  2. Bug Reports
  3. RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0
betarfm69cwbug2.1.12.0.0gateway not responding
57 Posts 6 Posters 17.7k Views 3 Watching
  • D
    DavidZH
    Well there's your problem! You have a 868MHz CW version. So NOT the HCW That means both of the above mentioned defines ar not valid. The only define you'd have to make is #define MY_RADIO_RFM69. That should work.
    You can tell that it is not the H version because of the missing components that make up the extra RF amplifier on the module.
    Hope this helps! Good luck!
    • F
      F
      Floca
      As i told above, i have no definitions for the H Module...
      Take a look in the posted Scripts, all definitions are excluded, that are belong to the H Version.
      • mfalkviddM
        I think @DavidZH was confused by @archiijs post about the H version.
        I double-checked your sketches and none has the definition for H so now that's out of the way at least.
        @Floca could you post debug output from the gateway and the node (preferably from the same time) ?
        Also, just to double-check, have you made any modifications to MyConfig.h or are you using the untouched original version?
        • archiijsA
          archiijsA
          archiijs
          Yes, sorry for this, I will stand back til @Floca gets his problem (and maybe mine) figured out and then jump in to avoid confusion, sorry again.
          • F
            F
            Floca
            wrote on last edited by Floca
            GW 2.0.0
            Ê$OH˜KlKùið¤0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
            0;255;3;0;9;TSM:INIT
            0;255;3;0;9;TSM:RADIO:OK
            0;255;3;0;9;TSM:GW MODE
            0;255;3;0;9;TSM:READY
            scandone
            state: 0 -> 2 (b0)
            state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 4
            cnt
            f r0, scandone
            connected with N3tw0rk.NET, channel 1
            dhcp client start...
            ..ip:192.168.178.118,mask:255.255.255.0,gw:192.168.178.1
            .IP: 192.168.178.118
            pm open,type:2 0
            0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
            0;255;3;0;9;TSP:MSG:BC
            0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
            0;255;3;0;9;TSP:CHKUPL:OK
            0;255;3;0;9;TSP:MSG:GWL OK
            0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
            0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
            0;255;3;0;9;TSP:MSG:PINGED (ID=100, hops=1)
            0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
            0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            0;255;3;0;9;!TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
            0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
            0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
            0;255;3;0;9;TSP:MSG:READ 100-100-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
            0;255;3;0;9;TSP:MSG:READ 100-100-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
            0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
            0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
            0;255;3;0;9;TSP:MSG:READ 100-100-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.8
            0;255;3;0;9;TSP:MSG:READ 100-100-0 s=0,c=1,t=1,pt=7,l=5,sg=0:80.7
            0;255;3;0;9;TSP:SANCHK:OK
            SENSOR 2.0.0
            Starting sensor (RRNNA-, 2.0.0)
            TSM:INIT
            TSM:RADIO:OK
            TSP:ASSIGNID:OK (ID=100)
            TSM:FPAR
            TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
            TSP:MSG:PAR OK (ID=0, dist=1)
            TSM:FPAR:OK
            TSM:ID
            TSM:CHKID:OK (ID=100)
            TSM:UPL
            TSP:PING:SEND (dest=0)
            TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
            TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
            TSP:MSG:PONG RECV (hops=1)
            TSP:CHKUPL:OK
            TSM:UPL:OK
            TSM:READY
            TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
            !TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
            !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=fail:0
            TSP:MSG:READ 0-0-100 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=2,st=ok:TemperatureAndHumidity
            !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=fail:1.1
            TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=1,st=ok:
            TSP:MSG:SEND 100-100-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
            Request registration...
            TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
            TSP:MSG:READ 0-0-100 s=255,c=3,t=27,pt=1,l=1,sg=0:1
            Node registration=1
            Init complete, id=100, parent=0, distance=1, registration=1
            TSP:MSG:SEND 100-100-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.8
            T: 22.80
            TSP:MSG:SEND 100-100-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:80.8
            H: 80.80
            Gateway 2.2.0
            ÈDpÈtAhÀD´ðCXXüü0;255;3;0;9;238 MCO:BGN:INIT GW,CP=RRNGE---,VER=2.2.0-beta
            0;255;3;0;9;299 TSF:LRT:OK
            0;255;3;0;9;327 TSM:INIT
            0;255;3;0;9;353 TSF:WUR:MS=0
            scandone
            state: 0 -> 2 (b0)
            state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 4
            cnt
            0;255;3;0;9;470 TSM:INIT:TSP OK
            0;255;3;0;9;502 TSM:INIT:GW MODE
            0;255;3;0;9;537 TSM:READY:ID=0,PAR=0,DIS=0
            0;255;3;0;9;582 MCO:REG:NOT NEEDED
            f r0, scandone
            .....ip:192.168.178.118,mask:255.255.255.0,gw:192.168.178.1
            0;255;3;0;9;3682 MCO:BGN:STP
            0;255;3;0;9;3735 MCO:BGN:INIT OK,TSP=1
            pm open,type:2 0
            Sensor 2.2.0
            0 MCO:BGN:INIT NODE,CP=RRNNA---,VER=2.2.0-beta
            4 TSM:INIT
            4 TSF:WUR:MS=0
            8 TSM:INIT:TSP OK
            10 TSM:FPAR
            1228 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            3237 !TSM:FPAR:NO REPLY
            3239 TSM:FPAR
            4468 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            6477 !TSM:FPAR:NO REPLY
            6479 TSM:FPAR
            7698 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            9707 !TSM:FPAR:NO REPLY
            9709 TSM:FPAR
            10928 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            12937 !TSM:FPAR:FAIL
            12939 TSM:FAIL:CNT=1
            12941 TSM:FAIL:DIS
            12943 TSF:TDI:TSL
            22947 TSM:FAIL:RE-INIT
            22949 TSM:INIT
            22951 TSM:INIT:TSP OK
            22956 TSM:FPAR
            24174 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            26183 !TSM:FPAR:NO REPLY
            26185 TSM:FPAR
            27404 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            29413 !TSM:FPAR:NO REPLY
            29415 TSM:FPAR
            30633 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            32643 !TSM:FPAR:NO REPLY
            32645 TSM:FPAR
            33867 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            35876 !TSM:FPAR:FAIL
            35878 TSM:FAIL:CNT=2
            35880 TSM:FAIL:DIS
            35883 TSF:TDI:TSL
            45887 TSM:FAIL:RE-INIT
            45889 TSM:INIT
            45891 TSM:INIT:TSP OK
            45895 TSM:FPAR
            47114 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            49123 !TSM:FPAR:NO REPLY
            49125 TSM:FPAR
            50370 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            52379 !TSM:FPAR:NO REPLY
            52381 TSM:FPAR
            53600 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            55609 !TSM:FPAR:NO REPLY
            55611 TSM:FPAR
            56829 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            58839 !TSM:FPAR:FAIL
            58841 TSM:FAIL:CNT=3
            58843 TSM:FAIL:DIS
            58845 TSF:TDI:TSL
            68849 TSM:FAIL:RE-INIT
            68851 TSM:INIT
            68853 TSM:INIT:TSP OK
            68857 TSM:FPAR
            70076 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            72085 !TSM:FPAR:NO REPLY
            72087 TSM:FPAR
            73306 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            75315 !TSM:FPAR:NO REPLY
            75317 TSM:FPAR
            76535 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            78546 !TSM:FPAR:NO REPLY
            78548 TSM:FPAR
            79767 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            81776 !TSM:FPAR:FAIL
            81778 TSM:FAIL:CNT=4
            81780 TSM:FAIL:DIS
            81782 TSF:TDI:TSL
            91785 TSM:FAIL:RE-INIT
            91787 TSM:INIT
            91789 TSM:INIT:TSP OK
            91793 TSM:FPAR
            93011 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            95021 !TSM:FPAR:NO REPLY
            95023 TSM:FPAR
            96241 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            98250 !TSM:FPAR:NO REPLY
            98252 TSM:FPAR
            99471 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            101480 !TSM:FPAR:NO REPLY
            101482 TSM:FPAR
            102703 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            104712 !TSM:FPAR:FAIL
            104714 TSM:FAIL:CNT=5
            104716 TSM:FAIL:DIS
            104718 TSF:TDI:TSL
            114722 TSM:FAIL:RE-INIT
            114724 TSM:INIT
            114728 TSM:INIT:TSP OK
            114731 TSM:FPAR
            115951 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            117960 !TSM:FPAR:NO REPLY
            117962 TSM:FPAR
            119183 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            121192 !TSM:FPAR:NO REPLY
            121194 TSM:FPAR
            122443 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            124452 !TSM:FPAR:NO REPLY
            124454 TSM:FPAR
            125673 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            127682 !TSM:FPAR:FAIL
            127684 TSM:FAIL:CNT=6
            127686 TSM:FAIL:DIS
            127688 TSF:TDI:TSL
            137691 TSM:FAIL:RE-INIT
            137693 TSM:INIT
            137697 TSM:INIT:TSP OK
            137699 TSM:FPAR
            138919 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            140929 !TSM:FPAR:NO REPLY
            140931 TSM:FPAR
            142151 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            144160 !TSM:FPAR:NO REPLY
            144162 TSM:FPAR
            145381 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            • The Config is the Standard Config which comes with the Package on Github.
