  2. Bug Reports
  3. RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0
betarfm69cwbug2.1.12.0.0gateway not responding
57 Posts 6 Posters 17.7k Views 3 Watching
  • F
    F
    Floca
    wrote on last edited by Floca
    Oh, of course, i wrote Nano, my mistake :(
    I use Arduino PRO MINI's 3.3v for my Nodes.
    • mfalkviddM
      I'll dig out some modules and see if I can reproduce the problem.
      • mfalkviddM
        @Floca which pins (GPIOxx or Dx) do these correspond to?
        #define MY_RF69_IRQ_PIN 4
        #define MY_RF69_SPI_CS 15
        MySensors is not able to initialize the radio, probably due to my wiring not being the same as yours.
        • F
          F
          Floca
          I use this Module...
          https://www.openhardware.io/view/386/Minimalist-RFM69CW-WeMos-D1-Mini-Shield
          IRQ=DIO0= GPIO4=D2
          CS=NSS=GPIO15=D8
          • mfalkviddM
            I've spent 2 hours and I can't even get gw+node working on 2.0.0.
            I'll take a break and try to clear my head so I can figure out what is wrong.
            • F
              F
              Floca
              ...on 2.0.0 or on 2.2.0?
              • F Floca
                @Floca on 2.0.0.
                I can't do any troubleshooting unless I know I have a working configuration.
                Troubleshooting 2.2.0-beta with a configuration that I know is broken on 2.0.0 it totally useless.
                • F
                  F
                  Floca
                  Ok, i know what you mean, that is true.
                  • F
                    F
                    Floca
                    I have researched and have found out that an arduino nano as a serial gateway also does not seem to work (same log as above).
                    I hope this helps you a bit.
                    • F Floca
                      sundberg84S
                      sundberg84S
                      @Floca - A nano will fry your radio (5v SPI/data lines) but maybe you wrote the wrong mcu?
                      I can comfirm that a RFM69w and Pro Mini 3.3v 8mhz works great on dev branch.
                      im using this code: https://github.com/sundberg84/MySensors2.0.0/blob/master/RFM69gw/Rfm69gw.ino
                      And this hardware: https://forum.mysensors.org/topic/6809/easy-newbie-pcb-rfm69-hw-w-edition-for-mysensors/16
                      F 1 Reply Last reply
                      • sundberg84S sundberg84
                        F
                        F
                        Floca
                        @sundberg84 said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
                        whoops, i forget that, but it still works ^^
                        Seems to be an Gateway problem, because the Sensor waits for the gateway...
                        @mfalkvidd doublechecked my script, tht should not be the Problem :(
                        • F Floca
                          sundberg84S
                          sundberg84S
                          #31
                          @Floca which controller do you use ? I have a gw and two sensors working great.
                          • F
                            F
                            Floca
                            Gateway: Wemos D1 Mini
                            Nodes: Arduino Pro Mini
                            • F Floca
                              sundberg84S
                              sundberg84S
                              @Floca good maybe the issue is rfm+vemos but which controller do you use?
                              • F
                                F
                                Floca
                                Oh you mean which System uses the Data?
                                I use Fhem.
                                • F Floca
                                  I use Fhem.
                                  sundberg84S
                                  sundberg84S
                                  @Floca I'm not familiar with fhem but I guess that controller hands out Id?
                                  • F
                                    F
                                    Floca
                                    I think FHEM hands it out, yes, because you can configure the ID's in the Mysensors Module.
                                    ...with nRF24 the beta is no Problem with FHEM.
                                    • F Floca
                                      #37
                                      @Floca I now have working nodes with 2.0.0. Unfortunately (at least for this troubleshooting) they also work with 2.2.0-beta.
                                      Sensor 2.0.0 and Gateway 2.0.0:
                                      Starting sensor (RRNNA-, 2.0.0)
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSP:ASSIGNID:OK (ID=1)
                                      TSM:FPAR
                                      TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                      TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      TSP:MSG:PAR OK (ID=0, dist=1)
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=1)
                                      TSM:UPL
                                      TSP:PING:SEND (dest=0)
                                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      TSP:MSG:PONG RECV (hops=1)
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                      !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=ok:TemperatureAndHumidity
                                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
                                      TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                                      TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                      Request registration...
