  3. nRF5 action!
nRF5 action!
    @Terrence
    Maybe you'd like this one (or similar) a little better, as it has some additional sensors already built into it:
    https://www.aliexpress.com/item/Free-Ship-Bluetooth-4-0-temperature-sensor-pressure-sensor-acceleration-sensor-gyroscope-light-nRF51822-bluetooth-4/32705653095.html?spm=2114.10010108.1000013.6.5TTgVd&traffic_analysisId=recommend_2088_3_82199_new&scm=1007.13339.82199.0&pvid=71d80c46-bd50-4ed5-bdc6-1d6253d9e038&tpp=1
    Or there's this from Arduino: http://www.ebay.com/itm/Arduino-Primo-Core-MCU-nRF52832-ARM-32-bit-64MHz-ESP8266-WiFi-BT-BLE-A0000138-/122599125462?hash=item1c8b7a31d6:g:LQkAAOSwmFNZaQRe
    TerrenceT 1 Reply Last reply
      TerrenceT
      TerrenceT
      Terrence
      wrote on last edited by Terrence
      #205
      @NeverDie Here is Kris's great looking board over on Tindie for $40
      https://www.tindie.com/products/onehorse/nrf52832-development-board/
      And his great GitHub repo showing how to program it.
      https://github.com/kriswiner/nRF52832DevBoard
      And Sandeep Mistry's Arduino core lib
      https://github.com/sandeepmistry/arduino-nRF5
      I am going to try and contact Kris and see if he will come over and join us.
      • TerrenceT Terrence
        #206
        @Terrence
        All the bluetooth sketches that I've heard of so far boil down to a bluetooth node communicating with your smartphone. That's great, and I'm glad for that, but it seems more like a wireless GUI than the internet of things.
        • Nca78N Nca78
          @d00616 said in Minimalist SAMD21 TQFP32 Pro Mini:
          @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
          So, what's the smallest nRF52 module that also includes a 32Khz crystal? I think I might want to standardize as much as possible on a single module rather than juggle a bunch of different ones.
          I have found the Raytec Modules. http://www.raytac.com/products.php?id=1
          The smallest one is the MDBT42V 8,4x6,4x1,5mm with PCB antenna and 80m range in open space.
          This module https://www.mtmtech.com.tw/M905.html is 6.5 ✕ 6.5 x 1.1 mm
          M905 is impressive, but with connectors at the bottom it's impossible to hand solder...
          Raytac module is what scalz used for the prototype of his "Aeos" board, pretty small but he didn't look so happy with the range.
          #207
          @Nca78 said in Minimalist SAMD21 TQFP32 Pro Mini:
          What's great is that both nodes are built around the Nordic nRF52, so the software still works.
          With such a small antenna on the small Raytac node, at least some impairment is probably unavoidable. @Scalz How many dBm are lost because of it?
          Regarding the M905, if there were some company that could simply solder the M905 to a PCB of the same size with castellated pins along the edges.... we'd be set, because we could then hand solder to that. I have no idea what that would cost or what the minimum batch size would have to be for it to make economic sense. Maybe someone here knows about such things? Perhaps it's something that Itead or one of the mysensors manufacturing partners could comment on or do?
            @Terrence
            TerrenceT
            TerrenceT
            Terrence
            #208
            @NeverDie Here is a repo from Seeed showing master and slave comms.
            https://github.com/Seeed-Studio/Bluetooth_Shield_Demo_Code/tree/master/examples
            Oh and it looks like Kris posted his dev board on ohw.io
            https://forum.mysensors.org/topic/7160/nrf52-development-board
            • d00616D d00616
              What do you think about creating an table with known modules including integrated hardware, available ports and size?
              I think, most small modules comes without 32kHz crystal. This is mostly an option. Maybe for the 9x9mm module. But I think the antenna is no good choice for indoor usage.
              I have a lot of RedBear BLE Nano 2 (18x21mm) modules. It's complete including 32Khz crystal and a 3-13V voltage converter. With 2.54mm pins it's easy to solder.
              I have asked the manufacturer(cdebyte) of the nice nRF24 and nRF52 modules if it's possible to build an module including the nRF52, an RGB LED, an button and 5V protected inputs with the layout like the popular nRF24 modules plus two optional pins (6/8 IO Ports!). I think such type of nRF52 module makes it easy to migrate to 32 Bit using existing boards or build new boards.
              Sounds like a good way to get started, as well as build quick prototypes.
