  3. nRF5 action!
nRF5 action!
    Check on adafruits feather reference they use two resistors as a voltage divider for that simple and effective.
    I'm not finding it. Do you have a link?
    Mike_Lemo
    @NeverDie but a much better but more expensive solution would be a lipo fuel guage from spark fun they use a Max chip for that.
    • Nca78N
      If supplied with less than 3.6V you can do it with ADC, 1.2V voltage reference and 1/3 prescaling.
      But I've only looked at the theory yet.
      Rules are Vdd+0.3V max at the pin, and max 2.4V as input of ADC (after prescaling)
      d00616D 1 Reply Last reply
        #429
        Well, as you all know, on the atmega328p you can read the 1.1v gap voltage using the battery voltage as the reference voltage, by doing analogRead(A0), and from just that one measurement then calculate the battery voltage by doing a little bit of math. So, I'm just wondering what the code is to do the equivalent of that (using 1.2v instead of 1.1v) on the nRF52832.
        • Nca78N Nca78
          d00616D
          d00616D
          d00616
          For this, you can use the implemented hwCPUVoltage() function. Reading the voltage costs nRF51: 260µA/20µs | nRF52: 700µA/3µs
            #431
            hwCPUVoltage()
            I'm finally installing Visual Micro, because I hope it will help me quickly find where all these functions are defined. With all these new layers, the Arduino IDE is just no longer cutting it.
            NeverDieN scalzS TerrenceT 3 Replies Last reply
              hwCPUVoltage()
              #432
              LOL. Well, Visual Micro found it alright, but just in the wrong place. It found it in MyHwAVR.cpp
                hwCPUVoltage()
                hwCPUVoltage()
                good choice :+1:
                for nrf5, the function is located in MyHwNRF5.cpp
                • d00616D d00616
                  #434
                  I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage. So, probably I just need to do a pin mapping so that it reads the voltage on the proper pin. But which pin/mapping would it be? I thought that Vcc wouldn't really be mappable to anything but Vcc. I guess whichever analog pin (if that's what it is?) is connected to Vcc on the nRF52 DK is the pin I need to find and re-map to its equivalent pin on the Ebyte module. Hmmm.... I'll have to look into which one that would be.
                    #435
                    Actually, something different may be going on. Here's the function definition:
                    uint16_t hwCPUVoltage()
                    #if defined(NRF_ADC)
                    	// NRF51:
                    	// 20uS@260uA
                    	NRF_LPCOMP->ENABLE = 0;
                    	// Enable and configure ADC
                    	NRF_ADC->ENABLE = 1;
                    	NRF_ADC->EVENTS_END = 0;
                    	NRF_ADC->TASKS_START = 1;
                    	while(!NRF_ADC->EVENTS_END);
                    	NRF_ADC->TASKS_STOP = 1;
                    	NRF_ADC->ENABLE = 0;
                    	// Restore LPCOMP state
                    	return (sample*3600)/255;
                    #elif defined(NRF_SAADC)
                    	// NRF52:
                    	// Sampling time 3uS@700uA
                    	int32_t sample;
                    	NRF_SAADC->RESULT.MAXCNT = 1;
                    	NRF_SAADC->TASKS_START = 1;
                    	NRF_SAADC->EVENTS_END = 0;
                    	NRF_SAADC->TASKS_SAMPLE = 1;
                    	NRF_SAADC->TASKS_STOP = 1;
                    	// unknown MCU
                    	return 0;
                    One, perhaps likely, theory would be that it doesn't recognize the MCU, which would explain why it returns the value of zero. Well, to debug that, I added the Serial.println(...) statements into the library code (see above) in an attempt to see which of the if-else branches is being taken, but none of the Serial.println(...)'s were printed! Here's a sample of the output from the Ebyte Module:
                    332641 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    332968 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    332973 TSF:MSG:FPAR OK,ID=0,D=1
                    334649 TSM:FPAR:OK
                    334650 TSM:ID
                    334651 TSM:ID:REQ
                    334654 TSF:MSG:SEND,255-255-0-0,s=59,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    336662 TSM:ID
                    336663 TSM:ID:REQ
                    336665 TSF:MSG:SEND,255-255-0-0,s=23,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    338673 TSM:ID
                    338674 TSM:ID:REQ
                    338676 TSF:MSG:SEND,255-255-0-0,s=242,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    340684 TSM:ID
                    340685 TSM:ID:REQ
                    340687 TSF:MSG:SEND,255-255-0-0,s=205,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    342695 !TSM:ID:FAIL
                    342696 TSM:FAIL:CNT=7
                    342698 TSM:FAIL:DIS
                    342700 TSF:TDI:TSL
                    402703 TSM:FAIL:RE-INIT
                    402705 TSM:INIT
                    402706 TSM:INIT:TSP OK
                    402708 TSM:FPAR
                    402711 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    403472 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    403478 TSF:MSG:FPAR OK,ID=0,D=1
                    404719 TSM:FPAR:OK
                    404720 TSM:ID
