  3. nRF5 action!
nRF5 action!
    sleep(60000); // Sleeps for a minute in deep sleep
    Thanks! That's a big improvement. I'm now reading 51uA. I did the measurements on the Ebyte nRF52832 module, powering it at 3.3v.
    However, to be frank, that's still rather high compared to, say, an atmega328p with a RFM69 radio, which can have a combined sleep current of less than 1uA.
    Is there anything more that can be done to lower the sleep current further?
    rmtuckerR
    rmtuckerR
    rmtucker
    Is that a bare board with nothing connected (Not even serial)?
    • rmtuckerR rmtucker
      Yes. It's the bare Ebyte nRF52832 module. The only connections are Vcc and GND.
      rmtuckerR 1 Reply Last reply
        rmtuckerR
        rmtuckerR
        rmtucker
        Theoretically it should be around 1.9uA
          Interestingly, I just now tried the same measurement with one of these nRF52832 modules instead of the Ebyte module:
          https://www.aliexpress.com/item/nRF52832-Bluetooth-4-1-BLE-Module-M4-Transparent-Transmission-SMA-512K-FLASH-64K-RAM-pass-through/32798522093.html?spm=a2g0s.9042311.0.0.KKA3PF
          and during sleep it measured 6uA. Quite a bit lower!
          Anyone know of a module which tests even lower than that?
          Nca78N 1 Reply Last reply
            Did you use the same board definition in the IDE and the same script ?
            • Nca78N Nca78
              Yes.
                Yes.
                rmtuckerR
                rmtuckerR
                rmtucker
                Have you tried sleep and wait for an external interrupt instead of sleep and wake on timer?
                Just in case it is the lfxtl that is causing the problem.
                  Haven't tried that yet. Is there a library functional call for that, or do I need to start addressing the registers directly? With this new mpu, I feel like I'm learning to walk all over again.
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    Try
                      Try
                      #518
                      Try
                      Unexpected result: using that as the sleep invocation, the infor-link module measures at 14ua while sleeping. i.e. worse, not better, compared to the 6ua measured earlier.
                        #519
                        Looks as though the infor-link is using an A620N crystal:
                        I tried to see if I could find a datasheet for it, in the hope of learning what its current consumption is (or, at least, should be). Unfortunately, though, I couldn't find a datasheet for an A620N.
                          #520
                          Maybe it doesn't matter, because in looking at the actual module I received, it appears to use a different XTAL anyway: A649N.
                            #521
                            Maybe from a current consumption standpoint, not using an external XTAL crystal, but rather relying on the nRF52832's internal resonator would draw less current? I know that's true for the atmega328p. If so, then that's a trade-off worth examining more carefully.
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              Sorry i have been a little distracted because my waveshare BLE400 and jlink just turned up.
                              Took a little time to get it running but i loaded up the mockmysensors sketch with all the sensors un commented and pow all 30 odd sensors showed up in domoticz which made me chuckle.
                              Anyway post your sketch for the consumption testing and i will put it in and see if it works on my board.
                              The only problem is i can not unplug it from the Ble400 because i have no way of connecting wires to the core board because of the smaller pitch pins.
                                @rmtucker
                                Here's the sketch I tested with:
                                * MockMySensors
                                //#define MY_RADIO_NRF24
                                #define MY_RADIO_NRF5_ESB
                                //#define MY_RADIO_RFM95
                                #define MY_NODE_ID 254
                                // Wait times
                                #define LONG_WAIT 500
                                #define SHORT_WAIT 50
                                #define SKETCH_VERSION "v0.5"
                                // Define Sensors ids
                                	S_SCENE_CONTROLLER
                                // one at a time.
