  3. 💬 HALO : ESP32 multi transport GW/Bridge for Mysensors
nrf24bridgewifirfm95canrgbblasteresp32blerfm69serial wi-fisnifferbluetoothgateway
40 Posts 13 Posters 16.9k Views 13 Watching
  • scalzS scalz
    @gohan exactly what i've thought when i started this project :)
    @scalz
    Can it recognize gestures, like you briefly mentioned in the introduction?
      @NeverDie no but it can be easily added with an extension board from aliexpress, or a custom board on the centered MYSX connector.
      I started from the board i mentioned, "sort of mote" with everything onboard, ring, gesture, atsamd21 etc. but i thought i could make things more modular for improving a bit assembly cost in case, and i have added more features thx to esp32 mcu. IT's now a bridge
      For gesture i'll have something, but that'll be for my other "node" project.
        Hi.
        just to keep you up that everything is going very well. I'm a bit late on releasing but i preferred that people don't order it if there were some mistakes.
        Last piece to check is CAN bus. and then it's ok ;)
        and @tekka ... as usual, impressive :+1:
        Imho, HALO is a little beast :yum:
          I'm actually adding "last minute" features (so the delay) without increasing board size.
          Features like:
          • one more RFM radio footprint : so we could do more combo. Like 1xRFM95 + 1xRFM69 or 2xRFM etc, plus the NRF24 and ESP32 of course!
          • switching NRF24 smd to NRF24 PA
          • 3x sma connectors
          • extension board for Ethernet if possible
          • etc
          See you soon with good news i hope :)
          Nca78N 1 Reply Last reply
          • scalzS scalz
            Features like:
            • 3x sma connectors
            • etc
            @scalz said in 💬 HALO : ESP32 multi transport GW/Bridge for Mysensors:
            Do you mean SMD PA LNA or through hole ?
              @Nca78
              on the proto board, it is nrf24 low power, smd version, actually. Works ok here but for better perf, i'm planning to use the PA/LNA through hole version with sma connector.
              So far (but not digged a lot) i've only seen PA smd modules with ipex (but would be better if i could fit sma) or chip antenna (lol). Are you thinking to an other reference, or have a favorite module??
              E Nca78N 2 Replies Last reply
              • scalzS scalz
                @Nca78
                E
                E
                emc2
                This work quite well with the IPX PA+LNA SMD modules
                • scalzS scalz
                  @Nca78
                  @scalz I have those with chip antenna , soldered one board but didn't try it yet.
                  I also noticed this week that my local shop sells low power smd version with a PCB antennad design similar to the one used in ESP12F which is pretty good. I will order next week and test the range. They have the same pad footprint than the SMD PA LNA (GND pin moved opposite side from VCC) so I could be interested in keeping this footprint for those leaving in appartments and that don't need a long range.
                  I have a 130sqm appartments and I have few packets losses only despite very thick (30cms) concrete walls, using only basic nrf24 modules at the moment. So I will only need a bit of improvement to have perfect reception everywhere, if it can be done with the 3€ PA LNA with chip antenna or 2€ module with improved antenna it's great for me.
                  Blasting my messages to the 350 other appartments in my building doesn't sound like a safe option :D
                    thx for feedbacks.
                    @Nca78 oki. noted! To be sure, are you talking about these modules ?
                    http://www.cdebyte.com/en/product-class-news.aspx?pid=32&okey=nRF24L01P
                    • scalzS scalz
                      thx for feedbacks.
                      @scalz yes these are the ones.
                      And they have versions with external antenna connectors also, amplified and even non amplified.
                        They look genuine, where did you buy them?
                          @gohan
                          yes in theory they are genuine as they claim to buy the chip from Nordic. you can find those modules at ali or ebay. just search for the module ref you need.
                          gohanG 1 Reply Last reply
                            @gohan so they claim but at less than 2$ for one module I have doubts...
                            Check on the website they have a "sample" button or "order sample", it links to the module on their ebay shop, they use it for selling samples.
                              I think I'll still go for the Itead ones then
                              • scalzS scalz
                                @gohan
                                @scalz how is the project going?
                                • ranseyerR
                                  ranseyerR
                                  ranseyer
                                  Hi Scalz,
                                  is it possible that you share the schematic ? Im Interestet mostly which Pins you uses to the "? mysX ?" Connector...
                                  Greetings
                                  • ranseyerR ranseyer
                                    Hi Scalz,
                                    Greetings
                                    @ranseyer if you mean the mysx connector itself, the pins are available at https://www.mysensors.org/hardware/mysx
                                    • ranseyerR
                                      ranseyerR
                                      ranseyer
                                      @mfalkvidd : Thats correct, but im working on a pin assignment (for STM32 and) ESP32... Mybe its a goot idea to open o new thread for that...
                                      scalzS 1 Reply Last reply
                                        #27
                                        I'll update asap my projects (new designs&more features, softwares etc.). I've been quiet but not inactive :)
                                        I just need to rethink how I'll share all of this because there is quite lot of stuff.. (interesting imho). I hope you'll like them.
                                        @ranseyer said in 💬 HALO : ESP32 multi transport GW/Bridge for Mysensors:
                                        I agree with mfalkvidd, you can take a look at myxs definition. Your pin assignment doesn't have to be the same as mine.. these mcus (STM32 and ARMs, esp32 etc) are flexible, you should check the datasheet ;)
                                        • berkseoB
                                          berkseoB
                                          berkseo
                                          Have you tried some of the examples to run the gateway? I recently tested ESP32
                                          Sketches in examples do not work in a sheaf of ESP-RF24
                                          Board downloaded from git hub Expessif
                                          I tested on NODE MCU32S
