  3. πŸ’¬ Micro (nano) ampere meter (double)
measurement
39 Posts 16 Posters 17.8k Views 15 Watching
  • rvendrameR rvendrame
    @Nca78 , my HX711 board looks like yours. I'm a bit confused on how to connect the J1 pins to the load / power. Can you share how did you connected it? Thx!
    @rvendrame said in πŸ’¬ Micro (nano) ampere meter (double):
    Soldering is a bit messy and not helping much to understand, so I did a (gorgeous) drawing. I think I'll frame that in my living room :D
    And in case you want to increase the data rate
    rvendrameR alexsh1A metceynM 4 Replies Last reply
    • Nca78N Nca78
      rvendrameR
      rvendrameR
      rvendrame
      @Nca78 , perfect, thank you! I was right with the two 1K resistors, but I connected the 1R 1W resistors both to E+, instead A+ and B+ separately...
      One more question, how did you connect the load to be measured? Sorry for dumb question, but this is the first time I build such type of device...
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • Nca78N Nca78
        rvendrameR
        rvendrameR
        rvendrame
        @Nca78 , updating: I figured out how to connect the load, so I'm done with it (including calibration).
        I changed the original code a bit, as I also wanted it a bit more responsive. I didn't lift pin 15 as you did.
        BTW, what bootloader + clock are you using? Perhaps that could influence? I'm using MYSBootloaderV13pre.hex, 8Mhz internal clock...
        Changes:
        • Less average reading per cycle (from 32 to 4 ) --> Didn't notice significant changes in measurements.
        • More accumulated avg reads ( from 16 to 32 ) --> Just to keep a less volatile avg numbers in display.
        • Change the logic of short/long press. short press (~1s) = change mode, long press (~3s) = Offset.
        In case you want to give it a try...
        // uA meter with HX711
         PROJECT: MySensors - uA meter with HX711
         PROGRAMMER: AWI
         DATE: 20170414/ last update:
         FILE: AWI_uA_meter.ino
         LICENSE: Public domain
         Performance improvements: rvendrame
        Hardware: tbd Nano ATmega328p board w/ NRF24l01
        Special:
        	program with Arduino Nano
        SUMMARY:
        	Measures mV accross a shunt resistor ~ uA - channel A
        	Measures mV on channel B
        	Modes:
        		- default: measure uV in full resolution (Stable reading only for 0.1uV)
        		- other:
        			A: channel A: default, amplification 128 - div 500: 0.1uV stable,  range +/- 20mV, (1ohm +/- 20mA, res 100 nA)
        			B: channel B: amplification 32 - div 125: 100nA stable, range +/- 80mV,  (10 ohm +/- 8 mA, res 10 nA)
        			AB: both channels:
        		- uA - calibration: depending on the actual shunt:
        			0.47 ohm -> 1 uV ~ 2uA, range -40 mA - 40 mA
        			1 ohm -> 1 uV = 1uA, range -20 mA - 20 mA
        			10 ohm -> 1 uv = 0.1uA
        		- mV - calibration, depend on amplification
        	Button switch:
        		- Short press, reset current channel to offset 0 (keep terminals shorted, no need with uA ;-)
        		- Long press, change channel A (uA) / B(uA)/ A & B (uA)
        	Hx711 24bit weight scale sensor
        		- Noise and temperature sensitive (x bit effective)
        	OLED 128x64 display
        Remarks:
        	Size is large as result of font library for display
        update:
        #include <U8g2lib.h>									// U8glib for OLED display
        #include <Wire.h> 										// I2C
        #include <Button.h>										// https://github.com/JChristensen/Button
        #include "HX711.h"										// local ADC lib
        const double calibrationFactorA = 599.18f ;				// calibration for channel A: set to 1.0 for known current and divide
        const double calibrationFactorB = 149.76f ;				// calibration for channel B: set to 1.0 for known current and divide
        long offsetChannelA = 0 ;								// channel offsets for A and B (drifts) are calibrated at startup and on command.
        long offsetChannelB = 0 ;
        const uint8_t HX711_dout = A1 ;							// HX711 data out pin
        const uint8_t HX711_sck = A0 ;							// HX711 serial clock
        const uint8_t buttonPin = A2 ;							// connects the button to select function and reset offset
        //const unsigned long longPress = 1500UL ;				//	- long press set reference temperature - in ms												// 	- when alarm, short press resets alarm
        Button myBtn(buttonPin, true,  true, 40);				// Declare the button( pin, pullup, invert, debounce ms)
        enum convertMode_t {channelA, channelB, channelAB} ;	// measurement modes, 32 port B / 128 port A / A & B
        HX711 scale;											// instantiate ADC
        // U8G instantiate, Change this constructor to match the display!!!
