  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.2m Views 44 Watching
    @d00616
    Right. But after that, which of the four do I re-install from Zadig? Or, am I misunderstanding?
    d00616D
    d00616D
    d00616
    @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
    The CDC and BULK interface. All other are other Hardware.
      #226
      FWIW, I ran across another example of where someone is using the DK to program an external nRF5 board:
      (https://github.com/electronut/ElectronutLabs-bluey/blob/master/nRF52-DK-prog.md)
      Unfortunately, that photo is also roughly the extent of their documentation, though they do spell out the pin mapping and tell which Linux commands to use.
        #227
        I tried wiring it up as shown in the photos to the Adafruit nRF52832 and doing a programming through the DK and the Arduino IDE, but as you would expect it just programmed the nRF52832 that's on the DK and not the Adafruit. So, either there's a jumper that needs to be set, or different software is required to program an off-board nRF52832.
          #228
          Well, I found this in the user manual of the DK, which sounds quite encouraging:
          The nRF52 Development Kit board supports programming and debugging nRF51 and nRF52 devices mounted on external boards. To debug an external board with SEGGER J-Link OB IF, connect to the Debug out connector (P19) with a 10 pin cable. Figure 22: Debug output connector
          When the external board is powered, the interface MCU will detect the supply voltage of the board and program/debug the target chip on the external board instead of the on-board nRF52832.
          Important: The voltage supported by external debugging/programming is 3.0 V.
          You can also use P20 as a debug out connection to program shield mounted targets. For the Debug out header (P19),the Interface MCU will detect the supply voltage on the mounted shield and program/debug the shield target.
          So, I'll try powering the off-board nrf52832 separately and see if it then works as described.
            Success! Got Blink compiled and uploaded to the Adafruit nRF52832 Feather using the nRF52832 DK.
            BTW, the adafruit LED works the opposite of the DK LED: on the Adafruit (as with most Arduino's), LOW means OFF, and HIGH means ON. For some reason the DK is the opposite of that.
            gohanG 1 Reply Last reply
              #230
              Here is a photo to document the solution which worked:
              For some reason the wiring shown in the Sparkfun and Bluey photos using header P20 didn't work for me, but using the ten pin P19 header, in combination with externally powering the Adafruit nRF52832 Feather, did work. :) So far, this is the only solution I've found which works from the Microsoft Windows environment using the Arduino IDE. So, this is what I'm going to move forward with.
                #231
                So, I have the Mysensors Light Sensor demo sketch running now on the Adafruit. I'm sorry to report though that the range is not good. Not sure why. Maybe it's that chip antenna Adafruit is using on its nRF52 Feather? Now that I know this, I won't be buying any more of them.
                TerrenceT 1 Reply Last reply
                  TerrenceT
                  TerrenceT
                  Terrence
                  @NeverDie Good work, I am glad you have successfully programmed a chip from the DK.
                  Do you think we should open a new thread devoted to all of this Bluetooth action?
                  • TerrenceT Terrence
                    #233
                    @Terrence said in Bluetooth action!:
                    Meh, I'll leave that up to the moderator. Meanwhile, I changed this thread's title to match your catch phrase.
                    • MiKaM MiKa
                      next nice board with NRF 52832
                      http://www.espruino.com/Puck.js
                      #234
                      @MiKa said in nRF5 Bluetooth action!:
                      Thanks for your post! Looks as though they have some very nice tutorials to go with it. That really sets it apart and makes it much more desirable.
                      Perhaps most significant of all: it claims it can be "programmed and debugged wirelessly"! Well, that makes sense, given the nature of its language.
                        wrote on last edited by gohan
                        #235
                        Maybe it is like the esp32 that the led is connected to vcc and not to gnd
                          TerrenceT
                          TerrenceT
                          Terrence
                          Perfect.
                            #237
                            Looks as though the nRF52832 sparkfun board has more of a conventional trace antenna:
                            though isn't it somewhat odd that it appears to also be directly connected to the ground plane(?), or at least a copper pour. Is that normal? This was one of the images produced by sending their .BRD file to oshpark, so that I could get a look at the antenna.
                            NeverDieN JokgiJ 2 Replies Last reply
                            • J
                              J
                              jpb
                              http://news.silabs.com/2016-11-08-Bluetooth-SiP-Module-from-Silicon-Labs-Offers-Worlds-Smallest-Footprint-for-IoT-End-Nodes
                              Please, take a look at the Soc version, only 3,33,10,5 ... Ok it is a Soc version ...
                              but unbelievable ....
                              BR
                              JP
                              Same question for WIFI bgn and bng/ac ... including a low power CortexM4F also ?
                              • J jpb
                                BR
                                JP
                                #239
                                @jpb said in nRF5 Bluetooth action!:
                                BR
                                JP
                                @jpb
                                Nice, but for present purposes the problem is that it doesn't use a Nordic nRF5. The existing mysensors development release doesn't support bluetooth per se, but rather the nRF24-type modes of the nRF5 chip. A chip from a non-Nordic chip manufacturer wouldn't support those modes.
                                What will be interesting is if/when mysensors does in some way support bluetooth proper, at which point maybe some kinds (?) of bluetooth interactions with non-nordic bluetooth devices may be possible. Nordic has a bluetooth stack available for use on its nRF5 chips, and so it's ripe for integration.
                                  For people who like coincell motes, this type of PCB design should be easy to put together:
                                  https://www.aliexpress.com/item/iBeacon-Module-Bluetooth-4-0-BLE-Support-Near-field-Positioning-Sensor-Wireless-Acquisition/2049663760.html?spm=2114.search0104.3.32.DOxJ8e&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_10084_10083_10080_10082_10081_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_5360020_10189_10052_10053_10142_10107_10050_10051-normal#cfs,searchweb201603_1,ppcSwitch_4&btsid=4fa0fbcf-4595-46be-bd67-15faeeec2be5&algo_expid=f9915ec2-6be8-4ffb-aa7c-5da25d04f4a1-4&algo_pvid=f9915ec2-6be8-4ffb-aa7c-5da25d04f4a1
                                    #241
                                    I have some of these 1.27mm 10 pin box connectors on order from Aliexpress (above), but I'm ordering a few more from Digikey so I can get them faster:
                                    https://www.digikey.com/product-detail/en/3220-10-0100-00/1175-1627-ND/3883661
                                    It should make wire-ups for chip programming/debugging a lot easier.
                                    Of course, I'd most prefer to do it all wirelessly.... Has anyone reading this had any success with that, or know of anyone who has without resorting to espruino?
                                      #242
                                      If we upload to an nRF52840 the current mysensors demo code examples for an nRF52832, will it work? Anyone tried it?
                                      d00616D 1 Reply Last reply
                                        d00616D
                                        d00616D
                                        d00616
                                        The 52840 is currently unsupported:
                                        https://github.com/sandeepmistry/arduino-nRF5/issues/70
                                        You can try the source code from: https://github.com/lpercifield/arduino-nRF5/tree/nrf52840
                                          #244
                                          In that case I think I may order another nRF52832 DK, because I want to establish very soon some kind of reasonable baseline for the kind of range I should expect. The adafruit nRF52832 Feather seems to have awful range, and I'm not sure if that's what I should expect generally, or whether it's just that particular design/device. If it turns out to be true for nRF52832 generally, then I may just shelve things and wait for the nRF52840 to become supported and then try again with that.
                                          12.5k
