  3. 💬 NRF2RFM69
💬 NRF2RFM69
rfm69adapterconverternrf24l01
113 Posts 29 Posters 59.9k Views 24 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    I have used the board with a couple of sensebender micros.. and they worked fine..
      Looking at the https://www.mysensors.org/build/raspberry page I have the current mapping on the board rfm69 side:
      pin above DI00 is connected to CE pin
      DI00 is connected to IRQ
      NSS is connected to CSN
      MOSI to MOSI ok
      MISO to MISO ok
      SCK to SCK ok
      Do you think is correct?
      • tbowmoT
        tbowmoT
        tbowmo
        RFM69 NSS is equivalent of NRF24 CSN
        DIO0 act as interrupt line, and is attached in accordance with connecting the radio.
        the pin above DIO0 is actually the reset line for the RFM69 module.. Which might come in handy, if you want to do a hardware reset at some point in time :)
          So why isn't it working then? Did I fry the radio?
          • tbowmoT
            tbowmoT
            tbowmo
            @gohan
            Could you have added it to a 5V arduino? RFM is not 5V tolerant, so that could fry the radio..
              No, I used it only on the raspberry
                wrote on last edited by gohan
                #59
                New update: I used the module on the EasyPCB, nrf24 version, from @sundberg84 and recompiled the sketch to use the rfm69 and it is able to initialize the radio. So there must be something wrong with the compiled gateway on the RPI as it should be a direct swap from a NRF24. I am moving to the RPI thread
                PS Now it seems to be working... I haven't changed anything.... must have been a bad connection then
                mysgw: MCO:BGN:INIT CP=RPNG----
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:INIT:TSP OK
                mysgw: TSM:INIT:GW MODE
                mysgw: MCO:REG:NOT NEEDED
                mysgw: MCO:BGN:STP
                mysgw: MCO:BGN:INIT OK,TSP=1
                  Markus.
                  Hi all,
                  which size of cap should be used on this board and is it possible to connect a SMA Antenna ?
                  Many thanks
                  Markus
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    use a 4.7uF capacitor, or there about..
                    There is no pads for a SMA connector, but you could attach one with a pigtail..
                    • tbowmoT tbowmo
                      Markus.
                      @tbowmo Thanks for the Information... One stupid question about the SMA conenctor :-) Is it enough to connect only the Antenna Output conenction or must GND also conencted...?
                        You can just solder the antenna only on pcb. I use a coil spring type
                          Markus.
                          wrote on last edited by Markus.
                          #64
                          just one more question... I have on the Gateway a RFM69HW and a node with a RFM69W module. In the Gateway Sketch is the HW type enabled
                          #define MY_RFM69_FREQUENCY RF69_868MHZ
                          #define MY_IS_RFM69HW
                          But there is no comunication from the node... I use Mysensors 2.1.1.
                          Any idea?
                            What gateway is that? I'd suggest to try mysensors 2.2 development
                              Markus.
                              @gohan It at the Moment only a test. So I have one EasyPCB NRF board with FTDI as Gateway and another EasyPCB board with DHT22 Sensor attached as Node. On both is a 4,7uF electrolytic condensator attached Close to the NRF socket. Both boards are at the Moment with RFM69W 868. The sensor node is battey powered.
                                Get latest 2.2 library and use new rfm69 driver. Did you remember to close the IRQ contact in the easypcb?
                                  Markus.
                                  #68
                                  @gohan Oh Sh* must check this... I've tried it yesterday on both devices the 2.2 Dev. But will Keep ypu informed...
                                  Don't find the jumperfor the IRQ on the Rev 9 board. can you please post a Picture. Seems that this one is definitly not closed...
                                  --> Edit... found it in the documentation but still the same.
                                  Think the next Point to check for me are the antennas... :-(
                                    I'd suggest to buy the coil spring antennas for your frequency, they are cheap and compact.
                                      Markus.
                                      in principle there is traffic between node and Gateway..