        U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);   // All Boards without Reset of the Display
        const int nettReadingsSize = 32 ; 						// the number of readings to determine the average and calculate variance/ accuracy
        double lastReading, lastReadingB ;
        double nettReadings[nettReadingsSize] ; 				// store the rolling average of readings
        int nettReadingPointer = 0 ;
        convertMode_t convertMode = channelA ;					// default channelA
        enum state_t {idleState, waitForRelease} ;      // define possible states
        static state_t state = idleState ;
          Serial.println("AWI uA meter");
        	// u8g setup
        	u8g.begin() ;
        	u8g.setFont(u8g2_font_helvR14_tf);					// 'r' = reduced (or 'n' = numeric) font only for size
        	//u8g.setFont(u8g2_font_profont15_tf);					// 'r' = reduced (or 'n' = numeric) font only for size
        	// HX711.DOUT	- pin #A1
        	// HX711.PD_SCK	- pin #A0
        	// if parameter "gain" is ommited; the default value 128 is used by the library
        	//   64 & 128 is port A ; 32 is port B
        	scale.begin(HX711_dout, HX711_sck, 128); 			// set port based on state of selection
        	LCD_banner("Initializing") ;
        	Serial.print("read average: \t\t");
        	Serial.println(scale.read_average(20));  			// print the average of 20 raw readings from the ADC
        	getOffset();										// get the offsets (drift values)
        	scale.set_offset(offsetChannelA) ;					// set it for measured channel
        	scale.set_scale(calibrationFactorA);				// this value is obtained by calibrating with known value; see the README for details
        	Serial.print("read: \t\t");
        	Serial.println(scale.read());						// print a raw reading from the ADC
        	Serial.println(scale.read_average(10));				// print the average of 20 readings from the ADC
        	Serial.print("get value: \t\t");
        	Serial.println(scale.get_value(5));					// print the average of 5 readings from the ADC minus the tare weight, set with tare()
        	Serial.print("get units: \t\t");
        	Serial.println(scale.get_units(5), 3);				// print the average of 5 readings from the ADC minus tare weight, divided by scale
        	Serial.println("Readings:");
        	//Serial.print("one reading:\t");
        	//Serial.print(scale.get_units(), 1);
        	//Serial.print("\t| average:\t");
        	//Serial.println(scale.get_units(30), 3);
          checkButton();
        	// get ADC readings dependent on setting: read A, B or A & B
        	// only A reads has average buffer when A&B mode is selected
        	if (convertMode == channelA){
        		scale.set_gain(128) ;
        		scale.set_scale(calibrationFactorA );			// set division to A value and set mode to A
        		lastReading = scale.get_units(4) ; 			// get value (average 4 readings)corrected with scaling
        		nettReadings[nettReadingPointer] = lastReading ;	// store readings in averagebuffer
        		nettReadingPointer = (++nettReadingPointer) % nettReadingsSize ; // increment and wrap
            checkButton();
            LCD_local_display();
        	} else if (convertMode == channelB){
        		scale.set_gain(32) ;
        		scale.set_offset(offsetChannelB) ;
        		scale.set_scale(calibrationFactorB);			// set division to B value and set mode to B
            checkButton();
        	} else if (convertMode == channelAB){				// if both channels average 128 readings iso 32 (no buffer)
        		scale.set_scale(calibrationFactorA);			// set division to A value and set mode to A
        		lastReading = scale.get_units(2) ; 		  	// get value (average 4 readings)corrected with scaling
        		checkButton();
        		scale.set_scale(calibrationFactorB);			// set division to A value and set mode to A
        		lastReadingB = scale.get_units(2) ; 			// get value (average 4 readings) corrected with scaling
            checkButton();
        		LCD_local_displayAB();
        	//scale.power_down();			       				// put the ADC in sleep mode
        	//delay(500);
        	//scale.power_up();
        	//delay(100);
        void checkButton() {
          myBtn.read();                   // read button state
          switch (state){
             case idleState:                  // Idle
              if (myBtn.wasPressed()) {       // Pressed
                // change channel and wait release
                state = waitForRelease ;
              break ;
            case waitForRelease:
              if (myBtn.pressedFor(3000UL)) {  // Long Press
                 LCD_banner("Offset");
                 getOffset();
                 state = idleState;
              } else if (myBtn.wasReleased()) { // Short Press
                state = idleState;
                switchMode() ;
              break ;
        void LCD_banner(const char *s){
        /* prints all avaiable variables on LCD display with units
        	input: all "last" variables
        	u8g.firstPage();
        	do {
        		int strWidth = u8g.getStrWidth(s) ;				// get the length of the string to determine print position
