  2. Announcements
  • Richard van der PlasR
    hi there, somehow my gateway seems to stop receiving data after a day or so from my sensors,
    restarting the service seems to solve it for a time, how can i troubleshoot this issue ?
    Carl HC gohanG 2 Replies Last reply
    • Richard van der PlasR Richard van der Plas
      Carl HC
      Carl HC
      Carl H
      @Richard-van-der-Plas
      Same trouble for me. I use mySensors since 2 years and I have no problem with my Arduino Gateway. But from now 2 weeks, I try to use a pi gateway. It's working well but sometime, don't no why, my nrf24 stop to receive messages. Just restarting mygw service and re-work again. I don't see nothing anormal in my log, stop randomlly after 1 or 2 days.
      Maybe a power issue to nrf24, I will try to add capacitor just for testing if can resolve this problem.
      • skywatchS
        skywatchS
        skywatch
        Same here too. With Rpi3 gateway. Would stop for hours, maybe start agian for a hour or two and then stop.
        Have been running debug mode for last day, no idea what happened, but been stable so perhaps something in the update/upgrade made a problem and has now been fixed.
        Will keep an eye on here and let you know if I find anything.
          Looks as if it happened after updating Home Assistant, but that should be 2 different things right ?
            @Richard-van-der-Plas what version are you using?
            Carl HC Richard van der PlasR 2 Replies Last reply
              Carl HC
              Carl HC
              Carl H
              @gohan for me version dev (2.2)
              • skywatchS
                skywatchS
                skywatch
                dev 2.2.0 beta
                  Have you tried both ethernet or mqtt?
                    @gohan the latest stable version i guess. Where can i check?
                    gohanG 1 Reply Last reply
                      @Richard-van-der-Plas try the 2.2 beta, it usually works better
                      Richard van der PlasR 1 Reply Last reply
                        @gohan just checked it's 2.1.1, is it easy to upgrade?
                          @Richard-van-der-Plas just clone the 2.2 dev instead of the stable, the rest is the same
                            @gohan fatal: destination path 'MySensors' already exists and is not an empty directory. It goes wrong with the first command, could you please give me some pointers ?
                              you need to either delete or rename the Mysensors folder :)
                              • llegoffL
                                llegoffL
                                llegoff
                                I designed a PCB for rfm or nrf -> raspberry pi
                                https://www.openhardware.io/view/470/MySensors-Gateway-for-Raspberry-PI
                                  I am trying to get the gateway to run the RFM69W radio but when I issue the "make" command I get this
                                  In file included from ./MySensors.h:318:0,
                                                   from examples_linux/mysgw.cpp:83:
                                  ./drivers/RFM69/new/RFM69_new.cpp:658:12: warning: ‘void RFM69_ATCmode(bool, int16_t)’ defined but not used [-Wunused-function]
                                   LOCAL void RFM69_ATCmode(const bool onOff, const int16_t targetRSSI)
                                  It is latest beta.
                                    It is latest beta.
                                    #629
                                    @gohan what configure command did you use? Knowing that would make it easier to reproduce the problem...
                                    Does this warning cause any problem?
                                      Just simple rfm69w 433 with default options. It compiles but I get no communication with nodes and 100% processor, but maybe I did a bad wiring
                                        @gohan debug output could be useful ;-)
                                          wrote on last edited by gohan
                                          #632
                                          I would have posted it but it just shows as no nodes are trying to connect and nodes are unable to find a parent of course. I'm using the rfm2nrf pcb in order to have the pins to connect to the raspberry.
                                          PS here is the log of the startup
                                           __  __       ____
                                                  |___/                      2.2.0-beta
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: TSM:INIT:TSP OK
                                          mysgw: TSM:INIT:GW MODE
                                          mysgw: MCO:REG:NOT NEEDED
                                          mysgw: MCO:BGN:STP
                                          mysgw: MCO:BGN:INIT OK,TSP=1
                                          mysgw: Client 0 connected
                                          mysgw: Client 0: 0;0;3;0;2;