                                //#define ID_S_TEMP              7
                                //// Lib 1.5 sensors
                                //#define ID_S_SPRINKLER         29
                                // Global Vars
                                unsigned long SLEEP_TIME = 3600000; // Sleep time between reads (in milliseconds)
                                bool metric = true;
                                long randNumber;
                                #ifdef ID_S_ARMED
                                bool isArmed;
                                #ifdef ID_S_LIGHT
                                bool isLightOn=0;
                                #ifdef ID_S_DIMMER
                                int dimmerVal=100;
                                #ifdef ID_S_COVER
                                #ifdef ID_S_TEMP
                                #ifdef ID_S_HUM
                                #ifdef ID_S_BARO
                                //MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
                                #ifdef ID_S_WIND
                                #ifdef ID_S_RAIN
                                #ifdef ID_S_UV
                                #ifdef ID_S_WEIGHT
                                #ifdef ID_S_POWER
                                #ifdef ID_S_HEATER
                                float heater_setpoint=21.5;
                                //  float heater_temp=23.5;
                                //  bool heater_status=false;
                                #ifdef ID_S_DISTANCE
                                #ifdef ID_S_LIGHT_LEVEL
                                #ifdef ID_S_LOCK
                                bool isLocked = 0;
                                #ifdef ID_S_IR
                                long irVal = 0;
                                #ifdef ID_S_WATER
                                #ifdef ID_S_AIR_QUALITY
                                #ifdef ID_S_DUST
                                #ifdef ID_S_SCENE_CONTROLLER
                                char *scenes[] = {
                                	(char *)"Good Morning",
                                	(char *)"Clean Up!",
                                	(char *)"All Lights Off",
                                	(char *)"Music On/Off"
                                int sceneVal=0;
                                int sceneValPrevious=0;
                                #ifdef ID_S_RGB_LIGHT
                                String rgbState="000000";
                                //RGB light V_RGB, V_WATT
                                #ifdef ID_S_RGBW_LIGHT
                                String rgbwState="00000000";
                                #ifdef ID_S_COLOR_SENSOR
                                //Color sensor	V_RGB
                                #ifdef ID_S_HVAC
                                //Thermostat/HVAC device
                                // NOT IMPLEMENTED YET
                                #ifdef ID_S_MULTIMETER
                                // V_VOLTAGE	38	Voltage level
                                // V_CURRENT	39	Current level
                                #ifdef ID_S_SPRINKLER
                                #ifdef ID_S_WATER_LEAK
                                #ifdef ID_S_SOUND
                                #ifdef ID_S_VIBRATION
                                #ifdef ID_S_MOISTURE
                                #ifdef ID_S_CUSTOM
                                	// Random SEED
                                	randomSeed(analogRead(0));
                                	wait(LONG_WAIT);
                                	Serial.println("GW Started");
                                	Serial.print(SKETCH_NAME);
                                	wait(LONG_WAIT);
                                	Serial.print("Get Config: ");
                                	wait(LONG_WAIT);
                                	// Init Armed
                                #ifdef ID_S_ARMED
                                	isArmed = true;
                                #ifdef ID_S_DOOR
                                	Serial.println("  S_DOOR");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_MOTION
                                	Serial.println("  S_MOTION");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_SMOKE
                                	Serial.println("  S_SMOKE");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_LIGHT
                                	Serial.println("  S_LIGHT");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_DIMMER
                                	Serial.println("  S_DIMMER");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_COVER
                                	Serial.println("  S_COVER");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_TEMP
                                	Serial.println("  S_TEMP");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_HUM
                                	Serial.println("  S_HUM");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_BARO
                                	Serial.println("  S_BARO");
                                	present(ID_S_BARO,S_BARO," Voltage");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_WIND
                                	Serial.println("  S_WIND");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_RAIN
                                	Serial.println("  S_RAIN");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_UV
                                	Serial.println("  S_UV");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_WEIGHT
                                	Serial.println("  S_WEIGHT");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_POWER
                                	Serial.println("  S_POWER");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_HEATER
                                	Serial.println("  S_HEATER");
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_LOCK
                                	Serial.println("  S_LOCK");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_IR
                                	Serial.println("  S_IR");
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_WATER
                                	Serial.println("  S_WATER");
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_DUST
                                	Serial.println("  S_DUST");
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_HVAC
                                	Serial.println("  HVAC");
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_SOUND
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_CUSTOM
                                	Serial.println("  S_CUSTOM");
                                	wait(SHORT_WAIT);
                                	Serial.println("");
                                	Serial.println("");
                                	Serial.println("");
                                	randNumber=random(0,101);
                                	Serial.println(randNumber);
                                	// Send fake battery level
                                	sendBatteryLevel(randNumber);
                                	wait(LONG_WAIT);
                                	// Request time
                                	requestTime();
