  2. Bug Reports
  3. RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0
betarfm69cwbug2.1.12.0.0gateway not responding
57 Posts 6 Posters 17.7k Views 3 Watching
  • F Floca
    ...on 2.0.0 or on 2.2.0?
    @Floca on 2.0.0.
    I can't do any troubleshooting unless I know I have a working configuration.
    Troubleshooting 2.2.0-beta with a configuration that I know is broken on 2.0.0 it totally useless.
    • F
      F
      Floca
      Ok, i know what you mean, that is true.
      • F
        F
        Floca
        I have researched and have found out that an arduino nano as a serial gateway also does not seem to work (same log as above).
        I hope this helps you a bit.
        • F Floca
          sundberg84S
          sundberg84S
          @Floca - A nano will fry your radio (5v SPI/data lines) but maybe you wrote the wrong mcu?
          I can comfirm that a RFM69w and Pro Mini 3.3v 8mhz works great on dev branch.
          im using this code: https://github.com/sundberg84/MySensors2.0.0/blob/master/RFM69gw/Rfm69gw.ino
          And this hardware: https://forum.mysensors.org/topic/6809/easy-newbie-pcb-rfm69-hw-w-edition-for-mysensors/16
          F 1 Reply Last reply
          • sundberg84S sundberg84
            F
            F
            Floca
            @sundberg84 said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
            whoops, i forget that, but it still works ^^
            Seems to be an Gateway problem, because the Sensor waits for the gateway...
            @mfalkvidd doublechecked my script, tht should not be the Problem :(
            • F Floca
              sundberg84S
              sundberg84S
              #31
              @Floca which controller do you use ? I have a gw and two sensors working great.
              • F
                F
                Floca
                Gateway: Wemos D1 Mini
                Nodes: Arduino Pro Mini
                • F Floca
                  sundberg84S
                  sundberg84S
                  @Floca good maybe the issue is rfm+vemos but which controller do you use?
                  • F
                    F
                    Floca
                    Oh you mean which System uses the Data?
                    I use Fhem.
                    • F Floca
                      I use Fhem.
                      sundberg84S
                      sundberg84S
                      @Floca I'm not familiar with fhem but I guess that controller hands out Id?
                      • F
                        F
                        Floca
                        I think FHEM hands it out, yes, because you can configure the ID's in the Mysensors Module.
                        ...with nRF24 the beta is no Problem with FHEM.
                        • F Floca
                          #37
                          @Floca I now have working nodes with 2.0.0. Unfortunately (at least for this troubleshooting) they also work with 2.2.0-beta.
                          Sensor 2.0.0 and Gateway 2.0.0:
                          Starting sensor (RRNNA-, 2.0.0)
                          TSM:INIT
                          TSM:RADIO:OK
                          TSP:ASSIGNID:OK (ID=1)
                          TSM:FPAR
                          TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                          TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          TSP:MSG:PAR OK (ID=0, dist=1)
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:CHKID:OK (ID=1)
                          TSM:UPL
                          TSP:PING:SEND (dest=0)
                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                          TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          TSP:MSG:PONG RECV (hops=1)
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                          !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=ok:TemperatureAndHumidity
                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
                          TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                          TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                          Request registration...
                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                          TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          Node registration=1
                          Init complete, id=1, parent=0, distance=1, registration=1
                          TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:1.0
                          T: 1.00
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:35.0
                          H: 35.00
                          0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
                          0;255;3;0;9;TSM:INIT
                          0;255;3;0;9;TSM:RADIO:OK
                          0;255;3;0;9;TSM:GW MODE
                          0;255;3;0;9;TSM:READY
                          scandone
                          state: 0 -> 2 (b0)
                          state: 2 -> 3 (0)
                          state: 3 -> 5 (10)
                          add 0
                          aid 1
                          cnt
                          connected with Mr-IoT.com, channel 2
                          dhcp client start...
