundberg84S
        @nickgosling - take the sketch and add one child for each sensor. Define one input for each sensor and in the loop check each pin for a statechange. With a if you can then send the status for each changed pin.
        • N
          N
          nickgosling
          Thank you I'll give that a go.
          • J
            J
            Justas
            Maybe it is a little off-topic here, but maybe you could point me to the right direction: I want to build nice wall switch, and from technological point of view it is not that difficult using mysensors, this part is clear, including battery powering or making some kind of power conversion from AC to DC (in openhardware there are quite a few examples on that). What is bothering me is the switch "enclosure". I have one example from TKB Home:
            http://www.ebay.de/itm/TKB-Home-Z-Wave-Plus-Dual-Paddle-Wall-Switch-TZ56D-ZW5-/122201876698?ssPageName=ADME:X:EAC:GB:1120
            that I have bought to try with smarttnings controller (which is not intended to work with, now I know), but what it has - it is the enclosure: it is nice switch with 2 micro switches inside (4 in total, since it is dual wall switch), that are not locking in the pressed position - you press up and it clicks one button/switch and returns back to its initial "neutral" position, you press down - again, click and back to "neutral".
            I think the similar are are in aliexpress, that are called like wall wireless remote switch Transmitter, but I'm not sure about that, since I didn't bought one to disassemble.
            Maybe some one have met something similar for making some nice RF controlled wall switches?
            Thanks in advance!
            Regards
            Nca78N 1 Reply Last reply
            • J Justas
              Thanks in advance!
              Regards
              @Justas Hello, please check the dedicated category, if you don't find your hapiness please post there :)
              https://forum.mysensors.org/category/42/enclosures-3d-printing
              • skywatchS
                skywatchS
                skywatch
                I tried this today and it wouldn't find a parent.
                Adding #define MY_NODE_ID 1 seems to have solved the problem, so maybe this (and other) examples need to be updated with this info?
                Thanks for the work on this project though, I think it will be a lort of fun when I get it all working! :)
                • skywatchS skywatch
                  @skywatch that shouldn't bee needed. Would it be possible for you to post the entire log from when the node was unable to find parent?
                  • skywatchS
                    skywatchS
                    skywatch
                    I'll see if I can replicate it ...been nusy trying to sork out a controller now Heheh.....Not fun!
                    • skywatchS
                      skywatchS
                      skywatch
                      I just uploaded the sketch again without the define and it is working - I didn't clear the eeprom before uploading so maybe that would have made a difference? Is there a list of what is held in eeprom anywhere?
                      • J
                        J
                        joseyapor
                        Hi instead of using a arduino nano can i use esp8266 for a sensor
                        mfalkviddM E 2 Replies Last reply
                        • J joseyapor
                          @joseyapor yes you can but the esp8266 has very few usable io pins so connecting a radio and sensor at the same time might be difficult.
                          • J joseyapor
                            E
                            E
                            Ed1500
                            @joseyapor Yes no problem. 8 digital I/O. One of them a bit problematic as input (used for program mode)
                            • EuromirE
                              EuromirE
                              Euromir
                              Another newbie sorry.
                              Trying to use this as a simple doorbell, just to send a trigger to Domoticz.
                              I connect doorbell button to digital pin 3, the Node appears in Domoticz ok as a "security sensor" but shows as state "ON". However pressing the button appears to do nothing sadly, switch status stays as on, and log shows no activity at all?
                              Using a Uno (clone) and wondering if somethings up with it? :(
                              • L
                                L
                                LastSamurai
                                What does the nodes and/or the gateways log say?
                                It might not change in domoticz if you just send on but no off signals but it should still be visible in the nodes log (arduino and in domotizc)
                                • EuromirE
                                  EuromirE
                                  Euromir
                                  wrote on last edited by Euromir
                                  #48
                                  Hold that thought, embarrassingly it might just be a bad connection! Oops
                                  Just took it all apart in frustration, had a cuppa and put it back together.
                                  And something is triggering now, need to play some more, but first hurdle looks like possibly a simply connection maybe.
                                  I'll let you know.
                                  • B
                                    B
                                    bluezr1
                                    Not sure what I'm doing wrong but I tried to add more than one sensor and didn't get very far. Was hoping to do a motion and a door sensor from the same arduino.
                                    • skywatchS
                                      skywatchS
                                      skywatch
                                      As doors and windows are usually not near power sources would it not be better to have this sketch with a SLEEP function and trigger on interupt?
                                      • P
                                        P
                                        Psilin
                                        wrote on last edited by Psilin
                                        #51
                                        what is the logic of the variable "V_TRIPPED"to use? I just messed a little with the MyController application, and by using the V_TRIPPED the value changes from off to on,and stays on,even if the button is released? ( simular to close an opened door)
                                        Should the variable not be of a binary type with according sensor type?
                                          Slimz
                                          I have my sensor working well, Arduino pro mini with an Ethernet gateway using Home Assistant. .This is the first sensor I'm actually using a battery, so I've never really needed it, I see the battery level in HA as 0, how do I turn that on and use the battery level? Any pointers?
                                          Jim
