  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.9k Views 42 Watching
    Does that work for both nrf24 and rfm69?
    • J
      J
      jolo
      wrote on last edited by jolo
      #106
      Many thanks for help - today I made it work :) Here are my steps that worked for me:
      • I used MYSController 1.0.0 beta, took bootloader MYSBootloaderV13pre.hex and uploaded to Arduino Mini Pro with AVRDUDESS and USBasp programmer
      • then uploaded serial gateway sketch to another Mini Pro
      • attached nR24L01+ radios to both
      • connected MYSController, configured serial connection and all just started to work
      • then uploaded simple DHT sketch, edited csv file in MYSController and selected it for OTA FW update
      After less than minute new FW was already at the node and it started to send data. I am very happy :) I played with Arduino projects for several years, but this stuff you have made is absolutely amazing! Now time for some real nodes - first one will be stepper controller for telescope focuser.
      astrojolo.com
      • J
        J
        jolo
        It still works fine - however I have one more question, maybe stupid :) About RF channels. I use nR24L01+ radios at default channel 76, however for final solution I would like to switch to some higher freq. Does precompiled bootlader work only at this default channel 76? So if I would like to switch to channel 101 I need to compile bootloader with this setting? Or there is some magic behind that makes it work some other way?
        astrojolo.com
        tekkaT 1 Reply Last reply
        • J jolo
          tekkaT
          tekkaT
          tekka
          @jolo Glad to hear that :) re RF24 channel: yes, you need to change and recompile the bootloader for different communication settings. See here: https://github.com/mysensors/MySensorsBootloaderRF24/blob/development/MYSBootloader.c#L45-L51
            moskovskiy82
            Really want to try FOTA with MYSBoatloader but a little bit confused. First - do i have to burn the fuses (i'm using a chinese arduino mini pro 16Mhz) or can simply download MYSBootloader_16MHz.hex from dev brach and i'm good to go?
            Another thing - i'm using an MQTT gateway attached to RPi3. Don't really want to change the gateway type - so is there a way to do OTA update? I have a spare UNO which i can connect to a notebook.
              It was mentioned in a previous thread that mycontroller can do fota also through mqtt
                moskovskiy82
                wrote on last edited by moskovskiy82
                #111
                @gohan Excellent. Searched through the thread but couldn't find any mentions how it can be done via mqtt What about the fuses?
                  Just try using mycontroller, the procedure should be the same as the ethernet gateway
                    moskovskiy82
                    Yes thank you for the tip! Mycontroller works.
                    For Mini Pro - no fuses are needed. Just download the hex - rename and flash.
                    What about the nano?
                    Looking at boards.txt i see only two difeerences
                    Nano
                    nano.menu.cpu.atmega328.bootloader.extended_fuses=0xFD
                    Mys
                    But at the same time PRO mini is same as nano... So can also flash straight away?
                      moskovskiy82
                      Nano also doesn't need any fuses. So everything works. Except to begin the flash procedure i have to unplug and plug the node. Is this intended behaviour? Otherwise i only see in MQTT one line of code and no response from node
                        Is the node doing any kind of sleep?
                          moskovskiy82
                          No it's powered off mains so no sleep functions added
                            I think you have to issue a reboot node from the mycontroller or myscontroller to have the OTA start
                              moskovskiy82
                              @gohan So is it first reboot. Or start flashing - reboot?
                              J 1 Reply Last reply
                                You assign firmware to upload to node and then you send a reboot, if I remember correctly
                                • M moskovskiy82
                                  J
                                  J
                                  jkandasa
                                  @moskovskiy82 If you use MyController, Yes, you should assign the firmware for the node and send reboot.
                                  • J jkandasa
                                    moskovskiy82
                                    #121
                                    @jkandasa Thank you!
