  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 329.8k Views 52 Watching
  • tombstoneT
    tombstoneT
    tombstone
    Domoticz LOOKS :-D GOOD
    BUT new to all this :-D
    • Black CatB
      Black CatB
      Black Cat
      If you are looking for Software, try openhab.
      You need to buy Vera, but the software is free.
      tombstoneT 1 Reply Last reply
      • Black CatB Black Cat
        tombstoneT
        tombstoneT
        tombstone
        @Black-Cat thanks 😁
        • tombstoneT
          tombstoneT
          tombstone
          ok so when adding to Domoticz..
          I go to hardware...
          I name is..... test...
          then choose.. MySensors Gateway with LAN interface....
          Data Timeout: .... Disabled.....
          Remote Address.... (I have tryed)....
          IP Address, Subnet Mask, Default Gateway, Primary DNS, Secondary DNS.
          (i try everythinbg I can think of and still not work)
          Port: ... 5003
          My pro min has the red light on and blink blue occassionally.
          what I get from the Domoticz log is
          2017-07-30 18:00:00.627 Error: MySensors: Can not connect to: 61.9.211.33:5003
          2017-07-30 18:00:00.627 TCP: Connection problem (Unable to connect to specified IP/Port)
          2017-07-30 18:00:00.627 TCP: Reconnecting in 30 seconds...
          • tbowmoT
            tbowmoT
            tbowmo
            @tombstone
            What hardware are you using for the gateway? Arduino, Sensebender GW, ESP8266, is it wired or wireless?
            Does it get an IP address from your router?
            Can you successfully telnet to the above IP address on port 5003? (And what is the output)
            Does the gateway send any logs to the serial port? If yes, then post them on the forum.
            • tbowmoT tbowmo
              @tombstone
              tombstoneT
              tombstoneT
              tombstone
              @tbowmo
              The hardware I'am using for the gateway is the Arduino pro mini and its wireless from the NRF24L01+ 2.4GHz Wireless Transceiver
              I don't know if it is getting IP address from my router.
              have not use telnet before (I have just youtube it and enabled it... all what i got from youtube was that you can send email lol cool)
              Does the gateway send any logs to the serial port? If yes, then post them on the forum. (were do I get them logs the ones from Domoticz and below but not much info to go on)
              Thanks :-D
              • tbowmoT
                tbowmoT
                tbowmo
                @tombstone
                How is the promini connected to the device runnning domoticz?
                To me it sounds like that you have the promini connected directly to your computer where domoticz is running, then you should add it as a serial gateway, and not ethernet gateway
                If you haven't already done this, I suggest that you read about the mysensors network so you have a basic understanding on how mysensors works.
                • tbowmoT tbowmo
                  @tombstone
                  tombstoneT
                  tombstoneT
                  tombstone
                  wrote on last edited by tombstone
                  #317
                  @tbowmo
                  I have it runing both ways but with serial gateway there no errors but when going to setup there is no NODES.
                  2017-07-30 19:20:55.764 TCP: Connection problem (Unable to connect to specified IP/Port)
                  2017-07-30 19:20:55.766 TCP: Reconnecting in 30 seconds...
                  2017-07-30 19:21:26.035 TCP: Reconnecting...
                  2017-07-30 19:21:37.093 MySensors: TCP/IP Worker stopped...
                  2017-07-30 19:27:03.150 MySensors: Using serial port: COM4
                  • tombstoneT tombstone
                    @tbowmo
                    tombstoneT
                    tombstoneT
                    tombstone
                    #318
                    @tombstone
                    //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
                    IS there someing I have missed with adding NODES???
