  3. nRF5 action!
nRF5 action!
  • rmtuckerR rmtucker
    Yes checked that and it is using the correct wire.h.
    #538
    @rmtucker
    Is there a mysensors demo sketch that involves i2c? I could try it on my end, though I expect I'd probably get the same as you.
    d00616D 1 Reply Last reply
      I see that Amazon is selling the Arduino Primo now: https://www.amazon.com/Arduino-A000138-low-power-coin-sized-wearables/dp/B073JN7XXR/ref=sr_1_12?ie=UTF8&qid=1501982634&sr=8-12&keywords=nrf52832
      First time I've seen it for sale anywhere.
        Toyman
        wrote on last edited by Toyman
        #540
        @NeverDie they also has started to sell "big" Primo
        • T Toyman
          Yeah, the big version has Wi-Fi, so I suspect it's meant to function much like a wireless serial gateway.
          For the convenience of other readers here, here's a link:
          https://www.amazon.com/Arduino-A000135-featuring-Nordic-processor/dp/B0721P6STJ/ref=sr_1_1?ie=UTF8&qid=1502011422&sr=8-1&keywords=arduino+primo
            Maybe you can get much of the same benefits--but at a lower cost--by combining an nRF5 with an ESP8266. Example:
              #543
              This is strange: now when I do the timed sleep on the infor-link module, it shows a current drain of about 60ua, whereas yesterday it was around 6ua. Maybe I somehow damaged it by connecting a couple of the input pins (A2 and A4) to Vcc? I wouldn't think so, though, because the datasheet says it should be safe to Vcc + 0.3v.
              I have one unused infor-link module left. I'll try wiring it up, but without the input pins this time, and measure it. I'm wondering now whether the sleep current will measure out to be 60ua, or 6ua.
                @rmtucker
                d00616D
                d00616D
                d00616
                I have used I2C with an display and u8g2 without any problem.
                With the nRF51 there is an bug, after using the debug interface the current consumption is higher until reset.
                rmtuckerR 1 Reply Last reply
                • d00616D d00616
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  Yes But it seems to have trouble reading sensors.
                  It has been mentioned on sandeepmistry github.
                    #546
                    The answer is.... neither. This time, with a fresh infor-link module, it measured at about 16ua.
                    However, I'm guessing there's quite a lot of noise involved, because this time I noticed I could change the reading just by moving my hand closer or further away from the infor-link module. So, I may have to scope this to see what's going on.
                      d00616D
                      d00616D
                      d00616
                      I have found this issue: https://github.com/sandeepmistry/arduino-nRF5/issues/180
                      Is this yours?
                      rmtuckerR NeverDieN 2 Replies Last reply
                      • d00616D d00616
                        Is this yours?
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        @d00616
                        No not mine but that is the issue i was talking about.
                        When connecting DS3231 RTC i get the same as that guy mentions.
                        When connecting HTU21D the readings are all over the place.
                          #549
                          So, I decided to try running it from a 10F 2.7v supercap and see how long it lasts. It reports its voltage once every 5 minutes. I'm using Domoticz to log the values and graph them.
                          • d00616D d00616
                            Is this yours?
                            #550
                            Is this yours?
                            Does it rest entirely on Sandeep's shoulders as to if/when it gets fixed? I'm trying to understand how big/small the workforce is.
                              @d00616
                              #551
                              @d00616
                              @scalz Have you encountered any I2C problems in your work on Aeos? I seem to recall you have a TH sensor in it.
                                Is this yours?
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                Actually i wonder if development has stopped?
                                no new commits in three months?
                                  @d00616
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  Trouble is the aeos is using nrf52 not nrf51.
                                    #554
                                    At least it would be something, rather than nothing. Wouldn't you rather be on nRF52 anyway? It has advantages. (I say that even though I do have some nRF51's on order, but only just because they're small and cheap).
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      yes but it would take 4-6weeks and i was impatient so thought i would start with what i could get.
                                      But it seems it does not work on either looking at some of the other issues on sandeeps github.
                                      NeverDieN 3 Replies Last reply
                                        #556
                                        @rmtucker
                                        Hmmmm... Maybe this explains why I didn't notice any MySensor's example demo code that used I2C.
                                        On the other hand, I wouldn't think the gap can be all that big if d00616 is able to use I2C for display purposes.
                                        Still, that by itself doesn't get you there.
                                          @rmtucker
                                          Bummer. I guess you still have anticimex's suggestion though of the bit-bang workaround, if you're so inclined. If you're able to get that to work, please do post to let us know.
