  3. 💬 MDMSNode "Lighting" Rev 1.1
lightingatmega328patsha204amysensorsrfm69hwnrf24l01otaarduinohlk-pm01triac
9 Posts 4 Posters 4.6k Views 4 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/444/MDMSNode-Lighting-Rev-11
    • kalinaK
      kalinaK
      kalina
      Added thermal fuse.
      • A
        artipi
        Nice Work! When you plan to publish the PCB design?
        kalinaK 1 Reply Last reply
        • A artipi
          kalinaK
          kalinaK
          kalina
          @artipi At the first I should check the new design (ordering pcbs + wait delivering (3 weeks) + solder and test (3-4 days). In my opinion, it will be in September.
          • A
            artipi
            Ok, thanks!
            • kalinaK
              kalinaK
              kalina
              The first batch of devices will be shipping to the customer soon :airplane:
              • jeremushkaJ
                jeremushkaJ
                jeremushka
                Now i can understand the modifications on the rev1.1. Do you detect in the firmware if the light is off or on with the ACS712 ? Does the push switch from the wall will still be acting independently of this Mysensors board?
                Light status (on/off) will update when the physical switch will be pressed?
                • jeremushkaJ jeremushka
                  kalinaK
                  kalinaK
                  kalina
                  @jeremushka I developed this device and added functionality to it that can be useful for many users of MySensors technology. Personally, I use only the lamp on / off function. I do not use the wall switch, current flow detecting, etc. I can only theoretically answer on your questions. For confirmation it, is necessary to implement all this in the sketch.
                  @jeremushka said in 💬 MDMSNode "Lighting" Rev 1.1:
                  It is possibility.
                  Wall switch must connect directly to terminal block. No other connections should be.
                  This needs to be controlled by the sketch.
                  • jeremushkaJ
                    jeremushkaJ
                    jeremushka
                    @kalina, Thanks. So it will not work for my configuration. Wall switch (push button) is already installed. No possibilities to draw more electrical wires.
                    Moreover, if i put the board near the light, i have just the Neutral and the return wire from the wall switch. No Live wire to power on the mysensors board.
                    I think in my ase the best way is to manage everything in my garage in the electrical main board where all the wires are mapped. I can get L + N for mysensors power supply. And i can continue to reuse the original wall switch independently of the Mysensors board.