                    404721 TSM:ID:REQ
                    404724 TSF:MSG:SEND,255-255-0-0,s=241,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    406732 TSM:ID
                    406733 TSM:ID:REQ
                    406735 TSF:MSG:SEND,255-255-0-0,s=205,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    408743 TSM:ID
                    408744 TSM:ID:REQ
                    408747 TSF:MSG:SEND,255-255-0-0,s=168,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    410754 TSM:ID
                    410755 TSM:ID:REQ
                    410757 TSF:MSG:SEND,255-255-0-0,s=131,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    412765 !TSM:ID:FAIL
                    412766 TSM:FAIL:CNT=7
                    412768 TSM:FAIL:DIS
                    412770 TSF:TDI:TSL
                    472773 TSM:FAIL:RE-INIT
                    472775 TSM:INIT
                    472776 TSM:INIT:TSP OK
                    472778 TSM:FPAR
                    472781 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    472955 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    472960 TSF:MSG:FPAR OK,ID=0,D=1
                    474789 TSM:FPAR:OK
                    474790 TSM:ID
                    474791 TSM:ID:REQ
                    474794 TSF:MSG:SEND,255-255-0-0,s=167,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    476802 TSM:ID
                    476803 TSM:ID:REQ
                    476805 TSF:MSG:SEND,255-255-0-0,s=131,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    478813 TSM:ID
                    478814 TSM:ID:REQ
                    478816 TSF:MSG:SEND,255-255-0-0,s=94,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    480824 TSM:ID
                    480825 TSM:ID:REQ
                    480827 TSF:MSG:SEND,255-255-0-0,s=57,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    482835 !TSM:ID:FAIL
                    482836 TSM:FAIL:CNT=7
                    482838 TSM:FAIL:DIS
                    482840 TSF:TDI:TSL
                    I'm not quite sure how to interpret that, but pretty clearly it doesn't contain the println's that I was expecting.
                    Any theories as to what's going on?
                      Bracketing that and setting it aside, I do now notice this line in the BatteryPoweredSensor demo sketch:
                      So, if I map that A0 in the sketch to the A0 of the Ebyte Module, then maybe (hopefully) the voltage measurement will work on the Ebyte Module. I'll give it a try.
                        #437
                        Unfortunately, after I add:
                        #include <mySensors.h>
                        the locus of control goes somewhere else (I guess the gateway or something?). Anyhow, it makes this very hard to debug.
                        For instance, the pin of interest is PIN_AIN0. I can't find where it's defined, and I can't print out its value either, because of this locus of control issue.
                        Anyhow, I think I may wait for others to get up and running with their modules, and start facing the same issues. Maybe then we can help each other figure this stuff out.
                        • d00616D
                          d00616D
                          d00616
                          @NeverDie I don't know why the println() doesn't work. There is an "DEBUG_OUTPUT(x, ##VA_ARGS)" macro, you can use when debug is enabled.
                          NRF_ADC is the nRF51 ADC and NRF_SAADC is the ADC of the nRF52. They are defined when "nrf.h" is included.
                          • d00616D d00616
                            The nRF52832 Ebyte Module.
                              hwCPUVoltage()
                              TerrenceT
                              TerrenceT
                              Terrence
                              @NeverDie VS Code with the Arduino Extension is your friend.
                              • d00616D d00616
                                #441
                                • TerrenceT Terrence
                                  #442
                                    #443
                                    //#define MY_RADIO_NRF24
                                    #define MY_RADIO_NRF5_ESB
                                    //#include <MySensors.h>
                                    int oldBatteryPcnt = 0;
                                    uint16_t counter=0;
                                    uint16_t volts=0;
                                    uint16_t theHwCPUVoltage()
                                      // NRF51:
                                      // 20uS@260uA
                                      // NRF52:
                                      int32_t sample;
                                      // unknown MCU
                                      return 0;
                                      while (true) {
                                        volts=theHwCPUVoltage();
                                        Serial.print("counter=");
                                        Serial.print(counter++);
                                        Serial.println(volts);
                                    //#else
                                    //	analogReference(INTERNAL);
                                    //#endif
                                        d00616D
                                        d00616D
                                        d00616
                                          mtiutiuM 1 Reply Last reply
