  3. Help: Some explanation requested regarding NACK
26 Posts 5 Posters 7.0k Views 4 Watching
  • O
    O
    Omemanti
    @gohan said in Help: Some explanation requested regarding NACK:
    d you try to put them just a couple of meters away from each other? Just to exclud
    how much should you advice? atm, its 3 meters.
      1-2 meters is the right distance to exclude range problem. Then also power issues could cause messages to be lost.
      • O
        O
        Omemanti
        oke,
        well will look into the lost mssg.
        But my biggest question might be, why the node thinks they are NACK, but my gate tells me their fine?
        Y gohanG 2 Replies Last reply
        • O Omemanti
          oke,
          Y
          Y
          yury
          @Omemanti said in Help: Some explanation requested regarding NACK:
          but my
          Could you post part of the code where you send those messages? do you send the node to sleep?
          • O Omemanti
            oke,
            @Omemanti Because the node can't receive the ack message so it assumes it's lost: could the the gateway didn't receive it or the node itself couldn't receive the ack from gateway. It could me many reasons, so you need to address it one by one until you find it 😀
            • O
              O
              Omemanti
              mjah, ofcourse,
              Well I'll build me some more of these, see If the same things happen with some other nodes.
              thnx for the help so far!
              • O
                O
                Omemanti
                wrote on last edited by Omemanti
                After some time off I made more nodes. but somehow they all give me NACK's. (also changed the gateway, antennas and added more caps.)
                The strange thing still is that even if I get NACK's the gateway seems the handle them..
                Should I just accept this? Or am I missing something?
                MYSController :
                291	27/07/2017 22:46:03	RX	15 - Zolder	0 - S_HUM	C_SET	NO	V_HUM	49.1
                292	27/07/2017 22:46:09	RX	15 - Zolder	1 - S_TEMP	C_SET	NO	V_TEMP	25.5
                293	27/07/2017 22:46:09	RX	15 - Zolder	0 - S_HUM	C_SET	NO	V_HUM	49.2
                294	27/07/2017 22:46:16	RX	15 - Zolder	1 - S_TEMP	C_SET	NO	V_TEMP	25.5
                295	27/07/2017 22:46:16	RX	15 - Zolder	0 - S_HUM	C_SET	NO	V_HUM	49.2
                296	27/07/2017 22:46:23	RX	15 - Zolder	1 - S_TEMP	C_SET	NO	V_TEMP	25.5
                297	27/07/2017 22:46:23	RX	15 - Zolder	0 - S_HUM	C_SET	NO	V_HUM	49.2
                Serial Monitor
                227573 !TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=5,st=NACK:49.1
                227655 !TSM:READY:UPL FAIL,STATP
                227885 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                227950 MCO:SLP:TPD
                227966 MCO:SLP:WUP=-1
                227999
                Loop
                228524 !TSF:MSG:SEND,15-15-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=NACK:25.5
                228982 !TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=1,st=NACK:49.2
                229294 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                229359 MCO:SLP:TPD
                229376 MCO:SLP:WUP=-1
                229408
                Loop
                229933 !TSF:MSG:SEND,15-15-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=NACK:25.5
                230391 !TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=3,st=NACK:49.2
                230703 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                230768 MCO:SLP:TPD
                230785 MCO:SLP:WUP=-1
                230817
                Loop
                231342 !TSF:MSG:SEND,15-15-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=4,st=NACK:25.5
                231800 !TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=5,st=NACK:49.2
                231882 !TSM:READY:UPL FAIL,STATP
                232112 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                232177 MCO:SLP:TPD
                I should add that booting up takes a couple of tries, but after a minute of the folling it pulls through and starts the previous shenanigans.
