  3. [solved] RPI Gateway with RFM95 does not receive any nodes
27 Posts 2 Posters 7.7k Views 3 Watching
    micropet
    wrote on last edited by micropet
    have built many gateways with an RPI2 and the RFM96. All work well. Now I wanted to test an RFM95 gateway.
    The software compiles and starts properly.
    My 3 RFM95 Nodes get but no connection.
    Has anyone ever run an RPI gateway with RFM95?
    Info: I have compiled the Gateway with:
    .myconfigure --my-gateway = mqtt --my-controller-ip-address = 192.168.0.23 --my-mqtt-publish-topic-prefix = mysensors2-out --my-mqtt-subscribe-topic-prefix = I have the same problem with mymy-leds -my-leds-err-pin = 12 - my-leds-rx-pin = 16 --my-leds-tx -pin = 18
    The wiring:
    Raspberry RFM69
    GND GND
    3.3V VCC
    24 NSS
    23 SCK
    19 MOSI
    21 MISO
    22 DI00
    Gateway starts successfully but does not receive anything.
    The hardware is fine. The gateway and the node run with the LowCost gateway:
    http://cpham.perso.univ-pau.fr/LORA/RPIgateway.html
    • mfalkviddM
      Adding link to the github issue, in case the information there helps anyone: https://github.com/mysensors/MySensors/issues/863
      • M micropet
        The wiring:
        Raspberry RFM69
        GND GND
        3.3V VCC
        24 NSS
        23 SCK
        19 MOSI
        21 MISO
        22 DI00
        @micropet Since no-one else seems to be able to help, I have dug out an old raspberry pi and started to retrace your steps. It is going slow, but forwards.
        One thing I notice is that the configure command above does not include --my-transport=rfm95
        Just a quick check - was rfm95 included in your configure command?
        Also, could you post the debug output from the gateway?
        I realize that you might have given up, but I hope to be able to check that rfm95 works.
        • mfalkviddM
          I now have the gateway up and running, at least it seems so:
          pi@raspi1:~/MySensors $ sudo ./bin/mysgw -d
          mysgw: Config file /etc/mysensors.dat does not exist, creating new config file.
          mysgw: Starting gateway...
          mysgw: MCO:BGN:INIT GW,CP=RLNG----,VER=2.2.0-beta
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:INIT:TSP OK
          mysgw: TSM:INIT:GW MODE
          mysgw: MCO:REG:NOT NEEDED
          mysgw: MCO:BGN:STP
          mysgw: MCO:BGN:INIT OK,TSP=1
          Parsed log
          Next step is to build a rfm95 node.
          EDIT: My configure command:
          ./configure --my-transport=rfm95
          • mfalkviddM
            My test node (a binary switch that toggles state every 2 seconds) is able to communicate with the gateway.
            Gateway log:
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: MCO:BGN:STP
            mysgw: TSF:SAN:OK
            mysgw: TSM:READY:NWD REQ
            mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            mysgw: TSF:SRT:OK
            mysgw: TSF:SAN:OK
            mysgw: TSF:MSG:READ,102-102-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            mysgw: TSF:MSG:BC
            mysgw: TSF:MSG:FPAR REQ,ID=102
            mysgw: TSF:PNG:SEND,TO=0
            mysgw: TSF:CKU:OK
            mysgw: TSF:MSG:GWL OK
            mysgw: TSF:MSG:SEND,0-0-102-102,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            mysgw: TSF:MSG:PINGED,ID=102,HP=1
            mysgw: TSF:MSG:SEND,0-0-102-102,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            mysgw: TSF:MSG:SEND,0-0-102-102,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Binary Sensor
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
            mysgw: TSF:MSG:READ,102-102-0,s=3,c=0,t=0,pt=0,l=0,sg=0:
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
            mysgw: TSF:MSG:SEND,0-0-102-102,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
            mysgw: TSF:MSG:READ,102-102-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
            mysgw: TSF:MSG:READ,102-102-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
            Node log:
            5134 MCO:BGN:INIT NODE,CP=RLNNE---,VER=2.2.0-beta
            5176 TSM:INIT
            5177 TSF:WUR:MS=0
            5194 TSM:INIT:TSP OK
            5196 TSF:SID:OK,ID=102
            5198 TSM:FPAR
            5248 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            5881 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            5886 TSF:MSG:FPAR OK,ID=0,D=1
            7255 TSM:FPAR:OK
            7256 TSM:ID
            7257 TSM:ID:OK
            7258 TSM:UPL
            7363 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            7414 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            7419 TSF:MSG:PONG RECV,HP=1
            7422 TSM:UPL:OK
            7423 TSM:READY:ID=102,PAR=0,DIS=1
            7558 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            7609 TSF:MSG:READ,0-0-102,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            7764 TSF:MSG:SEND,102-102-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
            7865 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            9990 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Binary Sensor
            10102 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
            10203 TSF:MSG:SEND,102-102-0-0,s=3,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
            10209 MCO:REG:REQ
            10305 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            10356 TSF:MSG:READ,0-0-102,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            10361 MCO:PIM:NODE REG=1
            10363 MCO:BGN:STP
            10365 MCO:BGN:INIT OK,TSP=1
            10501 TSF:MSG:SEND,102-102-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
            12614 TSF:MSG:SEND,102-102-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
            14728 TSF:MSG:SEND,102-102-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
            16833 TSF:MSG:SEND,102-102-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
            18938 TSF:MSG:SEND,102-102-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
            21052 TSF:MSG:SEND,102-102-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
            23158 TSF:MSG:SEND,102-102-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
            25272 TSF:MSG:SEND,102-102-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
              micropet
              Thanks for testing.
