  3. Office plant monitor
mysensorsplanthumidity
41 Posts 11 Posters 15.8k Views 10 Watching
    Completely unrelated, but I just noticed this:
    https://www.aliexpress.com/item/SHT10-SHT11-SHT15-waterproof-sensor-case-temperature-and-humidity-protective-cover-soil-sensor-cover-40mm-15mm/32575966509.html?spm=2114.8153822.cb0001.16.lITM8E&scm=1007.13409.76764.0&pvid=0acc75b7-138d-456f-a5bf-5147c2ea763f&tpp=1
    So with that, you could just use a regular humidity sensor inside it to judge soil moisture. Pretty cool, yes? Not sure how big it is, but maybe you could even fit your entire sensor node inside it.
    @NeverDie said in Office plant monitor:
    One of the local shops I buy electronic parts from has those. Unfortunately it's too small to house an entire sensor.
      This thread also has a lot of good background information and links about capacitive soil moisture sensors: https://lowpowerlab.com/forum/general-topics/using-capsense-to-measure-soil-moisture/
        #27
        It might be that one could more or less whack an 80Mhz frequency oscillation chip into the Chirp circuit: https://www.digikey.com/product-detail/en/linear-technology/LTC6905CS5-80-TRMPBF/LTC6905CS5-80-TRMPBFCT-ND/810907
          #28
          i agree with @NeverDie ;)
          It's better to use high freq for a reliable soil moisture, regarding soils, calibration etc. and some studies argues even more than 200Mhz. but with 80-100 it's nice.
          I have one design at this freq, non corrosive design, and not same as chirp though, but can't really help you (mine is not open yet, and busy on others projects).
          Regarding the chirp design, I think it may need an opamp for better results regarding the 1M resistor etc, and some more tuning if going high freq.
            simbic
            Trying to get this working but getting alot of errors. New to this so bear with me.
            In file included from C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino:55:0:
            C:\...\Arduino\libraries\MySensors/MyTransportRFM69.h:31:1: error: expected class-name before '{' token
            C:\...\Arduino\libraries\MySensors/MyTransportRFM69.h:33:36: error: 'RFM69_FREQUENCY' was not declared in this scope
              MyTransportRFM69(uint8_t freqBand=RFM69_FREQUENCY, uint8_t networkId=RFM69_NETWORKID, uint8_t slaveSelectPin=RF69_SPI_CS, uint8_t interruptPin=RF69_IRQ_PIN, bool isRFM69HW=false, uint8_t interruptNum=RF69_IRQ_NUM);
            C:\...\Arduino\libraries\MySensors/MyTransportRFM69.h:33:71: error: 'RFM69_NETWORKID' was not declared in this scope
            In file included from C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino:56:0:
            C:\...\Arduino\libraries\MySensors/MySigningAtsha204Soft.h:55:1: error: expected class-name before '{' token
            C:\...\Arduino\libraries\MySensors/MySigningAtsha204Soft.h:62:25: error: 'MY_RANDOMSEED_PIN' was not declared in this scope
               uint8_t randomseedPin=MY_RANDOMSEED_PIN);
            Moisture_sensor:83: error: call to 'MySigningAtsha204Soft::MySigningAtsha204Soft(bool, uint8_t)' uses the default argument for parameter 2, which is not yet defined
             MySigningAtsha204Soft signer;
            Moisture_sensor:84: error: 'MyHwATMega328' does not name a type
             MyHwATMega328 hw;
            Moisture_sensor:85: error: call to 'MyTransportRFM69::MyTransportRFM69(uint8_t, uint8_t, uint8_t, uint8_t, bool, uint8_t)' uses the default argument for parameter 1, which is not yet defined
             MyTransportRFM69 transport;
            Moisture_sensor:85: error: call to 'MyTransportRFM69::MyTransportRFM69(uint8_t, uint8_t, uint8_t, uint8_t, bool, uint8_t)' uses the default argument for parameter 2, which is not yet defined
            Moisture_sensor:86: error: 'MySensor' does not name a type
             MySensor node(transport, hw, signer);
            C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino: In function 'void setup()':
            Moisture_sensor:112: error: 'node' was not declared in this scope
               node.begin();
            C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino: In function 'void loop()':
            Moisture_sensor:163: error: 'node' was not declared in this scope
               node.send(msgMoisture.set((moistureLevel + oldMoistureLevel) / 2.0 / 10.23, 1));
            C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino: In function 'int readMoisture()':
            Moisture_sensor:200: error: 'node' was not declared in this scope
               node.sleep(STABILIZATION_TIME);
            exit status 1
            I have looked through the code but can't seem to see what is wrong with it.
