Can't load from Codebender :-(
My first go in a long while at making sensors and playing with Arduino. I have build the Ethernet Gateway, and am trying to upload the sketch using my Chrome browser and the Codebender Plugin. I Clone and edit the sketch, and it asked me if I want to use the libraries, and I say yes. I ask it to verify the code, and I get this message:Looks like your project uses header files or libraries that do not exist in our system, in your personal libraries or in your sketch. More info
In file included from libraries/16221_cb_personal_lib_MySensors/Relay.cpp:12:
In file included from libraries/16221_cb_personal_lib_MySensors/Relay.h:15:
libraries/16221_cb_personal_lib_MySensors/Sensor.h:23:10: fatal error: 'EEPROM.h' file not found
#include <EEPROM.h>
1 error generated.Can someone tell me what the problem is?
Which browser do you use?
See http://www.mysensors.org/build/arduino:
Some browsers might need some extra care to get the plugin working.
I also read:
The code compiles on cloud server with all libraries installed and ready to use.
So did you get the code from http://www.mysensors.org/build/ethernet_gateway ?
@daulagari said:
I can clone and verify sketch without any problems on my mac with chrome (just tested).
But if you want to use the Ethernet sketch with the W5100 you still have to use the download Arduino IDE and modify things in sourcecode according to instructions.
Ok cool, thanks for checking this for me :-)
I am trying to use the W5100. I am having troubles trying to understand how to follow the instructions on how to edit. Can I edit and then still use the Codebender Plugin?
:-( I'm hopeless..... I had this working months ago with the same parts, but it won't work. Last time I used the Codebender plugin, because it just wouldn't work on the computer. Now that I have to edit stuff, i am trying to do it on the computer, but it won't work. This is what I get:
Arduino: 1.0.6 (Mac OS X), Board: "Arduino Uno"
EthernetGateway:75: error: 'MyGateway' does not name a type
EthernetGateway:81: error: 'MAX_RECEIVE_LENGTH' was not declared in this scope
EthernetGateway.ino: In function 'void setup()':
EthernetGateway:87: error: 'gw' was not declared in this scope
EthernetGateway:87: error: 'RF24_PA_LEVEL_GW' was not declared in this scope
EthernetGateway:87: error: 'RF24_CHANNEL' was not declared in this scope
EthernetGateway:87: error: 'RF24_DATARATE' was not declared in this scope
EthernetGateway.ino: In function 'void loop()':
EthernetGateway:116: error: 'MAX_RECEIVE_LENGTH' was not declared in this scope
EthernetGateway:121: error: 'inputString' was not declared in this scope
EthernetGateway:126: error: 'gw' was not declared in this scope
EthernetGateway:132: error: 'inputString' was not declared in this scope
EthernetGateway:141: error: 'gw' was not declared in this scope -
I just did what the output suggested. Here is what I get:
/Users//Desktop/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -I/Users//Desktop/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino -I/Users//Desktop/Arduino.app/Contents/Resources/Java/hardware/arduino/variants/standard -I/Users//Desktop/Arduino.app/Contents/Resources/Java/libraries/SPI -I/Users/*****/Desktop/Arduino.app/Contents/Resources/Java/libraries/Ethernet /var/folders/b6/mgvw5s257pd5pyz73nwwt4_r0000gn/T/build8097901850594856372.tmp/EthernetGateway.cpp -o /var/folders/b6/mgvw5s257pd5pyz73nwwt4_r0000gn/T/build8097901850594856372.tmp/EthernetGateway.cpp.o
EthernetGateway.ino:41:90: warning: DigitalIO.h: No such file or directory
EthernetGateway.ino:43:22: warning: MySensor.h: No such file or directory
EthernetGateway.ino:44:25: warning: MyGateway.h: No such file or directory
Nope, looks like I celebrated too early....Vera can't communicate with the gateway, and I can't ping it. After uploading the sketch again I dug a little more and a find this:
n file included from /Users//Documents/Arduino/libraries/DigitalIO/DigitalIO.h:34,
from EthernetGateway.ino:35:
/Users//Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h: In member function 'bool SoftI2cMaster::writeScl(bool)':
/Users//Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:146: warning: no return statement in function returning non-void
/Users//Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h: In member function 'bool SoftI2cMaster::writeSda(bool)':
/Users/*/Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:159: warning: no return statement in function returning non-voidAt this stage I have no idea what I need to do to fix this, but I'll look and see what I find. Fingers crossed...
OK, I am starting to feel really dumb... Many months ago I had the Ethernet Gateway working great, but I left it to pursue other stuff until now. I figure I would update stuff, but I should have left it all alone...