                                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                      TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      Node registration=1
                                      Init complete, id=1, parent=0, distance=1, registration=1
                                      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:1.0
                                      T: 1.00
                                      TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:35.0
                                      H: 35.00
                                      0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
                                      0;255;3;0;9;TSM:INIT
                                      0;255;3;0;9;TSM:RADIO:OK
                                      0;255;3;0;9;TSM:GW MODE
                                      0;255;3;0;9;TSM:READY
                                      scandone
                                      state: 0 -> 2 (b0)
                                      state: 2 -> 3 (0)
                                      state: 3 -> 5 (10)
                                      add 0
                                      aid 1
                                      cnt
                                      connected with Mr-IoT.com, channel 2
                                      dhcp client start...
                                      f r0, scandone
                                      ip:192.168.1.215,mask:255.255.255.0,gw:192.168.1.1
                                      .IP: 192.168.1.215
                                      pm open,type:2 0
                                      0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSP:MSG:BC
                                      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
                                      0;255;3;0;9;TSP:CHKUPL:OK
                                      0;255;3;0;9;TSP:MSG:GWL OK
                                      0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                                      0;255;3;0;9;TSP:SANCHK:OK
                                      0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                      0;255;3;0;9;TSP:MSG:PINGED (ID=1, hops=1)
                                      0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                      0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:1.0
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:35.0
                                      Sensor 2.2.0-beta and Gateway 2.0.0:
                                      0 MCO:BGN:INIT NODE,CP=RRNNA---,VER=2.2.0-beta
                                      4 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      8 TSM:INIT:TSP OK
                                      10 TSM:INIT:STATID=1
                                      12 TSF:SID:OK,ID=1
                                      14 TSM:FPAR
                                      22 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      446 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      452 TSF:MSG:FPAR OK,ID=0,D=1
                                      2031 TSM:FPAR:OK
                                      2031 TSM:ID
                                      2033 TSM:ID:OK
                                      2035 TSM:UPL
                                      2043 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      2158 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      2164 TSF:MSG:PONG RECV,HP=1
                                      2166 TSM:UPL:OK
                                      2168 TSM:READY:ID=1,PAR=0,DIS=1
                                      2385 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      2459 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      2678 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                                      2899 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      4919 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:TemperatureAndHumidity
                                      5140 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                                      5359 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      5578 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                                      5584 MCO:REG:REQ
                                      5799 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      5869 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      5875 MCO:PIM:NODE REG=1
                                      5879 MCO:BGN:STP
                                      5881 MCO:BGN:INIT OK,TSP=1
                                      6098 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:1.0
                                      T: 1.00
                                      6318 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.0
                                      H: 35.00
                                      6326 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      6332 TSF:TDI:TSL
                                      Gateway 2.0.0 (did not restart it from previous log):
                                      0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
                                      Sensor 2.2.0-beta and gateway 2.2.0-beta:
                                      4 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      8 TSM:INIT:TSP OK
                                      12 TSF:SID:OK,ID=1
                                      14 TSM:FPAR
                                      1234 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      1540 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      1546 TSF:MSG:FPAR OK,ID=0,D=1
                                      3244 TSM:FPAR:OK
                                      3244 TSM:ID
                                      3246 TSM:ID:OK
                                      3248 TSM:UPL
                                      3258 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      3387 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      3393 TSF:MSG:PONG RECV,HP=1
                                      3395 TSM:UPL:OK
                                      3397 TSM:READY:ID=1,PAR=0,DIS=1
                                      3612 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      3694 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      3915 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                                      4136 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      6154 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:TemperatureAndHumidity
                                      6377 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                                      6594 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6813 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6821 MCO:REG:REQ
                                      7034 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      7118 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      7124 MCO:PIM:NODE REG=1
                                      7129 MCO:BGN:STP
                                      7131 MCO:BGN:INIT OK,TSP=1
                                      7348 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:1.0
                                      T: 1.00
                                      7569 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.0
                                      H: 35.00
                                      7577 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      7583 TSF:TDI:TSL
                                      7585 MCO:SLP:WUP=-1
                                      7587 TSF:TRI:TSB
                                      8820 !TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=NACK:31.0
                                      T: 31.00
                                      10070 !TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=1,st=NACK:84.0
                                      H: 84.00
