  3. MultiSensor - relays, temp, hum, PIR, gesture with various controller overrides
19 Posts 3 Posters 7.0k Views 4 Watching
  • B Offline
    B Offline
    Ben Andrewes
    wrote on last edited by Ben Andrewes
    This is my first real effort at making a sensor... It is also my first time programming Arduinos - I learnt BASIC at school 30yrs ago and use VBA at work but that is it so be kind please... :) I am grateful for any suggestions on how to improve it and cut out any lines I don't need
    I already use RFLink and Domoticz to do some controlling around my house but with MySensors I thought I could add to that. The aim is to create one lot of code that can then be used on about 10 separate idenitcal nodes around the house. That way I can debug the code before deployment rather than having to debug every node.
    I decided I needed temp, humidity, a couple of relays, a PIR, and (on a whim) a gesture sensor. I used a dht11 for the temp/hum and apds-9960 for the gestures. I wanted lots of possibilities for sending command to Domoticz which will then handle the logic e.g. using the gesture sensor, if I swipe up I'll get Domoticz to switch on a relay.
    I've also made it so that there is a separate switch that can deactivate motion sensing from the controller (don't know why, just seemed like a good idea. In addition I made a temperature adjustment child by declaring a dimmer switch then using the value to calculate an adjustment where 50% dimmed is 0 degrees offset. 0% = -5 degrees, 25% = -2.5 degrees, 50% = no offset, 75% = +2.5 degrees, 76% = +2.6 degrees etc.
    Fianlly I thought that dealing with the status of the relays, the PIR, and temp offset might be different depending on the sensor (e.g. I might want a relay connected to a fridge to default to "On" if the node rebooted for any reason, but e.g. the light in the garage to default to off, I might also want the sensor to get the last value from eeprom as in the relay example sketch or even query Domoticz to find the current state according to it).
    To do this I added a StoreXState variable that can be 1,2, or 3 and after a power cycle, it decides if the "Motion Enable/disable", Relays, & Temp Offset states are either default, got from EEPROM, or requested from Domoticz.
    I'm pretty pleased with it as a first attempt, so thought I'd share the code. A few things:
    • there are loads of Serial Prints so I could see what was happening
    • if debug is defined then it uses loads of memory (like 99%) on a pro mini and I got really odd behaviour from the node
    • I've borrowed heavily from other people's code, thank you to them
    • it is currently a jumble of wires on my desk so no pics yet
    • massive thanks to the MySensors team
    Hardware Connections:
    IMPORTANT: The APDS-9960 can only accept 3.3V!
     Arduino Pin  APDS-9960 Board  Function
     3.3V         VCC              Power
     GND          GND              Ground
     A4           SDA              I2C Data
     A5           SCL              I2C Clock
     2            INT              Interrupt
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 103
    #include <SparkFun_APDS9960.h>
    #define RELAY_1_PIN  5  // Arduino Digital I/O pin number for first relay
    #define RELAY_2_PIN  6  // Arduino Digital I/O pin number for second relay
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay - domoticz needs 0 for on, 1 for off
    #define CHILD_ID_RELAY1 1
    #define CHILD_ID_RELAY2 2
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    #define CHILD_ID_MOT 5   // Id of the sensor child
    #define CHILD_ID_TEMP_OFFSET 20
    #define CHILD_ID_MotionOnOff 21
    #define CHILD_ID_GESTUREUD 30  //up down gesture
    #define CHILD_ID_GESTURELR 31 //left right gesture
    #define CHILD_ID_GESTURENF 32 //near far gesture
    #define GestureUp 1 //command to send on gesture, 0 = off, 1 = on
    #define GestureDown 0 //command to send on gesture, 0 = off, 1 = on
    #define GestureLeft 0 //command to send on gesture, 0 = off, 1 = on
    #define GestureRight 1 //command to send on gesture, 0 = off, 1 = on
    #define GestureNear 0 //command to send on gesture, 0 = off, 1 = on
    #define GestureFar 1 //command to send on gesture, 0 = off, 1 = on
    #define GestureSensitivity  0  // value between 0 & 3, 0 most sensitive, 3 least
    #define HUMIDITY_SENSOR_DIGITAL_PIN 7
    #define APDS9960_INT    2  // for the APDS-9960 - Needs to be an interrupt pin
    #define INTERRUPT DIGITAL_INPUT_SENSOR-2 // for the PIR - Usually the interrupt = pin -2 (on uno/nano anyway)
    SparkFun_APDS9960 apds = SparkFun_APDS9960();
    volatile int isr_flag = 0; //handles the interrupt process for gesture sensor
    unsigned long SLEEP_TIME = 120000; // Sleep time between reads of temp/hum (in milliseconds)
    unsigned long lastRefreshTime = 0; // Use this to implement a non-blocking delay function
    unsigned long RefreshCyclesUntilForcedUpdate = 5; // use to force a temp/hum reading after 'n' SLEEP_TIME cycles even if value hasn't changed, set v.high (e.g. 10,000) to effectively disable
