  3. nRF5 action!
nRF5 action!
  • Nca78N Nca78
    Good news! Using the above method, I've established that the EByte nRF52832 module consumes an order of magnitude less current if "MY_PASSIVE_NODE" is defined. :) :) :)
    Does that mean you are reaching consumption levels as low as atmega+nrf24 ?
    #631
    Not for all cases, but maybe for this case, provided I can run it off of both of its internal resonators (the 32Khz and the 64Mhz). The datasheet promises a "fast wakeup" if run off the internal 64mHz resonator, and its access to the radio should be a lot faster through DMA, which is automatic.
    Presently, running it all night long (12 hours), it lost less than 50mv off the supercap, and some of that is probably just self-discharge by the supercap.
    Also, getting the DCDC to work would no doubt help...
      #632
      Maybe using the internal oscillator doesn't matter. Thge datasheet says, "The HFXO must be running to use the RADIO..."
      i.e. without the external 64Mhz oscillator, the radio can't be used. So, if that's true, then I guess from my point of view the 64Mhz external oscillator isn't optional after all. Perhaps that explains why there is one on literaly every module I've seen so far.
        #633
        I'm ordering today some AVX supercaps with smaller Farad values so that I can get more resolution on the amount of energy (at least relatively) being consumed in different configurations.
          #634
          I received the nRF51822 modules I had ordered (center of photograph):
          Small enough to fit almost anywhere!
            @Nca78
            Did you ever figure out how to reset the MCU on the Ebyte module?
            Nca78N 1 Reply Last reply
              I tried my nrf24l01 pa lna sma but it seemed to be only working every now and again so waiting on a new one being delivered.
              According to hackaday, there's a certain very common model which doesn't perform well unless you wrap it first in saran wrap (as an electrical insulator) and then in aluminum foil (except for the antenna, obviously).
              rmtuckerR
              rmtuckerR
              rmtucker
              I connected a new amplified nrf24 to the gateway with the tin foil as mentioned and it is reading -60dB compared to -89dB with the non amplified version.
              Now lets see how far it goes past the original test.😉
              rmtuckerR NeverDieN 2 Replies Last reply
              • rmtuckerR rmtucker
                rmtuckerR
                rmtuckerR
                rmtucker
                @rmtucker
                Well outside of the garden now no problem.😊
                On to supercaps now i think.😉
                  #638
                  Did the tin foil make a difference? Hackaday seemed to think it made a big difference. I haven't tried it yet.
                  rmtuckerR 1 Reply Last reply
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    I think it did but what do you have to lose😉
                      Here's the Hackaday article: http://hackaday.com/2016/05/31/fixing-the-terrible-range-of-your-cheap-nrf24l01-palna-module/
                        @Nca78
                        @Nca78
                        Sorry didn't touch my NRF5 in the last weeks. A bit busy on other things...
                          #642
                          What's the best way to make a "receive only" gateway? i.e. one that cannot transmit? Then I wouldn't need to worry about whether the gateway is turned on before powering up a MY_PASSIVE_NODE sensor mote. Is there a way to do it simply in hardware, or do I have to sabotage the gateway library code?
                            #643
                            It's getting too baroque. What I'd really like to have is a short nRF5 library of just the bare essentials (like the MIRF library is for the RF24).
                            d00616D 1 Reply Last reply
                              Hmmm... it looks like radiohead may be such a library: http://www.airspayce.com/mikem/arduino/RadioHead/classRH__NRF52.html
                                d00616D
                                d00616D
                                d00616
                                You can take a look into the actual Nordic NRF SDK. There are the ESB library for nRF24 compatible communication.
                                • d00616D d00616
                                  The RadioHead library seems very easy to pickup and start using. Maybe it's me, but I can't say the same for the Nordic SDK.
                                  Interestingly, it looks as though @Yveaux may (?) have written the nRF51 part of the RadioHead library.
                                    I was able to program the tiny nRF51822 (earlier photograph above) by programming it as an xxaa Generic nRF51 with an RC oscillator.
                                    Nice!
                                      Here's a close-up photo:
                                        FWIW, range on the tiny nRF51822 does seem compromised when compared against larger sized nRF52832 modules. Not really surprising, but I had hoped it might be a little better than it is.
                                          d00616D
                                          d00616D
                                          d00616
                                          This is an idea, I don't know if this helps. The two pins near the antenna are GND. Try to solder an 3cm isolated wire to the pin near your PCB and route it parallel of your pcb away from the nRF51 board. The extends the GND pane size.