                                      10078 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      10084 TSF:TDI:TSL
                                      10086 MCO:SLP:WUP=-1
                                      10088 TSF:TRI:TSB
                                      10100 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=OK:42.0
                                      T: 42.00
                                      10323 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:81.0
                                      H: 81.00
                                      10332 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      10338 TSF:TDI:TSL
                                      10340 MCO:SLP:WUP=-1
                                      10342 TSF:TRI:TSB
                                      10354 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:31.0
                                      T: 31.00
                                      10577 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:45.0
                                      H: 45.00
                                      10586 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      10592 TSF:TDI:TSL
                                      10594 MCO:SLP:WUP=-1
                                      10596 TSF:TRI:TSB
                                      10608 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:2.0
                                      T: 2.00
                                      10831 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:38.0
                                      H: 38.00
                                      10840 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      10846 TSF:TDI:TSL
                                      10848 MCO:SLP:WUP=-1
                                      10852 TSF:TRI:TSB
                                      10862 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.0
                                      T: 28.00
                                      11085 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:18.0
                                      H: 18.00
                                      11094 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      11100 TSF:TDI:TSL
                                      11102 MCO:SLP:WUP=-1
                                      11104 TSF:TRI:TSB
                                      11116 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:43.0
                                      T: 43.00
                                      11339 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:72.0
                                      H: 72.00
                                      11347 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      11354 TSF:TDI:TSL
                                      11358 MCO:SLP:WUP=-1
                                      11360 TSF:TRI:TSB
                                      11372 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:8.0
                                      T: 8.00
                                      11593 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:30.0
                                      H: 30.00
                                      11601 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      11608 TSF:TDI:TSL
                                      11610 MCO:SLP:WUP=-1
                                      11612 TSF:TRI:TSB
                                      11626 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:3.0
                                      T: 3.00
                                      11847 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:17.0
                                      H: 17.00
                                      11855 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      11862 TSF:TDI:TSL
                                      11864 MCO:SLP:WUP=-1
                                      11868 TSF:TRI:TSB
                                      11878 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.0
                                      T: 40.00
                                      12101 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:38.0
                                      H: 38.00
                                      12109 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      12115 TSF:TDI:TSL
                                      0;255;3;0;9;5695 MCO:BGN:INIT GW,CP=RRNGE---,VER=2.2.0-beta
                                      0;255;3;0;9;5757 TSF:LRT:OK
                                      0;255;3;0;9;5786 TSM:INIT
                                      0;255;3;0;9;5813 TSF:WUR:MS=0
                                      scandone
                                      state: 0 -> 2 (b0)
                                      state: 2 -> 3 (0)
                                      state: 3 -> 5 (10)
                                      add 0
                                      aid 1
                                      cnt
                                      0;255;3;0;9;5993 TSM:INIT:TSP OK
                                      0;255;3;0;9;6027 TSM:INIT:GW MODE
                                      0;255;3;0;9;6062 TSM:READY:ID=0,PAR=0,DIS=0
                                      0;255;3;0;9;6108 MCO:REG:NOT NEEDED
                                      f r0, scandone
                                      .IP: 192.168.1.215
                                      0;255;3;0;9;6647 MCO:BGN:STP
                                      0;255;3;0;9;6698 MCO:BGN:INIT OK,TSP=1
                                      pm open,type:2 0
                                      0;255;3;0;9;40166 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:42.0
                                      0;255;3;0;9;40388 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:81.0
                                      0;255;3;0;9;99604 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:31.0
                                      0;255;3;0;9;99826 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:45.0
                                      0;255;3;0;9;159042 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:2.0
                                      0;255;3;0;9;159264 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:38.0
                                      0;255;3;0;9;218484 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:28.0
                                      0;255;3;0;9;218706 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:18.0
                                      0;255;3;0;9;277923 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:43.0
                                      0;255;3;0;9;278146 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:72.0
                                      0;255;3;0;9;337356 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.0
                                      0;255;3;0;9;337577 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:30.0
                                      0;255;3;0;9;396783 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:3.0
                                      0;255;3;0;9;397005 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:17.0
                                      These are the defines I used
                                      Node:
                                      #define MY_NODE_ID 1 // To avoid having to involve a controller
                                      #define MY_RADIO_RFM69
                                      #define MY_RFM69_FREQUENCY RFM69_433MHZ // RFM69_433MHZ for development branch, RF69_433MHZ for master
                                      #define MY_RF69_IRQ_PIN 2
                                      #define MY_RF69_SPI_CS 10
                                      Gateway:
                                      #define MY_RF69_IRQ_PIN D2
                                      #define MY_RF69_SPI_CS D8
                                      The only difference I see is that my radio modules are for 433MHz, while yours are for 868 (which is default). I don't see why it should matter, but it is a difference.
