  3. Recommendation for PCB fab?
71 Posts 13 Posters 28.1k Views 14 Watching
    I have a not small PCB that I want to have made (let's say 10 copies):
    https://www.openhardware.io/view/436/nRF52832-Breakout-Board
    Seeed Studio can make 10 of them for $5, but the $18 in shipping isn't desirable. On the other hand, it would be cheaper than getting 10 boards done at OSH Park.
    Which good quality fab has both low prices and low shipping costs? Any suggestions?
    @NeverDie how big is it? Looks like less than 50x50mm? Dirtypcbs' protopack perhaps?
      @NeverDie I agree with @mfalkvidd.
      Dirty pcbs produces decent quality boards and allows panalization without extra costs.
      I usually combine some designs in a single 10x10 panel, and fill the remaining space with small adapter boards. Cost per pcb will be very low that way.
      • tbowmoT
        tbowmoT
        tbowmo
        There are some contradictions here, you want things fast, to have top quality, and won't pay for it.. :)
        http://fastgood.cheap/
        That aside, as others have pointed out.. Look at dirtypcbs.. perhaps even panelizing things, there is an excellent tool available for assembling multiple gerbers into one production file http://blog.thisisnotrocketscience.nl/projects/pcb-panelizer/
        mfalkviddM NeverDieN 2 Replies Last reply
        • tbowmoT tbowmo
          @tbowmo I fixed it!
          • tbowmoT tbowmo
            @tbowmo said in Recommendation for PCB fab?:
            No. In my OP, I never said "fast." You read something into it that isn't there.
              @NeverDie then it's simple : panelized ditypcbs :satisfied:
                How does dirtypcb's compare to elecrow? Does Elecrow also let you panelize as well?
                Nca78N 1 Reply Last reply
                  @NeverDie said in Recommendation for PCB fab?:
                  I only made boards for Livolo switches with them so I couldn't panelize.
                  As they have an option to select number of boards that are panelized that adds additional cost, I suppose they will not let you.
                    mtiutiuM
                    mtiutiuM
                    mtiutiu
                    For me, elecrow is the best. But you can query this online tool which is very good: https://pcbshopper.com
                    gohanG 1 Reply Last reply
                    • mtiutiuM mtiutiu
                      wrote on last edited by gohan
                      @mtiutiu I tried to use it some time ago, but I didn't find it very accurate... Maybe it was just me
                        Well, if anyone is in a rush, it sounds like SeeedStudio might be a good choice. @nitroburn ordered 450 boards (I presume they were panelized) on a Saturday, and they were delivered to his door by Wednesday: https://forum.mysensors.org/topic/7231/small-nrf24l01-shield-for-esp8266-wemos-d1-mini/6
                        tbowmoT gohanG 2 Replies Last reply
                          tbowmoT
                          tbowmoT
                          tbowmo
                          that can be done with the other fab house as well, you just have to pay for express service/shipping :)
                            @NeverDie it took over a month for me with the standard shipping, as 10 days were taken by custom for no apparent reason
                              @gohan said in Recommendation for PCB fab?:
                              Which one?
                                Seeed studio. The production was done in a few days, but the shipping with singapore post was the usual 3-4 weeks as all the products from China. Next time I'll try dirtypcb and panelize some pcbs in order to optimize the order
                                  Elecrow charges extra to panelize, but it wasn't clear to me whether they do panelizing or whether you have to submit already panelized gerbers.
                                    The easiest way, if you want to panelize, for cheap, with mouse bites (drills for breakable), has been explained by tbowmo and yveaux above, by using dirtypcb.
                                    Else that needs some tinkering.
                                    I usually use elecrow, and seeedstudio service too. it's up to you to panelize. ask them maybe they'll do it for free, but not sure. i imagine if all people would ask them this..
                                    And doing this, costs the same as ordering separate design boards (which are already milled..).
                                    So when i want to use their service, and not pay for sub boards, i panelize in one bigger board and separate sub boards with silkscreen lines (not milling) and cut them myself (i have saws for this, circular etc.). If you think to add mouse bites for breakable in this case, that won't be ok. They will ask you to remove them and to fix your panel or use their subboards fee.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      dirtypcbs support mousebites to separate pcb's, without extra fees..
                                      It seems that the tool from thisisnotrocketscience is tested primarily with dirtypcbs :)
                                      • tbowmoT tbowmo
                                        @tbowmo is there any guide on how to use that program?
                                        scalzS 1 Reply Last reply
                                          @gohan
                                          maybe you can find some more howtos on google, here is one:
                                          https://hackaday.io/project/19202-small-pcbs-for-panelizing-tutorial/log/59210-panelization-using-gerberpanelizer-on-windows-linux-possible
