  2. Announcements
  • Richard van der PlasR Richard van der Plas
    hi there, somehow my gateway seems to stop receiving data after a day or so from my sensors,
    restarting the service seems to solve it for a time, how can i troubleshoot this issue ?
    @Richard-van-der-Plas what version are you using?
    Carl HC Richard van der PlasR 2 Replies Last reply
      Carl HC
      Carl HC
      Carl H
      @gohan for me version dev (2.2)
      • skywatchS
        skywatchS
        skywatch
        dev 2.2.0 beta
          Have you tried both ethernet or mqtt?
            @gohan the latest stable version i guess. Where can i check?
            gohanG 1 Reply Last reply
              @Richard-van-der-Plas try the 2.2 beta, it usually works better
              Richard van der PlasR 1 Reply Last reply
                @gohan just checked it's 2.1.1, is it easy to upgrade?
                  @Richard-van-der-Plas just clone the 2.2 dev instead of the stable, the rest is the same
                    @gohan fatal: destination path 'MySensors' already exists and is not an empty directory. It goes wrong with the first command, could you please give me some pointers ?
                      you need to either delete or rename the Mysensors folder :)
                      • llegoffL
                        llegoffL
                        llegoff
                        I designed a PCB for rfm or nrf -> raspberry pi
                        https://www.openhardware.io/view/470/MySensors-Gateway-for-Raspberry-PI
                          I am trying to get the gateway to run the RFM69W radio but when I issue the "make" command I get this
                          In file included from ./MySensors.h:318:0,
                                           from examples_linux/mysgw.cpp:83:
                          ./drivers/RFM69/new/RFM69_new.cpp:658:12: warning: ‘void RFM69_ATCmode(bool, int16_t)’ defined but not used [-Wunused-function]
                           LOCAL void RFM69_ATCmode(const bool onOff, const int16_t targetRSSI)
                          It is latest beta.
                            It is latest beta.
                            #629
                            @gohan what configure command did you use? Knowing that would make it easier to reproduce the problem...
                            Does this warning cause any problem?
                              Just simple rfm69w 433 with default options. It compiles but I get no communication with nodes and 100% processor, but maybe I did a bad wiring
                                @gohan debug output could be useful ;-)
                                  wrote on last edited by gohan
                                  #632
                                  I would have posted it but it just shows as no nodes are trying to connect and nodes are unable to find a parent of course. I'm using the rfm2nrf pcb in order to have the pins to connect to the raspberry.
                                  PS here is the log of the startup
                                   __  __       ____
                                          |___/                      2.2.0-beta
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: TSM:INIT:TSP OK
                                  mysgw: TSM:INIT:GW MODE
                                  mysgw: MCO:REG:NOT NEEDED
                                  mysgw: MCO:BGN:STP
                                  mysgw: MCO:BGN:INIT OK,TSP=1
                                  mysgw: Client 0 connected
                                  mysgw: Client 0: 0;0;3;0;2;
                                    On my test RPI3 it is working.... I have to double check the other one.
                                      @gohan Hi there updated to the latest dev, but i still have to restart the service after a few days, this is the message in the log:
                                      Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Closing socket at ('192.168.1.115', 5003).#033[0m
                                      Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Socket closed at ('192.168.1.115', 5003).#033[0m
                                      Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] No response. Disconnected.#033[0m
                                      Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.115', 5003)#033[0m
                                      checking with top, i see high CPU utilization:
                                      20921 root      20   0   20036    872    784 R  CPU ->99,5  0,1 682:53.59 mysgw
                                      • C ccy
                                        @Grubstake: Thanks. I have tried to follow "NRF24L01+ Radio" pin out connection. I have double / triple check my wiring is correct. But I still get the same fail message in mysgw debug mode:
                                        [root@alarmpi bin]# ./mysgw -d
                                        mysgw: Starting gateway...
