  2. Bug Reports
  3. RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0
betarfm69cwbug2.1.12.0.0gateway not responding
57 Posts 6 Posters 17.7k Views 3 Watching
  • archiijsA
    archiijsA
    archiijs
    Hi, I will look closely this, because I would really like to get RFM network going for my outide, not with NRF reachable sensors.
    In my definition, I added
    #define MY_RFM69_FREQUENCY RF69_433MHZ // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
    and
    #define MY_IS_RFM69HW // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
    cause my radio was like 4th from left in the picture below. I was using antenna bundled with radios (173mm) stranded but changed to solid but with the same length.
    • D DavidZH
      Can you post a picture of het back of your RFM module? That way we can eliminate the definitions you won't need.
      I run on 2.1.1 with 868MHz versions of both HW and low power. No problems whatsoever. I'm getting very curious as to why I keep reading about users facing issues with the RFM based nodes.
      F
      F
      Floca
      wrote on last edited by Floca
      @DavidZH said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
      RFM69CW
      • D
        DavidZH
        Well there's your problem! You have a 868MHz CW version. So NOT the HCW That means both of the above mentioned defines ar not valid. The only define you'd have to make is #define MY_RADIO_RFM69. That should work.
        You can tell that it is not the H version because of the missing components that make up the extra RF amplifier on the module.
        Hope this helps! Good luck!
        • F
          F
          Floca
          As i told above, i have no definitions for the H Module...
          Take a look in the posted Scripts, all definitions are excluded, that are belong to the H Version.
          • mfalkviddM
            I think @DavidZH was confused by @archiijs post about the H version.
            I double-checked your sketches and none has the definition for H so now that's out of the way at least.
            @Floca could you post debug output from the gateway and the node (preferably from the same time) ?
            Also, just to double-check, have you made any modifications to MyConfig.h or are you using the untouched original version?
            • archiijsA
              archiijsA
              archiijs
              Yes, sorry for this, I will stand back til @Floca gets his problem (and maybe mine) figured out and then jump in to avoid confusion, sorry again.
              • F
                F
                Floca
                GW 2.0.0
                Ê$OH˜KlKùið¤0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSM:RADIO:OK
                0;255;3;0;9;TSM:GW MODE
                0;255;3;0;9;TSM:READY
                scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 5 (10)
                add 0
                aid 4
                cnt
                f r0, scandone
                connected with N3tw0rk.NET, channel 1
                dhcp client start...
                ..ip:192.168.178.118,mask:255.255.255.0,gw:192.168.178.1
                .IP: 192.168.178.118
                pm open,type:2 0
                0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;TSP:MSG:BC
                0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
                0;255;3;0;9;TSP:CHKUPL:OK
                0;255;3;0;9;TSP:MSG:GWL OK
                0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                0;255;3;0;9;TSP:MSG:PINGED (ID=100, hops=1)
                0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                0;255;3;0;9;!TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
                0;255;3;0;9;TSP:MSG:READ 100-100-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;TSP:MSG:READ 100-100-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                0;255;3;0;9;TSP:MSG:READ 100-100-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.8
                0;255;3;0;9;TSP:MSG:READ 100-100-0 s=0,c=1,t=1,pt=7,l=5,sg=0:80.7
                0;255;3;0;9;TSP:SANCHK:OK
                SENSOR 2.0.0
                Starting sensor (RRNNA-, 2.0.0)
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=100)
                TSM:FPAR
                TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSP:MSG:PAR OK (ID=0, dist=1)
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=100)
                TSM:UPL
                TSP:PING:SEND (dest=0)
                TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                TSP:MSG:PONG RECV (hops=1)
                TSP:CHKUPL:OK
                TSM:UPL:OK
                TSM:READY
                TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                !TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=fail:0
                TSP:MSG:READ 0-0-100 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=2,st=ok:TemperatureAndHumidity
                !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=fail:1.1
                TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=1,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                Request registration...
                TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                TSP:MSG:READ 0-0-100 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                Node registration=1
                Init complete, id=100, parent=0, distance=1, registration=1
                TSP:MSG:SEND 100-100-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.8
                T: 22.80
                TSP:MSG:SEND 100-100-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:80.8
                H: 80.80
                Gateway 2.2.0
                ÈDpÈtAhÀD´ðCXXüü0;255;3;0;9;238 MCO:BGN:INIT GW,CP=RRNGE---,VER=2.2.0-beta
                0;255;3;0;9;299 TSF:LRT:OK
                0;255;3;0;9;327 TSM:INIT
                0;255;3;0;9;353 TSF:WUR:MS=0
                scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 5 (10)
                add 0
                aid 4
                cnt
                0;255;3;0;9;470 TSM:INIT:TSP OK
                0;255;3;0;9;502 TSM:INIT:GW MODE
                0;255;3;0;9;537 TSM:READY:ID=0,PAR=0,DIS=0
                0;255;3;0;9;582 MCO:REG:NOT NEEDED
                f r0, scandone
                .....ip:192.168.178.118,mask:255.255.255.0,gw:192.168.178.1
                0;255;3;0;9;3682 MCO:BGN:STP
                0;255;3;0;9;3735 MCO:BGN:INIT OK,TSP=1
                pm open,type:2 0
                Sensor 2.2.0
                0 MCO:BGN:INIT NODE,CP=RRNNA---,VER=2.2.0-beta
                4 TSM:INIT
                4 TSF:WUR:MS=0
                8 TSM:INIT:TSP OK
                10 TSM:FPAR
                1228 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                3237 !TSM:FPAR:NO REPLY
                3239 TSM:FPAR
                4468 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                6477 !TSM:FPAR:NO REPLY
                6479 TSM:FPAR
                7698 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                9707 !TSM:FPAR:NO REPLY
                9709 TSM:FPAR
                10928 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                12937 !TSM:FPAR:FAIL
                12939 TSM:FAIL:CNT=1
                12941 TSM:FAIL:DIS
                12943 TSF:TDI:TSL
                22947 TSM:FAIL:RE-INIT
                22949 TSM:INIT
                22951 TSM:INIT:TSP OK
                22956 TSM:FPAR
                24174 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                26183 !TSM:FPAR:NO REPLY
                26185 TSM:FPAR
                27404 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                29413 !TSM:FPAR:NO REPLY
                29415 TSM:FPAR
                30633 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                32643 !TSM:FPAR:NO REPLY
                32645 TSM:FPAR
                33867 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                35876 !TSM:FPAR:FAIL
                35878 TSM:FAIL:CNT=2
                35880 TSM:FAIL:DIS
                35883 TSF:TDI:TSL
                45887 TSM:FAIL:RE-INIT
                45889 TSM:INIT
                45891 TSM:INIT:TSP OK
                45895 TSM:FPAR
                47114 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                49123 !TSM:FPAR:NO REPLY
                49125 TSM:FPAR
                50370 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                52379 !TSM:FPAR:NO REPLY
                52381 TSM:FPAR
                53600 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                55609 !TSM:FPAR:NO REPLY
                55611 TSM:FPAR
                56829 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                58839 !TSM:FPAR:FAIL
                58841 TSM:FAIL:CNT=3
                58843 TSM:FAIL:DIS
                58845 TSF:TDI:TSL
                68849 TSM:FAIL:RE-INIT
                68851 TSM:INIT
                68853 TSM:INIT:TSP OK
                68857 TSM:FPAR
                70076 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                72085 !TSM:FPAR:NO REPLY
                72087 TSM:FPAR
                73306 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                75315 !TSM:FPAR:NO REPLY
                75317 TSM:FPAR
                76535 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                78546 !TSM:FPAR:NO REPLY
                78548 TSM:FPAR
                79767 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                81776 !TSM:FPAR:FAIL
                81778 TSM:FAIL:CNT=4
                81780 TSM:FAIL:DIS
                81782 TSF:TDI:TSL
                91785 TSM:FAIL:RE-INIT
                91787 TSM:INIT
                91789 TSM:INIT:TSP OK
                91793 TSM:FPAR
                93011 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                95021 !TSM:FPAR:NO REPLY
                95023 TSM:FPAR
                96241 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                98250 !TSM:FPAR:NO REPLY
                98252 TSM:FPAR
                99471 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                101480 !TSM:FPAR:NO REPLY
                101482 TSM:FPAR
                102703 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                104712 !TSM:FPAR:FAIL
                104714 TSM:FAIL:CNT=5
                104716 TSM:FAIL:DIS
                104718 TSF:TDI:TSL
                114722 TSM:FAIL:RE-INIT
                114724 TSM:INIT
                114728 TSM:INIT:TSP OK
                114731 TSM:FPAR
                115951 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                117960 !TSM:FPAR:NO REPLY
                117962 TSM:FPAR
                119183 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                121192 !TSM:FPAR:NO REPLY
                121194 TSM:FPAR
                122443 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                124452 !TSM:FPAR:NO REPLY
                124454 TSM:FPAR
                125673 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                127682 !TSM:FPAR:FAIL
                127684 TSM:FAIL:CNT=6
                127686 TSM:FAIL:DIS
                127688 TSF:TDI:TSL
                137691 TSM:FAIL:RE-INIT
                137693 TSM:INIT
                137697 TSM:INIT:TSP OK
                137699 TSM:FPAR
                138919 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                140929 !TSM:FPAR:NO REPLY
                140931 TSM:FPAR
                142151 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                144160 !TSM:FPAR:NO REPLY
                144162 TSM:FPAR
                145381 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                • The Config is the Standard Config which comes with the Package on Github.