                    gohanG 1 Reply Last reply
                    • tombstoneT
                      tombstoneT
                      tombstone
                      3 TSM:INIT
                      4 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      13 TSM:FPAR
                      15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      2022 !TSM:FPAR:NO REPLY
                      2024 TSM:FPAR
                      2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      4034 !TSM:FPAR:NO REPLY
                      4036 TSM:FPAR
                      4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      6046 !TSM:FPAR:NO REPLY
                      6048 TSM:FPAR
                      6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      8058 !TSM:FPAR:FAIL
                      8059 TSM:FAIL:CNT=1
                      8061 TSM:FAIL:PDT
                      18065 TSM:FAIL:RE-INIT
                      18067 TSM:INIT
                      18074 TSM:INIT:TSP OK
                      18076 TSM:FPAR
                      18078 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      20086 !TSM:FPAR:NO REPLY
                      20088 TSM:FPAR
                      20090 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      22099 !TSM:FPAR:NO REPLY
                      22102 TSM:FPAR
                      22104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      24112 !TSM:FPAR:NO REPLY
                      24114 TSM:FPAR
                      24116 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      26124 !TSM:FPAR:FAIL
                      26125 TSM:FAIL:CNT=2
                      26127 TSM:FAIL:PDT
                      36130 TSM:FAIL:RE-INIT
                      36132 TSM:INIT
                      36140 TSM:INIT:TSP OK
                      36142 TSM:FPAR
                      36144 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      38152 !TSM:FPAR:NO REPLY
                      38154 TSM:FPAR
                      38156 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      40164 !TSM:FPAR:NO REPLY
                      40166 TSM:FPAR
                      40168 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      42176 !TSM:FPAR:NO REPLY
                      42178 TSM:FPAR
                      42180 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      44188 !TSM:FPAR:FAIL
                      44189 TSM:FAIL:CNT=3
                      44191 TSM:FAIL:PDT
                      54194 TSM:FAIL:RE-INIT
                      54196 TSM:INIT
                      54203 TSM:INIT:TSP OK
                      54205 TSM:FPAR
                      54207 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      56215 !TSM:FPAR:NO REPLY
                      56217 TSM:FPAR
                      56219 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      58227 !TSM:FPAR:NO REPLY
                      58229 TSM:FPAR
                      58231 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      60239 !TSM:FPAR:NO REPLY
                      60241 TSM:FPAR
                      60243 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      62252 !TSM:FPAR:FAIL
                      62254 TSM:FAIL:CNT=4
                      62255 TSM:FAIL:PDT
                      72258 TSM:FAIL:RE-INIT
                      72260 TSM:INIT
                      72267 TSM:INIT:TSP OK
                      72269 TSM:FPAR
                      72271 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      74280 !TSM:FPAR:NO REPLY
                      74283 TSM:FPAR
                      74285 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      76293 !TSM:FPAR:NO REPLY
                      76295 TSM:FPAR
                      76297 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      78305 !TSM:FPAR:NO REPLY
                      78307 TSM:FPAR
                      78309 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      80317 !TSM:FPAR:FAIL
                      80318 TSM:FAIL:CNT=5
                      80320 TSM:FAIL:PDT
                      90323 TSM:FAIL:RE-INIT
                      90326 TSM:INIT
                      90333 TSM:INIT:TSP OK
                      90335 TSM:FPAR
                      90337 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      92345 !TSM:FPAR:NO REPLY
                      92347 TSM:FPAR
                      92349 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      94357 !TSM:FPAR:NO REPLY
                      94359 TSM:FPAR
                      94361 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      96369 !TSM:FPAR:NO REPLY
                      96371 TSM:FPAR
                      96373 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      98381 !TSM:FPAR:FAIL
                      98383 TSM:FAIL:CNT=6
                      98384 TSM:FAIL:PDT
                      108387 TSM:FAIL:RE-INIT
                      108389 TSM:INIT
                      108396 TSM:INIT:TSP OK
                      108398 TSM:FPAR
                      108401 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      110408 !TSM:FPAR:NO REPLY
                      110410 TSM:FPAR
                      110413 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      112420 !TSM:FPAR:NO REPLY
                      112422 TSM:FPAR
                      112425 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      114433 !TSM:FPAR:NO REPLY
                      114435 TSM:FPAR
                      114438 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      116445 !TSM:FPAR:FAIL
                      116447 TSM:FAIL:CNT=7
                      116449 TSM:FAIL:PDT
                      This is my debug log. will like to know if there some thing I missed as I learning thanks :+1:
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @tombstone
                        Just to be sure, you have one pro mini with NRF24 working as a gateway, connected to your computer?
                        And then you have one (or more) pro minis also with NRF24, acting as nodes?