    unsigned long ForceUpdate = RefreshCyclesUntilForcedUpdate * SLEEP_TIME; // Force update read after this amount of time
    unsigned long lastForceUpdateTime = 0; // Use this to implement a non-blocking delay function that forces update even if temp hasn't changed
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    bool lastTripped = 0;   // Used to store last motion sensor value
    boolean FirstBoot = true;
    // the below allow you decide if the default state of certain sensors is stored in EEPROM or Controller or always start in a certain state
    // 1 = EEPROM 2 = Controller (e.g. Domoticz), 3 or any other number then they start as with default values
    // If option 1 or 3 is selected then we will also send a message to the controller to tell it the states
    // unsigned long WaitBetweenSendingMessages = 150; //how long to wait between sending messages and presenting nodes
    int StoreTempOffset = 2;
    int StoreMotionOnOff = 2;
    int StoreRelayState = 2;
    // below are the default states that you can set to be loaded at boot each time
    // these will be reverted to in EEPROM values are corrupted
    bool MotionON = 0;      //enable/disable the PIR reports (1=enabled 0=disabled)
    bool RelayState = 0;    // default state for relays (1 = on, 0 = off)
    int TempOffset = 50; // a value of 50 means that initial offset is zero when first loaded.  Tempoffset can be between 0-100
    volatile float ActualTempOffset = (TempOffset / 10.0) - 5.0;  //Adjust temp offset to a decimal between +/- 5 degrees
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
    MyMessage msgTempOffset(CHILD_ID_TEMP_OFFSET, V_PERCENTAGE);
    MyMessage msgMotOnOff(CHILD_ID_MotionOnOff, V_STATUS);
    MyMessage msgRelay1(1, V_STATUS);
    MyMessage msgRelay2(2, V_STATUS);
    MyMessage msgGestureUpDown(CHILD_ID_GESTUREUD, V_STATUS);
    MyMessage msgGestureLeftRight(CHILD_ID_GESTURELR, V_STATUS);
    MyMessage msgGestureNearFar(CHILD_ID_GESTURENF, V_STATUS);
    void before()
      pinMode(RELAY_1_PIN , OUTPUT);
      pinMode(RELAY_2_PIN , OUTPUT);
      // Set gesture sensor interrupt pin as input
      pinMode(APDS9960_INT, INPUT);
        //define sensitivity of gesture sensor
        apds.setGestureGain( GestureSensitivity );
      // metric = getConfig().isMetric;
      // Initialize interrupt service routine for gestures
     attachInterrupt(digitalPinToInterrupt(APDS9960_INT), interruptRoutine, FALLING);
      // Initialize APDS-9960 (configure I2C and initial values)
      if ( apds.init() ) {
        Serial.println(F("APDS-9960 initialization complete"));
        Serial.println(F("Something went wrong during APDS-9960 init!"));
      // Start running the APDS-9960 gesture sensor engine
      if ( apds.enableGestureSensor(true) ) {
        Serial.println(F("Gesture sensor is now running"));
        Serial.println(F("Something went wrong during gesture sensor init!"));
      sendSketchInfo("MyMultiSensor", "1.4");
      present(CHILD_ID_RELAY1, S_BINARY, "Relay 1");
      wait(100);
      present(CHILD_ID_RELAY2, S_BINARY, "Relay 2");
      wait(100);
      present(CHILD_ID_HUM, S_HUM, "Humidity");
      wait(100);
      present(CHILD_ID_TEMP, S_TEMP, "Temperature");
      wait(100);
      present(CHILD_ID_MOT, S_MOTION, "PIR");
      wait(100);
      present(CHILD_ID_TEMP_OFFSET, S_DIMMER, "Temp Calibration");
      wait(100);
      present(CHILD_ID_MotionOnOff, S_BINARY, "PIR Enable/Disable");
      wait(100);
      present(CHILD_ID_GESTUREUD, S_BINARY, "Gesture Up/Down");
      wait(100);
      present(CHILD_ID_GESTURELR, S_BINARY, "Gesture Left/Right");
      wait(100);
      present(CHILD_ID_GESTURENF, S_BINARY, "Gesture Near/Far");
      wait(100);
    void firstboot()
      if(FirstBoot)
      Serial.println("FirstBoot sequence started");
      // Set relay to correct state (using eeprom/default/domoticz value)
      switch (StoreRelayState) {
        case 1:
          if (loadState(CHILD_ID_RELAY1) == 1)  {
            digitalWrite(RELAY_1_PIN , RELAY_ON);
            digitalWrite(RELAY_1_PIN , RELAY_OFF);
          if (loadState(CHILD_ID_RELAY2) == 1)  {
            digitalWrite(RELAY_2_PIN , RELAY_ON);
            digitalWrite(RELAY_2_PIN , RELAY_OFF);
            Serial.print("Relay 1 loadstate from EEPROM: ");
            Serial.println(loadState(CHILD_ID_RELAY1));
            Serial.print("Relay 2 loadstate from EEPROM: ");
            Serial.println(loadState(CHILD_ID_RELAY2));
            //best let domoticz know
            send(msgRelay1.set(RelayState));
            wait(100);
            send(msgRelay2.set(RelayState));
            wait(100);
            Serial.print("Default Relay state sent to Domoticz: ");
            Serial.println(RelayState);
        case 2:
            //get Relay Statuses from Domoticz
              Serial.println("Relay status requested from Domoticz");
              request(CHILD_ID_RELAY1, V_STATUS);
              wait(1000);
              request(CHILD_ID_RELAY2, V_STATUS);
              wait(1000);
        default:
