nRF5 action!
I have used I2C with an display and u8g2 without any problem.
Yes But it seems to have trouble reading sensors.
It has been mentioned on sandeepmistry github.@rmtucker said in nRF5 Bluetooth action!:
It has been mentioned on sandeepmistry github.I have found this issue: https://github.com/sandeepmistry/arduino-nRF5/issues/180
Is this yours?
Is this yours?
This is strange: now when I do the timed sleep on the infor-link module, it shows a current drain of about 60ua, whereas yesterday it was around 6ua. Maybe I somehow damaged it by connecting a couple of the input pins (A2 and A4) to Vcc? I wouldn't think so, though, because the datasheet says it should be safe to Vcc + 0.3v.
I have one unused infor-link module left. I'll try wiring it up, but without the input pins this time, and measure it. I'm wondering now whether the sleep current will measure out to be 60ua, or 6ua.
The answer is.... neither. This time, with a fresh infor-link module, it measured at about 16ua.
However, I'm guessing there's quite a lot of noise involved, because this time I noticed I could change the reading just by moving my hand closer or further away from the infor-link module. So, I may have to scope this to see what's going on.
So, I decided to try running it from a 10F 2.7v supercap and see how long it lasts. It reports its voltage once every 5 minutes. I'm using Domoticz to log the values and graph them.
Is this yours?
@d00616 said in nRF5 Bluetooth action!:I have used I2C with an display and u8g2 without any problem.
Is this yours?
Does it rest entirely on Sandeep's shoulders as to if/when it gets fixed? I'm trying to understand how big/small the workforce is.
@d00616
No not mine but that is the issue i was talking about.
When connecting DS3231 RTC i get the same as that guy mentions.
When connecting HTU21D the readings are all over the place.@rmtucker said in nRF5 Bluetooth action!:
@d00616
When connecting HTU21D the readings are all over the place.@scalz Have you encountered any I2C problems in your work on Aeos? I seem to recall you have a TH sensor in it.
Is this yours?
@d00616
Trouble is the aeos is using nrf52 not nrf51.At least it would be something, rather than nothing. Wouldn't you rather be on nRF52 anyway? It has advantages. (I say that even though I do have some nRF51's on order, but only just because they're small and cheap).
yes but it would take 4-6weeks and i was impatient so thought i would start with what i could get.
But it seems it does not work on either looking at some of the other issues on sandeeps github.@rmtucker
Hmmmm... Maybe this explains why I didn't notice any MySensor's example demo code that used I2C.On the other hand, I wouldn't think the gap can be all that big if d00616 is able to use I2C for display purposes.
Still, that by itself doesn't get you there.
But it seems it does not work on either looking at some of the other issues on sandeeps github. -
On the 10F supercap, the infor-link module was losing about 0.025v per hour, and that included it reporting its voltage every 5 minutes. So, I've hooked it up to a mini solar panel now so that the supercap will charge during daytime, and with that it should run in perpetuity. :)
@NeverDie nice results! What kind of overcharge protection are you using?
A 2.7v LDO. Very low quiescent current of just 1ua.
I notice someone on AliExpress is selling a similar concept for the nRF52832 to what you're using for the nRF51:
https://www.aliexpress.com/item/NRF52832-Development-Board-NRF52832-Test-Board-Bluetooth-BLE4-2/32824948546.html?spm=2114.search0104.3.1.YoEIHi&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_5430020_5410020_10307_10137_10060_10155_10154_5370011_10056_10055_10054_10059_100031_10099_5400020_10103_10102_10052_10053_10142_10107_10050_10051_5380020_5390020_10084_10083_10119_10080_10082_10081_10178_10110_10111_10112_10113_10114_10312_10313_10314_10315_10078_10079_10073_10120_5420011,searchweb201603_19,ppcSwitch_4&btsid=abd93cae-a709-47f9-989d-0c52b4cde846&algo_expid=450d3875-3c65-41c4-99a8-0a2b5eb4479e-0&algo_pvid=450d3875-3c65-41c4-99a8-0a2b5eb4479e&transAbTest=ae803_3 -
I did another sleep current measurement, this time on a Ebyte module that I had mounted to one of my breakout boards. The sleep current measured between 8ua and 9ua. However, it would jump considerably higher depending on whether I was moving or otherwise close to it. I got the lower measurements by positioning myself about 6 feet away (further than that and it gets hard to read the multimeter that's connected to the uCurrent Gold). I've never seen this kind of behavior before in anything other than the nrf52832 boards. Very curious. They're acting almost like proximity detectors. I have no idea what to make of it, but I thought I'd report it in case anyone else here is doing measurements too.
Also, I'm going to avoid exposing the IO pins to voltages that approach Vcc in magnitude. Despite what the datasheet says, they don't seem to handle it well.
Does anybody know why the function tone() doesn't work for the nrf52?
tone() and other things like NFC are implemented with the new Arduino Primo board. There is no MySensors support at the moment because the Primo comes with the SoftDevice which doesn't allow accessing the complete hardware without using the SoftDevice API, which is not implemented.
What you using for pcb design?
I would like to design something for the waveshare core board to plug into similar to what you just designed for the nrf52832 modules to adapt to 2.54mm pitch headers.
Similar to what you did here but with two sockets on top for the waveshare board.
https://www.openhardware.io/view/436/nRF52832-Breakout-Board
