  3. nRF5 action!
nRF5 action!
    hwCPUVoltage()
    I'm finally installing Visual Micro, because I hope it will help me quickly find where all these functions are defined. With all these new layers, the Arduino IDE is just no longer cutting it.
    #432
    LOL. Well, Visual Micro found it alright, but just in the wrong place. It found it in MyHwAVR.cpp
      hwCPUVoltage()
      hwCPUVoltage()
      good choice :+1:
      for nrf5, the function is located in MyHwNRF5.cpp
      • d00616D d00616
        If supplied with less than 3.6V you can do it with ADC, 1.2V voltage reference and 1/3 prescaling.
        But I've only looked at the theory yet.
        For this, you can use the implemented hwCPUVoltage() function. Reading the voltage costs nRF51: 260µA/20µs | nRF52: 700µA/3µs
        #434
        I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage. So, probably I just need to do a pin mapping so that it reads the voltage on the proper pin. But which pin/mapping would it be? I thought that Vcc wouldn't really be mappable to anything but Vcc. I guess whichever analog pin (if that's what it is?) is connected to Vcc on the nRF52 DK is the pin I need to find and re-map to its equivalent pin on the Ebyte module. Hmmm.... I'll have to look into which one that would be.
        d00616D 1 Reply Last reply
          #435
          Actually, something different may be going on. Here's the function definition:
          uint16_t hwCPUVoltage()
          #if defined(NRF_ADC)
          	// NRF51:
          	// 20uS@260uA
          	NRF_LPCOMP->ENABLE = 0;
          	// Enable and configure ADC
          	NRF_ADC->ENABLE = 1;
          	NRF_ADC->EVENTS_END = 0;
          	NRF_ADC->TASKS_START = 1;
          	while(!NRF_ADC->EVENTS_END);
          	NRF_ADC->TASKS_STOP = 1;
          	NRF_ADC->ENABLE = 0;
          	// Restore LPCOMP state
          	return (sample*3600)/255;
          #elif defined(NRF_SAADC)
          	// NRF52:
          	// Sampling time 3uS@700uA
          	int32_t sample;
          	NRF_SAADC->RESULT.MAXCNT = 1;
          	NRF_SAADC->TASKS_START = 1;
          	NRF_SAADC->EVENTS_END = 0;
          	NRF_SAADC->TASKS_SAMPLE = 1;
          	NRF_SAADC->TASKS_STOP = 1;
          	// unknown MCU
          	return 0;
          One, perhaps likely, theory would be that it doesn't recognize the MCU, which would explain why it returns the value of zero. Well, to debug that, I added the Serial.println(...) statements into the library code (see above) in an attempt to see which of the if-else branches is being taken, but none of the Serial.println(...)'s were printed! Here's a sample of the output from the Ebyte Module:
          332641 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          332968 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          332973 TSF:MSG:FPAR OK,ID=0,D=1
          334649 TSM:FPAR:OK
          334650 TSM:ID
          334651 TSM:ID:REQ
          334654 TSF:MSG:SEND,255-255-0-0,s=59,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          336662 TSM:ID
          336663 TSM:ID:REQ
          336665 TSF:MSG:SEND,255-255-0-0,s=23,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          338673 TSM:ID
          338674 TSM:ID:REQ
          338676 TSF:MSG:SEND,255-255-0-0,s=242,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          340684 TSM:ID
          340685 TSM:ID:REQ
          340687 TSF:MSG:SEND,255-255-0-0,s=205,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          342695 !TSM:ID:FAIL
          342696 TSM:FAIL:CNT=7
          342698 TSM:FAIL:DIS
          342700 TSF:TDI:TSL
          402703 TSM:FAIL:RE-INIT
          402705 TSM:INIT
          402706 TSM:INIT:TSP OK
          402708 TSM:FPAR
          402711 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          403472 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          403478 TSF:MSG:FPAR OK,ID=0,D=1
          404719 TSM:FPAR:OK
          404720 TSM:ID
          404721 TSM:ID:REQ
          404724 TSF:MSG:SEND,255-255-0-0,s=241,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          406732 TSM:ID
          406733 TSM:ID:REQ
          406735 TSF:MSG:SEND,255-255-0-0,s=205,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          408743 TSM:ID
          408744 TSM:ID:REQ
          408747 TSF:MSG:SEND,255-255-0-0,s=168,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          410754 TSM:ID
          410755 TSM:ID:REQ
          410757 TSF:MSG:SEND,255-255-0-0,s=131,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          412765 !TSM:ID:FAIL
          412766 TSM:FAIL:CNT=7
          412768 TSM:FAIL:DIS
          412770 TSF:TDI:TSL
          472773 TSM:FAIL:RE-INIT
          472775 TSM:INIT
          472776 TSM:INIT:TSP OK
          472778 TSM:FPAR