            digitalWrite(RELAY_1_PIN ,  RelayState ? RELAY_ON : RELAY_OFF);
            digitalWrite(RELAY_2_PIN ,  RelayState ? RELAY_ON : RELAY_OFF);
            Serial.print("Relays set to default boot state: ");
            wait(100);
            wait(100);
      // Set tempoffset to correct state (using eeprom/default/domoticz value) - needs to be 0 - 100 otherwise set to no offset
        switch (StoreTempOffset)  {
          case 1:
            if (loadState(CHILD_ID_TEMP_OFFSET) >100) {
              ActualTempOffset = 5.0;
              TempOffset = loadState(CHILD_ID_TEMP_OFFSET);
              Serial.print("Temp Offset retrieved from eeprom: ");
              Serial.println(ActualTempOffset);
              //let Domoticz know the value
              send(msgTempOffset.set(TempOffset, 1));
              wait(100);
              Serial.print("tempOffset from sensor sent to Domoticz: ");
              Serial.println(TempOffset);
          case 2:
            //get TempOffSet from Domoticz
              Serial.println("TempOffset value requested from Domoticz");
              request(CHILD_ID_TEMP_OFFSET, V_PERCENTAGE);
              wait(1000);
          default:
              Serial.print("Default boot temperature offset is: ");
              wait(100);
        // Set PIR enable/disable (using eeprom/default/domoticz value)
        switch(StoreMotionOnOff) {
          case 1:
            if (loadState(CHILD_ID_MotionOnOff) == 1 || loadState(CHILD_ID_MotionOnOff) == 0) { //check for odd values in EEPROM
              MotionON = loadState(CHILD_ID_MotionOnOff);
            else {
              Serial.print("Error in PIR Enable/Disable Value in EEPROM");
              Serial.println("Default value used instead");
            //Let Domoticz know
              send(msgMotOnOff.set(MotionON, 1));
              wait(100);
              Serial.print("PIR ENABLE status from sensor sent to Domoticz: ");
              Serial.println(MotionON);
          case 2:
            //get PIR enable status from Domoticz
              Serial.println("MotionOnOff status requested from Domoticz");
              request(CHILD_ID_MotionOnOff, V_STATUS);
              wait(1000);
          default:
              wait(100);
              Serial.print("Default PIR ENABLE status used and sent to Domoticz: ");
      wait(2000);
      Serial.println("First boot checks completed");
      FirstBoot = false;
      //check if gesture sensor interrupt is triggered
        if( isr_flag == 1 ) {
        detachInterrupt(digitalPinToInterrupt(APDS9960_INT));
        handleGesture();
        isr_flag = 0;
      // Read digital motion value
      if (MotionON) {
        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        if (lastTripped != tripped) {
          Serial.print("New Motion State: ");
          Serial.println(tripped);
          // Send tripped value to gw
          send(msgMot.set(tripped ? "1" : "0"));
          lastTripped = tripped;
      boolean needRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
      if (needRefresh)
        Serial.println("I'm alive");
        lastRefreshTime = millis();
        float temperature = dht.getTemperature() + ActualTempOffset;
        if (isnan(temperature)) {
        else if (temperature != lastTemp  ) {
          lastTemp = temperature;
          if (!metric) {
          Serial.print("T: ");
        else if (millis() - lastForceUpdateTime > ForceUpdate) {
          lastForceUpdateTime = millis();
          if (!metric) {
        if (isnan(humidity)) {
        else if (humidity != lastHum) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
          lastHum = humidity;
    void interruptRoutine() {
      //Serial.println("Interrupt Routine started");
      isr_flag = 1;
    void handleGesture() {
        if ( apds.isGestureAvailable() ) {
        switch ( apds.readGesture() ) {
          case DIR_UP:
            Serial.println("UP");
            send(msgGestureUpDown.set(GestureUp));
          case DIR_DOWN:
            Serial.println("DOWN");
            send(msgGestureUpDown.set(GestureDown));
          case DIR_LEFT:
            Serial.println("LEFT");
            send(msgGestureLeftRight.set(GestureLeft));
          case DIR_RIGHT:
            Serial.println("RIGHT");
            send(msgGestureLeftRight.set(GestureRight));
          case DIR_NEAR:
            Serial.println("NEAR");
            send(msgGestureNearFar.set(GestureNear));
          case DIR_FAR:
            Serial.println("FAR");
            send(msgGestureNearFar.set(GestureFar));
          default:
            Serial.println("NONE");
     //For debugging just checking why controller sent a msg e.g. was it in response to a request by node
          case C_SET:
            Serial.println("msg sent by controller");
          case C_REQ:
            Serial.println("msg state sent by controller in response to request");
          default:
            Serial.println("msg isn't C_SET or C_REQ so what you gonna do?");
      // We only expect V_STATUS (for relays) or V_Percentage (for temp offset) message from controller. But we better check anyway.