                          f r0, scandone
                          ip:192.168.1.215,mask:255.255.255.0,gw:192.168.1.1
                          .IP: 192.168.1.215
                          pm open,type:2 0
                          0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSP:MSG:BC
                          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
                          0;255;3;0;9;TSP:CHKUPL:OK
                          0;255;3;0;9;TSP:MSG:GWL OK
                          0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                          0;255;3;0;9;TSP:SANCHK:OK
                          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          0;255;3;0;9;TSP:MSG:PINGED (ID=1, hops=1)
                          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:1.0
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:35.0
                          Sensor 2.2.0-beta and Gateway 2.0.0:
                          0 MCO:BGN:INIT NODE,CP=RRNNA---,VER=2.2.0-beta
                          4 TSM:INIT
                          4 TSF:WUR:MS=0
                          8 TSM:INIT:TSP OK
                          10 TSM:INIT:STATID=1
                          12 TSF:SID:OK,ID=1
                          14 TSM:FPAR
                          22 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          446 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          452 TSF:MSG:FPAR OK,ID=0,D=1
                          2031 TSM:FPAR:OK
                          2031 TSM:ID
                          2033 TSM:ID:OK
                          2035 TSM:UPL
                          2043 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          2158 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          2164 TSF:MSG:PONG RECV,HP=1
                          2166 TSM:UPL:OK
                          2168 TSM:READY:ID=1,PAR=0,DIS=1
                          2385 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          2459 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          2678 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                          2899 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                          4919 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:TemperatureAndHumidity
                          5140 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                          5359 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          5578 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                          5584 MCO:REG:REQ
                          5799 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                          5869 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          5875 MCO:PIM:NODE REG=1
                          5879 MCO:BGN:STP
                          5881 MCO:BGN:INIT OK,TSP=1
                          6098 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:1.0
                          T: 1.00
                          6318 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.0
                          H: 35.00
                          6326 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          6332 TSF:TDI:TSL
                          Gateway 2.0.0 (did not restart it from previous log):
                          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
                          Sensor 2.2.0-beta and gateway 2.2.0-beta:
                          4 TSM:INIT
                          4 TSF:WUR:MS=0
                          8 TSM:INIT:TSP OK
                          12 TSF:SID:OK,ID=1
                          14 TSM:FPAR
                          1234 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          1540 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          1546 TSF:MSG:FPAR OK,ID=0,D=1
                          3244 TSM:FPAR:OK
                          3244 TSM:ID
                          3246 TSM:ID:OK
                          3248 TSM:UPL
                          3258 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          3387 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          3393 TSF:MSG:PONG RECV,HP=1
                          3395 TSM:UPL:OK
                          3397 TSM:READY:ID=1,PAR=0,DIS=1
                          3612 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          3694 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          3915 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                          4136 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                          6154 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:TemperatureAndHumidity
                          6377 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                          6594 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          6813 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                          6821 MCO:REG:REQ
                          7034 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                          7118 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          7124 MCO:PIM:NODE REG=1
                          7129 MCO:BGN:STP
                          7131 MCO:BGN:INIT OK,TSP=1
                          7348 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:1.0
                          T: 1.00
                          7569 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.0
                          H: 35.00
                          7577 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          7583 TSF:TDI:TSL
                          7585 MCO:SLP:WUP=-1
                          7587 TSF:TRI:TSB
                          8820 !TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=NACK:31.0
                          T: 31.00
                          10070 !TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=1,st=NACK:84.0
                          H: 84.00
                          10078 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          10084 TSF:TDI:TSL
                          10086 MCO:SLP:WUP=-1
                          10088 TSF:TRI:TSB
                          10100 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=OK:42.0
                          T: 42.00
                          10323 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:81.0
                          H: 81.00