          472781 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          472955 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          472960 TSF:MSG:FPAR OK,ID=0,D=1
          474789 TSM:FPAR:OK
          474790 TSM:ID
          474791 TSM:ID:REQ
          474794 TSF:MSG:SEND,255-255-0-0,s=167,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          476802 TSM:ID
          476803 TSM:ID:REQ
          476805 TSF:MSG:SEND,255-255-0-0,s=131,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          478813 TSM:ID
          478814 TSM:ID:REQ
          478816 TSF:MSG:SEND,255-255-0-0,s=94,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          480824 TSM:ID
          480825 TSM:ID:REQ
          480827 TSF:MSG:SEND,255-255-0-0,s=57,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          482835 !TSM:ID:FAIL
          482836 TSM:FAIL:CNT=7
          482838 TSM:FAIL:DIS
          482840 TSF:TDI:TSL
          I'm not quite sure how to interpret that, but pretty clearly it doesn't contain the println's that I was expecting.
          Any theories as to what's going on?
            Bracketing that and setting it aside, I do now notice this line in the BatteryPoweredSensor demo sketch:
            So, if I map that A0 in the sketch to the A0 of the Ebyte Module, then maybe (hopefully) the voltage measurement will work on the Ebyte Module. I'll give it a try.
              #437
              Unfortunately, after I add:
              #include <mySensors.h>
              the locus of control goes somewhere else (I guess the gateway or something?). Anyhow, it makes this very hard to debug.
              For instance, the pin of interest is PIN_AIN0. I can't find where it's defined, and I can't print out its value either, because of this locus of control issue.
              Anyhow, I think I may wait for others to get up and running with their modules, and start facing the same issues. Maybe then we can help each other figure this stuff out.
              • d00616D
                d00616D
                d00616
                @NeverDie I don't know why the println() doesn't work. There is an "DEBUG_OUTPUT(x, ##VA_ARGS)" macro, you can use when debug is enabled.
                NRF_ADC is the nRF51 ADC and NRF_SAADC is the ADC of the nRF52. They are defined when "nrf.h" is included.
                • d00616D d00616
                  The nRF52832 Ebyte Module.
                    hwCPUVoltage()
                    TerrenceT
                    TerrenceT
                    Terrence
                    @NeverDie VS Code with the Arduino Extension is your friend.
                    • d00616D d00616
                      #441
                      • TerrenceT Terrence
                        #442
                          #443
                          //#define MY_RADIO_NRF24
                          #define MY_RADIO_NRF5_ESB
                          //#include <MySensors.h>
                          int oldBatteryPcnt = 0;
                          uint16_t counter=0;
                          uint16_t volts=0;
                          uint16_t theHwCPUVoltage()
                            // NRF51:
                            // 20uS@260uA
                            // NRF52:
                            int32_t sample;
                            // unknown MCU
                            return 0;
                            while (true) {
                              volts=theHwCPUVoltage();
                              Serial.print("counter=");
                              Serial.print(counter++);
                              Serial.println(volts);
                          //#else
                          //	analogReference(INTERNAL);
                          //#endif
                              d00616D
                              d00616D
                              d00616
                                mtiutiuM 1 Reply Last reply
                                    Mike_Lemo
                                    @NeverDie Dam you why would you make it so wide? can it fit on a single bread board?
                                    • M Mike_Lemo
                                      #449
                                      Sorry, you'll need two.
                                        mtiutiuM
                                        mtiutiuM
                                        mtiutiu
                                        #450
                                        • mtiutiuM mtiutiu
                                          Here: https://www.aliexpress.com/item/NRF52832-Bluetooth-4-2-module-Bluetooth-5-program-PCBA-serial-transmission-cost-effective/32818791344.html?spm=a2g0s.9042311.0.0.jWh9gH
                                          Nca78N 1 Reply Last reply