        // Change relay state
        if (message.sensor == 1 ) {
          digitalWrite(RELAY_1_PIN , message.getBool() ? RELAY_ON : RELAY_OFF);
          // Store state in eeprom
          Serial.print("Incoming Relay 1 State: ");
        else if (message.sensor == 2) {
          digitalWrite(RELAY_2_PIN , message.getBool() ? RELAY_ON : RELAY_OFF);
          Serial.print("Incoming Relay 2 State: ");
        else if (message.sensor == CHILD_ID_MotionOnOff) {
            if (message.getBool() == 1) {
              MotionON = 1;
              saveState(CHILD_ID_MotionOnOff, MotionON);
              MotionON = 0;
        Serial.print("Motion Sensor on/off state: ");
      else if (message.type == V_PERCENTAGE)  {
        int TempOffset = atoi(message.data);
        Serial.print("Temp Offset value: ");
        saveState(CHILD_ID_TEMP_OFFSET, TempOffset);
    D 1 Reply Last reply
    • B Ben Andrewes
       3.3V         VCC              Power
       GND          GND              Ground
       A4           SDA              I2C Data
       A5           SCL              I2C Clock
       2            INT              Interrupt
      DHT dht;
      float lastTemp;
      float lastHum;
      void before()
        wait(100);
        wait(100);
        wait(100);
        wait(100);
        wait(100);
        wait(100);
        wait(100);
        wait(100);
        wait(100);
        wait(100);
      void firstboot()
        if(FirstBoot)
          case 1:
              wait(100);
              wait(100);
          case 2:
                wait(1000);
                wait(1000);
          default:
              wait(100);
              wait(100);
            case 1:
                wait(100);
            case 2:
                wait(1000);
            default:
                wait(100);
            case 1:
              else {
              //Let Domoticz know
                wait(100);
            case 2:
                wait(1000);
            default:
                wait(100);
        wait(2000);
        FirstBoot = false;
          handleGesture();
          isr_flag = 0;
        if (MotionON) {
        if (needRefresh)
            if (!metric) {
            if (!metric) {
            lastHum = humidity;
            lastHum = humidity;
        isr_flag = 1;
            case DIR_UP:
            case DIR_DOWN:
            case DIR_LEFT:
            case DIR_RIGHT:
            case DIR_NEAR:
            case DIR_FAR:
            default:
            case C_SET:
            case C_REQ:
            default:
                MotionON = 1;
                MotionON = 0;
      @Ben-Andrewes If you have loads of serial prints, that is probably why you have 99% memory usage. I bet if you pull those out, or at least use a define to be able to turn them on and off like, or even with MY_DEBUG or the like, you can see the difference when shutting them off at compile time.
      B 1 Reply Last reply
      • D dbemowsk
        B Offline
        B Offline
        Ben Andrewes
        @dbemowsk Sounds like a good idea, but I'm not sure how... does that mean I'd do something like
        #define serialmessages
        then around each Serial.print
        do some sort of if clause?
        Thanks in advance for any advice
        • B Ben Andrewes
          @Ben-Andrewes This is really easy. The code for the debug is like this:
          //define this at the top of your sketch
          ....other code....
          #ifdef MY_DEBUG
          ...your debug code here....
          Then if you comment out the define at the top of the sketch, all of the debug code is ignored when compiling. Change MY_DEBUG to whatever name you want if you want to only block out certain bits of code at compile time.