        		u8g.drawStr((128- strWidth)/2, 40, s ) ;			// print right aligned
        	} while (u8g.nextPage()) ;
        void LCD_local_display(void){
        	char buf[21];  										// buffer for max 20 char display
        	char lastNettBuf[14];
        	dtostrf(lastReading, 10, 2, lastNettBuf);			// Convert real to char
        	char averageNettBuf[14];
        	dtostrf(nettReadingsAverage(), 10, 2, averageNettBuf);	// Convert real to char
        	char spreadNettBuf[14];
        	dtostrf(nettReadingsSpread(), 10, 2, spreadNettBuf);	// Convert real to char
        	Serial.print("Average: \t") ; Serial.print(nettReadingsAverage());
        	Serial.print("\tSpread: \t") ; Serial.println(nettReadingsSpread());
        	u8g.firstPage();
        	do {
            checkButton();
        		snprintf(buf, sizeof buf, "Current %s", (convertMode==channelB)?"B":"A"); // Header
        		int strWidth = u8g.getStrWidth(buf) ;			//   length of the string to determine print position
        		u8g.drawStr((128- strWidth)/2, 14, buf ) ;		//   print middle aligned
        		u8g.drawStr(0,31,"I") ;							// Current
        		snprintf(buf, sizeof buf, "%10s\xB5\A", lastNettBuf);
        		u8g.drawStr((128- strWidth), 31, buf ) ;		//   print right aligned
        		u8g.drawStr(0,47,"avg") ;						// Average current
        		snprintf(buf, sizeof buf, "%10s\xB5\A", averageNettBuf);
        		strWidth = u8g.getStrWidth(buf) ;				// get the length of the string to determine print position
        		u8g.drawStr((128- strWidth), 47, buf ) ;		// print right aligned
        		u8g.drawStr(0,63,"d\xB1") ;						// delta +/-
        		snprintf(buf, sizeof buf, "%10s\xB5\A", spreadNettBuf);
        		u8g.drawStr((128- strWidth), 63, buf ) ;		// print right aligned
        void LCD_local_displayAB(void){
        /* prints A & B channel on LCD display with units
        	char lastNettBufB[14];
        	dtostrf(lastReadingB, 10, 2, lastNettBufB);			// Convert real to char
        	char lastNettBufAB[14];
        	dtostrf(lastReading +lastReadingB, 10, 2, lastNettBufAB);	// Convert real to char for added values
        	u8g.firstPage();
        	do {
            checkButton();
        		snprintf(buf, sizeof buf, "Current A+B"); 		// Header
        		u8g.drawStr(0,31,"IA");							// Current A
        		u8g.drawStr(0,47,"IB");							// Current B
        		snprintf(buf, sizeof buf, "%10s\xB5\A", lastNettBufB);
        		u8g.drawStr(0,63,"A+B");						// Current A + B
        		snprintf(buf, sizeof buf, "%10s\xB5\A", lastNettBufAB);
        // calculate average of nett readings
        double nettReadingsAverage() {
        	double sum = 0;
        	for (byte i = 0; i < nettReadingsSize; i++) {
        		sum += nettReadings[ i ];
        	return sum / nettReadingsSize;
        // calculate spread of nett readings (+/-)
        double nettReadingsSpread() {
        	double minReading = nettReadings[0];
        	double maxReading = minReading ;
        	for (byte i = 1; i < nettReadingsSize; i++) {
            checkButton();
        		if (minReading > nettReadings[ i ]){
        			minReading = nettReadings[i] ;
        		if (maxReading < nettReadings[ i ]){
        			maxReading = nettReadings[i] ;
        	return (maxReading - minReading)/2 ;
        // switch the mode
        void switchMode(){
        		convertMode = channelB ;
        		convertMode = channelAB ;
        // assuming both channels are shorted, calculate the offset values for channel A and B
        double getOffset(){
        	scale.set_gain(128) ;							// get channel A
        	offsetChannelA = scale.read_average(32) ;		// average 512 readings for offset
        	Serial.print("Offset A: \t") ;
        	Serial.println(offsetChannelA);
        	scale.set_gain(32) ;							// get channel B
        	offsetChannelB = scale.read_average(32) ;		// average 512 readings for offset
        	Serial.print("Offset B: \t") ;
        	Serial.println(offsetChannelB);
        Alexa / Google Home
        Nca78N 1 Reply Last reply
          Changes:
           PROGRAMMER: AWI
          Special:
          SUMMARY:
          	Modes:
          		- other:
          			AB: both channels:
          	Button switch:
          	OLED 128x64 display
          Remarks:
          update:
          	// u8g setup
          	u8g.begin() ;
            checkButton();
              checkButton();
              checkButton();
          		checkButton();
              checkButton();
          	//delay(500);
          	//scale.power_up();
          	//delay(100);
            switch (state){
                break ;
                   getOffset();
                   state = idleState;
                  state = idleState;
                  switchMode() ;
                break ;
          	u8g.firstPage();
          	do {
          	u8g.firstPage();
          	do {
              checkButton();
          	u8g.firstPage();
          	do {
              checkButton();
          	double sum = 0;
              checkButton();
          // switch the mode
          void switchMode(){
          double getOffset(){
          @rvendrame thank you I will try it, good idea for the button change.