            Please help :)
            • S simbic
               MyHwATMega328 hw;
                 node.begin();
              exit status 1
              Please help :)
              @simbic did you modify the sketch in any way? If so, could you please post it?
              My guess would be an incomplete #define or using incompatible versions. Which version of MySensors are you using?
              S 1 Reply Last reply
                simbic
                @mfalkvidd
                I have assembled a copy of @carlierd 's office plant monitor since it looked kinda neat.
                When I first tried to upload @carlierd 's Moisture_sensor.ino it complained that several libraries were missing.
                So I started google-fu around to find them.
                What was missing was:
                MyTransportRFM69.h
                MyTransport.h
                MySigning.h
                MyMessage.h
                aswell as drivers, that I placed in folder /utility/
                ATSHA204.h
                RFM69.h
                sha256.h
                The code is as follows. I have only pressed include mysensors' library since it complained that it was missing.
                 * Code and idea from mfalkvidd (http://forum.mysensors.org/user/mfalkvidd).
                /* Moisture sensor.        */
                /* Version     : 1.2.5        */
                /* Date        : 11/04/2016                                                           */
                /* Modified by : David Carlier                                                        */
                /*                            RST |             |  A5                                 */
                /*                            RX  |             |  A4                                 */
                /*                            TX  |   ARDUINO   |  A3                                 */
                /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
                /*                            D3  |             |  A1 --------- Moisture probe        */
                /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Moisture probe        */
                /*              +3v --------- VCC |             | GND --------- GND                   */
                /*              GND --------- GND |  8MHz int.  | REF                                 */
                /*                            OSC |             | VCC --------- +3v                   */
                /*                            OSC |             | D13 --------- RFM69 (SCK)           */
                /*                            D5  |             | D12 --------- RFM69 (MISO)          */
                /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
                /*                            D7  |             | D10 --------- RFM69 (NSS)           */
                /*              LED --------- D8  |             |  D9                                 */
                /* +3v = 2*AA        */
                #include <MyTransportRFM69.h>
                //Define functions
                #define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
                //Constants for MySensors
                #define SKETCH_NAME           "Moisture Sensor"
                #define SKETCH_VERSION        "1.2.6"
                #define CHILD_ID_MOISTURE     0
                #define CHILD_ID_VOLTAGE      1
                #define LED_PIN               8
                #define THRESHOLD             1.1     // Only make a new reading with reverse polarity if the change is larger than 10%
                #define STABILIZATION_TIME    1000    // Let the sensor stabilize before reading
                //#define BATTERY_FULL          3143    // 2xAA usually gives 3.143V when full
                #define BATTERY_FULL          3100    // CR2032 usually gives 3.1V when full
                #define BATTERY_ZERO          2340    // 2.34V limit for 328p at 8MHz
                #define SLEEP_TIME            7200000 // Sleep time between reads (in milliseconds) (close to 2 hours)
                const int SENSOR_ANALOG_PINS[] = {A0, A1};
                //Variables
                byte direction = 0;
                int oldMoistureLevel = -1;
                //Construct MySensors library
                MyHwATMega328 hw;
                MyMessage msgMoisture(CHILD_ID_MOISTURE, V_HUM);
                MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
                /* Initialization        */
                  //Get time (for setup duration)
                  #ifdef DEBUG
                    unsigned long startTime = millis();
                  //Setup LED pin
                  pinMode(LED_PIN, OUTPUT);
                  blinkLedFastly(3);
                  //Set moisutre sensor pins
                  for (int i = 0; i < N_ELEMENTS(SENSOR_ANALOG_PINS); i++)
                    pinMode(SENSOR_ANALOG_PINS[i], OUTPUT);
                    digitalWrite(SENSOR_ANALOG_PINS[i], LOW);
                  //Start MySensors and send the sketch version information to the gateway
                  node.begin();
                  node.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
                  //Register all sensors
                  node.present(CHILD_ID_MOISTURE, S_HUM);
                  node.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
                  //Setup done !
