  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.2m Views 44 Watching
  • d00616D d00616
    @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
    I've tried installing each of the Zadig usb drivers, in turn, with no difference.
    You have to remove the J-Link software completely. With my old j-link I had to install the J-Link software for Firmwareupdate. After that I removed the J-Link Software and all drivers via "device manager" (module plugged in) and reinstalled the correct driver with zadig (plugin module after starting zadig).
    @d00616
    OK, I'll try that. Which of those 4 Zadig usb drivers should I pick?
    d00616D 1 Reply Last reply
      @d00616
      d00616D
      d00616D
      d00616
      Open the windows device manager and pull/plug the device and remove all depending drivers with option to uninstall the drivers.
      • d00616D d00616
        @d00616
        Right. But after that, which of the four do I re-install from Zadig? Or, am I misunderstanding?
        • Nca78N Nca78
          Has anyone noticed that a bunch of cheap Chinese "smart bands" use a nrf51822 ?
          This opens some new possibilities if used as MySensors actuator !
          https://www.youtube.com/watch?v=SBHyQ1OSM-4
          MiKaM
          MiKaM
          MiKa
          @Nca78 said in Minimalist SAMD21 TQFP32 Pro Mini:
          https://www.aliexpress.com/item/SCOMAS-ID107-Plus-heart-rate-monitor-Smart-bracelets-pedometer-Sports-Fitness-tracker-Silicone-ID-107-plus/32815883691.html?spm=2114.search0204.3.3.AScOX6&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10171_10084_10083_10080_10082_10081_10110_10303_10137_10111_10060_10112_10155_10113_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_10189_10052_10053_10142_10107_10050_10051,searchweb201603_2,ppcSwitch_5_ppcChannel&btsid=6c368be3-dd10-4a1e-903f-9fe10df3c995&algo_expid=86c55568-ad7f-409b-bae9-7b5635555f62-0&algo_pvid=86c55568-ad7f-409b-bae9-7b5635555f6also bolded text
          • MiKaM
            MiKaM
            MiKa
            this one with nodic 52832
            • MiKaM
              MiKaM
              MiKa
              next nice board with NRF 52832
              http://www.espruino.com/Puck.js
                @d00616
                d00616D
                d00616D
                d00616
                The CDC and BULK interface. All other are other Hardware.
                  #226
                  FWIW, I ran across another example of where someone is using the DK to program an external nRF5 board:
                  (https://github.com/electronut/ElectronutLabs-bluey/blob/master/nRF52-DK-prog.md)
                  Unfortunately, that photo is also roughly the extent of their documentation, though they do spell out the pin mapping and tell which Linux commands to use.
                    #227
                    I tried wiring it up as shown in the photos to the Adafruit nRF52832 and doing a programming through the DK and the Arduino IDE, but as you would expect it just programmed the nRF52832 that's on the DK and not the Adafruit. So, either there's a jumper that needs to be set, or different software is required to program an off-board nRF52832.
                      #228
                      Well, I found this in the user manual of the DK, which sounds quite encouraging:
                      The nRF52 Development Kit board supports programming and debugging nRF51 and nRF52 devices mounted on external boards. To debug an external board with SEGGER J-Link OB IF, connect to the Debug out connector (P19) with a 10 pin cable. Figure 22: Debug output connector
                      When the external board is powered, the interface MCU will detect the supply voltage of the board and program/debug the target chip on the external board instead of the on-board nRF52832.
                      Important: The voltage supported by external debugging/programming is 3.0 V.
                      You can also use P20 as a debug out connection to program shield mounted targets. For the Debug out header (P19),the Interface MCU will detect the supply voltage on the mounted shield and program/debug the shield target.
                      So, I'll try powering the off-board nrf52832 separately and see if it then works as described.
                        Success! Got Blink compiled and uploaded to the Adafruit nRF52832 Feather using the nRF52832 DK.
                        BTW, the adafruit LED works the opposite of the DK LED: on the Adafruit (as with most Arduino's), LOW means OFF, and HIGH means ON. For some reason the DK is the opposite of that.
                        gohanG 1 Reply Last reply
                          #230
                          Here is a photo to document the solution which worked:
                          For some reason the wiring shown in the Sparkfun and Bluey photos using header P20 didn't work for me, but using the ten pin P19 header, in combination with externally powering the Adafruit nRF52832 Feather, did work. :) So far, this is the only solution I've found which works from the Microsoft Windows environment using the Arduino IDE. So, this is what I'm going to move forward with.
                            #231
                            So, I have the Mysensors Light Sensor demo sketch running now on the Adafruit. I'm sorry to report though that the range is not good. Not sure why. Maybe it's that chip antenna Adafruit is using on its nRF52 Feather? Now that I know this, I won't be buying any more of them.
                            TerrenceT 1 Reply Last reply
                              TerrenceT
                              TerrenceT
                              Terrence
                              @NeverDie Good work, I am glad you have successfully programmed a chip from the DK.
                              Do you think we should open a new thread devoted to all of this Bluetooth action?
                              • TerrenceT Terrence
                                #233
                                @Terrence said in Bluetooth action!:
                                Meh, I'll leave that up to the moderator. Meanwhile, I changed this thread's title to match your catch phrase.
                                • MiKaM MiKa
                                  #234
                                  @MiKa said in nRF5 Bluetooth action!:
                                  Thanks for your post! Looks as though they have some very nice tutorials to go with it. That really sets it apart and makes it much more desirable.
                                  Perhaps most significant of all: it claims it can be "programmed and debugged wirelessly"! Well, that makes sense, given the nature of its language.
                                    wrote on last edited by gohan
                                    #235
                                    Maybe it is like the esp32 that the led is connected to vcc and not to gnd
                                      TerrenceT
                                      TerrenceT
                                      Terrence
                                      Perfect.
                                        #237
                                        Looks as though the nRF52832 sparkfun board has more of a conventional trace antenna:
                                        though isn't it somewhat odd that it appears to also be directly connected to the ground plane(?), or at least a copper pour. Is that normal? This was one of the images produced by sending their .BRD file to oshpark, so that I could get a look at the antenna.
                                        NeverDieN JokgiJ 2 Replies Last reply
                                        • J
                                          J
                                          jpb
                                          http://news.silabs.com/2016-11-08-Bluetooth-SiP-Module-from-Silicon-Labs-Offers-Worlds-Smallest-Footprint-for-IoT-End-Nodes
                                          Please, take a look at the Soc version, only 3,33,10,5 ... Ok it is a Soc version ...
                                          but unbelievable ....
                                          BR
                                          JP
                                          Same question for WIFI bgn and bng/ac ... including a low power CortexM4F also ?
                                          12.5k