            • The Scripts from above are used to flash the devices.
            • The Gateway on 2.2.0-beta gives only these lines as in Codebox, then, nothing else happens.
            • I have cleaned the EEPROM from the devices with the eeprom clean example in mysensors examples
              @Floca
              thx for logs. Logs are always useful ;)
              I tried a few weeks ago rfm69 with atsam, esp32 etc and was working well here.
              So I'll take a look asap. Need to find a wemos to have same setup.
              Note:
              • in your first post, you say that you tried with a nano. But nano is 5v whereas rfm69 is not 5v tolerant. So this can't work.
              • all rfm69 modules works the same. C, W the same. HW and HCW the same too. These are just different package and mapping, that's all. But sure, if using HW, HCW, needs the high power dfine in MySensors (not your case here)
              • F
                F
                Floca
                Oh, of course, i wrote Nano, my mistake :(
                I use Arduino PRO MINI's 3.3v for my Nodes.
                • mfalkviddM
                  I'll dig out some modules and see if I can reproduce the problem.
                  • mfalkviddM
                    @Floca which pins (GPIOxx or Dx) do these correspond to?
                    #define MY_RF69_IRQ_PIN 4
                    #define MY_RF69_SPI_CS 15
                    MySensors is not able to initialize the radio, probably due to my wiring not being the same as yours.
                    • F
                      F
                      Floca
                      I use this Module...
                      https://www.openhardware.io/view/386/Minimalist-RFM69CW-WeMos-D1-Mini-Shield
                      IRQ=DIO0= GPIO4=D2
                      CS=NSS=GPIO15=D8
                      • mfalkviddM
                        I've spent 2 hours and I can't even get gw+node working on 2.0.0.
                        I'll take a break and try to clear my head so I can figure out what is wrong.
                        • F
                          F
                          Floca
                          ...on 2.0.0 or on 2.2.0?
                          • F Floca
                            @Floca on 2.0.0.
                            I can't do any troubleshooting unless I know I have a working configuration.
                            Troubleshooting 2.2.0-beta with a configuration that I know is broken on 2.0.0 it totally useless.
                            • F
                              F
                              Floca
                              Ok, i know what you mean, that is true.
                              • F
                                F
                                Floca
                                I have researched and have found out that an arduino nano as a serial gateway also does not seem to work (same log as above).
                                I hope this helps you a bit.
                                • F Floca
                                  sundberg84S
                                  sundberg84S
                                  @Floca - A nano will fry your radio (5v SPI/data lines) but maybe you wrote the wrong mcu?
                                  I can comfirm that a RFM69w and Pro Mini 3.3v 8mhz works great on dev branch.
                                  im using this code: https://github.com/sundberg84/MySensors2.0.0/blob/master/RFM69gw/Rfm69gw.ino
                                  And this hardware: https://forum.mysensors.org/topic/6809/easy-newbie-pcb-rfm69-hw-w-edition-for-mysensors/16
                                  F 1 Reply Last reply
                                  • sundberg84S sundberg84
                                    F
                                    F
                                    Floca
                                    @sundberg84 said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
                                    whoops, i forget that, but it still works ^^
                                    Seems to be an Gateway problem, because the Sensor waits for the gateway...
                                    @mfalkvidd doublechecked my script, tht should not be the Problem :(
                                    • F Floca
                                      sundberg84S
                                      sundberg84S
                                      #31
                                      @Floca which controller do you use ? I have a gw and two sensors working great.
                                      • F
                                        F
                                        Floca
                                        Gateway: Wemos D1 Mini
                                        Nodes: Arduino Pro Mini
                                        • F Floca
                                          sundberg84S
                                          sundberg84S
                                          @Floca good maybe the issue is rfm+vemos but which controller do you use?