              Transport word in it. The line was something mixed up here in the forum. :)
              ./configure --my-gateway=mqtt --my-controller-ip-address=192.168.0.23 --my-mqtt-publish-topic-prefix=mysensors2-out --my-mqtt-subscribe-topic-prefix=mysensors2-in --my-mqtt-client-id=mygateway5 --my-transport=rfm95 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
              The Gateway shows:
              ./bin/mysgw -d
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: MCO:BGN:STP
              mysgw: connected to 192.168.0.23
              mysgw: MQTT connected
              mysgw: Sending message on topic: mysensors2-out/0/255/0/0/18
              I have to look for a MySensor Node.
              I had changed everything to the TTN network.
              I'll get back to you.
              Greetings Peter
              • M micropet
                Thanks for testing.
                The Gateway shows:
                ./bin/mysgw -d
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                Greetings Peter
                @micropet great. The problem might be mqtt related. I am not sure if I have a mqtt broker to connect to so I just tried the ethernet variant. Could you see if switching to ethernet helps? That would narrow down the scope.
                  micropet
                  Thus, the node is in operation. The gateway does not show anything new.
                  I need mqtt. My RFM69 Nodes (433 MHz and 868 MHz) also run with mqtt.
                  The Node output is:
                  0 MCO:BGN:INIT NODE,CP=RLNNA---,VER=2.2.0-beta
                  4 TSM:INIT
                  4 TSF:WUR:MS=0
                  6 RFM95:INIT
                  8 RFM95:INIT:PIN,CS=10,IQP=4,IQN=0
                  22 RFM95:PTX:LEVEL=5
                  24 TSM:INIT:TSP OK
                  26 TSM:INIT:STATID=150
                  28 TSF:SID:OK,ID=150
                  30 TSM:FPAR
                  32 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
                  2037 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4046 !TSM:FPAR:NO REPLY
                  4048 TSM:FPAR
                  4050 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
                  6057 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  8067 !TSM:FPAR:NO REPLY
                  8069 TSM:FPAR
                  8071 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
                  10076 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  12085 !TSM:FPAR:NO REPLY
                  12087 TSM:FPAR
                  12089 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
                  14094 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  16103 !TSM:FPAR:FAIL
                  16105 TSM:FAIL:CNT=1
                  16107 TSM:FAIL:DIS
                  16109 TSF:TDI:TSL
                  16111 RFM95:RSL
                  26114 TSM:FAIL:RE-INIT
                  26116 TSM:INIT
                  26118 RFM95:INIT
                  26120 RFM95:INIT:PIN,CS=10,IQP=4,IQN=0
                  26134 RFM95:PTX:LEVEL=5
                  26136 TSM:INIT:TSP OK
                  26138 TSM:INIT:STATID=150
                  26140 TSF:SID:OK,ID=150
                  26144 TSM:FPAR
                  26146 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
                  28151 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  30162 !TSM:FPAR:NO REPLY
                  30164 TSM:FPAR
                  30167 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
                  32172 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  • M micropet
                    The Node output is:
                    4 TSM:INIT
                    4 TSF:WUR:MS=0
                    6 RFM95:INIT
                    24 TSM:INIT:TSP OK
                    30 TSM:FPAR
                    4048 TSM:FPAR
                    8069 TSM:FPAR
                    12087 TSM:FPAR
                    16107 TSM:FAIL:DIS
                    16109 TSF:TDI:TSL
                    16111 RFM95:RSL
                    26116 TSM:INIT
                    26118 RFM95:INIT
                    26144 TSM:FPAR
                    30164 TSM:FPAR
                    @micropet I understand you prefer mqtt. But if you are able to verify that the gateway works with ethernet, we would know that the problem is mqtt related. Now the problem might be related to anything.
                      micropet
                      Yes I understand.
                      I'm just checking the pin assignment of the node.
                      How did you connect the Node to the RFM95?
                        micropet
                        I use the same connections as for a TTN node.
                        Board is Arduino Pro mini.
                        10 NSS CS
                        13 SCK
                        11 MOSI
                        12 MISO
                        4 DI00
                        5 DIO1
                        And have in the sketch:
                        #define MY_RFM95_CS_PIN 10 // NSS
                        #define MY_RFM95_IRQ_PIN 4 // IRQ D100
                        • M micropet
                          Yes I understand.