              • d00616D d00616
                hanks! I had been using a computer running Windows 7, and I got no joy with Zadig and st-link v2 on that. However, you just now mentioned Windows 10, so I'll give that a try.
                I think the best option for beginners is to use an CMSIS-DAP/DAPLink adapter. Firmware and drivers are open source and there is an integrated serial port.
                The ST-Link adapter is initialized with an ST-Link driver by libwdi. If you have luck you can find an old variant.
                #210
                Is this how to wire up a CMSIS-DAP to the nRF52832?
                i.e. it's the same as a j-tag wiring setup, except that you add the serial Rx and Tx lines?
                d00616D 1 Reply Last reply
                  Well, this is bordering on ridiculous. I received the CMSIS-DAP from Adafruit, but there is no windows driver for it. Furthermore, the company that made it (armstart) has apparently gone out of business.
                  gohanG 1 Reply Last reply
                    d00616D
                    d00616D
                    d00616
                    You have to wire SWCLK and SWDIO. In a note of RedBear BLE Nano 2 i have seen, you require DAPLink >1.5 for nRF52832 support. Rx+Tx is not required for programming.
                    You should see an storage device and an serial device. The serial device windows driver is available at https://developer.mbed.org/handbook/Windows-serial-configuration
                    • d00616D d00616
                      Unfortunately, when I try installing that, it says, "The driver could not be installed. No mbed Micronctrollers were found."
                        That sucks a lot. Try searching for the hardware id you see in windows, maybe you can find some other drivers from other vendors.
                        • Nca78N
                          Has anyone noticed that a bunch of cheap Chinese "smart bands" use a nrf51822 ?
                          This opens some new possibilities if used as MySensors actuator !
                          https://www.youtube.com/watch?v=SBHyQ1OSM-4
                          d00616D MiKaM 2 Replies Last reply
                          • Nca78N Nca78
                            d00616D
                            d00616D
                            d00616
                            Yes. There are people working with it. Please read the discussion at github. There are watches with non nordic chips.
                            https://github.com/sandeepmistry/arduino-nRF5/issues/165
                            There are a lot of other hardware like the Noke Lock
                            Or the iStubb 2 with integrated stop up converter (maybe inductor + software) which works with 0.9V.
                            • d00616D d00616
                              #217
                              @d00616
                              Fortunately, I just received the J-link segger from aliexpress. When I plug it in, Windows seems to immediately recognize it. However, the problem is that the Arduino IDE doesn't seem to recognize it: it doesn't show up in the IDE port list under the tools menu.
                              I've tried installing each of the Zadig usb drivers, in turn, with no difference.
                              I tried installing the mbed usb windows driver, but it fails with the same error message as before.
                              I also tried downloading the segger software pack and installing it. Still fails.
                              Frustrating!
                                @d00616
                                Frustrating!
                                d00616D
                                d00616D
                                d00616
                                You have to remove the J-Link software completely. With my old j-link I had to install the J-Link software for Firmwareupdate. After that I removed the J-Link Software and all drivers via "device manager" (module plugged in) and reinstalled the correct driver with zadig (plugin module after starting zadig).
                                • d00616D d00616
                                  @d00616
                                  OK, I'll try that. Which of those 4 Zadig usb drivers should I pick?
                                    @d00616
                                    d00616D
                                    d00616D
                                    d00616
                                    Open the windows device manager and pull/plug the device and remove all depending drivers with option to uninstall the drivers.
                                    • d00616D d00616
                                      @d00616
                                      Right. But after that, which of the four do I re-install from Zadig? Or, am I misunderstanding?
                                      • Nca78N Nca78
                                        MiKaM
                                        MiKaM
                                        MiKa
                                        https://www.aliexpress.com/item/SCOMAS-ID107-Plus-heart-rate-monitor-Smart-bracelets-pedometer-Sports-Fitness-tracker-Silicone-ID-107-plus/32815883691.html?spm=2114.search0204.3.3.AScOX6&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10171_10084_10083_10080_10082_10081_10110_10303_10137_10111_10060_10112_10155_10113_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_10189_10052_10053_10142_10107_10050_10051,searchweb201603_2,ppcSwitch_5_ppcChannel&btsid=6c368be3-dd10-4a1e-903f-9fe10df3c995&algo_expid=86c55568-ad7f-409b-bae9-7b5635555f62-0&algo_pvid=86c55568-ad7f-409b-bae9-7b5635555f6also bolded text
                                        • MiKaM
                                          MiKaM
                                          MiKa
                                          this one with nodic 52832