          Just need to change the code for another screen as I broke my oled :(
            For the short press, with the original code, I noticed that an easy way to get it every time is to press until the display changes, then release. Anyhow, worked for me.
            • mfalkviddM
              @AWI I'm unable to find the "local ADC lib". Is it available somewhere?
              AWIA 1 Reply Last reply
                AWIA
                AWIA
                AWI
                @mfalkvidd the 'local adc' library is the hx711 library which I placed in the sketch folder. Sorry for the confusion
                • AWIA AWI
                  @AWI where can I download it? It does not seem to be compatible with the hx711 library I found through the Arduino IDE Library Manager :(
                  EDIT: Seems to work with https://github.com/bogde/HX711 (if installing it manually)
                  • rmtuckerR
                    rmtuckerR
                    rmtucker
                    I am confused the 1k resistors seem to be wired differently in AWI photo's and Nca78 photo's.
                    I would like to build this but not certain how it is wired now
                    • rmtuckerR rmtucker
                      @rmtucker said in πŸ’¬ Micro (nano) ampere meter (double):
                      If you do like drawn on my post from July 7, it works.
                      rmtuckerR 1 Reply Last reply
                      • Nca78N Nca78
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        @Nca78 said in πŸ’¬ Micro (nano) ampere meter (double):
                        Are the blue and green resistors you have drawn on the back of the adc module the 1k resistors?
                        Have you soldered them on the other side?
                          Yes & yes.
                          • Nca78N Nca78
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @nca78 Exactly the same pin of the IC can be connected to the next pin (VCC) to change the refresh rate.
                            https://github.com/iforce2d/thrustTester/blob/master/README.md
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              I had some spare time and all parts so decided to assemble ampere meter.
                              Firstly, the sketch has to be changed. The lib Button.h does not exist (it has been renamed). It has to be changed to JC_Button.h. This has to be added to setup {}:
                              myBtn.begin();
                              in order for the button to work.
                              My question is this - reading are jumping like a yo-yo despite having a separate power supply (power bank). After calibration, reading maybe +30% or -30% off needless to say that its drifting dynamically. So constant current of 120uA is read +90 or +150 jumping up and down. Is this the way this meter is supposed to work?
                                soroush_habibi
                                Can you make a schematic of this circuit please?
                                I need this project.
                                • V
                                  V
                                  vidalv
                                  Hello, is there, somewhere, a real complete diagram of this project? This subject is interesting but not clearly documented ... It's a shame! Thank you.
                                  • E
                                    E
                                    Enzo65
                                    Hi, pin A+ and pin B+ are connected together, on the same terminal block?
                                    • metceynM
                                      metceynM
                                      metceyn
                                      @mfalkvidd If you have something related to this project, can you share it? (circuit schema or something)
                                      mfalkviddM Nca78N 2 Replies Last reply
                                      • metceynM metceyn
                                        @Metin-Can-AYAR sorry, I have nothing.
                                        E 1 Reply Last reply
                                        • metceynM metceyn
                                          @metceyn said in πŸ’¬ Micro (nano) ampere meter (double):
                                          Hello, I will try to work again on this project in the coming days, I have made one years ago but reused (then broke !) the screen so it's not fonctional now. I will use another screen and make a functional one again as I will need it for some project.
                                          metceynM 1 Reply Last reply
                                          With your input, this post could be even better πŸ’—
