  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • d00616D d00616
    If supplied with less than 3.6V you can do it with ADC, 1.2V voltage reference and 1/3 prescaling.
    But I've only looked at the theory yet.
    For this, you can use the implemented hwCPUVoltage() function. Reading the voltage costs nRF51: 260µA/20µs | nRF52: 700µA/3µs
    #434
    I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage. So, probably I just need to do a pin mapping so that it reads the voltage on the proper pin. But which pin/mapping would it be? I thought that Vcc wouldn't really be mappable to anything but Vcc. I guess whichever analog pin (if that's what it is?) is connected to Vcc on the nRF52 DK is the pin I need to find and re-map to its equivalent pin on the Ebyte module. Hmmm.... I'll have to look into which one that would be.
    d00616D 1 Reply Last reply
      #435
      Actually, something different may be going on. Here's the function definition:
      uint16_t hwCPUVoltage()
      #if defined(NRF_ADC)
      	// NRF51:
      	// 20uS@260uA
      	NRF_LPCOMP->ENABLE = 0;
      	// Enable and configure ADC
      	NRF_ADC->ENABLE = 1;
      	NRF_ADC->EVENTS_END = 0;
      	NRF_ADC->TASKS_START = 1;
      	while(!NRF_ADC->EVENTS_END);
      	NRF_ADC->TASKS_STOP = 1;
      	NRF_ADC->ENABLE = 0;
      	// Restore LPCOMP state
      	return (sample*3600)/255;
      #elif defined(NRF_SAADC)
      	// NRF52:
      	// Sampling time 3uS@700uA
      	int32_t sample;
      	NRF_SAADC->RESULT.MAXCNT = 1;
      	NRF_SAADC->TASKS_START = 1;
      	NRF_SAADC->EVENTS_END = 0;
      	NRF_SAADC->TASKS_SAMPLE = 1;
      	NRF_SAADC->TASKS_STOP = 1;
      	// unknown MCU
      	return 0;
      One, perhaps likely, theory would be that it doesn't recognize the MCU, which would explain why it returns the value of zero. Well, to debug that, I added the Serial.println(...) statements into the library code (see above) in an attempt to see which of the if-else branches is being taken, but none of the Serial.println(...)'s were printed! Here's a sample of the output from the Ebyte Module:
      332641 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      332968 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      332973 TSF:MSG:FPAR OK,ID=0,D=1
      334649 TSM:FPAR:OK
      334650 TSM:ID
      334651 TSM:ID:REQ
      334654 TSF:MSG:SEND,255-255-0-0,s=59,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      336662 TSM:ID
      336663 TSM:ID:REQ
      336665 TSF:MSG:SEND,255-255-0-0,s=23,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      338673 TSM:ID
      338674 TSM:ID:REQ
      338676 TSF:MSG:SEND,255-255-0-0,s=242,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      340684 TSM:ID
      340685 TSM:ID:REQ
      340687 TSF:MSG:SEND,255-255-0-0,s=205,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      342695 !TSM:ID:FAIL
      342696 TSM:FAIL:CNT=7
      342698 TSM:FAIL:DIS
      342700 TSF:TDI:TSL
      402703 TSM:FAIL:RE-INIT
      402705 TSM:INIT
      402706 TSM:INIT:TSP OK
      402708 TSM:FPAR
      402711 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      403472 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      403478 TSF:MSG:FPAR OK,ID=0,D=1
      404719 TSM:FPAR:OK
      404720 TSM:ID
      404721 TSM:ID:REQ
      404724 TSF:MSG:SEND,255-255-0-0,s=241,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      406732 TSM:ID
      406733 TSM:ID:REQ
      406735 TSF:MSG:SEND,255-255-0-0,s=205,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      408743 TSM:ID
      408744 TSM:ID:REQ
      408747 TSF:MSG:SEND,255-255-0-0,s=168,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      410754 TSM:ID
      410755 TSM:ID:REQ
      410757 TSF:MSG:SEND,255-255-0-0,s=131,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      412765 !TSM:ID:FAIL
      412766 TSM:FAIL:CNT=7
      412768 TSM:FAIL:DIS
      412770 TSF:TDI:TSL
      472773 TSM:FAIL:RE-INIT
      472775 TSM:INIT
      472776 TSM:INIT:TSP OK
      472778 TSM:FPAR
      472781 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      472955 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      472960 TSF:MSG:FPAR OK,ID=0,D=1
      474789 TSM:FPAR:OK
      474790 TSM:ID
      474791 TSM:ID:REQ
      474794 TSF:MSG:SEND,255-255-0-0,s=167,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      476802 TSM:ID
      476803 TSM:ID:REQ
      476805 TSF:MSG:SEND,255-255-0-0,s=131,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      478813 TSM:ID
      478814 TSM:ID:REQ
      478816 TSF:MSG:SEND,255-255-0-0,s=94,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      480824 TSM:ID
      480825 TSM:ID:REQ
      480827 TSF:MSG:SEND,255-255-0-0,s=57,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      482835 !TSM:ID:FAIL
      482836 TSM:FAIL:CNT=7
      482838 TSM:FAIL:DIS
      482840 TSF:TDI:TSL
      I'm not quite sure how to interpret that, but pretty clearly it doesn't contain the println's that I was expecting.