                          @micropet mqtt works:
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: MCO:BGN:STP
                          mysgw: connected to 192.168.1.101
                          mysgw: Sending message on topic: mysensors-rfm95-out/0/255/0/0/18
                          mysgw: TSF:MSG:BC
                          mysgw: TSF:CKU:OK
                          mysgw: Sending message on topic: mysensors-rfm95-out/102/255/0/0/17
                          mysgw: Sending message on topic: mysensors-rfm95-out/102/255/3/0/6
                          mysgw: Sending message on topic: mysensors-rfm95-out/102/255/3/0/11
                          mysgw: Sending message on topic: mysensors-rfm95-out/102/255/3/0/12
                          mysgw: Sending message on topic: mysensors-rfm95-out/102/3/0/0/0
                          mysgw: Sending message on topic: mysensors-rfm95-out/102/3/1/0/16
                          I used this configure command:
                          ./configure --my-gateway=mqtt --my-controller-ip-address=192.168.1.101 --my-mqtt-publish-topic-prefix=mysensors-rfm95-out --my-mqtt-subscribe-topic-prefix=mysensors-rfm95-in --my-mqtt-client-id=mygateway-rfm95 --my-transport=rfm95 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                          For the wiring, I used the instructions for rfm69 on the raspberry pi gateway page.
                          • mfalkviddM
                            For the node, I used this sketch (esp8266 nodemcu):
                            //#define MY_RADIO_NRF24
                            #define MY_RADIO_RFM95
                            #define MY_RFM95_CS_PIN D8 // NSS
                            #define MY_RFM95_IRQ_PIN D1 // IRQ DIO0
                            #define MY_RFM95_RST_PIN D3 // Reset, not connected
                            #define SKETCH_MAJOR_VER "1"
                            #define SKETCH_MINOR_VER "0"
                            #define PRIMARY_CHILD_ID 3
                            #define SECONDARY_CHILD_ID 4
                              static uint8_t sentValue = 2;
                              wait(5);
                              uint8_t  value = !sentValue;
                              if (value != sentValue) {
                                send(msg.set(value == HIGH));
                                sentValue = value;
                              wait(2000);
                              micropet
                              My gateway will work, I think.
                              Pity,
                              I am using an Arduino Pro mini.
                              I can make a node with esp8266.
                              But I can not do that today, I think I have time for it tomorrow.
                              • M micropet
                                Pity,
                                @micropet no rush, you've had to wait a long time to get any help :wink:
                                Just post here when/if you have some news. If you are unable to find an esp I can probably find a Pro Mini and build a node.
                                  micropet
                                  Have a node with a NodeMCU built.
                                  Does not work either.
                                  At the gateway comes nothing.
                                  Since I must look further.
                                  22820 !TSM:FPAR:NO REPLY
                                  22822 TSM:FPAR
                                  24824 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  26831 !TSM:FPAR:NO REPLY
                                  26833 TSM:FPAR
                                  28835 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  30842 !TSM:FPAR:NO REPLY
                                  30844 TSM:FPAR
                                  32846 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  34853 !TSM:FPAR:FAIL
                                  34854 TSM:FAIL:CNT=1
                                  34856 TSM:FAIL:DIS
                                  34858 TSF:TDI:TSL
                                  44860 TSM:FAIL:RE-INIT
                                  44861 TSM:INIT
                                  44878 TSM:INIT:TSP OK
                                  44880 TSF:SID:OK,ID=33
                                  44882 TSM:FPAR
                                  46885 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  48892 !TSM:FPAR:NO REPLY
                                  48894 TSM:FPAR
                                  50896 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  52903 !TSM:FPAR:NO REPLY
                                  52905 TSM:FPAR
                                  54907 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  56914 !TSM:FPAR:NO REPLY
                                  56916 TSM:FPAR
                                  58918 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  60925 !TSM:FPAR:FAIL
                                  60926 TSM:FAIL:CNT=2
                                  60928 TSM:FAIL:DIS
                                  60930 TSF:TDI:TSL
                                    micropet
                                    A Node with a Pro mini or a Teensy would help me more.
                                    All my RFM69 Nodes have a Pro mini (50 pcs)
                                    The TTN Nodes a Pro mini or a Teensy. (Approx. 20 pieces)
                                      micropet
                                      Now I do not understand anything anymore.
                                      I have made an update on the RPI and compiled the gateway software again.
                                      I had already done more than 10 times.
                                      After the start of the RPI nothing worked.
                                      Multiple resets of the NodeMCU also brought nothing.
                                      I pulled the micro usb plug and plugged again - suddenly it works. WAU
                                      Then I must have a fault in the wiring between the RFM95 and the Arduino Pro.
                                        Just for info: I had set up 5 pieces. All do not work.
                                      ./bin/mysgw -d
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: MCO:BGN:STP
                                      mysgw: TSF:MSG:READ,33-33-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                                      mysgw: Sending message on topic: mysensors2-out/33/3/1/0/16
                                      mysgw: TSF:MSG:READ,33-33-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                                        micropet
                                        I have connected my Arduino Pro Nodes. They do not work.
                                        The ESP Node has been running since last night without problems.
                                        Can you try an Arduino?
                                        • M micropet
                                          @micropet great work. I should be able to set up an Arduino node tomorrow. The forecast shows rain anyway :)