                • The Scripts from above are used to flash the devices.
                • The Gateway on 2.2.0-beta gives only these lines as in Codebox, then, nothing else happens.
                • I have cleaned the EEPROM from the devices with the eeprom clean example in mysensors examples
                  @Floca
                  thx for logs. Logs are always useful ;)
                  I tried a few weeks ago rfm69 with atsam, esp32 etc and was working well here.
                  So I'll take a look asap. Need to find a wemos to have same setup.
                  Note:
                  • in your first post, you say that you tried with a nano. But nano is 5v whereas rfm69 is not 5v tolerant. So this can't work.
                  • all rfm69 modules works the same. C, W the same. HW and HCW the same too. These are just different package and mapping, that's all. But sure, if using HW, HCW, needs the high power dfine in MySensors (not your case here)
                  • F
                    F
                    Floca
                    Oh, of course, i wrote Nano, my mistake :(
                    I use Arduino PRO MINI's 3.3v for my Nodes.
                    • mfalkviddM
                      I'll dig out some modules and see if I can reproduce the problem.
                      • mfalkviddM
                        @Floca which pins (GPIOxx or Dx) do these correspond to?
                        #define MY_RF69_IRQ_PIN 4
                        #define MY_RF69_SPI_CS 15
                        MySensors is not able to initialize the radio, probably due to my wiring not being the same as yours.
                        • F
                          F
                          Floca
                          I use this Module...
                          https://www.openhardware.io/view/386/Minimalist-RFM69CW-WeMos-D1-Mini-Shield
                          IRQ=DIO0= GPIO4=D2
                          CS=NSS=GPIO15=D8
                          • mfalkviddM
                            I've spent 2 hours and I can't even get gw+node working on 2.0.0.
                            I'll take a break and try to clear my head so I can figure out what is wrong.
                            • F
                              F
                              Floca
                              ...on 2.0.0 or on 2.2.0?
                              • F Floca
                                @Floca on 2.0.0.
                                I can't do any troubleshooting unless I know I have a working configuration.
                                Troubleshooting 2.2.0-beta with a configuration that I know is broken on 2.0.0 it totally useless.
                                • F
                                  F
                                  Floca
                                  Ok, i know what you mean, that is true.
                                  • F
                                    F
                                    Floca
                                    I have researched and have found out that an arduino nano as a serial gateway also does not seem to work (same log as above).
                                    I hope this helps you a bit.
                                    • F Floca
                                      sundberg84S
                                      sundberg84S
                                      @Floca - A nano will fry your radio (5v SPI/data lines) but maybe you wrote the wrong mcu?
                                      I can comfirm that a RFM69w and Pro Mini 3.3v 8mhz works great on dev branch.
                                      im using this code: https://github.com/sundberg84/MySensors2.0.0/blob/master/RFM69gw/Rfm69gw.ino
                                      And this hardware: https://forum.mysensors.org/topic/6809/easy-newbie-pcb-rfm69-hw-w-edition-for-mysensors/16
                                      F 1 Reply Last reply
                                      • sundberg84S sundberg84
                                        F
                                        F
                                        Floca
                                        @sundberg84 said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
                                        whoops, i forget that, but it still works ^^
                                        Seems to be an Gateway problem, because the Sensor waits for the gateway...
                                        @mfalkvidd doublechecked my script, tht should not be the Problem :(
                                        • F Floca
                                          sundberg84S
                                          sundberg84S
                                          #31
                                          @Floca which controller do you use ? I have a gw and two sensors working great.
