  2. Announcements
  • E erobot
    Hello folks,
    my past experience is using nrf24 library at https://github.com/Blavery/lib_nrf24, and i was able to send/receive "text" data (or "string" data) in between Raspi3 (master node) and Arduino (slave). And this is a big issue, because what i need is numerical data (float or integer), not text data, so Raspi 3 can process the numerical data (such as to do the plotting), and based on the processed data to make some decisions. My raspi 3 is controlling a moving robot. Can you advise appropriate nrf24 library for raspberry pi and Arduino, and sample codes for this kind of applicaitons? Thanks
    Welcome to the MySensors community @erobot !
    Not sure how you found us, but the library we use here is...MySensors. It certanly does what you describe. The best way to start is to read how MySensors works at https://www.mysensors.org/about and then go on to the many build examples and build your first node.
    • Richard van der PlasR
      hi there, somehow my gateway seems to stop receiving data after a day or so from my sensors,
      restarting the service seems to solve it for a time, how can i troubleshoot this issue ?
      Carl HC gohanG 2 Replies Last reply
      • Richard van der PlasR Richard van der Plas
        Carl HC
        Carl HC
        Carl H
        @Richard-van-der-Plas
        Same trouble for me. I use mySensors since 2 years and I have no problem with my Arduino Gateway. But from now 2 weeks, I try to use a pi gateway. It's working well but sometime, don't no why, my nrf24 stop to receive messages. Just restarting mygw service and re-work again. I don't see nothing anormal in my log, stop randomlly after 1 or 2 days.
        Maybe a power issue to nrf24, I will try to add capacitor just for testing if can resolve this problem.
        • skywatchS
          skywatchS
          skywatch
          Same here too. With Rpi3 gateway. Would stop for hours, maybe start agian for a hour or two and then stop.
          Have been running debug mode for last day, no idea what happened, but been stable so perhaps something in the update/upgrade made a problem and has now been fixed.
          Will keep an eye on here and let you know if I find anything.
            Looks as if it happened after updating Home Assistant, but that should be 2 different things right ?
              @Richard-van-der-Plas what version are you using?
              Carl HC Richard van der PlasR 2 Replies Last reply
                Carl HC
                Carl HC
                Carl H
                @gohan for me version dev (2.2)
                • skywatchS
                  skywatchS
                  skywatch
                  dev 2.2.0 beta
                    Have you tried both ethernet or mqtt?
                      @gohan the latest stable version i guess. Where can i check?
                      gohanG 1 Reply Last reply
                        @Richard-van-der-Plas try the 2.2 beta, it usually works better
                        Richard van der PlasR 1 Reply Last reply
                          @gohan just checked it's 2.1.1, is it easy to upgrade?
                            @Richard-van-der-Plas just clone the 2.2 dev instead of the stable, the rest is the same
                              @gohan fatal: destination path 'MySensors' already exists and is not an empty directory. It goes wrong with the first command, could you please give me some pointers ?
                                you need to either delete or rename the Mysensors folder :)
                                • llegoffL
                                  llegoffL
                                  llegoff
                                  I designed a PCB for rfm or nrf -> raspberry pi
                                  https://www.openhardware.io/view/470/MySensors-Gateway-for-Raspberry-PI
                                    I am trying to get the gateway to run the RFM69W radio but when I issue the "make" command I get this
                                    In file included from ./MySensors.h:318:0,
                                                     from examples_linux/mysgw.cpp:83:
                                    ./drivers/RFM69/new/RFM69_new.cpp:658:12: warning: ‘void RFM69_ATCmode(bool, int16_t)’ defined but not used [-Wunused-function]
                                     LOCAL void RFM69_ATCmode(const bool onOff, const int16_t targetRSSI)
                                    It is latest beta.
                                      It is latest beta.
                                      #629
                                      @gohan what configure command did you use? Knowing that would make it easier to reproduce the problem...
                                      Does this warning cause any problem?
                                        Just simple rfm69w 433 with default options. It compiles but I get no communication with nodes and 100% processor, but maybe I did a bad wiring
                                          @gohan debug output could be useful ;-)