                                    One more question. Now need to use a 3,3V arduino Pro (chinese version) (Nano and 5V version flashed via the uno without a hitch)
                                    This is what i put into boards.txt The MYSBootloader_8Mhz.hex is from the dev branch
                                    proMYSBL8.name=ATmega328 8Mhz MYSBootloader
                                    proMYSBL8.upload.tool=avrdude
                                    proMYSBL8.upload.speed=57600
                                    proMYSBL8.bootloader.lock_bits=0xFF
                                    proMYSBL8.bootloader.file=MySensors/MYSBootloader_8Mhz.hex
                                    proMYSBL8.build.board=AVR_UNO
                                    proMYSBL8.build.core=arduino
                                    Tried to flash the mysbootloader but get the following error
                                    C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x06:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
                                    avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
                                             Using Port                    : COM7
                                             Programmer Type : STK500
                                             Hardware Version: 2
                                             Firmware Version: 1.18
                                             Topcard         : Unknown
                                             Vtarget         : 0.0 V
                                             Varef           : 0.0 V
                                             Oscillator      : Off
                                             SCK period      : 0.1 us
                                    Reading | ################################################## | 100% 0.03s
                                    avrdude: erasing chip
                                    avrdude: verifying ...
                                    Writing |  ***failed;
                                    avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
                                    This behaviour is deprecated and will result in an error in future version
                                    You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
                                    C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex:i -Ulock:w:0xFF:m
                                    avrdude done.  Thank you.
                                             Using Port                    : COM7
                                             Hardware Version: 2
                                             Topcard         : Unknown
                                             Vtarget         : 0.0 V
                                             Varef           : 0.0 V
                                             Oscillator      : Off
                                             SCK period      : 0.1 us
                                    avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex"
                                    avrdude: writing flash (32754 bytes):
                                    avrdude: 32754 bytes of flash written
                                    avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex:
                                    avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex:
                                    avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex contains 32754 bytes
                                    avrdude: verification error, first mismatch at byte 0x7800
                                             0x00 != 0x11
                                    luizrrochaL 1 Reply Last reply
                                    • M moskovskiy82
                                               Using Port                    : COM7
                                               Hardware Version: 2
                                               Topcard         : Unknown
                                               Vtarget         : 0.0 V
                                               Varef           : 0.0 V
                                               Oscillator      : Off
                                               SCK period      : 0.1 us
                                               Using Port                    : COM7
                                               Hardware Version: 2
                                               Topcard         : Unknown
                                               Vtarget         : 0.0 V
                                               Varef           : 0.0 V
                                               Oscillator      : Off
                                               SCK period      : 0.1 us
                                               0x00 != 0x11
                                      luizrrochaL
                                      luizrrochaL
                                      luizrrocha
                                      @moskovskiy82 My boards.txt specify bootloader.low_fuses=0xF7 as the Arduino being programmed has a crystal on board.
                                      One other thing: I built my own programming board, to support programming ATMega 328p chips and Pro boards in 3.3v@8MHz and 5v@16Mhz... I used a switch and a level converter board to connect the Uno ICSP port to the pins of the Pro.
                                      Uno pins are 5V output, they would burn the input pins of the 3.3v Pro chip, did you account for that ?
                                        You can use 5v to program a 3.3v pro mini as the chip is the same, one is only clocked down to 8Mhz in order to be stable at 3.3v
                                          luizrrochaL
                                          luizrrochaL
                                          luizrrocha
                                          @gohan I beg to differ. On Page 299 of Atmel's ATMega 328p datasheet you can verify that the Absolute Maximum Ratings table states : "Voltage on any Pin except RESET with respect to Ground . . . . . . . . . .-0.5V to VCC+0.5V" which adds to 3.8V for a 3.3V Pro.
                                          And also: *NOTICE: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device.
                                          Perhaps you have mistaken the Pro for the NRF24L01+ radio which is supplied by 3.3v but has 5Volt tolerant inputs ?
                                          Otherwise there would be no need for those USB to FTDI boards with 3v3/5V selection jumpers ...