          • B Offline
            B Offline
            Ben Andrewes
            Thanks for the help , much appreciated. I added 3 #defines so I have a bit of control over what gets cut out i.e. the verbose stuff is really only useful at development stage but I guess if I start getting weird sensor readings then it will be helpful to have a serial reading of what the sensors are reporting. If I comment out all 4 defines then I use less than half the available memory
            #define MY_DEBUG //mysensors protocol debug prints
            #define SerialPrints //all the verbose messages that state what the program is doing at certain points e.g. "Requesting message from Domoticz"
            #define ImAlive  // Heartbeat in main loop
            #define SerialReadings  //Sensor readings e.g. temp and certain messages from Domoticz e.g. if turning a relay on
            I might be starting to get a bit of an idea of how this stuff works... :)
            • B Ben Andrewes
              @Ben-Andrewes I think you got it. Great job.
              • B Offline
                B Offline
                BulldogLowell
                @Ben-Andrewes said in MultiSensor - temp, hum, PIR, gesture with various controller overrides:
                you do it here:
                but not here:
                You shouuld wrap every every every string constant in the F Macro
                D B 2 Replies Last reply
                • B BulldogLowell
                  you do it here:
                  but not here:
                  @BulldogLowell I was unaware of this, good call though. I looked it up because I wasn't sure what the F() method was. Here's a link for others that may be curious.
                  https://playground.arduino.cc/Learning/Memory
                  • B BulldogLowell
                    you do it here:
                    but not here:
                    B Offline
                    B Offline
                    Ben Andrewes
                    @BulldogLowell I didn't even notice the F() thing as I copied that bit of code from the sparkfun example. Thanks for the pointer though - I've update all the Serialprints to include it.
                    I guess that I am so used to not even thinking about memory limits with the GB of mem in everyday device that it hadn't even crossed my mind that I could (and should) choose where to store stuff. 30 yrs ago with my Spectrum 48k it was something to be careful of... The pro mini has almost the same amount memory!
                    • B Offline
                      B Offline
                      Ben Andrewes
                      I've put the updated code below in case it is useful to anyone..
                      I also found that the relays were switching on and off during first boot which was a pain, again my solution is below (I couldn't find a reference to this problem in the forums). As the relays are active low, I set the relay pins to high before setting them as outputs
                        digitalWrite(RELAY_1_PIN , HIGH);  //stops relays cycling state during boot
                        digitalWrite(RELAY_2_PIN , HIGH);  //stops relays cycling state during boot
                       3.3V         VCC              Power
                       GND          GND              Ground
                       A4           SDA              I2C Data
                       A5           SCL              I2C Clock
                       2            INT              Interrupt
                      // #define MY_DEBUG //mysensors protocol debug prints
                      // #define SerialPrints //all the verbose messages that state what the program is doing at certain points e.g. "Requesting message from Domoticz"
                      // #define ImAlive  // Heartbeat in main loop
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                      void before()
                      //Do not get rid of these if statements as they initialise the gesture sensing
                        wait(100);
                        wait(100);
                        wait(100);
                        wait(100);
                        wait(100);
                        wait(100);
                        wait(100);
                        wait(100);
                        wait(100);
                        wait(100);
                      void firstboot()
                        if(FirstBoot)
                      #ifdef SerialPrints
                        Serial.println(F("FirstBoot sequence started"));
                          case 1:
                            #ifdef SerialPrints
                              Serial.print(F("Relay 1 loadstate from EEPROM: "));
                              Serial.print(F("Relay 2 loadstate from EEPROM: "));
                              wait(100);
                              wait(100);
                            #ifdef SerialPrints
                              Serial.print(F("Default Relay state sent to Domoticz: "));
                          case 2:
                              #ifdef SerialPrints
                                Serial.println(F("Relay status requested from Domoticz"));
                                wait(1000);
                                wait(1000);
                          default:
                            #ifdef SerialPrints
                              Serial.print(F("Relays set to default boot state: "));
                              wait(100);
                              wait(100);
                            #ifdef SerialPrints
                            case 1:
                              #ifdef SerialPrints
                                Serial.print(F("Temp Offset retrieved from eeprom: "));
                                wait(100);
                              #ifdef SerialPrints
                                Serial.print(F("tempOffset from sensor sent to Domoticz: "));
                            case 2:
                              #ifdef SerialPrints
                                Serial.println(F("TempOffset value requested from Domoticz"));
                                wait(1000);
                            default:
                              #ifdef SerialPrints
                                Serial.print(F("Default boot temperature offset is: "));
                                wait(100);
                              #ifdef SerialPrints
                            case 1:
                              else {
                              #ifdef SerialPrints
                                Serial.print(F("Error in PIR Enable/Disable Value in EEPROM"));
                                Serial.println(F("Default value used instead"));
                              //Let Domoticz know
                                wait(100);
                              #ifdef SerialPrints
                                Serial.print(F("PIR ENABLE status from sensor sent to Domoticz: "));
                            case 2:
                              #ifdef SerialPrints