                                	wait(LONG_WAIT);
                                	//Read Sensors
                                #ifdef ID_S_DOOR
                                	door();
                                #ifdef ID_S_MOTION
                                	motion();
                                #ifdef ID_S_SMOKE
                                	smoke();
                                #ifdef ID_S_LIGHT
                                	light();
                                #ifdef ID_S_DIMMER
                                	dimmer();
                                #ifdef ID_S_COVER
                                	cover();
                                #ifdef ID_S_TEMP
                                	temp();
                                #ifdef ID_S_HUM
                                	hum();
                                #ifdef ID_S_BARO
                                	baro();
                                #ifdef ID_S_WIND
                                	wind();
                                #ifdef ID_S_RAIN
                                	rain();
                                #ifdef ID_S_UV
                                	uv();
                                #ifdef ID_S_WEIGHT
                                	weight();
                                #ifdef ID_S_POWER
                                	power();
                                #ifdef ID_S_HEATER
                                	heater();
                                	distance();
                                	light_level();
                                #ifdef ID_S_LOCK
                                	lock();
                                #ifdef ID_S_IR
                                	ir();
                                #ifdef ID_S_WATER
                                	water();
                                	air();
                                #ifdef ID_S_DUST
                                	dust();
                                	scene();
                                	rgbLight();
                                	rgbwLight();
                                	color();
                                #ifdef ID_S_HVAC
                                	hvac();
                                	multimeter();
                                #ifdef ID_S_SOUND
                                	moisture();
                                #ifdef ID_S_CUSTOM
                                	custom();
                                	wait(SHORT_WAIT);
                                	//wait(SLEEP_TIME); //sleep a bit
                                  //sleep(60000); // Sleeps for a minute in deep sleep
                                  //sleep(6000000); // Sleeps for 100 minutes in deep sleep
                                //void door(){}
                                #ifdef ID_S_DOOR
                                void door()
                                	Serial.print("Door is: " );
                                	if (randNumber <= 50) {
                                		Serial.println("Open");
                                		Serial.println("Closed");
                                #ifdef ID_S_ARMED
                                	Serial.print("System is: " );
                                #ifdef ID_S_MOTION
                                void motion()
                                	Serial.print("Motion is: " );
                                		Serial.println("Active");
                                		send(msg_S_MOTION_T.set(1));
                                		Serial.println("Quiet");
                                		send(msg_S_MOTION_T.set(0));
                                #ifdef ID_S_ARMED
                                #ifdef ID_S_SMOKE
                                void smoke()
                                	Serial.print("Smoke is: " );
                                		send(msg_S_SMOKE_T.set(1));
                                		send(msg_S_SMOKE_T.set(0));
                                #ifdef ID_S_ARMED
                                #ifdef ID_S_LIGHT
                                void light()
                                	Serial.print("Light is: " );
                                #ifdef ID_S_DIMMER
                                void dimmer()
                                	Serial.println(dimmerVal);
                                #ifdef ID_S_COVER
                                void cover()
                                	Serial.print("Cover is : " );
                                	if (coverState == 1) {
                                		Serial.println("Opening");
                                		send(msg_S_COVER_U.set(1));
                                		Serial.println("Closing");
                                		send(msg_S_COVER_D.set(0));
                                		Serial.println("Idle");
                                		send(msg_S_COVER_S.set(-1));
                                #ifdef ID_S_TEMP
                                void temp()
                                #ifdef ID_S_HUM
                                void hum()
                                #ifdef ID_S_BARO
                                void baro()
                                	//long pressure = map(randNumber,1,100,870,1086);// hPa?
                                	//int forecast = map(randNumber,1,100,0,5);
                                   long voltage =  hwCPUVoltage();
                                	Serial.print("Power source voltage is: " );
                                	Serial.println(voltage);
                                	send(msg_S_BARO_P.set(voltage));
                                	//Serial.print("Weather forecast: " );
                                	//send(msg_S_BARO_F.set(weather[forecast]));
                                #ifdef ID_S_WIND
                                void wind()
                                #ifdef ID_S_RAIN
                                void rain()
                                #ifdef ID_S_UV
                                void uv()
                                #ifdef ID_S_WEIGHT
                                void weight()
                                	Serial.print("Weight is: " );
                                #ifdef ID_S_POWER
                                void power()
                                	Serial.print("Watt is: " );
                                	Serial.print("KWH is: " );
                                #ifdef ID_S_HEATER
                                void heater()
                                	//  String heatState="Off";
                                void distance()
                                void light_level()
                                #ifdef ID_S_LOCK
                                void lock()
                                	Serial.print("Lock is: " );
                                #ifdef ID_S_IR
                                void ir()
                                	Serial.println(irVal);
                                	send(msg_S_IR_S.set(irVal));
                                	send(msg_S_IR_R.set(irVal));
                                #ifdef ID_S_WATER
                                void water()
                                void air()
                                #ifdef ID_S_DUST