                  blinkLedFastly(3);
                  //Print setup debug
                  #ifdef DEBUG
                    int duration = millis() - startTime;
                    Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
                /* Main loop        */
                  //Get time (for a complete loop)
                  #ifdef DEBUG
                  //Get moisture level
                  int moistureLevel = readMoisture();
                  //Send rolling average of 2 samples to get rid of the "ripple" produced by different resistance in the internal pull-up resistors
                  //See http://forum.mysensors.org/topic/2147/office-plant-monitoring/55 for more information
                  //Check if it was first reading, save current value as old
                  if (oldMoistureLevel == -1)
                  //Verify if current measurement is not too far from the previous one
                  if (moistureLevel > (oldMoistureLevel * THRESHOLD) || moistureLevel < (oldMoistureLevel / THRESHOLD))
                    //The change was large, so it was probably not caused by the difference in internal pull-ups.
                    //Measure again, this time with reversed polarity.
                  //Store current moisture level
                  //Report data to the gateway
                  long voltage = getVoltage();
                  node.send(msgVolt.set(voltage / 1000.0, 2));
                  int batteryPcnt = round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO));
                  if (batteryPcnt > 100) {batteryPcnt = 100;}
                  node.sendBatteryLevel(batteryPcnt);
                  //Print debug
                  #ifdef DEBUG
                    Serial.print((moistureLevel + oldMoistureLevel) / 2.0 / 10.23);
                    Serial.print("%");
                    Serial.print("   ");
                    Serial.print(voltage / 1000.0);
                    Serial.print("v");
                    Serial.print("   ");
                    Serial.print(batteryPcnt);
                    Serial.print("%");
                    Serial.print("   ");
                    Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
                    Serial.flush();
                  //Sleep until next measurement
                  blinkLedFastly(1);
                  node.sleep(SLEEP_TIME);
                /* Allows to get moisture.                                                            */
                int readMoisture()
                  //Power on the sensor and read once to let the ADC capacitor start charging
                  pinMode(SENSOR_ANALOG_PINS[direction], INPUT_PULLUP);
                  analogRead(SENSOR_ANALOG_PINS[direction]);
                  //Stabilize and read the value
                  int moistureLevel = (1023 - analogRead(SENSOR_ANALOG_PINS[direction]));
                  //Turn off the sensor to conserve battery and minimize corrosion
                  //Make direction alternate between 0 and 1 to reverse polarity which reduces corrosion
                  direction = (direction + 1) % 2;
                  return moistureLevel;
                /* Allows to fastly blink the LED.                                                    */
                void blinkLedFastly(byte loop)
                  byte delayOn = 150;
                  byte delayOff = 150;
                  for (int i = 0; i < loop; i++)
                    blinkLed(LED_PIN, delayOn);
                    delay(delayOff);
                /* Allows to blink a LED.                                                             */
                void blinkLed(byte pinToBlink, int delayInMs)
                  digitalWrite(pinToBlink,HIGH);
                  delay(delayInMs);
                  digitalWrite(pinToBlink,LOW);
                /* Allows to get the real Vcc (return value in mV).                                   */
                /* http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/   */
                long getVoltage()
                  ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
                  delay(50);  // Let mux settle a little to get a more stable A/D conversion
                  //Start a conversion
                  ADCSRA |= _BV( ADSC );
                  //Wait for it to complete
                  while (bit_is_set(ADCSRA, ADSC));
                  //Compute and return the value
                  uint8_t low  = ADCL;                  // must read ADCL first - it then locks ADCH
                  uint8_t high = ADCH;                  // unlocks both
                  result = 1125300L / result;           // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                  return result;                        // Vcc in millivolts
                I have just installed Arduino IDE, and are using the latest mysensors library 2.1.1.
                Another thing it complains about is:
                Invalid library found in C:\...\Arduino\libraries\Moisture_sensor: C:\...\Arduino\libraries\Moisture_sensor```
                which is wierd since I have just copy+pasted it from here:
                https://www.openhardware.io/view/123/Office-plant-monitor
                aswell as built the sensor from there.