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: !TSM:INIT:TSP FAIL
                                        mysgw: TSM:FAIL:CNT=1
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:FAIL:RE-INIT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:CNT=2
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:CNT=3
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: Received SIGINT
                                        Here is my /boot/config.txt:
                                        gpu_mem=64
                                        initramfs initramfs-linux.img followkernel
                                        dtparam=spi=on
                                        and the spi dev:
                                        # ls /dev/spidev0.*
                                        I am using ArchLinuxARM:
                                        # uname -a
                                        Linux alarmpi 4.9.13-3-ARCH #1 SMP Fri Mar 3 18:45:16 MST 2017 armv7l GNU/Linux
                                        I only wiring 7 pins (1-7) on NRF24l01+.
                                        Raspberry Pi 2 hardware information:
                                        # cat /proc/cpuinfo
                                        processor       : 0
                                        model name      : ARMv7 Processor rev 5 (v7l)
                                        BogoMIPS        : 38.40
                                        Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
                                        CPU implementer : 0x41
                                        CPU architecture: 7
                                        CPU variant     : 0x0
                                        CPU part        : 0xc07
                                        CPU revision    : 5
                                        processor       : 1
                                        BogoMIPS        : 38.40
                                        CPU architecture: 7
                                        CPU variant     : 0x0
                                        CPU part        : 0xc07
                                        CPU revision    : 5
                                        processor       : 2
                                        BogoMIPS        : 38.40
                                        CPU architecture: 7
                                        CPU variant     : 0x0
                                        CPU part        : 0xc07
                                        CPU revision    : 5
                                        processor       : 3
                                        BogoMIPS        : 38.40
                                        CPU architecture: 7
                                        CPU variant     : 0x0
                                        CPU part        : 0xc07
                                        CPU revision    : 5
                                        Hardware        : BCM2835
                                        Revision        : a21041
                                        Serial          : 00000000475d18a4
                                        # cat /sys/firmware/devicetree/base/model
                                        Raspberry Pi 2 Model B Rev 1.1
                                        Output from MySensors configure:
                                        # ./configure
                                        ./configure: line 111: warning: command substitution: ignored null byte in input
                                        [OK] Finished.
                                        I finally find out my raspberry pi board isn't detected properly in configure. I change the function detect_machine:
                                        function detect_machine {
                                            case $hardware in
                                            BCM2835)
                                                soc="BCM2835"
                                                if [[ $machine == "Raspberry"* ]]; then
                                                    local rev=($(detect_rpi_revision))
                                                    if [[ $rev == "a02082" || $rev == "a22082" ]]; then
                                                        tp="RPi3"
                                                        tp="Rpi2"
                                                    fi
                                                fi
                                        make mysgw again, and I get this finally:
                                        # ./mysgw -d
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: MCO:BGN:STP
                                        J
                                        J
                                        jacikaas
                                        @ccy
                                        Hello, I'm also have issue with this question. My Raspberry Pi 2 type is a01041, but by the original "configure" file it is not recognized:
                                        Maybe someone could explain why it is not recognized?
                                        "Configure" file lines:
                                            case $hardware in
                                            BCM2835)
                                                soc="BCM2835"
                                                        tp="RPi3"
                                                        tp="Rpi2"
                                                    fi
                                                fi
                                        My Raspberry Pi 2 info:
                                        processor       : 0
                                        BogoMIPS        : 38.40
                                        CPU architecture: 7
                                        CPU variant     : 0x0
                                        CPU part        : 0xc07
                                        CPU revision    : 5
                                        processor       : 1
                                        BogoMIPS        : 38.40
                                        CPU architecture: 7
                                        CPU variant     : 0x0
                                        CPU part        : 0xc07
                                        CPU revision    : 5
                                        processor       : 2
                                        BogoMIPS        : 38.40
                                        CPU architecture: 7
                                        CPU variant     : 0x0
                                        CPU part        : 0xc07
                                        CPU revision    : 5
                                        processor       : 3
                                        BogoMIPS        : 38.40
                                        CPU architecture: 7
                                        CPU variant     : 0x0
                                        CPU part        : 0xc07
                                        CPU revision    : 5
                                        Hardware        : BCM2835
                                        Revision        : a01041
                                        Serial          : 0000000049a14619
                                        • TriXwooDT
                                          TriXwooDT
                                          TriXwooD
                                          Double radio or alternative pin for spi1:
                                          https://forum.mysensors.org/topic/7702/double-spi-radio-raspberry-pi/2