                                Serial.println(F("MotionOnOff status requested from Domoticz"));
                                wait(1000);
                            default:
                                wait(100);
                              #ifdef SerialPrints
                                Serial.print(F("Default PIR ENABLE status used and sent to Domoticz: "));
                        wait(2000);
                      #ifdef SerialPrints
                        #ifdef ImAlive
                          Serial.println(F("I'm alive"));
                        FirstBoot = false;
                          handleGesture();
                          isr_flag = 0;
                        if (MotionON) {
                          #ifdef SerialReadings
                            Serial.print(F("New Motion State: "));
                        if (needRefresh)
                        #ifdef ImAlive
                            Serial.println(F("Failed reading temperature from DHT"));
                            if (!metric) {
                            Serial.print(F("T: "));
                            if (!metric) {
                            Serial.println(F("Failed reading humidity from DHT"));
                            lastHum = humidity;
                            Serial.print(F("H: "));
                            lastHum = humidity;
                      #ifdef SerialPrints
                        isr_flag = 1;
                            case DIR_UP:
                              Serial.println(F("UP"));
                            case DIR_DOWN:
                              Serial.println(F("DOWN"));
                            case DIR_LEFT:
                              Serial.println(F("LEFT"));
                            case DIR_RIGHT:
                              Serial.println(F("RIGHT"));
                            case DIR_NEAR:
                              Serial.println(F("NEAR"));
                            case DIR_FAR:
                              Serial.println(F("FAR"));
                            default:
                              Serial.println(F("NONE"));
                      #ifdef SerialPrints
                            case C_SET:
                              Serial.println(F("msg sent by controller"));
                            case C_REQ:
                              Serial.println(F("msg state sent by controller in response to request"));
                            default:
                              Serial.println(F("msg isn't C_SET or C_REQ so what you gonna do?"));
                            Serial.print(F("Incoming Relay 1 State: "));
                            Serial.print(F("Incoming Relay 2 State: "));
                                MotionON = 1;
                                MotionON = 0;
                                Serial.print(F("Motion Sensor on/off state from Domoticz: "));
                          Serial.print(F("Temp Offset value from Domoticz: "));
                      • B Ben Andrewes
                         3.3V         VCC              Power
                         GND          GND              Ground
                         A4           SDA              I2C Data
                         A5           SCL              I2C Clock
                         2            INT              Interrupt
                        DHT dht;
                        float lastTemp;
                        float lastHum;
                        void before()
                          wait(100);
                          wait(100);
                          wait(100);
                          wait(100);
                          wait(100);
                          wait(100);
                          wait(100);
                          wait(100);
                          wait(100);
                          wait(100);
                        void firstboot()
                          if(FirstBoot)
                        #ifdef SerialPrints
                            case 1:
                              #ifdef SerialPrints
                                wait(100);
                                wait(100);
                              #ifdef SerialPrints
                            case 2:
                                #ifdef SerialPrints
                                  wait(1000);
                                  wait(1000);
                            default:
                              #ifdef SerialPrints
                                wait(100);
                                wait(100);
                              #ifdef SerialPrints
                              case 1:
                                #ifdef SerialPrints
                                  wait(100);
                                #ifdef SerialPrints
                              case 2:
                                #ifdef SerialPrints
                                  wait(1000);
                              default:
                                #ifdef SerialPrints
                                  wait(100);
                                #ifdef SerialPrints
                              case 1:
                                else {
                                #ifdef SerialPrints
                                //Let Domoticz know
                                  wait(100);
                                #ifdef SerialPrints
                              case 2:
                                #ifdef SerialPrints
                                  wait(1000);
                              default:
                                  wait(100);
                                #ifdef SerialPrints
                          wait(2000);
                        #ifdef SerialPrints
                          #ifdef ImAlive
                          FirstBoot = false;
                            handleGesture();
                            isr_flag = 0;
                          if (MotionON) {
                          if (needRefresh)
                          #ifdef ImAlive
                              if (!metric) {
                              if (!metric) {
                              lastHum = humidity;
                              lastHum = humidity;
                        #ifdef SerialPrints
                          isr_flag = 1;
                              case DIR_UP:
                              case DIR_DOWN:
                              case DIR_LEFT:
                              case DIR_RIGHT:
                              case DIR_NEAR:
                              case DIR_FAR:
                              default:
                        #ifdef SerialPrints
                              case C_SET:
                              case C_REQ:
                              default:
                                  MotionON = 1;
                                  MotionON = 0;
                        @Ben-Andrewes So with the code rewrite, what does it show your memory usage at?
