  3. 💬 NRF2RFM69
💬 NRF2RFM69
rfm69adapterconverternrf24l01
113 Posts 29 Posters 59.6k Views 24 Watching
    I had other pcb in order so shipping cost was not that bad, in addition 10 pcbs are 4.90$
    • B bilbolodz
      @tbowmo How about PCBs.io? Any chance for direct link? I've trying to upload it but got an error about "Gerber normalization for Layer: Drill Holes". I'm a quite newbie for designing/uploading files for PCB factories so sorry for maybe stupid question.
      tbowmoT
      tbowmoT
      tbowmo
      @bilbolodz
      There is also a link to dirtypcbs somewhere in this thread, where you can order pcb's.
      GertSandersG J 2 Replies Last reply
      • tbowmoT tbowmo
        @bilbolodz
        GertSandersG
        GertSandersG
        GertSanders
        @tbowmo
        http://dirtypcbs.com/store/pcbs
        • tbowmoT tbowmo
          @bilbolodz
          J
          J
          jeti
          wrote on last edited by jeti
          #46
          @tbowmo i have some left over. If you are interested just shoot me a pm
          Jeti
          tbowmoT 1 Reply Last reply
          • J jeti
            Jeti
            tbowmoT
            tbowmoT
            tbowmo
            @jeti
            Thanks, but I still have a couple left in my parts bin :)
              Is it just me or there are some pins that are not exactly the same order as a normal 8 pins nrf24?
                tbowmoT
                tbowmoT
                tbowmo
                @gohan what do you mean?
                  Like CE pin is actually connected to the CSN pin on the 2x4 pin side
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    #51
                    @gohan
                    On NRF24 CSN is equivalent of CE signal on the SPI bus. While CE is a global on/off switch for the TX/RX on the NRF (Check page 11 in the nrf24 datasheet
                    On RFM69 CE is actually called NSS (pin 15). Datasheet are here
                    I don't have the schematics of this project at hand right now, as someone has forgotten to add a pdf of it to the repository ;)
                      I haven't mapped all the pins because yesterday I was a little tired, maybe tonight I'll check, but the fact is that I can't initialize the radio while the nrf24 works. 😕
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        I have used the board with a couple of sensebender micros.. and they worked fine..
                          Looking at the https://www.mysensors.org/build/raspberry page I have the current mapping on the board rfm69 side:
                          pin above DI00 is connected to CE pin
                          DI00 is connected to IRQ
                          NSS is connected to CSN
                          MOSI to MOSI ok
                          MISO to MISO ok
                          SCK to SCK ok
                          Do you think is correct?
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            RFM69 NSS is equivalent of NRF24 CSN
                            DIO0 act as interrupt line, and is attached in accordance with connecting the radio.
                            the pin above DIO0 is actually the reset line for the RFM69 module.. Which might come in handy, if you want to do a hardware reset at some point in time :)
                              So why isn't it working then? Did I fry the radio?
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @gohan
                                Could you have added it to a 5V arduino? RFM is not 5V tolerant, so that could fry the radio..
                                  No, I used it only on the raspberry
                                    wrote on last edited by gohan
                                    #59
                                    New update: I used the module on the EasyPCB, nrf24 version, from @sundberg84 and recompiled the sketch to use the rfm69 and it is able to initialize the radio. So there must be something wrong with the compiled gateway on the RPI as it should be a direct swap from a NRF24. I am moving to the RPI thread
                                    PS Now it seems to be working... I haven't changed anything.... must have been a bad connection then
                                    mysgw: MCO:BGN:INIT CP=RPNG----
                                    mysgw: TSF:LRT:OK
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: TSM:INIT:TSP OK
                                    mysgw: TSM:INIT:GW MODE
                                    mysgw: MCO:REG:NOT NEEDED
                                    mysgw: MCO:BGN:STP
                                    mysgw: MCO:BGN:INIT OK,TSP=1
                                      Markus.
                                      Hi all,
                                      which size of cap should be used on this board and is it possible to connect a SMA Antenna ?
                                      Many thanks
                                      Markus
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        use a 4.7uF capacitor, or there about..
                                        There is no pads for a SMA connector, but you could attach one with a pigtail..
                                        • tbowmoT tbowmo
                                          Markus.
                                          @tbowmo Thanks for the Information... One stupid question about the SMA conenctor :-) Is it enough to connect only the Antenna Output conenction or must GND also conencted...?
