  3. Beginner user: serial protocol help
serial protocol
19 Posts 5 Posters 9.3k Views 1 Watching
  • daulagariD
    daulagariD
    daulagari
    @asterisco : See also the "cannot send id thread", 255;255;3;0;3; means the gateway is requesting an address from the controller for a node.
    From you last post I understand you assigned the node a static node-id of 7 and you are receiving that.
    I can not help with Freedomotic but why don't you try the Freedomotic thread?
    • A
      asterisco
      ** I'm reading that thread** because I feel that the explanation about the Mysensors API and the serial protocol is just a little brief. I'd like to have a more detailed manual about serial protocol and the api,,, not only explaining the three main classes; MySensor, MyMessage and MyGateway but the constructor, and all the methods, propieties ...
      • daulagariD
        daulagariD
        daulagari
        The gateway protocol is I think reasonably clear documented on http://www.mysensors.org/build/serial_api.
          A Former User
          Hi, I feel the same way, being new to programming it inot clear to me how to change serial GW ore sensor sketch to get them to communicate. I have read the "Serial protocol" severel times but i still dont understand exactly what are the requried changes to set a simple GW to tempsensor network. My gateway can see transmits from sensor but no ID is set , i thought that was to handled automatically but
          appearantly thats not the case. Could i ask for some more basic explanation on the setup.
          regards Sigolhi
            First you must tell us what you want to achieve here.
            Normally you would have a controller in the setup to act on or store your sensor data (or as a GUI for sending out commands to your actuators). The gateway is just a gateway between the sensor network and the controller. All logic is normally handled over at the controller side including keeping track of and handing out ids to new sensors when they ask for it.
            To test things you can hook up the gateway to your Arduino IDE and serial monitor and answer the request for id yourself by typing in the reply. Or you can set a static id on the node which means it won't ask for it at startup.
            I suggest you have pick one of the open source controller softwares listed on www.mysensors.org to use the full potential of your home build sensors.
            • A
              asterisco
              ok sigolhi, do as hek says. dont let your sensor into AUTO mode, and put an ID manually, for example 7.
              If you want to have all your sensor automatically addresed you must program a controller or use one of mysensors administrators suggest. I`m trying freedomotics, (because of windows) but i dont make it works yet. Things are not so easy. Mybe im gonna use my ARM card to try an other one.
              best
              ? 1 Reply Last reply
              • A asterisco
                best
                A Former User
                @asterisco
                Hi, i've tried the Fredomatic but the plugin from MySensor fails to install/configure. Any idea?
                Is there another controller that runs under windows that you can recommend for a try.
                Regards
                A 1 Reply Last reply
                • D
                  dzairo
                  • ? A Former User
                    @asterisco
                    Regards
                    asterisco
                    my idead is to ask in the freedomotic thread:
                    http://forum.mysensors.org/topic/339/freedomotic
                      A Former User
                      Hi all,
                      I've switched to EasyIoT's controller running on a raspberrypi (radio connected directly to the pi) and it works fine, only supports a few sensors sofar, but for my temperature tests it works fine.
                      I haven't figured the log function yet but it looks promising.
                      Great work by the people on http://iot-playground.com/about
                      regards sigolhi
                      • ? A Former User
                        Hi all,
                        regards sigolhi
                        asterisco
                        @sigolhi
                        ok, i'll try your EasyIoT's, seems good.
                        Where can i find documentation to connect the pi to the radio??? I've got olinuxino-lime, it's cheaper but there is not documentation about. I need to connect the board to the radio via SPI, and it's not easy.
                        regards
                        • A asterisco
                          @sigolhi
                          regards
                          A Former User
                          @asterisco Hi,
                          This is instruktion is on their website: http://iot-playground.com/2-uncategorised/3-easyiot-server-installation.
                          hope it helps you.
                          • ? A Former User
                            @asterisco Hi,
                            hope it helps you.
                            asterisco
                            @sigolhi
                            This helps me a lot, but I'm not using RPi but olinuxino-lime a10 (european ARM board)
                            regards
