  2. Announcements
  3. 💬 Door, Window and Push-button Sensor
110 Posts 36 Posters 57.7k Views 32 Watching
    @Atesz very welcome to the MySensors community!
    "easily" is in the eye of the beholder, but I'd say yes. https://forum.mysensors.org/topic/2597/combining-mysensors-examples is a great starting poing for combining sketches.
    AteszA
    AteszA
    Atesz
    @mfalkvidd Thank you very much, it is almost what I've been looking for !
    • TON RIJNAARDT
      TON RIJNAARDT
      TON RIJNAARD
      Goodevening,
      I am new to mysensors (newby) i wil make 3 sensors on my mini pro can some one help me with the sketch.
      I am working a hole day but i can't get it writh help is very use vol.
      One switch (reed contact) is working.
        Hi Ton,
        You have to give us a little bit more information here (and please start a new thread for your project).
        Normally good to give information about:
        1. What are you trying to accomplish?
        2. What is working?
        3. What is not working?
        4. What did you try yourself before posting?
        5. What is the expected result?
        6. Logs from the sensor/gateway/controller.
        • Svante TegelandS
          Svante TegelandS
          Svante Tegeland
          I had big problems getting this one to work in Domoticz... But then I downgraded the Arduino IDE to IDE 1.6.7 (https://forum.mysensors.org/topic/5164/ethernet-gw-w5100-can-not-connect-to-domoticz/2) and then it worked!
          • TON RIJNAARDT
            TON RIJNAARDT
            TON RIJNAARD
            @hek,
            Thanks for the reply.
            I want to try 3 reed/door contacts on one mini-pro on pin 3,4 and 5
            What is working?
            One reed/door contact is working
            I don't no how i must make a second reed/door contact in the sketch (door/window push button)
            I am new to programming arduino and don't undertsand how to do that, ik look for a hint how i can implement a second reed/door switch in the sketch
            I look many sketches on internet and try to copy a copple of line in the working sketch but i don't get a second reed/switch in domoticz. I am trying this a hole day (i am with pension).
            What is the expected result? a second, thirth reed/sensor in domoticz i see here only the first sensor.
            The log for the first reed/door switch i see and it is working in domoticz, that is not the problem.
            Sorry for the bad English.
            • TON RIJNAARDT
              TON RIJNAARDT
              TON RIJNAARD
              @ Svante
              Thanks for the reply but is is working well with one reed switch. So that is not the problem I want on the mini/pro a second and thirt switch.
              • N
                N
                nickgosling
                Hi, New here but stumbled across this.
                I am planning on re-using an old wired alarm system that has door and window sensors all over my house terminating under my stairs. Can I combine one sketch into multiple door reed switches on one arduino. That seems to have been asked before but there doesn't seem to be an answer. It would be quite annoying to have 8 arduinos next to each other in order to do so.
                Nick
                • N nickgosling
                  Nick
                  sundberg84S
                  sundberg84S
                  @nickgosling - no problem if you have 1 wire for each reedswitch you could just add it to different input/pins and have 1 arduno check which pins is high or low.
                  • N
                    N
                    nickgosling
                    Thanks for the response. OK I'm fine with assigning a pin as an input but how would I change the code to reflect this .thanks.
                    • N nickgosling
                      sundberg84S
                      sundberg84S
                      @nickgosling - take the sketch and add one child for each sensor. Define one input for each sensor and in the loop check each pin for a statechange. With a if you can then send the status for each changed pin.
                      • N
                        N
                        nickgosling
                        Thank you I'll give that a go.
                        • J
                          J
                          Justas
                          Maybe it is a little off-topic here, but maybe you could point me to the right direction: I want to build nice wall switch, and from technological point of view it is not that difficult using mysensors, this part is clear, including battery powering or making some kind of power conversion from AC to DC (in openhardware there are quite a few examples on that). What is bothering me is the switch "enclosure". I have one example from TKB Home:
                          http://www.ebay.de/itm/TKB-Home-Z-Wave-Plus-Dual-Paddle-Wall-Switch-TZ56D-ZW5-/122201876698?ssPageName=ADME:X:EAC:GB:1120
                          that I have bought to try with smarttnings controller (which is not intended to work with, now I know), but what it has - it is the enclosure: it is nice switch with 2 micro switches inside (4 in total, since it is dual wall switch), that are not locking in the pressed position - you press up and it clicks one button/switch and returns back to its initial "neutral" position, you press down - again, click and back to "neutral".
                          I think the similar are are in aliexpress, that are called like wall wireless remote switch Transmitter, but I'm not sure about that, since I didn't bought one to disassemble.
                          Maybe some one have met something similar for making some nice RF controlled wall switches?
                          Thanks in advance!
                          Regards
                          Nca78N 1 Reply Last reply
                          • J Justas
                            Thanks in advance!
                            Regards
                            @Justas Hello, please check the dedicated category, if you don't find your hapiness please post there :)
                            https://forum.mysensors.org/category/42/enclosures-3d-printing
                            • skywatchS
                              skywatchS
                              skywatch
                              I tried this today and it wouldn't find a parent.
                              Adding #define MY_NODE_ID 1 seems to have solved the problem, so maybe this (and other) examples need to be updated with this info?
                              Thanks for the work on this project though, I think it will be a lort of fun when I get it all working! :)
                              • skywatchS skywatch
                                @skywatch that shouldn't bee needed. Would it be possible for you to post the entire log from when the node was unable to find parent?
                                • skywatchS
                                  skywatchS
                                  skywatch
                                  I'll see if I can replicate it ...been nusy trying to sork out a controller now Heheh.....Not fun!
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    I just uploaded the sketch again without the define and it is working - I didn't clear the eeprom before uploading so maybe that would have made a difference? Is there a list of what is held in eeprom anywhere?
                                    • J
                                      J
                                      joseyapor
                                      Hi instead of using a arduino nano can i use esp8266 for a sensor
                                      mfalkviddM E 2 Replies Last reply
                                      • J joseyapor
                                        @joseyapor yes you can but the esp8266 has very few usable io pins so connecting a radio and sensor at the same time might be difficult.
                                        • J joseyapor
                                          E
                                          E
                                          Ed1500
                                          @joseyapor Yes no problem. 8 digital I/O. One of them a bit problematic as input (used for program mode)