                          10332 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          10338 TSF:TDI:TSL
                          10340 MCO:SLP:WUP=-1
                          10342 TSF:TRI:TSB
                          10354 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:31.0
                          T: 31.00
                          10577 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:45.0
                          H: 45.00
                          10586 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          10592 TSF:TDI:TSL
                          10594 MCO:SLP:WUP=-1
                          10596 TSF:TRI:TSB
                          10608 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:2.0
                          T: 2.00
                          10831 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:38.0
                          H: 38.00
                          10840 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          10846 TSF:TDI:TSL
                          10848 MCO:SLP:WUP=-1
                          10852 TSF:TRI:TSB
                          10862 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.0
                          T: 28.00
                          11085 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:18.0
                          H: 18.00
                          11094 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          11100 TSF:TDI:TSL
                          11102 MCO:SLP:WUP=-1
                          11104 TSF:TRI:TSB
                          11116 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:43.0
                          T: 43.00
                          11339 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:72.0
                          H: 72.00
                          11347 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          11354 TSF:TDI:TSL
                          11358 MCO:SLP:WUP=-1
                          11360 TSF:TRI:TSB
                          11372 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:8.0
                          T: 8.00
                          11593 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:30.0
                          H: 30.00
                          11601 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          11608 TSF:TDI:TSL
                          11610 MCO:SLP:WUP=-1
                          11612 TSF:TRI:TSB
                          11626 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:3.0
                          T: 3.00
                          11847 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:17.0
                          H: 17.00
                          11855 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          11862 TSF:TDI:TSL
                          11864 MCO:SLP:WUP=-1
                          11868 TSF:TRI:TSB
                          11878 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.0
                          T: 40.00
                          12101 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:38.0
                          H: 38.00
                          12109 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          12115 TSF:TDI:TSL
                          0;255;3;0;9;5695 MCO:BGN:INIT GW,CP=RRNGE---,VER=2.2.0-beta
                          0;255;3;0;9;5757 TSF:LRT:OK
                          0;255;3;0;9;5786 TSM:INIT
                          0;255;3;0;9;5813 TSF:WUR:MS=0
                          scandone
                          state: 0 -> 2 (b0)
                          state: 2 -> 3 (0)
                          state: 3 -> 5 (10)
                          add 0
                          aid 1
                          cnt
                          0;255;3;0;9;5993 TSM:INIT:TSP OK
                          0;255;3;0;9;6027 TSM:INIT:GW MODE
                          0;255;3;0;9;6062 TSM:READY:ID=0,PAR=0,DIS=0
                          0;255;3;0;9;6108 MCO:REG:NOT NEEDED
                          f r0, scandone
                          .IP: 192.168.1.215
                          0;255;3;0;9;6647 MCO:BGN:STP
                          0;255;3;0;9;6698 MCO:BGN:INIT OK,TSP=1
                          pm open,type:2 0
                          0;255;3;0;9;40166 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:42.0
                          0;255;3;0;9;40388 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:81.0
                          0;255;3;0;9;99604 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:31.0
                          0;255;3;0;9;99826 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:45.0
                          0;255;3;0;9;159042 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:2.0
                          0;255;3;0;9;159264 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:38.0
                          0;255;3;0;9;218484 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:28.0
                          0;255;3;0;9;218706 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:18.0
                          0;255;3;0;9;277923 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:43.0
                          0;255;3;0;9;278146 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:72.0
                          0;255;3;0;9;337356 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.0
                          0;255;3;0;9;337577 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:30.0
                          0;255;3;0;9;396783 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:3.0
                          0;255;3;0;9;397005 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:17.0
                          These are the defines I used
                          Node:
                          #define MY_NODE_ID 1 // To avoid having to involve a controller
                          #define MY_RADIO_RFM69
                          #define MY_RFM69_FREQUENCY RFM69_433MHZ // RFM69_433MHZ for development branch, RF69_433MHZ for master
                          #define MY_RF69_IRQ_PIN 2
                          #define MY_RF69_SPI_CS 10
                          Gateway:
                          #define MY_RF69_IRQ_PIN D2
                          #define MY_RF69_SPI_CS D8
                          The only difference I see is that my radio modules are for 433MHz, while yours are for 868 (which is default). I don't see why it should matter, but it is a difference.