                32 TSM:INIT
                49 TSF:WUR:MS=0
                81 TSM:INIT:TSP OK
                98 TSM:INIT:STATID=15
                131 TSF:SID:OK,ID=15
                147 TSM:FPAR
                163 TSM:FPAR:STATP=0
                196 TSM:ID
                212 TSM:ID:OK
                229 TSM:UPL
                393 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                2490 TSM:UPL
                2654 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                4751 TSM:UPL
                4915 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                7012 TSM:UPL
                7176 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                9273 !TSM:UPL:FAIL
                9289 TSM:FPAR
                9306 TSM:FPAR:STATP=0
                9338 TSM:ID
                9338 TSM:ID:OK
                9371 TSM:UPL
                64274 TSM:ID
                64290 TSM:ID:OK
                64307 TSM:UPL
                64487 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                66584 TSM:UPL
                66748 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                66846 TSF:MSG:READ,0-0-15,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                66912 TSF:MSG:PONG RECV,HP=1
                66945 TSM:UPL:OK
                66961 TSM:READY:ID=15,PAR=0,DIS=1
                67158 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                69402 !TSF:MSG:SEND,15-15-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=NACK:2.1.1
                69648 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=NACK:0
                69746 TSF:MSG:READ,0-0-15,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                70172 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=11,pt=0,l=6,sg=0,ft=3,st=NACK:Zolder
                70418 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=4,st=NACK:1.0
                70860 !TSF:MSG:SEND,15-15-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=5,st=NACK:
                70942 !TSM:READY:UPL FAIL,STATP
                71286 !TSF:MSG:SEND,15-15-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
                71712 !TSF:MSG:SEND,15-15-0-0,s=2,c=0,t=4,pt=0,l=0,sg=0,ft=1,st=NACK:
                71811 MCO:REG:REQ
                71974 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=2,st=NACK:2
                74219 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=NACK:2
                76464 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=NACK:2
                78708 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=NACK:2
                78790 !TSM:READY:UPL FAIL,STATP
                80805 MCO:BGN:STP
                Si7021 Found
                Setup compleet
                80969 MCO:BGN:INIT OK,TSP=1
                  it seems as the node can't receive correctly or the gw is not sending correctly. How far are they? If you put them a couple of meters apart do you see any change?
                  • O
                    O
                    Omemanti
                    The node gateway is in the room below me (wooden floors) about 2 to 3 meters from my node.
                    • O
                      O
                      Omemanti
                      Funny Part still is, that once the connection is made, everything also if produced with a NACK is received by the controller. thats what im curious about. If I get errors, why does the controllers receive them without bottering.
                        As I said, the GW is receiving the packet correctly but then the node doesn't get a good response so it throws a NACK. You could try and put them in same room and see if gets better or change channel just to avoid a possible interference
                        • O
                          O
                          Omemanti
                          How can I change the channel? Can you point me in the right direction.?
                            Go in myconfig.h and search for "channel", you should find it in the nrf24 section, change the default channel there and recompile all your nodes and gateway
                            • O
                              O
                              Omemanti
                              Stupid question.. because I use the rfm69. Will the also comply?
                                Of course not. What version of rfm69 and frequency are you using? Are you sure you got the antenna of the right size?
                                • O
                                  O
                                  Omemanti
                                  Rfm69w 868mhz , springcoil antenna from ebay.
                                  will test a long single wire right away.
                                  • O
                                    O
                                    Omemanti
                                    Springcoil on the gw, straight line on the node, still the same
                                    • O
                                      O
                                      Omemanti
                                      Thnx for the help so far, Ill let it rest for a while, Im thinking of rebuilding the whole thing..
                                      K 1 Reply Last reply
                                      • O Omemanti
                                        K
                                        K
                                        kiesel
                                        @Omemanti
                                        Where you able to solve this? I am also experiencing a lot of NACKs in my rfm69 network (868mhz)
                                        O 1 Reply Last reply
                                        • K kiesel
                                          @Omemanti
                                          O
                                          O
                                          Omemanti
                                          @kiesel said in Help: Some explanation requested regarding NACK:
                                          Nope, not that I can remember.
                                          BTW: I ditched the rfm69 and moved over to the NRF52.
                                          R 1 Reply Last reply
