  3. nRF5 action!
nRF5 action!
    @d00616
    The specification for the nRF52832 advertises: "Fast wake-up using 64 MHz internal oscillator."
    However, there's not a menu item in the tool menu to set that. So, how is it done?
      MY_PASSIVE_NODE,
      I found a shlocky workaround for the current problems with MY_PASSIVE_NODE. It turns out that if you have the gateway up and running before the passive node power up, then the passive node often gets stuck in a loop trying to register itself. However, for whatever reason, if you first power up the passive node, let it run for a bit trying to register and failing, and then power on the gateway, the loop is avoided. Then the passive node will broadcast one packet per cycle and the gateway will receive it and send it to the serial port.
      Unfortunately, Domoticz can't really deal with it.
      Soooooo... For now, I'm using Termite on the serial port to capture the packets and time stamp them. That at least allows me to continue with measurements as to whether MY_PASSIVE_NODE saves significant energy or not. It also has 1 second resolution, not the 5 minute time resoluton of Domoticz.
      MY_PASSIVE_NODE,
      Good news! Using the above method, I've established that the EByte nRF52832 module consumes an order of magnitude less current if "MY_PASSIVE_NODE" is defined. :) :) :)
      Nca78N 1 Reply Last reply
        MY_PASSIVE_NODE,
        Does that mean you are reaching consumption levels as low as atmega+nrf24 ?
        • Nca78N Nca78
          #631
          Not for all cases, but maybe for this case, provided I can run it off of both of its internal resonators (the 32Khz and the 64Mhz). The datasheet promises a "fast wakeup" if run off the internal 64mHz resonator, and its access to the radio should be a lot faster through DMA, which is automatic.
          Presently, running it all night long (12 hours), it lost less than 50mv off the supercap, and some of that is probably just self-discharge by the supercap.
          Also, getting the DCDC to work would no doubt help...
            #632
            Maybe using the internal oscillator doesn't matter. Thge datasheet says, "The HFXO must be running to use the RADIO..."
            i.e. without the external 64Mhz oscillator, the radio can't be used. So, if that's true, then I guess from my point of view the 64Mhz external oscillator isn't optional after all. Perhaps that explains why there is one on literaly every module I've seen so far.
              #633
              I'm ordering today some AVX supercaps with smaller Farad values so that I can get more resolution on the amount of energy (at least relatively) being consumed in different configurations.
                #634
                I received the nRF51822 modules I had ordered (center of photograph):
                Small enough to fit almost anywhere!
                  @Nca78
                  Did you ever figure out how to reset the MCU on the Ebyte module?
                    I tried my nrf24l01 pa lna sma but it seemed to be only working every now and again so waiting on a new one being delivered.
                    According to hackaday, there's a certain very common model which doesn't perform well unless you wrap it first in saran wrap (as an electrical insulator) and then in aluminum foil (except for the antenna, obviously).
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    I connected a new amplified nrf24 to the gateway with the tin foil as mentioned and it is reading -60dB compared to -89dB with the non amplified version.
                    Now lets see how far it goes past the original test.😉
                    rmtuckerR NeverDieN 2 Replies Last reply
                    • rmtuckerR rmtucker
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      @rmtucker
                      Well outside of the garden now no problem.😊
                      On to supercaps now i think.😉
                        #638
                        Did the tin foil make a difference? Hackaday seemed to think it made a big difference. I haven't tried it yet.
                        rmtuckerR 1 Reply Last reply
                          rmtuckerR
                          rmtuckerR
                          rmtucker
                          I think it did but what do you have to lose😉
                            Here's the Hackaday article: http://hackaday.com/2016/05/31/fixing-the-terrible-range-of-your-cheap-nrf24l01-palna-module/
                              @Nca78
                              @Nca78
                              Sorry didn't touch my NRF5 in the last weeks. A bit busy on other things...
                                #642
                                What's the best way to make a "receive only" gateway? i.e. one that cannot transmit? Then I wouldn't need to worry about whether the gateway is turned on before powering up a MY_PASSIVE_NODE sensor mote. Is there a way to do it simply in hardware, or do I have to sabotage the gateway library code?
                                  #643
                                  It's getting too baroque. What I'd really like to have is a short nRF5 library of just the bare essentials (like the MIRF library is for the RF24).
                                  d00616D 1 Reply Last reply
                                    Hmmm... it looks like radiohead may be such a library: http://www.airspayce.com/mikem/arduino/RadioHead/classRH__NRF52.html
                                      d00616D
                                      d00616D
                                      d00616
                                      You can take a look into the actual Nordic NRF SDK. There are the ESB library for nRF24 compatible communication.
                                      • d00616D d00616
                                        The RadioHead library seems very easy to pickup and start using. Maybe it's me, but I can't say the same for the Nordic SDK.
                                        Interestingly, it looks as though @Yveaux may (?) have written the nRF51 part of the RadioHead library.
                                          I was able to program the tiny nRF51822 (earlier photograph above) by programming it as an xxaa Generic nRF51 with an RC oscillator.
                                          Nice!