                          I used this git commit
                          commit 3e75b52c33b06c70d60eb691bd127e2f585a0c87
                          Date:   Fri Jul 7 14:36:14 2017 +0200
                          On the node I used
                          float temperature = random(1,50);
                          float humidity = random(1,100);
                          to avoid involving the DHT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:CHKID:OK (ID=1)
                            TSM:UPL
                            TSP:CHKUPL:OK
                            TSM:UPL:OK
                            TSM:READY
                            Node registration=1
                            T: 1.00
                            H: 35.00
                            scandone
                            state: 0 -> 2 (b0)
                            state: 2 -> 3 (0)
                            state: 3 -> 5 (10)
                            add 0
                            aid 1
                            cnt
                            f r0, scandone
                            .IP: 192.168.1.215
                            pm open,type:2 0
                            4 TSM:INIT
                            4 TSF:WUR:MS=0
                            8 TSM:INIT:TSP OK
                            12 TSF:SID:OK,ID=1
                            14 TSM:FPAR
                            2031 TSM:FPAR:OK
                            2031 TSM:ID
                            2033 TSM:ID:OK
                            2035 TSM:UPL
                            2166 TSM:UPL:OK
                            5584 MCO:REG:REQ
                            5879 MCO:BGN:STP
                            T: 1.00
                            H: 35.00
                            6332 TSF:TDI:TSL
                            4 TSM:INIT
                            4 TSF:WUR:MS=0
                            8 TSM:INIT:TSP OK
                            12 TSF:SID:OK,ID=1
                            14 TSM:FPAR
                            3244 TSM:FPAR:OK
                            3244 TSM:ID
                            3246 TSM:ID:OK
                            3248 TSM:UPL
                            3395 TSM:UPL:OK
                            6821 MCO:REG:REQ
                            7129 MCO:BGN:STP
                            T: 1.00
                            H: 35.00
                            7583 TSF:TDI:TSL
                            7585 MCO:SLP:WUP=-1
                            7587 TSF:TRI:TSB
                            T: 31.00
                            H: 84.00
                            10084 TSF:TDI:TSL
                            10088 TSF:TRI:TSB
                            T: 42.00
                            H: 81.00
                            10338 TSF:TDI:TSL
                            10342 TSF:TRI:TSB
                            T: 31.00
                            H: 45.00
                            10592 TSF:TDI:TSL
                            10596 TSF:TRI:TSB
                            T: 2.00
                            H: 38.00
                            10846 TSF:TDI:TSL
                            10852 TSF:TRI:TSB
                            T: 28.00
                            H: 18.00
                            11100 TSF:TDI:TSL
                            11104 TSF:TRI:TSB
                            T: 43.00
                            H: 72.00
                            11354 TSF:TDI:TSL
                            11360 TSF:TRI:TSB
                            T: 8.00
                            H: 30.00
                            11608 TSF:TDI:TSL
                            11612 TSF:TRI:TSB
                            T: 3.00
                            H: 17.00
                            11862 TSF:TDI:TSL
                            11868 TSF:TRI:TSB
                            T: 40.00
                            H: 38.00
                            12115 TSF:TDI:TSL
                            scandone
                            state: 0 -> 2 (b0)
                            state: 2 -> 3 (0)
                            state: 3 -> 5 (10)
                            add 0
                            aid 1
                            cnt
                            f r0, scandone
                            .IP: 192.168.1.215
                            pm open,type:2 0
                            Node:
                            Gateway:
                            On the node I used
                            F
                            F
                            Floca
                            @mfalkvidd said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
                            The same commit as i used, freshly downloaded yesterday.
                            2.0.0 also not running?
                            • F Floca
                              @Floca said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
                              2.0.0 works
                              2.2.0-beta works
                              • F
                                F
                                Floca
                                wrote on last edited by Floca
                                #40
                                i cant declare
                                #define MY_RFM69_IRQ_NUM
                                Is that ok for the Gateway?
                                • F Floca
                                  i cant declare
                                  @Floca what happens if you declare it?
                                  • F
                                    F
                                    Floca
                                    #42
                                    It is grey, uploads it and same thing as before.
                                    Sensor cant get the gateway, gateway stops at "pm open,type:2 0".
                                    Don't know where the problem is :/0_1500825666558_Unbennt.jpg
                                    • F Floca
                                      @Floca seems like MY_RF69_IRQ_NUM is important. If I do this
                                      //#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
                                      my gateway stops at
                                      0;255;3;0;9;6624 MCO:BGN:STP
                                      0;255;3;0;9;6675 MCO:BGN:INIT OK,TSP=1
                                      pm open,type:2 0
                                      and never receives any messages. I even had to restart the node after a flashed the gateway with IRQ_NUM defined. Before I restarted the node it wasn't able to get the transport up and running again, showing repeated !TSF:SND:TNR.
                                      • F
                                        F
                                        Floca
                                        seems that this is the problem...
                                        When it is gray, the define is not found, am i right?
                                        What would you think? Arduino IDE reinstalling or what could be the problem?
                                        • F Floca
                                          @Floca gray or not is just syntax highliting. It does not affect the compiled code. This is what mine looks like:
                                          0_1500828198558_upload-5137e11f-7ff3-409b-b5ba-d998f24bd8f8
                                          But what you did before, with setting both to D2, should work. Could you try that again, and reset the temperature node after you have uploaded the new sketch to the gateway?