                                void dust()
                                void scene()
                                	Serial.print("Scene is: " );
                                		sceneValPrevious=sceneVal;
                                void rgbLight()
                                	Serial.println(rgbState);
                                void rgbwLight()
                                	Serial.println(rgbwState);
                                void color()
                                	String colorState;
                                	Serial.println(colorState);
                                #ifdef ID_S_HVAC
                                void hvac()
                                	Serial.println(hvac_Speed);
                                void multimeter()
                                	Serial.println(impedance);
                                	Serial.println(volt);
                                	Serial.println(amps);
                                #ifdef ID_S_SOUND
                                void moisture()
                                #ifdef ID_S_CUSTOM
                                void custom()
                                	switch (message.type) {
                                #ifdef ID_S_ARMED
                                	case V_ARMED:
                                		isArmed = message.getBool();
                                #ifdef ID_S_DOOR
                                		door();//temp ack for door
                                #ifdef ID_S_MOTION
                                		motion();//temp ack
                                #ifdef ID_S_SMOKE
                                		smoke();//temp ack
                                	case V_STATUS: // V_LIGHT:
                                #ifdef ID_S_LIGHT
                                			light(); // temp ack
                                		//    #ifdef ID_S_HEATER
                                		//    #endif
                                #ifdef ID_S_DIMMER
                                	case V_DIMMER:
                                		dimmerVal= message.getInt();
                                		dimmer();// temp ack
                                #ifdef ID_S_COVER
                                	case V_UP:
                                		coverState=1;
                                		Serial.println("V_UP");
                                		cover(); // temp ack
                                	case V_DOWN:
                                		coverState=-1;
                                		Serial.println("V_DOWN");
                                		cover(); //temp ack
                                	case V_STOP:
                                		coverState=0;
                                		Serial.println("V_STOP");
                                		cover(); //temp ack
                                	case V_HVAC_SETPOINT_HEAT:
                                #ifdef ID_S_HEATER
                                			heater();//temp ack
                                #ifdef ID_S_HVAC
                                			hvac();//temp ack
                                	case V_HVAC_FLOW_STATE:
                                #ifdef ID_S_HEATER
                                			heater();//temp ack
                                #ifdef ID_S_HVAC
                                			hvac();//temp ack
                                #ifdef ID_S_LOCK
                                	case V_LOCK_STATUS:
                                		lock(); //temp ack
                                #ifdef ID_S_IR
                                	case V_IR_SEND:
                                		irVal = message.getLong();
                                		ir(); // temp ack
                                	case V_IR_RECEIVE:
                                		ir(); // temp ack
                                	case V_SCENE_ON:
                                		sceneVal = message.getInt();
                                		Serial.println(" On");
                                		scene();// temp ack
                                	case V_SCENE_OFF:
                                		Serial.println(" Off");
                                		scene();// temp ack
                                	case V_RGB:
                                		rgbState=message.getString();
                                		rgbLight(); // temp ack
                                	case V_RGBW:
                                		rgbwLight();
                                #ifdef ID_S_HVAC
                                	//  hvac_SetPointHeat
                                	//  hvac_SetPointCool
                                	//  hvac_FlowState
                                	//  hvac_FlowMode
                                	//  hvac_Speed
                                	case V_HVAC_SETPOINT_COOL:
                                		hvac();//temp ack
                                	case V_HVAC_FLOW_MODE:
                                		hvac();//temp ack
                                	case V_HVAC_SPEED:
                                		hvac();//temp ack
                                	default:
                                		Serial.println(message.type);
                                I selected the board "Nordic nRF52832 DK" in the board manager.
                                You'll need a separate serial gateway running for it to communicate with, or else it will never get to the section where it sleeps.
                                  #524
                                  For the current measurement, just program it with the above sketch on your Waveshare, then unplug your module from the BLE400 board and power it using a GND dupont wire and a Vcc dupont wire connected through your uCurrent Gold, or whatever it is that you're using to measure current. I should think that would work, wouldn't it?
                                  Or do you only have the main board without the smaller plug-in module?
                                  It actually looks like a nice setup.
                                  rmtuckerR 3 Replies Last reply
                                    rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    When you unplug the little board it only has 1.27mm spaced pins and they are not standard dupont size so shy soldering to them which would mean i could not plug it back in to the BLE.
                                    Anyway i am only using a crappy multimeter and with it plugged in and running your sketch i am getting 140uA but i will find a way of unplugging it so hang fire.
                                      @rmtucker you could try to just solder 2 tiny wires on top of the board for vcc and gnd pins so you don't mess with the connectors for plugin it back on the main board ?
                                      • Nca78N Nca78
                                        #527
                                        @Nca78
                                        Agreed. It sounds as though the bigger problem is going to be his crappy multimeter, if that's all he has. Maybe a good time for an upgrade?
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          Ok with my crappy multimeter i am getting 4-5uA with just Vcc and Ground connected.