                        • D dbemowsk
                          B Offline
                          B Offline
                          Ben Andrewes
                          @dbemowsk with all the Serialprints & debugs etc defined, it is 78% of program storage & 65% of variable storage but importantly no warnings from the IDE that memory is low
                          if I comment out all of the defines then it is 49% & 59%. Good result either way.
                          One thing that I'd like to do is to call separate subroutines for e.g. firstboot but I had all sorts of strange results when I didn't just include it in the main loop(). I think this might be because the loop is still, um, looping while these subroutines run - do you think I am right in thinking this is the problem? If so, is there a way around it?
                          Ben
                          • B Ben Andrewes
                            Ben
                            @Ben-Andrewes Sounds like great results. I need to go through my weather station sketch and do this for the same reasons. Thanks for the heads up on the results.
                            • D dbemowsk
                              B Offline
                              B Offline
                              Ben Andrewes
                              @dbemowsk Just looked at your weather station - ace work.
                              I was intrigued by this:
                              #ifdef  DEBUG_ON
                              I think I understand that if DEBUG_ON is defined then wherever you have e.g.
                              DEBUG_PRINT("Hello")
                              The compiler will turn this into serial.print("Hello")
                              My question is what happens if DEBUG_ON is not defined? How does the compiler treat lines such as DEBUG_PRINT("Hello")?
                              Is it that because in the #else part DEBUG_PRINT is defined but not actually defined as anything then the compiler will delete the DEBUG_PRINT("Hello") completely?
                              Sorry for all the questions but I am trying to get my head around compiling vs programming and then how I can use it to make things more efficient...
                              D 2 Replies Last reply
                              • B Ben Andrewes
                                #ifdef  DEBUG_ON
                                In a sense it is ignored. It still defines DEBUG_PRINT(), DEBUG_PRINTLN() and SERIAL_START() because of the #else, but they do nothing if DEBUG_ON is not defined. You can then put DEBUG_PRINT{LN}(x) statements in your code without the need to do the #ifdef DEBUG_ON every time you want to print something for debugging. Makes for a lot cleaner code.
                                I cannot take credit for that bit of code though. That came from the rain gauge sketch in the build section of the site, but I liked it a lot. I should really use it for a bunch of different/separate debugs in that sketch that would allow me to turn on/off separate debugging code for each different sensor.
                                • B Ben Andrewes
                                  #ifdef  DEBUG_ON
                                  No need to be sorry, we all learn, even me. When I first saw that bit of code, I too thought it was genius.
                                  My understanding of things is that lines that start with a hashtag are dealt with by the compiler and are not compiled into the program, to a point. Here is an example.
                                  In the code below, the LED_PIN value is processed by the compiler and is good for static values that don't need to change. The value 5 is not stored in program memory and tied to a variable. If you scatter digitalWrites() throughout your code, allyou have to do is change your #define and you are good to go.
                                  #define LED_PIN 5
                                  pinmode(LED_PIN, OUTPUT);
                                  ... other code ...
                                  digitalWrite(LED_PIN, HIGH);
                                  The code below essentially does the same thing as the previous bit, but if you scatter any digitalWrite() lines in other places in your code and want to make a change, you have to find all of the lines that write to pin 5 and change them. Plus, it is MUCH harder to read and decipher.
                                  pinmode(5, OUTPUT);
                                  ... other code ...
                                  digitalWrite(5, HIGH);
                                  This code is similar. For scattered digitalWrites(), you only need to change the value in one place just like the #define, but uses a variable that is compiled and stored in memory.
                                  INT led_pin = 5;
                                  pinmode(led_pin, OUTPUT);
                                  ... other code ...
                                  digitalWrite(led_pin, HIGH);
                                  All three bits of code will do the same thing. I don't know about other people, but for variables used by the compiler as in a #define, I always make the variable name all upper case. For program variables such as the last example, I try to use lower case. It makes it easier for me to tell which is which.