      Any theories as to what's going on?
        Bracketing that and setting it aside, I do now notice this line in the BatteryPoweredSensor demo sketch:
        So, if I map that A0 in the sketch to the A0 of the Ebyte Module, then maybe (hopefully) the voltage measurement will work on the Ebyte Module. I'll give it a try.
          #437
          Unfortunately, after I add:
          #include <mySensors.h>
          the locus of control goes somewhere else (I guess the gateway or something?). Anyhow, it makes this very hard to debug.
          For instance, the pin of interest is PIN_AIN0. I can't find where it's defined, and I can't print out its value either, because of this locus of control issue.
          Anyhow, I think I may wait for others to get up and running with their modules, and start facing the same issues. Maybe then we can help each other figure this stuff out.
          • d00616D
            d00616D
            d00616
            @NeverDie I don't know why the println() doesn't work. There is an "DEBUG_OUTPUT(x, ##VA_ARGS)" macro, you can use when debug is enabled.
            NRF_ADC is the nRF51 ADC and NRF_SAADC is the ADC of the nRF52. They are defined when "nrf.h" is included.
            • d00616D d00616
              The nRF52832 Ebyte Module.
                hwCPUVoltage()
                I'm finally installing Visual Micro, because I hope it will help me quickly find where all these functions are defined. With all these new layers, the Arduino IDE is just no longer cutting it.
                TerrenceT
                TerrenceT
                Terrence
                @NeverDie VS Code with the Arduino Extension is your friend.
                • d00616D d00616
                  #441
                  • TerrenceT Terrence
                    #442
                      #443
                      //#define MY_RADIO_NRF24
                      #define MY_RADIO_NRF5_ESB
                      //#include <MySensors.h>
                      int oldBatteryPcnt = 0;
                      uint16_t counter=0;
                      uint16_t volts=0;
                      uint16_t theHwCPUVoltage()
                        // NRF51:
                        // 20uS@260uA
                        // NRF52:
                        int32_t sample;
                        // unknown MCU
                        return 0;
                        while (true) {
                          volts=theHwCPUVoltage();
                          Serial.print("counter=");
                          Serial.print(counter++);
                          Serial.println(volts);
                      //#else
                      //	analogReference(INTERNAL);
                      //#endif
                          d00616D
                          d00616D
                          d00616
                            mtiutiuM 1 Reply Last reply
                                Mike_Lemo
                                @NeverDie Dam you why would you make it so wide? can it fit on a single bread board?
                                • M Mike_Lemo
                                  #449
                                  Sorry, you'll need two.
                                    mtiutiuM
                                    mtiutiuM
                                    mtiutiu
                                    #450
                                    • mtiutiuM mtiutiu
                                      Here: https://www.aliexpress.com/item/NRF52832-Bluetooth-4-2-module-Bluetooth-5-program-PCBA-serial-transmission-cost-effective/32818791344.html?spm=a2g0s.9042311.0.0.jWh9gH
                                      Nca78N 1 Reply Last reply
                                        @NeverDie I guess you don't need to make a breakout board for those, your spare NModules will do if you use the "PA/LNA" radio footprint ;)
                                        • Nca78N Nca78
                                          @Nca78
                                          Thanks! Good to know.