Anyways, I am tired of trying to do this on my computer and not getting anywhere, so I am trying again using Codebender. For everyones info, this is what Codebender tells me:
In file included from libraries/16221_cb_personal_lib_MySensors/Sensor.h:18:
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:47:3: error: unknown type name 'uint8_t'
uint8_t ce_pin; /< "Chip Enable" pin, activates the RX or TX role */
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:48:3: error: unknown type name 'uint8_t'
uint8_t csn_pin; /< SPI Chip select /
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:51:3: error: unknown type name 'uint8_t'
uint8_t payload_size; /< Fixed size of payloads */
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:53:3: error: unknown type name 'uint64_t'
uint64_t pipe0_reading_address; /< Last address set on pipe 0 for reading. /
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:73:8: error: unknown type name 'uint8_t'
RF24(uint8_t _cepin, uint8_t _cspin);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:73:24: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:139:25: error: unknown type name 'uint8_t'
void read( void buf, uint8_t len );
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:162:32: error: unknown type name 'uint8_t'
bool write( const void buf, uint8_t len );
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:182:24: error: unknown type name 'uint64_t'
void openWritingPipe(uint64_t address);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:208:24: error: unknown type name 'uint8_t'
void openReadingPipe(uint8_t number, uint64_t address);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:208:40: error: unknown type name 'uint64_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:217:26: error: unknown type name 'uint8_t'
void closeReadingPipe( uint8_t pipe ) ;
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:245:18: error: unknown type name 'uint8_t'
bool available(uint8_t* pipe_num);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:279:32: error: unknown type name 'uint8_t'
bool write( const void* buf, uint8_t len, const bool multicast );
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:312:36: error: unknown type name 'uint8_t'
bool writeFast( const void* buf, uint8_t len );
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:325:36: error: unknown type name 'uint8_t'
bool writeFast( const void* buf, uint8_t len, const bool multicast );
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:355:40: error: unknown type name 'uint8_t'
bool writeBlocking( const void* buf, uint8_t len, uint32_t timeout );
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:355:53: error: unknown type name 'uint32_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:403:19: error: unknown type name 'uint32_t'
bool txStandBy(uint32_t timeout);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:419:24: error: unknown type name 'uint8_t'
void writeAckPayload(uint8_t pipe, const void* buf, uint8_t len);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:419:55: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:485:41: error: unknown type name 'uint8_t'
void startFastWrite( const void* buf, uint8_t len, const bool multicast );
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:511:37: error: unknown type name 'uint8_t'
void startWrite( const void* buf, uint8_t len, const bool multicast );
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:537:3: error: unknown type name 'uint8_t'
uint8_t flush_tx(void);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:607:19: error: unknown type name 'uint8_t'
void setRetries(uint8_t delay, uint8_t count);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:607:34: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:614:19: error: unknown type name 'uint8_t'
void setChannel(uint8_t channel);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:628:23: error: unknown type name 'uint8_t'
void setPayloadSize(uint8_t size);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:637:3: error: unknown type name 'uint8_t'
uint8_t getPayloadSize(void);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:650:3: error: unknown type name 'uint8_t'
uint8_t getDynamicPayloadSize(void);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:699:20: error: unknown type name 'uint8_t'
void setAutoAck( uint8_t pipe, bool enable ) ;
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:712:21: error: unknown type name 'uint8_t'
void setPALevel ( uint8_t level );
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:722:4: error: unknown type name 'uint8_t'
uint8_t getPALevel( void );
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:3: error: unknown type name 'uint8_t'
uint8_t read_register(uint8_t reg, uint8_t* buf, uint8_t len);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:25: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:38: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:52: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:810:3: error: unknown type name 'uint8_t'
uint8_t read_register(uint8_t reg);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:810:25: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:3: error: unknown type name 'uint8_t'
uint8_t write_register(uint8_t reg, const uint8_t* buf, uint8_t len);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:26: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:45: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:59: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:829:3: error: unknown type name 'uint8_t'
uint8_t write_register(uint8_t reg, uint8_t value);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:829:26: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:829:39: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:840:3: error: unknown type name 'uint8_t'
uint8_t write_payload(const void* buf, uint8_t len, const uint8_t writeType);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:840:42: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:840:61: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:851:3: error: unknown type name 'uint8_t'
uint8_t read_payload(void* buf, uint8_t len);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:851:35: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:858:3: error: unknown type name 'uint8_t'
uint8_t flush_rx(void);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:865:3: error: unknown type name 'uint8_t'
uint8_t get_status(void);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:874:21: error: unknown type name 'uint8_t'
void print_status(uint8_t status);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:883:25: error: unknown type name 'uint8_t'
void print_observe_tx(uint8_t value);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:896:46: error: unknown type name 'uint8_t'
void print_byte_register(const char* name, uint8_t reg, uint8_t qty = 1);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:896:59: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:909:49: error: unknown type name 'uint8_t'
void print_address_register(const char* name, uint8_t reg, uint8_t qty = 1);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:909:62: error: unknown type name 'uint8_t'
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:923:3: error: unknown type name 'uint8_t'
uint8_t spiTrans(uint8_t cmd);
libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:923:20: error: unknown type name 'uint8_t'
#include <EEPROM.h>
62 errors generated.Looks to me like the issue is maybe the linked libraries aren't accessable to everyone, which is why it repports that they are missing??
I don't think there is any point continuing to try and sort this out using Codebender. My guess is that the libraries attached to the sketches don't match anymore or something like that, because I have tried both types of gateways, as well as a couple sensors, and I'm getting errors all the time.
OK, I am trying again on my computer, and I get a lot further than using Codebender. Again, the message I am getting is this:
In file included from /Users//Documents/Arduino/libraries/DigitalIO/DigitalIO.h:34,
from EthernetGateway.ino:34:
/Users//Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:143: warning: no return statement in function returning non-void
/Users/***/Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:156: warning: no return statement in function returning non-voidCan anyone point me in the right direction as to how to fix this?
