  3. nRF5 action!
nRF5 action!
  • d00616D d00616
    I have used I2C with an display and u8g2 without any problem.
    Yes But it seems to have trouble reading sensors.
    It has been mentioned on sandeepmistry github.
    I have found this issue: https://github.com/sandeepmistry/arduino-nRF5/issues/180
    Is this yours?
    rmtuckerR
    rmtuckerR
    rmtucker
    @d00616
    No not mine but that is the issue i was talking about.
    When connecting DS3231 RTC i get the same as that guy mentions.
    When connecting HTU21D the readings are all over the place.
      This is strange: now when I do the timed sleep on the infor-link module, it shows a current drain of about 60ua, whereas yesterday it was around 6ua. Maybe I somehow damaged it by connecting a couple of the input pins (A2 and A4) to Vcc? I wouldn't think so, though, because the datasheet says it should be safe to Vcc + 0.3v.
      I have one unused infor-link module left. I'll try wiring it up, but without the input pins this time, and measure it. I'm wondering now whether the sleep current will measure out to be 60ua, or 6ua.
      The answer is.... neither. This time, with a fresh infor-link module, it measured at about 16ua.
      However, I'm guessing there's quite a lot of noise involved, because this time I noticed I could change the reading just by moving my hand closer or further away from the infor-link module. So, I may have to scope this to see what's going on.
      #549
      So, I decided to try running it from a 10F 2.7v supercap and see how long it lasts. It reports its voltage once every 5 minutes. I'm using Domoticz to log the values and graph them.
      • d00616D d00616
        Is this yours?
        #550
        Is this yours?
        Does it rest entirely on Sandeep's shoulders as to if/when it gets fixed? I'm trying to understand how big/small the workforce is.
        rmtuckerR 1 Reply Last reply
        • rmtuckerR rmtucker
          @d00616
          #551
          @d00616
          @scalz Have you encountered any I2C problems in your work on Aeos? I seem to recall you have a TH sensor in it.
            Is this yours?
            rmtuckerR
            rmtuckerR
            rmtucker
            Actually i wonder if development has stopped?
            no new commits in three months?
              @d00616
              rmtuckerR
              rmtuckerR
              rmtucker
              Trouble is the aeos is using nrf52 not nrf51.
                #554
                At least it would be something, rather than nothing. Wouldn't you rather be on nRF52 anyway? It has advantages. (I say that even though I do have some nRF51's on order, but only just because they're small and cheap).
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  yes but it would take 4-6weeks and i was impatient so thought i would start with what i could get.
                  But it seems it does not work on either looking at some of the other issues on sandeeps github.
                  NeverDieN 3 Replies Last reply
                    #556
                    @rmtucker
                    Hmmmm... Maybe this explains why I didn't notice any MySensor's example demo code that used I2C.
                    On the other hand, I wouldn't think the gap can be all that big if d00616 is able to use I2C for display purposes.
                    Still, that by itself doesn't get you there.
                      @rmtucker
                      Bummer. I guess you still have anticimex's suggestion though of the bit-bang workaround, if you're so inclined. If you're able to get that to work, please do post to let us know.
                        #558
                        @NeverDie i have no problem with my aeos (nrf52) and i2c so far. only tested the onboard sensors.
                        agree, in case, you can use a software i2c lib.
                          #559
                          On the 10F supercap, the infor-link module was losing about 0.025v per hour, and that included it reporting its voltage every 5 minutes. So, I've hooked it up to a mini solar panel now so that the supercap will charge during daytime, and with that it should run in perpetuity. :)
                            @NeverDie nice results! What kind of overcharge protection are you using?
                              A 2.7v LDO. Very low quiescent current of just 1ua.
                                @NeverDie thanks. My first supercap is on the way so I'm looking forward to build something with it.
                                  @rmtucker
                                  I notice someone on AliExpress is selling a similar concept for the nRF52832 to what you're using for the nRF51:
                                  https://www.aliexpress.com/item/NRF52832-Development-Board-NRF52832-Test-Board-Bluetooth-BLE4-2/32824948546.html?spm=2114.search0104.3.1.YoEIHi&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_5430020_5410020_10307_10137_10060_10155_10154_5370011_10056_10055_10054_10059_100031_10099_5400020_10103_10102_10052_10053_10142_10107_10050_10051_5380020_5390020_10084_10083_10119_10080_10082_10081_10178_10110_10111_10112_10113_10114_10312_10313_10314_10315_10078_10079_10073_10120_5420011,searchweb201603_19,ppcSwitch_4&btsid=abd93cae-a709-47f9-989d-0c52b4cde846&algo_expid=450d3875-3c65-41c4-99a8-0a2b5eb4479e-0&algo_pvid=450d3875-3c65-41c4-99a8-0a2b5eb4479e&transAbTest=ae803_3
                                    I did another sleep current measurement, this time on a Ebyte module that I had mounted to one of my breakout boards. The sleep current measured between 8ua and 9ua. However, it would jump considerably higher depending on whether I was moving or otherwise close to it. I got the lower measurements by positioning myself about 6 feet away (further than that and it gets hard to read the multimeter that's connected to the uCurrent Gold). I've never seen this kind of behavior before in anything other than the nrf52832 boards. Very curious. They're acting almost like proximity detectors. I have no idea what to make of it, but I thought I'd report it in case anyone else here is doing measurements too.
                                    Also, I'm going to avoid exposing the IO pins to voltages that approach Vcc in magnitude. Despite what the datasheet says, they don't seem to handle it well.
                                    • M Mike_Lemo
                                      Does anybody know why the function tone() doesn't work for the nrf52?
                                      d00616D
                                      d00616D
                                      d00616
                                      tone() and other things like NFC are implemented with the new Arduino Primo board. There is no MySensors support at the moment because the Primo comes with the SoftDevice which doesn't allow accessing the complete hardware without using the SoftDevice API, which is not implemented.
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        wrote on last edited by rmtucker
                                        #566
                                        What you using for pcb design?
                                        I would like to design something for the waveshare core board to plug into similar to what you just designed for the nrf52832 modules to adapt to 2.54mm pitch headers.
                                        0_1502221830970_upload-3b01b675-529e-4554-8142-f232a7d3e827
                                        Similar to what you did here but with two sockets on top for the waveshare board.
                                        https://www.openhardware.io/view/436/nRF52832-Breakout-Board
                                        NeverDieN T 2 Replies Last reply
                                          #567
                                          Diptrace.
                                          Very easy to learn. Watch this tutorial series, and in a little more than an hour you'll know enough to use it for doing real work: https://www.youtube.com/playlist?list=PLWy-YwxbAu8EkNv6iMsfLeH6Yahcwejwx