                                      I used this git commit
                                      commit 3e75b52c33b06c70d60eb691bd127e2f585a0c87
                                      Date:   Fri Jul 7 14:36:14 2017 +0200
                                      On the node I used
                                      float temperature = random(1,50);
                                      float humidity = random(1,100);
                                      to avoid involving the DHT
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:CHKID:OK (ID=1)
                                        TSM:UPL
                                        TSP:CHKUPL:OK
                                        TSM:UPL:OK
                                        TSM:READY
                                        Node registration=1
                                        T: 1.00
                                        H: 35.00
                                        scandone
                                        state: 0 -> 2 (b0)
                                        state: 2 -> 3 (0)
                                        state: 3 -> 5 (10)
                                        add 0
                                        aid 1
                                        cnt
                                        f r0, scandone
                                        .IP: 192.168.1.215
                                        pm open,type:2 0
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        8 TSM:INIT:TSP OK
                                        12 TSF:SID:OK,ID=1
                                        14 TSM:FPAR
                                        2031 TSM:FPAR:OK
                                        2031 TSM:ID
                                        2033 TSM:ID:OK
                                        2035 TSM:UPL
                                        2166 TSM:UPL:OK
                                        5584 MCO:REG:REQ
                                        5879 MCO:BGN:STP
                                        T: 1.00
                                        H: 35.00
                                        6332 TSF:TDI:TSL
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        8 TSM:INIT:TSP OK
                                        12 TSF:SID:OK,ID=1
                                        14 TSM:FPAR
                                        3244 TSM:FPAR:OK
                                        3244 TSM:ID
                                        3246 TSM:ID:OK
                                        3248 TSM:UPL
                                        3395 TSM:UPL:OK
                                        6821 MCO:REG:REQ
                                        7129 MCO:BGN:STP
                                        T: 1.00
                                        H: 35.00
                                        7583 TSF:TDI:TSL
                                        7585 MCO:SLP:WUP=-1
                                        7587 TSF:TRI:TSB
                                        T: 31.00
                                        H: 84.00
                                        10084 TSF:TDI:TSL
                                        10088 TSF:TRI:TSB
                                        T: 42.00
                                        H: 81.00
                                        10338 TSF:TDI:TSL
                                        10342 TSF:TRI:TSB
                                        T: 31.00
                                        H: 45.00
                                        10592 TSF:TDI:TSL
                                        10596 TSF:TRI:TSB
                                        T: 2.00
                                        H: 38.00
                                        10846 TSF:TDI:TSL
                                        10852 TSF:TRI:TSB
                                        T: 28.00
                                        H: 18.00
                                        11100 TSF:TDI:TSL
                                        11104 TSF:TRI:TSB
                                        T: 43.00
                                        H: 72.00
                                        11354 TSF:TDI:TSL
                                        11360 TSF:TRI:TSB
                                        T: 8.00
                                        H: 30.00
                                        11608 TSF:TDI:TSL
                                        11612 TSF:TRI:TSB
                                        T: 3.00
                                        H: 17.00
                                        11862 TSF:TDI:TSL
                                        11868 TSF:TRI:TSB
                                        T: 40.00
                                        H: 38.00
                                        12115 TSF:TDI:TSL
                                        scandone
                                        state: 0 -> 2 (b0)
                                        state: 2 -> 3 (0)
                                        state: 3 -> 5 (10)
                                        add 0
                                        aid 1
                                        cnt
                                        f r0, scandone
                                        .IP: 192.168.1.215
                                        pm open,type:2 0
                                        Node:
                                        Gateway:
                                        On the node I used
                                        F
                                        F
                                        Floca
                                        @mfalkvidd said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
                                        The same commit as i used, freshly downloaded yesterday.
                                        2.0.0 also not running?
                                        • F Floca
                                          @Floca said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
                                          2.0.0 works
                                          2.2.0-beta works
