  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.9k Views 42 Watching
  • G gonzalonal
    @mfalkvidd actually looking at the code of mysbootloder, it does support STK500 protocol. I haven't test if it really works...maybe it doesn't.
    @gonzalonal it did not a while ago according to this, but that might have changed. Maybe @tekka can shed a light?
    • tekkaT
      tekkaT
      tekka
      @mfalkvidd The most recent MYSBootloader supports OTA and serial uploads via STK500, see here: https://github.com/mysensors/MySensorsBootloaderRF24/tree/development
      • tekkaT tekka
        @tekka thanks.
        I did look there, but didn't find anything that I understood was related to serial. I also looked at the list of commit messages but none of them mentions anything about added support.
        Anyway, thanks for clarifying. I'll update the ota page again.
          Does that work for both nrf24 and rfm69?
          • J
            J
            jolo
            wrote on last edited by jolo
            #106
            Many thanks for help - today I made it work :) Here are my steps that worked for me:
            • I used MYSController 1.0.0 beta, took bootloader MYSBootloaderV13pre.hex and uploaded to Arduino Mini Pro with AVRDUDESS and USBasp programmer
            • then uploaded serial gateway sketch to another Mini Pro
            • attached nR24L01+ radios to both
            • connected MYSController, configured serial connection and all just started to work
            • then uploaded simple DHT sketch, edited csv file in MYSController and selected it for OTA FW update
            After less than minute new FW was already at the node and it started to send data. I am very happy :) I played with Arduino projects for several years, but this stuff you have made is absolutely amazing! Now time for some real nodes - first one will be stepper controller for telescope focuser.
            astrojolo.com
            • J
              J
              jolo
              It still works fine - however I have one more question, maybe stupid :) About RF channels. I use nR24L01+ radios at default channel 76, however for final solution I would like to switch to some higher freq. Does precompiled bootlader work only at this default channel 76? So if I would like to switch to channel 101 I need to compile bootloader with this setting? Or there is some magic behind that makes it work some other way?
              astrojolo.com
              tekkaT 1 Reply Last reply
              • J jolo
                tekkaT
                tekkaT
                tekka
                @jolo Glad to hear that :) re RF24 channel: yes, you need to change and recompile the bootloader for different communication settings. See here: https://github.com/mysensors/MySensorsBootloaderRF24/blob/development/MYSBootloader.c#L45-L51
                  moskovskiy82
                  Really want to try FOTA with MYSBoatloader but a little bit confused. First - do i have to burn the fuses (i'm using a chinese arduino mini pro 16Mhz) or can simply download MYSBootloader_16MHz.hex from dev brach and i'm good to go?
                  Another thing - i'm using an MQTT gateway attached to RPi3. Don't really want to change the gateway type - so is there a way to do OTA update? I have a spare UNO which i can connect to a notebook.
                    It was mentioned in a previous thread that mycontroller can do fota also through mqtt
                      moskovskiy82
                      wrote on last edited by moskovskiy82
                      #111
                      @gohan Excellent. Searched through the thread but couldn't find any mentions how it can be done via mqtt What about the fuses?
                        Just try using mycontroller, the procedure should be the same as the ethernet gateway
                          moskovskiy82
                          Yes thank you for the tip! Mycontroller works.
                          For Mini Pro - no fuses are needed. Just download the hex - rename and flash.
                          What about the nano?
                          Looking at boards.txt i see only two difeerences
                          Nano
                          nano.menu.cpu.atmega328.bootloader.extended_fuses=0xFD
                          Mys
                          But at the same time PRO mini is same as nano... So can also flash straight away?
                            moskovskiy82
                            Nano also doesn't need any fuses. So everything works. Except to begin the flash procedure i have to unplug and plug the node. Is this intended behaviour? Otherwise i only see in MQTT one line of code and no response from node
                              Is the node doing any kind of sleep?
                                moskovskiy82
                                No it's powered off mains so no sleep functions added
                                  I think you have to issue a reboot node from the mycontroller or myscontroller to have the OTA start
                                    moskovskiy82
                                    @gohan So is it first reboot. Or start flashing - reboot?
                                    J 1 Reply Last reply
                                      You assign firmware to upload to node and then you send a reboot, if I remember correctly
                                      • M moskovskiy82
                                        J
                                        J
                                        jkandasa
                                        @moskovskiy82 If you use MyController, Yes, you should assign the firmware for the node and send reboot.
                                        • J jkandasa
                                          moskovskiy82
                                          #121
                                          @jkandasa Thank you!
                                          One more question. Now need to use a 3,3V arduino Pro (chinese version) (Nano and 5V version flashed via the uno without a hitch)
                                          This is what i put into boards.txt The MYSBootloader_8Mhz.hex is from the dev branch
                                          proMYSBL8.name=ATmega328 8Mhz MYSBootloader
                                          proMYSBL8.upload.tool=avrdude
                                          proMYSBL8.upload.speed=57600
                                          proMYSBL8.bootloader.lock_bits=0xFF
                                          proMYSBL8.bootloader.file=MySensors/MYSBootloader_8Mhz.hex
                                          proMYSBL8.build.board=AVR_UNO
                                          proMYSBL8.build.core=arduino
                                          Tried to flash the mysbootloader but get the following error
                                          C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x06:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
                                          avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
                                                   Using Port                    : COM7
                                                   Programmer Type : STK500
                                                   Hardware Version: 2
                                                   Firmware Version: 1.18
                                                   Topcard         : Unknown
                                                   Vtarget         : 0.0 V
                                                   Varef           : 0.0 V
                                                   Oscillator      : Off
                                                   SCK period      : 0.1 us
                                          Reading | ################################################## | 100% 0.03s
                                          avrdude: erasing chip
                                          avrdude: verifying ...
                                          Writing |  ***failed;
                                          avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
                                          This behaviour is deprecated and will result in an error in future version
                                          You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
                                          C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex:i -Ulock:w:0xFF:m
                                          avrdude done.  Thank you.
                                                   Using Port                    : COM7
                                                   Hardware Version: 2
                                                   Topcard         : Unknown
                                                   Vtarget         : 0.0 V
                                                   Varef           : 0.0 V
                                                   Oscillator      : Off
                                                   SCK period      : 0.1 us
                                          avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex"
                                          avrdude: writing flash (32754 bytes):
                                          avrdude: 32754 bytes of flash written
                                          avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex:
                                          avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex:
                                          avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex contains 32754 bytes
                                          avrdude: verification error, first mismatch at byte 0x7800
                                                   0x00 != 0x11
                                          luizrrochaL 1 Reply Last reply