                If you can help, I would be very glad, as I just hoped it would be smooth sailing using mysensors. Build, upload and let it work its magic.
                Tack på förhand!
                Simon
                • S simbic
                  @mfalkvidd
                  MyTransportRFM69.h
                  MyTransport.h
                  MySigning.h
                  MyMessage.h
                  ATSHA204.h
                  RFM69.h
                  sha256.h
                  /*                            RST |             |  A5                                 */
                  /*                            RX  |             |  A4                                 */
                  /* +3v = 2*AA        */
                  //Define functions
                  #define LED_PIN               8
                  //Variables
                  byte direction = 0;
                  MyHwATMega328 hw;
                    #ifdef DEBUG
                    //Setup LED pin
                    blinkLedFastly(3);
                    node.begin();
                    //Setup done !
                    blinkLedFastly(3);
                    //Print setup debug
                    #ifdef DEBUG
                  /* Main loop        */
                    #ifdef DEBUG
                    //Print debug
                    #ifdef DEBUG
                      Serial.print("%");
                      Serial.print("   ");
                      Serial.print("v");
                      Serial.print("   ");
                      Serial.print("%");
                      Serial.print("   ");
                      Serial.flush();
                    blinkLedFastly(1);
                  int readMoisture()
                    byte delayOn = 150;
                      delay(delayOff);
                    delay(delayInMs);
                  long getVoltage()
                  Tack på förhand!
                  Simon
                  @simbic that sketch is made for MySensors 1.x so it won't work with MySensors 2.x.
                  You either need to convert it (guide: https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x) or use/create one for 2.x, for example https://www.mysensors.org/build/moisture
                  • Nca78N Nca78
                    https://www.aliexpress.com/item/SHT10-SHT11-SHT15-waterproof-sensor-case-temperature-and-humidity-protective-cover-soil-sensor-cover-40mm-15mm/32575966509.html?spm=2114.8153822.cb0001.16.lITM8E&scm=1007.13409.76764.0&amp;pvid=0acc75b7-138d-456f-a5bf-5147c2ea763f&amp;tpp=1
                    #33
                    @Nca78
                    I see now that they have expanded their selection of waterproof sensor shells:
                    https://www.aliexpress.com/item/2pcs-Waterproof-Temperature-and-humidity-sensor-shell-SHT10-SHT21-SHT15-shT11-sht20-SHT75-sensor-protective-sleeve/32725766858.html?spm=2114.10010108.1000013.6.PVGRb3&traffic_analysisId=recommend_2088_3_81019_new2&scm=1007.13339.81019.0&pvid=b9edd7ff-9069-4c39-be95-b2d3ca8bdf17&tpp=1
                    https://www.aliexpress.com/item/2pcs-YS1560J-Temperature-and-humidity-sensor-shell-Waterproof-temperature-sensor-protective-cover-SHT10-SHT15-SHT20/32725840346.html?spm=2114.10010108.1000013.25.PVGRb3&traffic_analysisId=recommend_2088_13_81019_new2&scm=1007.13339.81019.0&pvid=b9edd7ff-9069-4c39-be95-b2d3ca8bdf17&tpp=1
                    https://www.aliexpress.com/item/TM16-115-temperature-and-humidity-sensor-protective-cover-waterproof-SHT10-SHT11-SHT20-SHT21-SHT15-SHT75-sensor/32578099865.html?spm=2114.10010108.1000013.10.gZI6yC&traffic_analysisId=recommend_2088_5_82199_new&scm=1007.13339.82199.0&pvid=3cc09c58-99e7-4a67-834a-3313c87ab573&tpp=1
                    Perhaps one of those might be big enough? Or, if not, perhaps it could be joined onto a larger waterproof cavity, and just the sensor itself goes into it? Unfortunately for me, the parts appear to be metric. However, maybe a search would yield some kind of metric-to-imperial union, at which point I could then leverage cheap local parts from Home Depot or the like, to fabricate a larger cavity for the rest of a wireless mote.