                                      159631 !TSM:FPAR:NO REPLY
                                      159637 TSM:FPAR
                                      169848 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      171868 !TSM:FPAR:NO REPLY
                                      171874 TSM:FPAR
                                      179087 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      181106 !TSM:FPAR:FAIL
                                      181112 TSM:FAIL:CNT=4
                                      181118 TSM:FAIL:DIS
                                      181123 TSF:TDI:TSL
                                      191131 TSM:FAIL:RE-INIT
                                      191137 TSM:INIT
                                      191143 TSM:INIT:TSP OK
                                      191150 TSM:INIT:STATID=10
                                      191158 TSF:SID:OK,ID=10
                                      191164 TSM:FPAR
                                      198377 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      200396 !TSM:FPAR:NO REPLY
                                      200402 TSM:FPAR
                                      207616 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      209635 !TSM:FPAR:NO REPLY
                                      209641 TSM:FPAR
                                      216854 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      218873 !TSM:FPAR:NO REPLY
                                      218880 TSM:FPAR
                                      226093 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      228112 !TSM:FPAR:FAIL
                                      228118 TSM:FAIL:CNT=5
                                      228124 TSM:FAIL:DIS
                                      228128 TSF:TDI:TSL
                                      238135 TSM:FAIL:RE-INIT
                                      238141 TSM:INIT
                                      238147 TSM:INIT:TSP OK
                                      238153 TSM:INIT:STATID=10
                                      238161 TSF:SID:OK,ID=10
                                      238168 TSM:FPAR
                                      248385 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      250404 !TSM:FPAR:NO REPLY
                                      250411 TSM:FPAR
                                      257624 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      259643 !TSM:FPAR:NO REPLY
                                      259649 TSM:FPAR
                                      269731 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      271751 !TSM:FPAR:NO REPLY
                                      271757 TSM:FPAR
                                      0;255;3;0;9;189196 TSF:PNG:SEND,TO=0
                                      0;255;3;0;9;189206 TSF:CKU:OK
                                      0;255;3;0;9;189214 TSF:MSG:GWL OK
                                      0;255;3;0;9;191236 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                      0;255;3;0;9;244555 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;244574 TSF:MSG:BC
                                      0;255;3;0;9;244582 TSF:MSG:FPAR REQ,ID=10
                                      0;255;3;0;9;244594 TSF:PNG:SEND,TO=0
                                      0;255;3;0;9;244604 TSF:CKU:OK
                                      0;255;3;0;9;244613 TSF:MSG:GWL OK
                                      0;255;3;0;9;257744 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                      0;255;3;0;9;269957 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;269977 TSF:MSG:BC
                                      0;255;3;0;9;269985 TSF:MSG:FPAR REQ,ID=10
                                      0;255;3;0;9;269996 TSF:PNG:SEND,TO=0
                                      0;255;3;0;9;270006 TSF:CKU:OK
                                      0;255;3;0;9;270014 TSF:MSG:GWL OK
                                      0;255;3;0;9;281585 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                      0;255;3;0;9;289732 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;289753 TSF:MSG:BC
                                      0;255;3;0;9;289761 TSF:MSG:FPAR REQ,ID=10
                                      0;255;3;0;9;289771 TSF:PNG:SEND,TO=0
                                      0;255;3;0;9;289781 TSF:CKU:OK
                                      0;255;3;0;9;289789 TSF:MSG:GWL OK
                                      0;255;3;0;9;297015 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                      0;255;3;0;9;306757 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;306776 TSF:MSG:BC
                                      0;255;3;0;9;306784 TSF:MSG:FPAR REQ,ID=10
                                      0;255;3;0;9;306796 TSF:PNG:SEND,TO=0
                                      0;255;3;0;9;306806 TSF:CKU:OK
                                      0;255;3;0;9;306814 TSF:MSG:GWL OK
                                      0;255;3;0;9;316682 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                      0;255;3;0;9;322084 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;322103 TSF:MSG:BC
                                      0;255;3;0;9;322111 TSF:MSG:FPAR REQ,ID=10
                                      0;255;3;0;9;322123 TSF:PNG:SEND,TO=0
                                      0;255;3;0;9;322131 TSF:CKU:OK
                                      0;255;3;0;9;322142 TSF:MSG:GWL OK
                                      0;255;3;0;9;333180 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                        That's either the node not receiving or the gateway having problems when sending
                                          Markus.
                                          @gohan :-( any idea what else I can do/check ?
                                          alexsh1A 1 Reply Last reply