                          @tombstone
                          @tombstone said in Irrigation Controller (up to 16 valves with Shift Registers):
                          @tombstone
                          yuo need to uncomment that line
                          tbowmoT 1 Reply Last reply
                            @tombstone
                            tbowmoT
                            tbowmoT
                            tbowmo
                            @gohan
                            Only if he won't use auto id assignment from domoticz.
                            tombstoneT gohanG 2 Replies Last reply
                            • tbowmoT tbowmo
                              @tombstone
                              tombstoneT
                              tombstoneT
                              tombstone
                              #323
                              @tbowmo
                              I habe one pro mini with NRF24 and, connected to my computer. I have done everything from the video up too 22mins were I got stuck.
                              • tbowmoT tbowmo
                                @gohan
                                tombstoneT
                                tombstoneT
                                tombstone
                                #324
                                @tbowmo
                                Do the debug log. Look normal.. don't know how to read.
                                3 TSM:INIT
                                4 TSF:WUR:MS=0
                                11 TSM:INIT:TSP OK
                                13 TSM:FPAR
                                2024 TSM:FPAR
                                4036 TSM:FPAR
                                6048 TSM:FPAR
                                8058 !TSM:FPAR:FAIL
                                8059 TSM:FAIL:CNT=1
                                8061 TSM:FAIL:PDT
                                18067 TSM:INIT
                                18076 TSM:FPAR
                                20088 TSM:FPAR
                                22102 TSM:FPAR
                                24114 TSM:FPAR
                                26127 TSM:FAIL:PDT
                                36132 TSM:INIT
                                36142 TSM:FPAR
                                38154 TSM:FPAR
                                40166 TSM:FPAR
                                42178 TSM:FPAR
                                44191 TSM:FAIL:PDT
                                54196 TSM:INIT
                                54205 TSM:FPAR
                                56217 TSM:FPAR
                                58229 TSM:FPAR
                                60241 TSM:FPAR
                                62255 TSM:FAIL:PDT
                                72260 TSM:INIT
                                72269 TSM:FPAR
                                74283 TSM:FPAR
                                76295 TSM:FPAR
                                78307 TSM:FPAR
                                80320 TSM:FAIL:PDT
                                90326 TSM:INIT
                                90335 TSM:FPAR
                                92347 TSM:FPAR
                                94359 TSM:FPAR
                                96371 TSM:FPAR
                                98384 TSM:FAIL:PDT
                                108389 TSM:INIT
                                108398 TSM:FPAR
                                110410 TSM:FPAR
                                112422 TSM:FPAR
                                114435 TSM:FPAR
                                116449 TSM:FAIL:PDT
                                there alot of failing
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @tombstone
                                  It seems that you have not read up on how mysensors works.. The purpose of mysensors is to create wireless sensors. To do this, we normally have a gateway connected to a computer running some kind of controller software.
                                  Then we have sensor nodes that transmit (wireless) sensor data to the gateway which sends this to the controller software.
                                  Again, please read up on how mysensors are designed, find more here https://www.mysensors.org/about
                                  tombstoneT G 2 Replies Last reply
                                  • tbowmoT tbowmo
                                    @tombstone
                                    tombstoneT
                                    tombstoneT
                                    tombstone
                                    #326
                                    @tbowmo
                                    can you tell me if I got this wrong
                                    The "brain" is my pro min
                                    "The radio" is nRF24
                                    the brain (promiin) get and sends info to the (Radio)
                                    the controller (my PC that is running Domoticz)" gets and send info to the radio.
                                    That's how I get it after reading :-(
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      But how are the radio connected to your pc then? :) that needs an arduino as well.
                                      To have a functional mysensors network, you usually have 2 (or more) arduino compatible boards. One of thar m running SerialGateway (or another suitable sketch) with NRF24 connected. This connect to the computer running domoticz
                                      Then you have all the sensor nodes, they are also running on arduino compatible hardware (but separate to the gateway hardware), also with radio connected. THIS is running your sensor sketches, and communicates with the gateway arduino via the NRF24 radios.
                                      When the gateway receives messages on the NRF24, it sends these via UART to the computer at which you are running domoticz (or any other suitable controller software).
                                      • tbowmoT tbowmo
                                        @gohan
                                        @tbowmo according to the log nothing is assigning any ID :D
                                          @gohan where do you see that? I can't see anything in the log about id assignment.