                                  For this type of situation in my example, I think it is best to use compiler variables. They get rid of the needless use of variable storage space, even if the sketch is small. IMHO, program variables should be used for values that may/will change in your sketch
                                  Hope that helps clear your confusion
                                  • B Ben Andrewes
                                     3.3V         VCC              Power
                                     GND          GND              Ground
                                     A4           SDA              I2C Data
                                     A5           SCL              I2C Clock
                                     2            INT              Interrupt
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                    void before()
                                      wait(100);
                                      wait(100);
                                      wait(100);
                                      wait(100);
                                      wait(100);
                                      wait(100);
                                      wait(100);
                                      wait(100);
                                      wait(100);
                                      wait(100);
                                    void firstboot()
                                      if(FirstBoot)
                                    #ifdef SerialPrints
                                        case 1:
                                          #ifdef SerialPrints
                                            wait(100);
                                            wait(100);
                                          #ifdef SerialPrints
                                        case 2:
                                            #ifdef SerialPrints
                                              wait(1000);
                                              wait(1000);
                                        default:
                                          #ifdef SerialPrints
                                            wait(100);
                                            wait(100);
                                          #ifdef SerialPrints
                                          case 1:
                                            #ifdef SerialPrints
                                              wait(100);
                                            #ifdef SerialPrints
                                          case 2:
                                            #ifdef SerialPrints
                                              wait(1000);
                                          default:
                                            #ifdef SerialPrints
                                              wait(100);
                                            #ifdef SerialPrints
                                          case 1:
                                            else {
                                            #ifdef SerialPrints
                                            //Let Domoticz know
                                              wait(100);
                                            #ifdef SerialPrints
                                          case 2:
                                            #ifdef SerialPrints
                                              wait(1000);
                                          default:
                                              wait(100);
                                            #ifdef SerialPrints
                                      wait(2000);
                                    #ifdef SerialPrints
                                      #ifdef ImAlive
                                      FirstBoot = false;
                                        handleGesture();
                                        isr_flag = 0;
                                      if (MotionON) {
                                      if (needRefresh)
                                      #ifdef ImAlive
                                          if (!metric) {
                                          if (!metric) {
                                          lastHum = humidity;
                                          lastHum = humidity;
                                    #ifdef SerialPrints
                                      isr_flag = 1;
                                          case DIR_UP:
                                          case DIR_DOWN:
                                          case DIR_LEFT:
                                          case DIR_RIGHT:
                                          case DIR_NEAR:
                                          case DIR_FAR:
                                          default:
                                    #ifdef SerialPrints
                                          case C_SET:
                                          case C_REQ:
                                          default:
                                              MotionON = 1;
                                              MotionON = 0;
                                    B Offline
                                    B Offline
                                    BulldogLowell
                                    @Ben-Andrewes said in MultiSensor - relays, temp, hum, PIR, gesture with various controller overrides:
                                    #ifdef SerialPrints
                                    whoopsie... you missed a few.
                                    as a side note,
                                    if you have two identical string constants... the compiler is smart enough to evaluate them as such and store only one and access it accordingly.
                                    also, the following expression means wherever preprocessor sees an argument wrapped in DEBUG_PRINT(), it should replace it with that argument wrapped in Serial.print():
                                    this expression, on the other hand, means wherever preprocessor sees an argument wrapped in DEBUG_PRINT(), it should replace it with nothing:
                                    @dbemowsk said in MultiSensor - relays, temp, hum, PIR, gesture with various controller overrides:
                                    they are actually preprocessor directives, and that happens before compilation.
                                    • B BulldogLowell
                                      #ifdef SerialPrints
                                      as a side note,
                                      @BulldogLowell Thanks, I appreciate the clarification. I revert back to my previous statement, "we all learn, even me". So I assume that my other comments in the post are correct except for the fact that they are preprocessor directives, correct?
                                      • D dbemowsk
                                        #define LED_PIN 5
                                        ... other code ...
                                        pinmode(5, OUTPUT);
                                        ... other code ...
                                        INT led_pin = 5;
                                        ... other code ...
                                        B Offline
                                        B Offline
                                        BulldogLowell
                                        ... I think it is best to use compiler variables. They get rid of the needless use of variable storage space, even if the sketch is small. IMHO, program variables should be used for values that may/will change in your sketch
                                        The problem with using the #define directive for a constant is that they are not strongly typed. That is, suppose you are making a comparison, you may not realize that you are comparing a signed to unsigned number.
                                        You can see this if you compile this example with verbose on:
                                        #define LIMIT 6
                                        const unsigned int limit = 6;
                                          int myVar = 5;
                                          if(myVar > LIMIT){};
                                          if(myVar > limit){};
                                        void loop() {}
                                        in C++, it is generally preferred to use the const keyword over a #define directive; both methods will store the "variable" in FLASH, saving SRAM as you pointed out.
                                        There is (of course) a lot of discourse on this topic (see Stack Overflow).
                                        So there are benefits to using #define. A #define at the top of a program does usually get seen by the programmer (or you, later on, after a hiatus) where they/you may not notice a regular definition on a quick glance #define sort of sticks out in the crowd.
                                        Perhaps that is why you see so much of the #define directive in Arduino programming.
                                        12.1k
