  3. 💬 NRF2RFM69
💬 NRF2RFM69
rfm69adapterconverternrf24l01
113 Posts 29 Posters 59.9k Views 24 Watching
  • tbowmoT tbowmo
    @cimba007 said:
    @tbowmo: Any chance to add this to oshpark? I only need 6 piece max.
    Not using oshpark, sorry..
    B
    B
    bilbolodz
    @tbowmo How about PCBs.io? Any chance for direct link? I've trying to upload it but got an error about "Gerber normalization for Layer: Drill Holes". I'm a quite newbie for designing/uploading files for PCB factories so sorry for maybe stupid question.
    tbowmoT 1 Reply Last reply
      I ordered 10 from Seeed Studio and I had no problems; I am waiting for delivery.
      B 1 Reply Last reply
        B
        B
        bilbolodz
        @gohan Seeed Studio ask 11.16 for delivery :-(
        • B
          B
          bilbolodz
          I've uploaded (I hope all will be fine with PCB) on PCBs.io: https://pcbs.io/share/zZAMk
          3.10 USD for 4 pieces free shipment
            I had other pcb in order so shipping cost was not that bad, in addition 10 pcbs are 4.90$
            • B bilbolodz
              tbowmoT
              tbowmoT
              tbowmo
              @bilbolodz
              There is also a link to dirtypcbs somewhere in this thread, where you can order pcb's.
              GertSandersG J 2 Replies Last reply
              • tbowmoT tbowmo
                @bilbolodz
                GertSandersG
                GertSandersG
                GertSanders
                @tbowmo
                http://dirtypcbs.com/store/pcbs
                • tbowmoT tbowmo
                  @bilbolodz
                  J
                  J
                  jeti
                  wrote on last edited by jeti
                  #46
                  @tbowmo i have some left over. If you are interested just shoot me a pm
                  Jeti
                  • J jeti
                    Jeti
                    tbowmoT
                    tbowmoT
                    tbowmo
                    @jeti
                    Thanks, but I still have a couple left in my parts bin :)
                      Is it just me or there are some pins that are not exactly the same order as a normal 8 pins nrf24?
                        tbowmoT
                        tbowmoT
                        tbowmo
                        @gohan what do you mean?
                          Like CE pin is actually connected to the CSN pin on the 2x4 pin side
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            #51
                            @gohan
                            On NRF24 CSN is equivalent of CE signal on the SPI bus. While CE is a global on/off switch for the TX/RX on the NRF (Check page 11 in the nrf24 datasheet
                            On RFM69 CE is actually called NSS (pin 15). Datasheet are here
                            I don't have the schematics of this project at hand right now, as someone has forgotten to add a pdf of it to the repository ;)
                              I haven't mapped all the pins because yesterday I was a little tired, maybe tonight I'll check, but the fact is that I can't initialize the radio while the nrf24 works. 😕
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                I have used the board with a couple of sensebender micros.. and they worked fine..
                                  Looking at the https://www.mysensors.org/build/raspberry page I have the current mapping on the board rfm69 side:
                                  pin above DI00 is connected to CE pin
                                  DI00 is connected to IRQ
                                  NSS is connected to CSN
                                  MOSI to MOSI ok
                                  MISO to MISO ok
                                  SCK to SCK ok
                                  Do you think is correct?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    RFM69 NSS is equivalent of NRF24 CSN
                                    DIO0 act as interrupt line, and is attached in accordance with connecting the radio.
                                    the pin above DIO0 is actually the reset line for the RFM69 module.. Which might come in handy, if you want to do a hardware reset at some point in time :)
                                      So why isn't it working then? Did I fry the radio?
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @gohan
                                        Could you have added it to a 5V arduino? RFM is not 5V tolerant, so that could fry the radio..
                                          No, I used it only on the raspberry