                    On the face of it, it seems plausible. It's main virtue is simplicity. Not sure what the failure modes are, or how they might be avoided if there are any. Plainly, you don't want to use components which might rust or otherwise corrode from humidity. Probably my biggest worry would be the possibility of condensate forming on the humidity sensor and skewing results until it evaporated. However, a sensor heater, such as some sensors (e.g. si7021: https://www.aliexpress.com/item/Industrial-High-Precision-Si7021-Humidity-Sensor-with-I2C-Interface-for-Arduino/32524005324.html?spm=a2g0s.13010208.99999999.350.t9NHvJ ) already have, might remedy that if it were to occur.
                    Has anyone tried either one of the above or anything similar? For instance, perhaps wrapping a mote in Tyvek and sealing the seam with Dupont housewrap tape would work just as well.
                    Nca78N 1 Reply Last reply
                      @Nca78
                      @NeverDie they are all very small inside (5-6mm) so are only suitable for very thin PCB with SMD version of the sensor, even the breakout of si7021 that you linked is too big.
                      • Nca78N Nca78
                        #35
                        @Nca78
                        Golly, even an nRF52832 chip all by its lonesome self is bigger than 5-6mm. Those shells must be intended for just the sensor and nothing but the sensor (except maybe connecting wires). That would explain the presence of gland seals on some of them, such as:
                        https://www.aliexpress.com/item/Temperature-and-humidity-sensor-jacket-shell-protective-cover-waterproof-SHT10-SHT15-SHT20/32785090319.html?spm=2114.10010108.1000014.6.oDKhCV&traffic_analysisId=recommend_3035_null_null_null&scm=1007.13338.80878.000000000000000&pvid=2f02fcf9-5f96-485c-b076-6d892d6d2ae5&tpp=1
                        or
                        https://www.aliexpress.com/item/100pcs-lot-Free-shipping-SMD-resettable-fuse-SMD1206P150TF-60-1206-1-5A-1500MA-60V-PPTC/32422603296.html?spm=2114.search0104.3.126.qYG2gx&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_10130_10084_10083_10119_10080_10082_10081_10110_10178_10136_10137_10111_10060_10112_5360018_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_10120_10189_10052_10053_10142_10107_10050_10051-10120,searchweb201603_5,ppcSwitch_5&btsid=4b333183-9955-44bb-a985-eb0a3aed0e3f&algo_expid=ad603dac-549a-4315-8ae9-50a2bd436e1b-17&algo_pvid=ad603dac-549a-4315-8ae9-50a2bd436e1b
                        or
                        https://www.aliexpress.com/item/50pcs-lot-Free-shipping-SMD-ceramic-gas-discharge-tube-BC401M-1812-400V-2KA-4-5X3-2X2/32428795826.html?spm=2114.search0104.3.119.qYG2gx&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_10130_10084_10083_10119_10080_10082_10081_10110_10178_10136_10137_10111_10060_10112_5360018_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_10120_10189_10052_10053_10142_10107_10050_10051-10120,searchweb201603_5,ppcSwitch_5&btsid=4b333183-9955-44bb-a985-eb0a3aed0e3f&algo_expid=ad603dac-549a-4315-8ae9-50a2bd436e1b-16&algo_pvid=ad603dac-549a-4315-8ae9-50a2bd436e1b
                        • Nca78N Nca78
                          @Nca78 said in Office plant monitor:
                          I haven't confirmed it, but FWIW according to: http://www.wxforum.net/index.php?topic=32182.0
                          "The model shown in this link is too small for I2C boards, but seller has much larger models. L-04 has 12.8mm opening, L-06 has 17 mm and L-10 has 23mm opening."
                            #37
                            I've since had some communication with the seller. He said, "We have these dimensions," in reference to the photo below that he had attached:
                              #38
                              The seller says I can buy 3 of the 1" diameter units at $5/pc.
                              The communication with the seller is like playing 20 questions, but I only get to ask one question at a time, with typically one day turnaround for an answer. If I ask more than one question per interaction, he doesn't really answer any of them. So, getting truly meaningful answers is a slow process.
                                @NeverDie that sounds expensive, and I'm worried that at this size it's going to be difficult to stick in the soil for small plants...
                                • Nca78N Nca78
                                  @Nca78
                                  Well, for small potted plants, you might have to re-pot the plant. However, the nice benefit that would arise is: no visible sensors, which carries with it very high WAF.
                                  • A
                                    aramko aramko
                                    Banned
                                    wrote on last edited by aramko aramko
                                    #41
